G:\ESP32\play_mp3>idf.py menuconfig
Checking Python dependencies...
Python requirements from G:\ESP32\esp-idf\requirements.txt are satisfied.
Running cmake in directory g:\esp32\play_mp3\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 --warn-uninitialized -DWARN_UNINITIALIZED=1 -DCCACHE_ENABLE=1 g:\esp32\play_mp3"...
Warn about uninitialized values.
fatal: not a git repository (or any of the parent directories): .git
-- Found Git: F:/git/Git/cmd/git.exe (found version "2.27.0.windows.1")
-- mconf-idf version mconf-v4.6.0.0-idf-20190628-win32
-- IDF_TARGET not set, using default target: esp32
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 8.2.0
-- The CXX compiler identification is GNU 8.2.0
-- The ASM compiler identification is GNU
-- Found assembler: G:/ESP32/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: G:/ESP32/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: G:/ESP32/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: G:/ESP32/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe
-- Check for working CXX compiler: G:/ESP32/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Project version: 1
-- Building ESP-IDF components for target esp32
CMake Erro
一般出现上述问题据经验看,应该大概率是环境安装有问题,我测试了IDF4+ADF master分支上的是可以进去的;idf是可以的去的,adf不可以就要注意配置ADF_PATH或者是把adf里面的cmacklist 的idf path注释掉。会重定向idf path
ymf
