EL8102 BASED VIDEO AMPLIFIER W
- Video(44824)
- Amplifier(80638)
EL8102ISZ-T13
EL8102ISZ-T13 - 500MHz Rail-to-Rail Amplifiers - Intersil Corporation
2022-11-04 17:22:44
EL8102ISZ-T7
EL8102ISZ-T7 - 500MHz Rail-to-Rail Amplifiers - Intersil Corporation
2022-11-04 17:22:44
VIVA (昱盛电子)VA2208 15W Filterless Stereo Class D Audio Amplifier
2021-04-20 17:39:00
VIVA (昱盛电子)VA2228 Low EMI 20W Stereo/30W Mono Class D Audio Amplifier
VIVA (昱盛电子)VA2228Low EMI 20W Stereo/30W Mono Class D Audio Amplifier
2021-04-27 16:43:06
VIVA(昱盛电子)VA2239 2*50W Stereo Filterless Class D Audio Amplifier
2021-04-20 17:34:35
具有芯片使能的ISD8102 2W AB类音频放大器
具有芯片使能的ISD8102 2W AB类音频放大器的典型应用。 ISD8102是一款通用模拟音频放大器,能够以高达2Wrms的输出功率驱动4欧姆负载。该器件具有输出电流限制,芯片使能,低待机电流和出色的弹出和咔嗒抑制功能
2020-08-11 10:21:01
EL5111/EL5211/EL5411 pdf,EL541
The EL5111 represents a single amplifier, the EL5211 contains two amplifiers, and the EL5411 contains four amplifiers. Operating on supplies r
2008-09-06 19:14:338
EL8102/EL8103 pdf datasheet
The EL8102, EL8103 represent single rail-to-rail amplifiers with a -3dB bandwidth of 500MHz
2008-09-21 22:55:1422
Component Video Sync Formats (
the sync pulse from componentvideo signals (see Figure 1). The EL8102 is a single supplyVideo Op Amp with rail to rail output
2008-09-21 22:56:4133
Video Amplifier with Sync Stri
IntroductionThe circuit in Figure 1 transmits 200MHz (-3dB bandwidth) video signals while stripping
2008-09-21 22:58:5121
EL5462 pdf datasheet (500MHz L
The EL5462 is a current feedback amplifier with a bandwidth of 500MHz which makes this amplifier
2008-09-21 23:00:2819
EL5392A pdf datasheet (Triple
The EL5392A is a triple current feedback amplifier with a very high bandwidth of 600MHz. This makes
2008-09-21 23:01:5914
EL5178/EL5378 pdf datasheet (7
The EL5178 and EL5378 are single and triple high bandwidth amplifiers with an output
2008-09-21 23:04:0214
EL5374/EL5174 pdf datasheet (5
The EL5174 and EL5374 are single and triple high bandwidth amplifiers with an output
2008-09-21 23:07:4526
EL5164, EL5165,EL5364 pdf data
The EL5164, EL5165, and EL5364 are current feedback amplifiers with a very high bandwidth
2008-09-21 23:09:3227
EL5162, EL5163 pdf datasheet (
The EL5162, EL5163, EL5262, EL5263, and EL5362 are current feedback amplifiers with a bandwidth
2008-09-21 23:11:523
EL5262, EL5263,EL5362 pdf data
2008-09-21 23:12:4822
EL5104, EL5105, EL5204 pdf dat
based on the current feedback amplifier architecture. This gives the typical high slew rate benefits of a CFA family along with the stability a
2008-09-21 23:14:0210
EL5205, EL5304 pdf datasheet (
2008-09-21 23:15:0825
EL5292/EL5292A pdf datasheet (
The EL5292 and EL5292A represent dual current feedback amplifiers with a very high bandwidth
2008-09-21 23:16:2911
EL5132 SPICE Model
*EL5132-- Model Rev. A 2/09/2004*low power, wide bandwidth amplifier---700MHz*The AC response
2008-09-21 23:35:3215
EL5130 SPICE Model
*EL5130-- Model Rev. A 2/013/2004*low power, wide bandwidth amplifier---500MHz*The AC response
2008-09-21 23:39:2920
EL5367 pdf datasheet (1GHz Tri
The EL5367 triple amplifier is of the current feedback variety and exhibits a very high bandwidth
2008-09-21 23:41:2919
The EL5367 triple amplifier is of the current feedback varietyand exhibits a very high bandwidth
2009-01-15 21:31:3711
EL5178, EL5378 pdf datasheet (
The EL5178 and EL5378 are single and triple highbandwidth amplifiers with an output in differential
2009-01-16 08:18:219
The EL5462 is a current feedback amplifier with a bandwidthof 500MHz which makes this amplifier
2009-01-16 08:18:5920
EL5160, EL5161, EL5260 pdf dat
The EL5160, EL5161, EL5260, EL5261, and EL5360 arecurrent feedback amplifiers with a bandwidth
2009-01-16 08:40:0329
EL5261, EL5360 pdf datasheet (
2009-01-16 08:40:362
EL1517 pdf datasheet (xDSL Dif
The EL1517 is a dual operational amplifier designed for VDSLand ADSL line driving in DMT based
2009-01-16 09:02:3613
EL8108 pdf datasheet (Video Di
The EL8108 is a dual current feedbackoperational amplifier designed forvideo distribution
2009-01-16 09:03:4618
EL6272/EL6272C pdf datasheet (
The EL6272C is a single channel laser diode current amplifier that provides
2009-01-16 10:18:2813
EL5192, EL5192A pdf datasheet
The EL5192 and EL5192A are current feedback amplifierswith a very high bandwidth of 600MHz.
2009-01-16 19:19:3012
EL5193, EL5193A pdf datasheet
The EL5193 and EL5193A are current feedback amplifierswith a bandwidth of 300MHz. This makes
2009-01-16 19:20:419
EL5196, EL5196A pdf datasheet
The EL5196 and the EL5196A arefixed gain amplifiers with a bandwidthof 400MHz, making
2009-01-16 19:22:0412
EL5197, EL5197A pdf datasheet
The EL5197 and EL5197A are fixed gain amplifiers with abandwidth of 200MHz, making these amplifiers
2009-01-16 19:22:4612
EL5120, EL5220, EL5420 pdf dat
The EL5120contains a single amplifier, the EL5220 contains twoamplifiers, and the EL5420 contains four amplifiers.Operating on
2009-01-16 19:24:4614
EL5293, EL5293A pdf datasheet
The EL5293 and EL5293A represent dual current feedbackamplifiers with a bandwidth of 300MHz.
2009-01-16 19:29:4711
EL5392/EL5392A pdf datasheet (
The EL5392A is a triple current feedback amplifier with avery high bandwidth of 600MHz. This makes
2009-01-16 19:30:3920
EL5393/EL5393A pdf datasheet (
The EL5393A is a triple currentfeedback amplifier with a bandwidth of300MHz. This makes
2009-01-16 19:31:2810
EL5396/EL5396A pdf datasheet (
The EL5396A is a triple channel, fixedgain amplifier with a bandwidth of400MHz, making
2009-01-16 19:32:4518
EL5397/EL5397A pdf datasheet (
The EL5397A is a triple channel, fixed gain amplifier with abandwidth of 200MHz, making
2009-01-16 19:33:449
EL5493, EL5493A pdf datasheet
The EL5493 and EL5493A are quadcurrent feedback amplifiers with abandwidth of 300MHz.
2009-01-16 19:41:3814
EL5171, EL5371 pdf datasheet (
The EL5171 and EL5371 are single and triple bandwidthamplifiers with an output in differential
2009-01-16 20:47:0725
EL5174, EL5374 pdf datasheet (
The EL5174 and EL5374 are single and triple highbandwidth amplifiers with an output in differential
2009-01-16 20:52:3416
EL4543 pdf datasheet (Triple D
The EL4543 is a high bandwidth triple differential amplifierwith integrated encoding of video sync
2009-01-16 20:54:3622
EL4501 pdf datasheet (Video Fr
The EL4501 is a highly-integrated Video Front End (VFE)incorporating all of the key signal
2009-01-16 20:55:3025
EL1516, EL1516A pdf datasheet
The EL1516 is a dual, ultra low noise amplifier, ideally suitedto line receiving applications
2009-01-16 20:56:1710
EL5100, EL5101, EL5300 pdf dat
The EL5100, EL5101, and EL5300 represent high-speedvoltage feedback amplifiers based on the current
2009-01-16 20:57:0918
EL5102, EL5103, EL5202 pdf dat
The EL5x02 and EL5x03 families represent high-speedVFAs based on a CFA amplifier architecture.
2009-01-16 20:57:5549
EL5203, EL5302 pdf datasheet (
2009-01-16 20:58:311
EL5104, EL5105, EL5204, pdf da
feedback amplifiers based onthe current feedback amplifier architecture. This gives thetypical high slew rate benefits of a
2009-01-16 20:59:2523
based onthe current feedback amplifier architecture. This gives thetypical high slew rate benefits of a CFA family along with the
2009-01-16 21:00:1916
EL5106, EL5306 pdf datasheet (
The EL5106 and EL5306 are fixed gain amplifiers with abandwidth of 350MHz. This makes
2009-01-16 21:15:1919
EL5108, EL5308 pdf datasheet (
The EL5108 and EL5308 are fixed gain amplifiers with abandwidth of 450MHz. This makes
2009-01-16 21:16:0617
EL4093 pdf datasheet (300MHz D
The EL4093 is a complete DCrestoredvideo amplifier subsystem,featuring low power consumption
2009-01-16 21:16:4112
EL4094 pdf datasheet (Video Ga
The EL4094 is a complete two-inputfader. It combines two inputs accordingto the equation:VOUT
2009-01-16 21:17:2611
EL4095 pdf datasheet (Video Ga
The EL4095 is a versatile variable-gainbuilding block. At its core is a faderwhich can variably
2009-01-16 21:19:0716
EL4390 pdf datasheet (Triple 8
The EL4390 is three widebandcurrent-mode feedback amplifiersoptimized for video performance
2009-01-16 21:22:0613
EL4393 pdf datasheet (Triple 8
amplifier can drivea load of 150Ω at video levels. Each amplifier has a disablecapability, which is controlled by a TTL/CMOS compa
2009-01-16 21:23:0214
EL4450 pdf datasheet (Wideband
linearitywhile including a powerful output voltage amplifier, drawingmodest supply current.The EL4450 operates on ±5V supplies and
2009-01-16 21:24:495
EL4451 pdf datasheet (Wideband
while including apowerful output voltage amplifier, drawing modest supplycurrent.The EL4451 operates on ±5V to ±15V suppli
2009-01-16 21:25:3112
EL4452 pdf datasheet (Wideband
, while includinga powerful output voltage amplifier, drawing modest current.The higher gain and lower input noise makes the EL445
2009-01-16 21:27:1212
EL4453 pdf datasheet (Video Fa
for such applicationsas video picture-in-picture effects.The EL4453 operates on ±5V to ±15V supplies and has ananalog differential input r
2009-01-16 21:38:3610
EL4584 pdf datasheet (EL4584 H
The EL4584 is a PLL (Phase Lock Loop) sub system,designed for video applications but also suitable
2009-01-16 21:48:286
EL4585 pdf datasheet (Horizont
The EL4585 is a PLL (Phase Lock Loop) sub-system,designed for video applications and also suitable
2009-01-16 21:49:189
EL4089 pdf datasheet (DC Resto
The EL4089 is an 8-pin complete DCrestoredmonolithic video amplifiersub-system. It contains a high
2009-01-17 11:22:5318
EL400 pdf datasheet (200MHz Cu
The EL400 is a wide bandwidth, fastsettling monolithic amplifier built usingan advanced
2009-01-17 11:26:127
EL2386 pdf datasheet (250MHz T
The EL2386 is a triple currentfeedbackoperational amplifier whichachieves a -3dB bandwidth
2009-01-17 11:26:587
EL5111, EL5211, EL5411 pdf dat
2009-01-17 11:35:0318
EL2090 pdf datasheet (100MHz D
The EL2090 is the first complete DCrestoredmonolithic video amplifiersub-system. It contains a very
2009-01-17 12:37:2414
EL2110 pdf datasheet (Low Cost
The EL2110 operational amplifier, builtusing Elantec’s complementary bipolarprocess, offers
2009-01-17 12:40:319
EL2111 pdf datasheet (Low Cost
The EL2111 operational amplifier, builtusing Elantec’s complementary bipolarprocess, offers
2009-01-17 12:41:1510
EL2160 pdf datasheet (180MHz C
The EL2160 is a current feedbackoperational amplifier with -3dBbandwidth of 130MHz at a gain
2009-01-17 13:14:379
EL2166 pdf datasheet (110MHz C
The EL2166 is a current feedbackoperational amplifier with -3dBbandwidth of 110MHz at a gain
2009-01-17 13:15:2314
EL2186, EL2286 pdf datasheet (
The EL2186/EL2286 are single/dualcurrent-feedback operationalamplifiers which achieve
2009-01-17 18:42:1813
EL8102, EL8103 pdf datasheet (
The EL8102, EL8103 represent single rail-to-rail amplifierswith a -3dB bandwidth of 500MHz and slew
2009-01-17 20:42:5214
EL9211, EL9212, EL9214 pdf dat
The EL9211, EL9212, and EL9214 feature 1, 2, and 4channel high power output amplifiers.
2009-01-17 21:18:579
EL4511 pdf datasheet (Super Sy
, and projectorapplications, as well as broadcast equipment and otherapplications where video signals need to be processed.The EL4511
2009-01-17 21:20:4814
EL1881 pdf datasheet (Sync Sep
The EL1881 video sync separator is manufactured usingElantec’s high performance analog CMOS
2009-01-17 21:29:5615
MAX9508 pdf datasheet (Video F
The MAX9508 video filter amplifier with SmartSleep and bidirectional video support is ideal
2009-03-14 19:09:3418
输出频率150MHz的全波整流电路的介绍(涉及器件EL218
The circuit in Figure 1 utilizes the speed of a currentfeedback amplifier (EL
2009-06-05 15:22:4048
直流恢复概念以及EL4089和EL4390直流恢复视频放大器
The EL4089 is a complete monolithic video amplifiersub-system in a single 8-pin package.
2009-06-06 10:14:5436
AD8307,pdf datasheet (Logarithmic Amplifier)
It is a complete 500 MHz monolithic demodulating logarithmic amplifier based on the progressive
compression (successive detection)
2009-08-27 15:56:0745
AD810,pdf datasheet (Video Op
The AD810 is a current feedback amplifier optimized for use inhigh performance video and data
2009-09-02 10:01:2313
OPA360,pdf(3V Video Amplifier)
The OPA360 high-speed amplifier is optimized for 3V portable video applications. It has been
2010-09-12 23:14:5610
OPA361,pdf(3V Video Amplifier)
The OPA361 high-speed amplifier is optimized for 3V portable video applications. It is specifically
2010-09-12 23:16:2911
OPA692,pdf(Ultra Wideband, Fixed Gain Video Buffer Amplifier
The OPA692 provides an easy to use, broadband fixed gain video buffer amplifier. Depending
2010-09-27 19:05:0616
OPA362,pdf(3V VIDEO AMPLIFIER)
The OPA362 high-speed amplifier is optimized for 3V portable video applications. It is specifically
2010-09-27 19:30:1910
EL8102 APPLICATION CIRCUIT VID
EL8102 APPLICATION CIRCUIT VIDEO AMPLIFIER WITH SYNC STRIPPER
2008-09-22 19:00:06936
EL156 A类单端功率放大器,EL156 power amplifier
关键字:EL156 A类单端功率放大器
EL156 A类单端功率放大器
拉动滚动条查看完整电路+++++++++++++++
2018-09-20 19:11:111659
用EL34+6CY7制作的单端胆机,EL34 AMPLIFIER
关键字:EL34,6CY6,功放电路图
作者
2018-09-20 19:12:184052
LED8102SXTTR STMicroelectronics LED8102S LED阵列驱动器
电子发烧友网为你提供()LED8102SXTTR相关产品参数、数据手册,更有LED8102SXTTR的引脚图、接线图、封装手册、中文资料、英文资料,LED8102SXTTR真值表,LED8102SXTTR管脚等资料,希望可以帮助到广大的电子工程师们。
2020-10-21 10:45:36
DS8102+ 专用 IC
电子发烧友网为你提供Maxim(Maxim)DS8102+相关产品参数、数据手册,更有DS8102+的引脚图、接线图、封装手册、中文资料、英文资料,DS8102+真值表,DS8102+管脚等资料,希望可以帮助到广大的电子工程师们。
2022-11-18 18:58:24
查看更多
