Intel Coffee Lake 8th Gen Core i3/i5/i7 CPU (LGA1151) with Q370, 4*PCI-E, 3*PCI, 6*COM, 2*Intel LAN, 6*SATA 3.0
规格
General | |
CPU | Intel® Pentium®/ Celeron®/ 8th Generation CoreTM i3/i5/i7 CPU, LGA1151 |
Chipset | Intel® Q370 Chipset, TDP 6W |
Memory | Up to 64 GB DDR4 2666/2400 MHz, 4*DIMM |
Storage | 5*SATA 3.0, 1*SATA3.0/ mSATA |
Expansion Interface | 1*PCI-E 16X, 1*PCI-E 8X, 2*PCI-E 4X, 3*PCI |
BIOS | AMI UEFI BIOS |
System | Windows 10 x64, Linux |
I/O Interface | |
Serial Port | 6*RS232 (COM3, COM4 RS485 optional) |
USB | 6*USB 3.0, 7*USB 2.0 (6*on rear I/O, 6*header, 1*Type-A port) |
Ethernet | 2*Intel® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out/Line-inPorts |
PS/2 | 1*PS/2 |
Parallel Port | Null |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200 1*HDMI 1.4b: max resolution up to 4096*2160 |
Multiple Display | Triple |
Mechanical & Environment | |
Power Input | ATX PSU |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
3文章
3524浏览量
88398 -
嵌入式主板
7文章
6085浏览量
35196 -
信步科技
6文章
263浏览量
7139
嵌入式主板品牌有哪些_6大嵌入式主板品牌盘点
嵌入式主板一般理解为嵌入在设备里面做控制、数据处理使用的CPU板,也就是设备的“大脑”。嵌入式到设备里面,当然就会对主板的体积以及功耗(
信步科技EPC SV-19026嵌入式主板介绍
采用Intel Bay Trail单芯片处理器
嵌入式工控机专用主板
6*COM, 9*USB, 2*千兆网口
2*Mini-PCIe支持mSATA和Wifi/3G/4G
1*VGA, 1*HDMI/eDP, 1*LVDS/eDP, 支持双屏异显
信步科技SV7-38526嵌入式主板介绍
采用Intel Skylake-U 3855U处理器, 可选Intel 6/7/8代Core i3/i5/i7 U系列处理器
提供5*COM, 5*USB, 2*Intel千兆LAN
提供1
信步科技SV-IPC-3862U嵌入式主板介绍
Intel® Kaby Lake-U Celeron® 3865U CPU
10*COM, 2*USB 3.0, 12*USB 2.0
2*1000 Mbps LAN, 1*PCI-E 4X
信步科技SV-IPC-7200嵌入式主板介绍
Intel® Kaby Lake-U 7th Gen Core i5-7200U CPU
6*COM, 2*USB 3.0, 6*USB 2.0, 1*SATA 3.0
2*Intel
信步科技SV-KBL-U5嵌入式主板介绍
Double-layer Rear I/O which can expand to 18*COM and 16*USB
信步科技SV1-38526C嵌入式主板介绍
Intel Skylake-U Celeron 3855U CPU
Double-layer Rear I/O which can expand to 18*COM and 16*USB (use
嵌入式主板是什么意思?嵌入式主板全面解析
嵌入式主板,通常被称为嵌入式系统的核心组件,是一种用于控制和数据处理的计算机硬件,其设计旨在嵌入特定设备中执行专门任务。嵌入式
