ADI ADF5902 24GHz汽车雷达(MMIC)解决方案
电子工程师 来源:陈翠 2019-04-02 00:38 次阅读
ADI公司的ADF5902是24GHz微波集成电路(MMIC)发送器(TX),集成了24GHz压控振荡器(VCO),具有分数N频率合成器和可编栅阵列(PGA)和用在雷达系统的两路发送器。每个发送器包括功率控制电路和片上温度传感器。控制通过4线串行外设接口(SPI)进行,主要用在汽车雷达,工业雷达和微波雷达传感器。本文介绍了ADF5902主要特性,功能框图,FMCW雷达框图以及评估板EV-ADF5902SD1Z主要特性,电路图,材料清单和PCB设计图。
The ADF5902 is a 24 GHz transmitter (Tx) monolithic microwave integrated circuit (MMIC) with an on-chip, 24 GHz voltage controlled oscillator (VCO)。 The VCO features a fractional-N frequency synthesizer with waveform generation capability with programmable grid array (PGA) and dual transmitter channels for radar systems. The on-chip, 24 GHz VCO generates the 24 GHz signal for the two transmitter channels and the local oscillator (LO) output. Each transmitter channel contains a power control circuit. There is also an on-chip temperature sensor. Control of all the on-chip registers is through a simple, 4-wire serial peripheral interface (SPI)。 The ADF5902 comes in a compact, 32-lead, 5 mm×5 mm LFCSP package.
ADF5902主要特性:
24 GHz to 24.25 GHz VCO (industrial, scientific, and medical(ISM)radio band)
2-channel 24 GHz power amplifier with 8 dbm output
Single-ended outputs
2-channel muxed outputs with mute function
Programmable output power
LO output buffer
RF frequency range: 24 GHz to 24.25 GHz
Power control detector
Auxiliary 8-bit ADC
High and low speed
FMCW ramp generation
25-bit fixed modulus allows subhertz frequency resolution
PFD frequencies up to 110 MHz
Normalized phase noise floor of −222 dBc/Hz
Programmable charge pump currents
±5℃ temperature sensor
4-wire SPI
ESD performance
HBM: 2000 V
CDM: 250 V
Qualified for automotive applications
ADF5902应用:
Automotive radars
Industrial radars
Microwave radar sensors
图1.ADF5902功能框图
图2.采用ADF5902的FMCW雷达框图
评估板EV-ADF5902SD1Z
The EV-ADF5902SD1Z evaluation board allows the user to evaluate the performance of the ADF5902 24 GHz voltage controlled oscillator (VCO) programmable gain amplifier (PGA) with a 2-channel power amplifier (PA) output and ramping phase-locked loop (PLL)。 Figure 1 shows the EV-ADF5902SD1Z evaluation board, which contains the ADF5902, three high frequency K type Subminiature Version A (SMA) connectors for the local oscillator (LO) output, two transceiver outputs, banana connectors for the power supply, and a connector for the serial interface.
The EV-ADF5902SD1Z evaluation board requires an EVAL-SDP-CS1Z system demonstration platform serial (SDP-S) controller board, which the kit does not include. The EVAL-SDP-CS1Z SDP-S allows software programming of the ADF5902 device.
Full specifications on the ADF5902 are available in the ADF5902 data sheet. Consult the data sheet in conjunction with this user guide when working with the EV-ADF5902SDIZ evaluation board. The Windows®-based PLL software provides easy programming of the synthesizer.
评估板EV-ADF5902SD1Z主要特性:
ADPD2140 full configuration
Register level
Parameter level
Graph views
Time series view
Gesture recognition view
Triangulation view
UDP transfer capability
评估板EV-ADF5902SD1Z包括:
EVAL-ADPD2140Z standard evaluation board
USB-C cable
图3.评估板EV-ADF5902SD1Z外形图
图4.评估板EV-ADF5902SD1Z建立图
图5.评估板EV-ADF5902SD1Z电路图(1)
图6.评估板EV-ADF5902SD1Z电路图(2)
图7.评估板EV-ADF5902SD1Z电路图(3)
图8.评估板EV-ADF5902SD1Z电路图(4)
图9.评估板EV-ADF5902SD1Z电路图(5)
图10.评估板EV-ADF5902SD1Z电路图(6)
图11.评估板EV-ADF5902SD1Z电路图(7)
评估板EV-ADF5902SD1Z材料清单:
图12.评估板EV-ADF5902SD1Z PCB设计图(1):顶层
图13.评估板EV-ADF5902SD1Z PCB设计图(2):底层
  • ADI
    ADI
  • 汽车雷达
    ADI针对汽车和工业传感器推出24GHz FMCW雷达收发器芯片解决方案
    本文介绍了适于汽车和工业传感器应用的24GHz FMCW雷达收发器芯片组,ADF5904搭配IC (发射机ADF5901芯片和
    的头像 发表于 01-05 11:49 5960次阅读
    <b class='flag-5'>ADI</b>针对<b class='flag-5'>汽车</b>和工业传感器推出<b class='flag-5'>24GHz</b> FMCW<b class='flag-5'>雷达</b>收发器芯片<b class='flag-5'>解决方案</b>
    24GHZ雷达传感器的选型及运用基础
    汽车防撞系统、有人自动报警系统等功能。成本从几十元到几千元的解决方案都有,为用户和厂商提供各式各样的运用可行性。已有厂家将24GHZ雷达传感器K-LC3型号应用于
    发表于 12-20 16:56
    24GHz微波雷达FMCW测距系统设计概述
    `跟大家分享一篇24GHz微波雷达FMCW测距系统设计与实现的论文,24GHz微波雷达FMCW测距技术,目前主要应用于智能交通行业的断面车流量雷达
    发表于 12-29 11:37
    24GHz ADAS 雷达评估系统的搭建、评估与测试
    24GHz雷达解决方案可用于多种应用,比如智能交通信号灯、汽车雷达、油箱液位传感器、运动检测监控和安防、开门装置等等。
    发表于 04-17 16:13
    24GHz毫米波雷达系统
    谁做过汽车24GHz毫米波雷达系统,有没有关于微带贴片天线的技术资料,邮箱:junxin.yu@kuwe.com.cn 谢谢!
    发表于 03-12 09:48
    Ameya360 汽车雷达系统解决方案
    24Ghz 占据了大头。2、方案概述汽车微波 / 毫米波雷达因为其抗环境干扰能力强、稳定性高的特点而被各大汽车制造商看好。这类应用在欧美
    发表于 04-19 14:56
    关于使用SiGe和28nm CMOS的24GHz至44GHz无线电完整解决方案
    使用SiGe技术和28nm CMOS的24GHz至44GHz无线电解决方案上,也有完美的答案哦,让版主带大家一起来瞧瞧吧。 完整解决方案专场下图是一个Eaton ADS8系列过载继电器
    发表于 08-01 09:49
    请问用德国innosent的24GHZ雷达前端做汽车盲区监测有推荐方案吗?
    用德国innosent的24GHZ雷达前端做汽车盲区监测,对I、Q两路信号进行放大,属于mv级别甚至毫伏基本的交流小信号放大问题,求推荐方案?AD797可另外电源要求是对12v直流电源
    发表于 08-14 06:39
    ADF5902 24 GHz、ISM 频段、多频道 FMCW 雷达变送器
    电子发烧友网为你提供ADI(ti)ADF5902相关产品参数、数据手册,更有ADF5902的引脚图、接线图、封装手册、中文资料、英文资料,ADF5902真值表,
    发表于 02-22 15:06
    <b class='flag-5'>ADF5902</b> <b class='flag-5'>24</b> <b class='flag-5'>GHz</b>、ISM 频段、多频道 FMCW <b class='flag-5'>雷达</b>变送器
    演示雷达:新型24GHz雷达传感器评估平台解决方案
    演示雷达是一款新颖的24 GHz雷达传感器评估平台解决方案,可提供开箱即用软件示例并可在几分钟内轻松启动
    的头像 发表于 07-30 06:07 2331次阅读
    完全集成式24GHz雷达解决方案的应用范围分析
    完全集成式高性能24GHz雷达解决方案可用于多种应用,比如智能交通信号灯、汽车雷达、油箱液位传感器、运动检测监控和安防、开门装置等等。
    的头像 发表于 06-14 06:06 1839次阅读
    ADF5902 Evaluation Software
    发表于 02-01 09:54 0次下载
    <b class='flag-5'>ADF5902</b> Evaluation Software
    ADF5902评估软件
    ADF5902评估软件
    发表于 03-23 12:43 7次下载
    <b class='flag-5'>ADF5902</b>评估软件
    UG-1432:ADF5902 24 GHz、ISM波段多通道FMCW雷达发射机评估
    发表于 04-21 20:43 11次下载
    UG-1432:<b class='flag-5'>ADF5902</b> <b class='flag-5'>24</b> <b class='flag-5'>GHz</b>、ISM波段多通道FMCW<b class='flag-5'>雷达</b>发射机评估
    ADF590224 GHz,ISM磁带,MMCW雷达雷达传输数据Sheet
    发表于 04-22 13:10 7次下载
    <b class='flag-5'>ADF5902</b>:<b class='flag-5'>24</b> <b class='flag-5'>GHz</b>,ISM磁带,MMCW<b class='flag-5'>雷达</b><b class='flag-5'>雷达</b>传输数据Sheet
