基于AT90S8515的频率测量系统的设计
- AT90S8515(10186)
- AT90S8(5508)
奥地利微电子发布用于汽车电池测量系统的芯片AS8515
奥地利微电子公司(SIX股票代码:AMS)是全球领先的高性能模拟IC和传感器芯片制造商,专为消费、工业、汽车应用行业服务,该公司今日宣布推出系统级封装(SiP)芯片AS8515。当通过
2012-12-13 09:00:00
1557
8515A S参数和8513A反射/透射测试装置操作和维修手册
Part Number: 08515-90015 (Sep90). The 8515A and 8513A are discontinued products; this manual is provided for information only.
2019-01-07 16:21:19
AT90S8515
AT90S8515 - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
频率测量上限问题
目的:用stm32测量频率,测量频率范围越大越好做法:我是利用定时中断+外部中断来实现的。具体做法:外部中断每来一个脉冲上升沿促发中断一次,频率值加1,记到0.5s后定时器中断发生,显示此时频率的值
2013-07-13 13:47:15
AT90S8515-4AC
AT90S8515-4AC - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
AT90S8515-4AI
AT90S8515-4AI - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
AT90S8515-4JC
AT90S8515-4JC - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
AT90S8515-4JI
AT90S8515-4JI - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
AT90S8515-4PI
AT90S8515-4PI - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
AT90S8515-8AC
AT90S8515-8AC - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
AT90S8515-8AI
AT90S8515-8AI - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
AT90S8515-8JC
AT90S8515-8JC - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
AT90S8515-8JI
AT90S8515-8JI - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
AT90S8515-8PC
AT90S8515-8PC - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
AT90S8515-8PI
AT90S8515-8PI - 8-bit Microcontroller with 8K Bytes In-System Programmable Flash - ATMEL Corporation
2022-11-04 17:22:44
ATMEGA8515/8515L的中文数据手册
ATMEGA8515是基于增强的AVR RISC结构的低功耗8位CMOS微控制器。 由于其先进的指令集以及单时钟周期指令执行时间,ATMEGA8515 的数据吞吐率高达1 MIPS/MHz
2020-07-20 17:11:51
AVR单片机AT90系列介绍
在第二章以AT90S8515为例,详细叙述了AVR单片机的硬件结构,第四章详细叙述了AVR单片机的指令系统,相关器件简明指令表在附录4。本章重点叙述AT90S1200及AT90S8535单片机
2011-03-07 15:27:32
AVR单片机GCC程序设计
。Attiny系列中常用的有Attiny15、Attiny2313等产品,AT90S系列中常用的有AT90S2313、AT90S8535、AT90S8515等。AT90S2313引脚兼容AT89C2051,而
2011-03-02 12:19:16
AVR单片机GCC程序设计
的低、中、高档产品。Attiny系列中常用的有Attiny15、Attiny2313等产品,AT90S系列中常用的有AT90S2313、AT90S8535、AT90S8515等。AT90S2313引脚
2009-04-27 21:11:44
AVR单片机GCC程序设计
,AT90S系列中常用的有AT90S2313、AT90S8535、AT90S8515等。AT90S2313引脚兼容AT89C2051,而AT90S8515的引脚则兼容51单片机,在设计中很容易的替代51单片机
2011-03-02 12:25:28
AVR单片机有哪些优势
、tiny26,功能较简单,属于低档,适合功能相对单一的系统;(2)AT90S系列:AT90S8515等,属中档,适合一般系统开发,现在在慢慢的淘汰,向ATmega系列转型。(3)ATme
2021-07-13 08:33:08
PROTEUS--一种集单片机模拟和SPICE分析于一身的软件
和PIC系列,每个系列又有很多种不同的型号可供选择,如其中的AVR系列有TINY10、TINY11、TINY12、TINY15、AT90S2313、AT90S2323、AT90S2333、AT90S2343、AT90S4433、AT90S4434、AT90S8515及ATMEGA103等。
2011-03-03 16:38:39
一种基于FPGA的多通道频率测量系统的实现方法介绍
设计了一种多通道频率测量系统。系统由模拟开关、信号调理电路、FPGA、总线驱动电路构成,实现对频率信号的分压、放大、滤波、比较、测量,具备回路自测试功能,可与主设备进行数据交互,具有精度高、可扩展
2019-06-27 07:23:11
奥地利微电子公司推出系统级封装(SiP)芯片AS8515
21ic讯 奥地利微电子公司日前宣布推出系统级封装(SiP)芯片AS8515。当通过SPI接口连接任何一个微控制器时,新品可帮助实现完整的汽车电池测量系统。AS8515是一款堆叠晶元封装的产品,包含
2012-12-13 10:13:44
奥地利微电子公司日前宣布推出系统级封装(SiP)芯片AS8515。当通过SPI接口连接任何一个微控制器时,新品可帮助实现完整的汽车电池测量系统。AS8515是一款堆叠晶元封装的产品,包含一个具有两个
2012-12-22 19:46:23
微波测量系统实验
微波测量系统的认识和调整一、实验目的1、进一步了解波导测量系统,熟悉基本微波测量元件正确的使用。2、掌握用频率计校准频率的方法。3、掌握用驻波测量线测量矩形波导波长λg 的方法。
2019-06-04 06:39:02
新手问一个ATMEGA8515的问题
有一个用ATMEGA8515连一个PIDUSB2.0做了一个和电脑通讯,最近新买的ATMEGA8515-16pu就无法通讯上,但是用以前买的就可以,同一块板子,同一个程序,新买的8515就无法通讯上,这是怎么回事,我换了三家买,都不行。
2016-12-15 20:03:43
转轴角加速度测量及其USB数据采集
转轴角加速度是旋转机构转动时的一项重要参数,旋转体的角加速度在实践中有着广泛和重要的应用。对角加速度的测量原理方法进行了研究,寻求一种高精度连续测量角加速度可行的方法。设计了基于AT09S8515
2011-03-04 12:17:42
at90s8515-4414中文资料pdf
AT90S4414/8515 是一款基于AVR RISC 的低功耗CMOS 的8 位单片机通过在一个时钟周期内执行一条指令AT90S4414/8515 可以取得接近1MIPS/MHz 的性能从而使得设计人员可以在功耗和执行速度之
2008-04-07 09:00:09
42
ATmega8515-ATmega8515L中文资料pdf
ATmega8515是基于增强的AVR RISC结构的低功耗8位CMOS微控制器。由于其先进的指令集以及单时钟周期指令执行时间,ATmega8515 的数据吞吐率高达1 MIPS/MHz,从而可以缓减系统在功耗和
2008-04-08 09:26:13
256
at90s4414中文资料pdf
2008-07-17 23:45:43
3
at90s8515中文资料pdf
AT90S4414/8515 具有以下特点4K/8K 字节FLASH 256/512 字节EEPROM 256/512 字节SRAM 32 个通用I/0 口32 个通用工作寄存器具有比较模式的灵活的定时器/计数器内外中断源可编程的UART 可编程的
2008-07-17 23:46:28
289
基于AVR单片机的步进电机控制
摘 要: 对AVR 单片机AT90S8515 进行编程,实现对35BYJ46 型四相八拍步进电机的控制,以达到精确定位的目的. 使AT90S8515 单片机并行口C 口高四位PC7~PC4 分别与驱动接口芯片ULN2803
2008-08-28 16:05:47
194
SSD1332 OLED点亮细节 LCM产品设
SSD1332 OLED 点亮细节 LCM 产品设计课一、OLED 的显示理1二、OLED 相关关键工艺2三、OLED 的驱动技朮4四、具体点亮模块SSD1332、65K、OLED5五、利用AT90S8515 测
2008-11-01 15:01:35
75
频率与时间测量
频率与时间测量:6.1 频率与时间测量的特点与方法6.1.1 频率与时间测量的特点?与其他各种物理测量相比,频率与时间测量具有如下特点: ?(1) 时频测量具有动态性质。
2008-12-06 21:43:32
AT90S8515控制器与AT17C010 FPGA配置EE
using anAtmel AVR microcontroller and how tobit bang I2C using port pins on anAT90S8515 AVR microcontroller. TheAT17CXX
2009-05-19 15:26:36
14
基于AT90系列单片机的过载存储测试系统
基于ATMEL 90 系列单片机AT90S8515 为系统控制器的过载存储测试仪, 实现了野外过载存储系统的小型化。该过载存储测试仪由传感器、电荷放大器、模数转换接口、数据存储器及单片机
2009-06-19 15:33:42
11
基于微机的频率测量系统研究
根据涡流传感器输出频率信号的特点,介绍了一种实用的基于微机的采用闸门时间修正的测频法,通过具体的硬、软件设计,实现了较高精度的频率测量。【关键词】频率测量 闸门
2009-07-10 15:34:34
27
CPLD在数字频率测量中的应用
本文介绍了以CPLD 为核心处理芯片的频率测量系统,整个频率测量系统由CPLD和单片机(89C51)构成,CPLD 采集被测频率源,再由单片机读取频率值并由液晶同步显示频率和周期。本
2009-08-11 09:54:46
12
同步串行SPI在AD7888与AT90S8515接口中的应用
在高速串行模数转换器AD7888与AVR单片机AT90S8515的接口中采用同步串行接口SPI技术,实现起来十分方便。本文介绍了AD7888的特点,以及AT90S8515中SPI的实现,并给出了连接图和相应的程
2009-08-19 08:46:33
91
AD8515,pdf datasheet (Output O
The AD8515 is a rail-to-rail amplifier that can operate from a single-supply voltage as low as 1.8
2009-09-02 09:11:02
5
基于PLD及FPGA的频率与相位测量系统设计与实现
基于PLD及FPGA的频率与相位测量系统设计与实现:摘 要:本测量系统由频率相位测量仪和DDS 双路移相信号发生器两部分组成。频率相位测量由Altera EPM7128S84 CPLD 完成,双路移相信号
2009-09-25 15:50:03
30
太赫兹频率测量系统
太赫兹频率测量系统说明与示意图 太赫兹频率测量系统是由高莱盒探测器Golay Cell,太赫兹法布里-珀罗干涉仪(TSFPI),数据采集模块,太
2023-03-16 10:28:57
用AT90S8515控制4线两相步进电机(C语言)
用AT90S8515控制4线两相步进电机(C语言):现在四线两相步进电机应用很普遍下图是2 种5 伏步进电机的原理图及接线图用ULN2803A 驱动的步进电机电流应小于400mA;用晶体三极管驱动的步进
2010-01-09 13:40:57
198
太赫兹频率测量系统
2023-05-24 09:59:35
单片机仿真器
单片机仿真器和实验仪配套的8X51 CPU系列小型仿真器是一个支持keilc51设计软件的软件断点仿真机。该仿真器使用一片SST89C58单片机和一片AT90S8515(ATMEL公司
2010-04-14 14:44:24
129
AVR单片机AT90系列介绍
在第二章以AT90S8515为例,详细叙述了AVR单片机的硬件结构,第四章详细叙述了AVR单片机的指令系统,相关器件简明指令表在附录4本章重点叙述AT90S1200及AT90S8535单片机,与AT90S8515相同的内容
2010-07-01 10:06:53
23
LG-32K单片机仿真机使用说明
LG-32K是老古开发网推出的一个支持keilc51设计软件的软件断点仿真机使用一片SST89C58单片机和一片AT90S8515单片机来实现仿真功能(主CPU和用户CPU),两片CPU之间通过一根I/O引脚通讯(通讯
2010-08-06 12:32:35
29
MSP430在频率测量系统中的应用
介绍一种以MSP430单片机为基础的智能频率测量系统,采用硬件逻辑与软件指令相结合的方式控制闸门,实现0 MHz~10 MHz范围内无档切换的等精度测量。
2010-12-08 17:13:27
41
感应式电能表的智能化改进
摘要:介绍了利用AVR单片机AT90S8515的输入捕捉功能对感应式电能表进行智能化改进的方法,讨论了新型防盗电系统的结构原理,给出了用AT90S8515单片机设计带有防盗
2006-03-24 13:14:28
901
MAX8515, MAX8515A 宽输入、0.6V并联型稳
MAX8515, MAX8515A 宽输入、0.6V并联型稳压器,用于隔离型DC-DC转换器
MAX8515A/MAX8515并联稳压器简化了在高精度、输出电压低至0.6V的隔离式DC-DC转换器中设计稳
2009-03-23 21:23:50
809
基于80C196的频率测量及在电压采样中的应用
频率测量频率和电压是电力系统中的两个重要电气量。提出了一种基于80C196单片机HSI的频率测量方法,并依据测量的频率来改变电压的采样时间间隔,实现频率跟
2009-05-09 11:45:43
787
基于AT90S8515单片机的毫米波测距系统
基于AVR高速嵌入式单片机设计了一种毫米波测距系统,给出了相应的硬件组成结构和软件设计方案。针对毫米波探测系统的特点,测距系统能够满足采样速率快、信号实时处理的要求,可实
2011-08-19 14:38:13
126
频率测量研究综述
针对提高频率测量精度,使测量频率范围加宽、频率测量能高速可靠自适应地进行的问题。文中通过对频率测量分类介绍,结合各学者的研究成果,将各频率测量方法的优缺点进行比较。阐
2011-11-11 14:54:21
52
AT90S8515 pdf
The AT90S8515 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC
2011-12-14 15:41:58
40
基于虚拟仪器的电力系统频率测量
频率是电力系统和电气设备的重要运行参数采用基于离散傅立叶变换校正的电参量微机测量算法, 以为开发平台, 设计实现了应用于电力系统频率测量的虚拟仪器系统, 并详细论述了其工
2011-12-28 14:30:28
27
一种高可靠性的频率测量系统
提出并研制了一种高可靠性、高精度、使用简单且便于维护的频率测量系统,该系统用于电力电子测量领域。其硬件系统以嵌入式PC104计算机为测控平台,软件系统以LabWindows/CVI为开发平
2012-04-24 11:29:32
1266
基于AT90S8515的串行通信及其应用
T90S8515是功能较强的一种型号,它有40引脚PDIP和44引脚PLCC、TQFP等多种封装形式,具有120条功能强大的指令,而且大多数执行时间为单时钟周期,指令周期最短仅为125ns。它具有以下主要特
2012-05-24 13:55:35
2738
AVR单片机AT90S8515及其应用
2014-01-19 09:21:46
10
AT90S8515 Datasheet
2015-04-09 15:21:51
8
基于AVR单片机的步进电机控制
对AVR单片机AT90S8515进行编程,实现对35BYJ46型四相八拍步进电机的控制,以达到精确定位的目的.使AT90S8515单片机并行口c口高四位PC7~PC4分别与驱动接口芯片ULN2803
2016-10-11 15:35:01
12
基于AVR—AT90S8515的多通道智能大厦自动抄表系统
介绍了一种智能大厦住宅的水、电、气表的自动抄表系统。以新型单片机AVR—AT90S8515为中央处理单元,实现了采集器的多通道数据采集、数据存储和数字化的通信功能,系统运行稳定,具有精度高、可靠性好和实时性好等特性。对该嵌入式采集器的硬件和软件作了较为详尽的阐述。
2016-10-11 15:35:01
7
基于AT90S8515的剩余电量测试仪系统设计
利用新一代AVR单片机(AT90S8515)实现蓄电池剩余电量在线测量。该方法通过实时测量蓄电池内阻,推算出其剩余电量,最后给出了实验结果。
2017-09-02 10:46:53
22
基于AT90S8515单片机的直流伺服控制系统的设计
介绍一种用新型AT90S8515单片机设计的闭环位置伺服控制系统,详细介绍了AVR单片机的特点以及与PWM调速相关寄存器的设置。给出了系统硬件电路原理简图和相应的软件设计方法,说明了位置与速度
2017-12-06 10:41:32
11
基于PC104测控计算机的频率测量系统设计
提出并研制了一种高可靠性、高精度、使用简单且便于维护的频率测量系统,该系统用于电力电子测量领域。其硬件系统以嵌入式PC104计算机为测控平台,软件系统以LabWindows/CVI为开发平台,采用
2018-01-18 11:01:34
1534
电力系统频率测量方法及应用
电力系统频率测量存在精度与实时性无法同时满足的问题,因此提出一种多水平集单周期频率测量方法。首先采用数字低通滤波器滤除信号中的高频干扰,其次采用三次样条( not-a-knot)插值法对所设阈值附近
2018-02-12 15:10:03
1
如何用示波器测量无源晶振的输出频率
晶振,是电路中重要的电子元件,控制着系统运行的节拍。晶振有多种类型,无源晶振是其中价格便宜而又应用广泛的一种。在使用示波器测量无源晶振输出频率时,常常会发现晶振有输出无信号、晶振不起振等异常情况,那么如何用示波器测量无源晶振的输出频率?
2019-01-16 16:17:03
18029
AVR单片机在直流伺服控制系统中的应用说明
一种用新型AT90S8515单片机设计的闭环位置伺服控制系统 介绍了AVR单片机的特点以及和PWM 调速相关寄存嚣的设置,给出了系统硬件电路原理筒图和相应的软件设计方法,并说明了位置与速度的测量方法。
2019-01-23 11:08:57
2
AT90S8515单片机对LED数码显示管的控制设计
第1行表示程序中包含定义AT90S8515特殊功能寄存器的头文件8515def.inc,指明所用器件为AT90S85150接着定义寄存器r16、r22分别为暂存器temp、scndp。在程序前面
2019-03-01 14:24:32
2160
利用嵌入式系统与Internet相连接实现Web服务器的应用
在硬件系统的设计中,本文采用了ATMEL公司开发的高性能8位AVR(Advanced RISC)单片机AT90S8515,该单片机内置8 KB可编程Flash,使用精简指令集,支持C语言及汇编语言
2020-01-16 09:47:00
4015
基于单片机实现微波频率测量系统的设计
在通信系统中,频率测量具有重要地位。近几年来频率测量技术所覆盖的领域越来越广泛,测量精度越来越高,与不同学科的联系也越来越密切。与频率测量技术紧密相连的领域有通信、导航、空间科学、仪器仪表、材料科学、计量技术、电子技术、天文学、物理学和生物化学等。
2020-08-05 09:29:01
901
频率测量电路中的硬件设计
来源:罗姆半导体社区 近年来,随着电子信息产业的快速发展,频率信号测量在各个领域的应用越来越广泛。然而,以往由逻辑电路和时序电路设计的频率计一般测量的频率范围较小,运行速度较慢。基于单片机的频率
2022-12-09 10:43:48
900
ATmega8515A和Tmega8515L的微控制器的数据手册免费下载
ATmega8515是基于增强的AVR RISC结构的低功耗8位CMOS微控制器。由于其先进的指令集以及单时钟周期指令执行时间,ATmega8515 的数据吞吐率高达1 MIPS/MHz,从而可以缓减系统在功耗和处理速度之间的矛盾。
2021-03-25 16:18:09
11
基于ReFLEX技术的XMODEM模块的特点及应用设计
系统硬件总框图如图1所示。整个系统硬件由CPU(AT90S8515)、ReFLEX-XMODEM模板、由ID芯片组成的汽车安全保障电路以及接口电路和系统指示电路等组成。其中CPU采用Atmel公司
2021-04-02 10:16:55
1374
单片机设计 测量频率
单片机设计 测量频率一、电路设计单片机应用系统中,经常要对一个连续的脉冲波频率进行测量。在实际应用中,对于转速,位移、速度、流量等物理量的测量,一般也是由传感器转换成脉冲电信号,采用测量频率的手段
2021-11-04 11:21:01
32
如何使用STM32测量频率和占空比?
题目
(1)测量脉冲信号频率fo,频率范围为10Hz~2MHz,测量误差的绝对值不大于0.1%。
(2)测量脉冲信号占空比D,测量范围为10%~90%,测量误差的绝对值不大于2%。
使用官方
2022-02-11 11:01:31
34
MAX8515AEZK+T PMIC - 电压基准
电子发烧友网为你提供Maxim(Maxim)MAX8515AEZK+T相关产品参数、数据手册,更有MAX8515AEZK+T的引脚图、接线图、封装手册、中文资料、英文资料,MAX8515AEZK+T真值表,MAX8515AEZK+T管脚等资料,希望可以帮助到广大的电子工程师们。
2022-11-28 22:25:51
MAX8515EXK+T PMIC - 电压基准
电子发烧友网为你提供Maxim(Maxim)MAX8515EXK+T相关产品参数、数据手册,更有MAX8515EXK+T的引脚图、接线图、封装手册、中文资料、英文资料,MAX8515EXK+T真值表,MAX8515EXK+T管脚等资料,希望可以帮助到广大的电子工程师们。
2022-11-28 22:48:04
R&S推出测量高达90GHz的功率传感器NRP90S(N)
R&S 公司的新型R&S NRP90S和R&S NRP90SN功率传感器在功率测量方面实现了更多性能突破。新产品提供了50 MHz至90 GHz的频率范围和-70 dBm至20 dBm的动态范围
2022-11-30 09:30:30
860
频率计CNT-90测量结果不准维修
近日深圳某院校送修pendulum频率计CNT-90,客户反馈频率计测量结果不准。安泰维修检测实际是控制板组件损坏。本期将为大家分享本维修案例。 pendulum频率计CNT-90测量结果不准
2023-01-04 16:13:27
584
