Intel LGA1151全系列处理器, 25*SATA, 3*Intel千兆LAN, 12*USB, 2*PCI-E, 1*Mini-PCIe, ATX (305*244mm)
规格
General | |
CPU | Intel® Pentium®/ Celeron®/ Xeon® 6thand 7th Generation CoreTM i3/i5/i7 CPU, LGA1151 |
Chipset | Intel® B150 Chipset, TDP 6W |
Memory | Up to 32 GB DDR4 2133/1866 MHz, 4*DIMM |
Storage | 6*Mini-SAS (24*SATA), 1*SATA 3.0, 1*mSATA |
Expansion Interface | 1*PCI-E 16X, 1*PCI-E 4X, 1*Mini-PCIe (mSATA/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Server 2008/2012, Linux |
I/O Interface | |
Serial Port | 2*RS232 (1*RS485 optional) |
USB | 4*USB 3.0, 8*USB 2.0 (4*on rear I/O, 8*header) |
Ethernet | 3*Intel® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
PS/2 | 1*PS/2 header (Keyboard and Mouse Supported) |
Parallel Port | Null |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
Multiple Display | Triple |
Mechanical & Environment | |
Dimension | ATX, 305*244mm |
Power Input | ATX PSU |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
![](http://file.elecfans.com/web1/M00/A7/0C/o4YBAF2DXaCAbHpEAAKAzsGb_x4697.jpg)
![](http://file.elecfans.com/web1/M00/AB/DE/o4YBAF2_eeKAbvk2AAAYzQsgb2k563.jpg)
举报投诉
WINDOWS
4文章
3584浏览量
89481 -
嵌入式主板
7文章
6087浏览量
35672 -
信步科技
7文章
263浏览量
7297
信步科技NVR SV4-H27A6规格英文版
H270 chipset
4*Mini-SAS (16*SATA), 1*SATA 3.0, 2*1000 Mbps Intel LAN
NVR Alarm port (RS485, 4*in/2
![<b class='flag-5'>信步</b>科技<b class='flag-5'>NVR</b> <b class='flag-5'>SV4</b>-H27A6<b class='flag-5'>规格</b>英文版](https://file.elecfans.com/web1/M00/A7/0C/o4YBAF2DXXiALd-DAANGpKZV_gg085.jpg)
信步科技NVR SV4-B15B4规格英文版
Intel LGA1151 CPU with B150, 25*SATA, 3*1000 Mbps Intel LAN, 12*USB, 2*PCI-E, 1*Mini-PCIe, ATX (305
![<b class='flag-5'>信步</b>科技<b class='flag-5'>NVR</b> <b class='flag-5'>SV4-B15B4</b><b class='flag-5'>规格</b>英文版](https://file.elecfans.com/web1/M00/A7/5F/pIYBAF2DXf2ARaz1AAKAzsGb_x4511.jpg)
信步科技NVR SV6-B75A6主板英文版
Intel LGA1155 CPU with B75, 17*SATA, 2*1000 Mbps Intel LAN, 1*PCI-E 16X, 2*Mini-PCIe, NVR Alarm port
![<b class='flag-5'>信步</b>科技<b class='flag-5'>NVR</b> <b class='flag-5'>SV6-B</b>75A6主板英文版](https://file.elecfans.com/web1/M00/A7/0C/o4YBAF2DXfGAY-DoAAMkpAJzfVU392.jpg)
信步科技NVR SV4-B85B4主板规格英文版
Intel LGA1150 CPU with B85, 26*SATA, 3*1000 Mbps Intel LAN, 2*PCI-E, 1*Mini-PCIe, NVR Alarm port
![<b class='flag-5'>信步</b>科技<b class='flag-5'>NVR</b> <b class='flag-5'>SV4-B85B4</b>主板<b class='flag-5'>规格</b>英文版](https://file.elecfans.com/web1/M00/A7/5F/pIYBAF2DXpeAb_yHAAKxAUKPgtQ225.jpg)
及全系列LGA1150处理器 采用Intel B85芯片组 提供6*Mini-SAS (24*SATA), 2*SATA 3.0, 3*Intel千兆LAN 提供NVR专用报警端子(RS485, 4
![<b class='flag-5'>信步</b>科技<b class='flag-5'>NVR</b> <b class='flag-5'>SV4-B85B4</b>主板<b class='flag-5'>规格</b>英文版](https://file.elecfans.com/web1/M00/A7/61/pIYBAF2DYC2AdUU7AAKxAUKPgtQ824.jpg)
