ADI ADV7282A差分输入四路过取样SDTV视频译码解决方案
电子工程师 作者:工程师陈翠 2018-06-17 18:33 次阅读
ADI公司ADV7282A是10位四路过取样SDTV视频译码器,差分输入,支持NTSC/PAL/SECAM彩色解调,视频输入每路支持CVBS, Y/C和YPrPb模式,模拟视频输入通路配有抗混淆滤波器,NTSC/PAL/SECAM 自动检测,2线I2C兼容串行接口,具有汽车应用的资格和降功耗模式,工作温度−40℃ 到 +105℃ ,主要用在高档驾驶辅助,汽车娱乐系统,媒体播放器和视频安全DVR.本文介绍了ADV7282A主要特性,功能框图,应用电路以及评估板EVAL-ADV7282AEBZ主要特性,连接图和电路图。
The ADV7282A1 has the same pinout as and is softwarecompatible with the ADV7282. The mobile industry processorinterface (MIPIR) model of the ADV7282A (ADV7282A-M)has the same pinout as and is software compatible with theADV7282-M.
All features, functionality, and specifications are shared by theADV7282A and the ADV7282A-M, unless otherwise noted.The ADV7282A is a versatile one-chip, multiformat videodecoder that automatically detects standard analogbasebandvideo signals and converts them into YCrCb 4:2:2 componentvideo data streams.
The analog input of the ADV7282A features an input mux(4-channel on ADV7282A, 6-channel on ADV7282A-M), asingle 10-bit analog-to-digital converter (ADC) and an on-chipdifferential to single-ended converter to accommodate thedirect connection of differential, pseudo differential, or singleendedCVBS without the need for external amplifier circuitry.
The standard definition processor(SDP)in the ADV7282Aautomatically detects PAL, NTSC and SECAM standards in theform of composite, S-Video(Y/C)and component. The analogvideo is converted into a 4:2:2 component video data streamthat is output either via an 8-bit ITU-R BT.656standardcompatibleinterface(ADV7282A)or via a MIPI CSI-2 Tx(hereafter referred to as MIPI Tx) interface (ADV7282A-M)。
The ADV7282A also feature a deinterlacer for interlaced toprogressive (I2P) conversion.The ADV7282A offers short to battery (STB) diagnostic senseinputs and general-purpose outputs.
The ADV7282A is provided in a space-saving LFCSP surfacemount,RoHS compliant package. The ADV7282A is rated overthe −40℃ to +105℃ temperature range, making it ideal forautomotive applications.
ADV7282A主要特性:
Worldwide NTSC/PAL/SECAM color demodulation support
One 10-bit ADC, 4× oversampling per channel for CVBS, Y/C,and YPrPb modes
Analog video input channels with on-chip antialiasing filter
ADV7282A: up to 4 input channels
ADV7282A-M: up to 6 input channels
Video input support for CVBS (composite), S-Video (Y/C),and YPrPb (component)
Fully differential, pseudo differential, and single-ended
CVBS video input support
NTSC/PAL/SECAM autodetection
STB diagnostics on 2 video inputs
Up to 4 V common-mode input range solution
Excellent common-mode noise rejection capabilities
5-line adaptive 2D comb filter and CTI video enhancement
Integrated AGC with adaptive peak white mode
Fast switching capability
Integrated I2P video output converter (deinterlacer)ACE
Downdither (8-bit to 6-bit)
Rovi copy protection detection
8-bit ITU-R BT.656 YCrCb 4:2:2 output and HS,VS,or fieldsynchronization (ADV7282A)
MIPI CSI-2 output interface (ADV7282A-M only)
Full featured VBI data slicer with WST support
Power-down mode available
2-wire, I2C-compatible serial interface
Qualified for automotive applications
−40℃ to +105℃ temperature grade
32-lead, 5 mm × 5 mm, RoHS compliant LFCSP
ADV7282A应用:
Advanced driver assistance
Automotive infotainment
DVRs for video security
Media players
图1.ADV7282A功能框图
图2.ADV7282A-M功能框图
图3.ADV7282A典型连接图
图4. ADV7282A-M典型连接图
评估板EVAL-ADV7282AEBZ
The EVAL-ADV7282AEBZ evaluation kit is the platform provided by Analog Devices, Inc., to evaluate the ADV7282A video decoder. The EVAL-ADV7282AEBZ evaluation kit contains an EVAL-ADV7282AEBZ evaluation board and all of its necessary peripherals.
This user guide provides a detailed overview of the EVAL-ADV7282AEBZ evaluation board hardware and the software required to use it.The ADV7282A data sheet and the ADV7280A/ADV7281A/ ADV7282A Device Manual should be consulted in conjunction with this user guide when using the EVAL-ADV7282AEBZ evaluation board.EngineerZone can be accessed to find additional information about the ADV7282A.
评估板EVAL-ADV7282AEBZ主要特性:
Four video input ports capable of accepting any of the following formats: single-ended CVBS, S-video (Y/C), and component (YPbPr)
Digital (ITU-R BT.656) and YPbPr outputs
评估板EVAL-ADV7282AEBZ包括:
7.5 V power supply block
USB cable
图5.评估板EVAL-ADV7282AEBZ外形图
图6.评估板EVAL-ADV7282AEBZ连接图
图7.评估板EVAL-ADV7282AEBZ电路图(1)
图8.评估板EVAL-ADV7282AEBZ电路图(2)
图9.评估板EVAL-ADV7282AEBZ电路图(3)
  • ADI
    ADI
  • 译码器
    ADV7282A 具有输入的 10 位 4 倍采样 SDTV 视频解码器
    电子发烧友网为你提供ADI(ti)ADV7282A相关产品参数、数据手册,更有ADV7282A的引脚图、接线图、封装手册、中文资料、英文资料,ADV7282A真值表,
    发表于 02-22 13:19
    <b class='flag-5'>ADV7282A</b> 具有<b class='flag-5'>差</b><b class='flag-5'>分</b><b class='flag-5'>输入</b>的 10 位 4 倍<b class='flag-5'>过</b>采样 <b class='flag-5'>SDTV</b> <b class='flag-5'>视频</b>解码器
    ADV7282A Evaluation Board Script Files
    发表于 02-05 08:58 0次下载
    <b class='flag-5'>ADV7282A</b> Evaluation Board Script Files
    ADV7282A IBIS Model
    ADV7282A IBIS Model
    发表于 02-05 08:59 0次下载
    <b class='flag-5'>ADV7282A</b> IBIS Model
    发表于 03-06 11:24 0次下载
    ADV7282A IBIS Model
    ADV7282A IBIS Model
    发表于 03-06 11:27 1次下载
    ADV7281A:10位、4倍采样SDTV视频解码器,带输入数据表
    发表于 05-10 19:51 4次下载
    <b class='flag-5'>ADV7281A</b>:10位、4倍<b class='flag-5'>过</b>采样<b class='flag-5'>SDTV</b><b class='flag-5'>视频</b>解码器,带<b class='flag-5'>差</b><b class='flag-5'>分</b><b class='flag-5'>输入</b>数据表
    ADV7182A:带输入的10位SDTV视频解码器数据表
    发表于 05-10 21:08 0次下载
    <b class='flag-5'>ADV7182A</b>:带<b class='flag-5'>差</b><b class='flag-5'>分</b><b class='flag-5'>输入</b>的10位<b class='flag-5'>SDTV</b><b class='flag-5'>视频</b>解码器数据表
    UG-1155:带输入ADV7182A 10位SDTV视频解码器评估板
    发表于 05-15 12:36 1次下载
    UG-1155:带<b class='flag-5'>差</b><b class='flag-5'>分</b><b class='flag-5'>输入</b>的<b class='flag-5'>ADV7182A</b> 10位<b class='flag-5'>SDTV</b><b class='flag-5'>视频</b>解码器评估板
    ADV7282A:10位、4倍采样SDTV视频解码器,带输入数据表
    发表于 05-15 12:39 3次下载
    <b class='flag-5'>ADV7282A</b>:10位、4倍<b class='flag-5'>过</b>采样<b class='flag-5'>SDTV</b><b class='flag-5'>视频</b>解码器,带<b class='flag-5'>差</b><b class='flag-5'>分</b><b class='flag-5'>输入</b>数据表
    UG-1176:ADV7280A/ADV7281A/ADV7282A功能和特性
    发表于 05-15 15:22 0次下载
    UG-1176:<b class='flag-5'>ADV7280A</b>/<b class='flag-5'>ADV7281A</b>/<b class='flag-5'>ADV7282A</b>功能和特性
    UG-1175:ADV7282A-M 10位4倍采样输入SDTV视频解码器评估板
    发表于 05-24 18:49 4次下载
    UG-1175:<b class='flag-5'>ADV7282A</b>-M 10位4倍<b class='flag-5'>过</b>采样<b class='flag-5'>差</b><b class='flag-5'>分</b><b class='flag-5'>输入</b><b class='flag-5'>SDTV</b><b class='flag-5'>视频</b>解码器评估板
    UG-1173:ADV7281A-M 10位4倍采样输入SDTV视频解码器评估板
    发表于 05-24 18:50 4次下载
    UG-1173:<b class='flag-5'>ADV7281A</b>-M 10位4倍<b class='flag-5'>过</b>采样<b class='flag-5'>差</b><b class='flag-5'>分</b><b class='flag-5'>输入</b><b class='flag-5'>SDTV</b><b class='flag-5'>视频</b>解码器评估板
    ADV7282A评估板脚本文件
    ADV7282A评估板脚本文件
    发表于 05-28 11:17 3次下载
    <b class='flag-5'>ADV7282A</b>评估板脚本文件
    EVAVADV7282A ADV7282A 评估板
    EVAL-ADV7282AEBZ 评估套件是由 Analog Devices, Inc. 提供的平台,用于评估 ADV7282A 视频解码器。EVAL-ADV7282AEBZ 评估套件
    发表于 05-29 13:16 8次下载
    EVAVADV<b class='flag-5'>7282A</b> <b class='flag-5'>ADV7282A</b> 评估板
    ADV7282A IBIS型号
    ADV7282A IBIS型号
    发表于 06-01 21:26 1次下载
    <b class='flag-5'>ADV7282A</b> IBIS型号
