电子发烧友App
硬声App
电子发烧友网>通信网络>有线通信>基于AX88796B的网络接口模块的设计与实现
收藏
查看更多
一种低功耗以太网接口电路的设计方案
摘要:为了实现低功耗以太网接口电路的设计,同时满足兼容多种微处理器的目的,本文采用低功耗并支持SPI及Non-PCI总线的以太网控制器AX88796C作为核心芯片,提出了一种低功耗以太网接口电路
2014-01-14 11:11:347790
AX88796/AX88796b
The AX88796B is a low-pin-count (64-pin LQFP) non-PCI Ethernet controller for the Embedded
2010-05-16 10:59:49
AX88796BLF
AX88796BLF
2022-11-04 17:22:44
AX88796BLI
AX88796BLI - Low-pin-count Non-PCI 8/16-bit 10/100M Fast Ethernet Controller - ASIX Electronics Corporation
2022-11-04 17:22:44
AX88796C
High-performance non-PCI local bus Supports both 8 bit and 16 bit local CPU interfaces include MCS-51 series, 80186 series CPU and ISA bus SRAM-like host interface (US Patent Approval), easily interfaced to most common embedded MCUs Embeds 8Kx16 bits SRAM for packet buffers Supports Slave-DMA to minimize CPU overhead Supports burst-mode read for highest performance applications Interrupt pin with programmable Hold-off timerSingle-chip Fast Ethernet controller Compatible with IEEE802.3, 802.3u standards Integrates Fast Ethernet MAC/PHY transceiver in one chip Supports 10Mbps and 100Mbps data rate Supports full and half duplex operations Supports 10/100Mbps N-way Auto-negotiation operation Supports twisted pair crossover detection and auto-correction (Auto-MDIX) Supports IEEE 802.3x flow control for full-duplex operation Supports back-pressure flow control for half-duplex operationSupports Wake-on-LAN function to reduce power by following
2010-05-16 11:23:03
AX88796B
[The AX88796B is a low-pin-count (64-pin LQFP) non-PCI Ethernet controller for the Embedded
2010-05-16 11:02:28
Ax88796实现SA1110的软件方面
Ax88796实现SA1110的软件方面由于Ax88796是NE2000兼容芯片,所以Linux kernel中的驱动ne.c、8390.c只需作较少的改动就可以用来驱动SA1110平台
2011-07-15 14:53:26
网络接口可脱机时间继电器控制模块的设计与实现
我的毕业设计课题,网络接口可脱机时间继电器控制模块的设计与实现,基本上没有什么头绪,求各位大神指导,现在连开题报告都不知道怎么写,还有硬件电路,软件编程,各种烦人啊,求求各路大神给点思路,谢谢啊
2014-02-26 10:11:14
ATK-ENC28J60网络模块
接口方式:SPI,网络速率:10Mbps,外形尺寸:50*18mm,工作电压:3.3V,工作电流:190mA(max),工作温度:-40~85℃
2023-03-28 13:02:26
ENC28J60网络模块
2023-03-28 13:06:18
FPGA 配置 LAN8710A 100Mbps,类似AX88796B 缓存
使用FPGA+PHY,实现了类似AX88796B的功能,100Mbps有需要的查看,有问题提出宝贵意见
2016-01-22 10:14:05
Noiseken ESS-200AXNoiseKen ESS-200AX 静电放电发生器
HP 81531A光功率计传感插件Agilent HP 81532A传感器Agilent HP 81533A光功率计传感插件Agilent HP 81533B光探头接口模块Agilent HP
2019-12-20 18:33:13
SDIO接口WIFI模块怎么实现数据互发?
使用STM32F401单片机SDIO接口控制一个WIFI模块。目前能够成功初始化模块,但是不知道怎样和模块实现数据互发?查找网上资料基本都是驱动SD卡的,驱动SDIO卡的资料比较少。大家有谁做过这方面吗?下图程序是操作成功的SDIO卡初始化代码:
2019-04-26 05:46:08
SDIO接口WiFi模块的工作原理及特征概述
的符合wifi无线网络标准的嵌入式模块,内置无线网络协议IEEE802.11协议栈以及TCP/IP协议栈,能够实现用户主平台数据通过SDIO口到无线网络之间的转换。 SDIO接口wifi模块的工作原理
2019-06-21 04:36:35
SDIO接口WiFi模块的工作原理和基本特征介绍
2018-05-08 10:36:55
SKYLAB:简单介绍两款UART接口的WiFi模块
和IEEE802.11协议栈,能够实现用户串口到无线网络之间的转换。UART接口WiFi模块UART接口WiFi模块是基于UART接口的符合WiFi无线网络标准的嵌入式模块,内置无线网络协议IEEE802.11
2018-08-10 09:41:08
USB20网卡网络控制AX88772资料推荐
USB20网卡网络控制AX88772资料下载内容包括:AX88772引脚功能AX88772内部方框图
2021-03-24 06:19:17
串口输出信息是这样的,这个是什么问题?硬件有问题吗
= 80007774In:serialOut:serialErr:serialNet:ax88796cWarning: ax88796c MAC addresses don't match:Address in SROM
2013-08-31 13:29:14
二手ESS-200AX 二手ESS-200AX
`二手ESS-200AX静电枪,二手ESS-200AX 二手ESS-200AX静电枪,二手ESS-200AX本公司现在新进了一批频谱分析仪、网络分析仪、信号分析仪、示波器、综合测试仪、音频分析仪
2017-12-19 14:24:51
亚信AX58200 EtherCAT转Modbus TCP网关解决方案介绍视频
百兆以太网口,来连接EtherCAT网络;并使用另外一个内置支持RMII接口的百兆以太网MAC,连接10/100M百兆以太网PHY,来连接Modbus TCP网络。这个方案的AX58200韧体,会根据
2021-08-23 10:56:15
亚信电子展出全新AX58100 EtherCAT从站控制器
芯片解决方案 - AX58100 2/3端口EtherCAT从站控制器。 相对于其它的EtherCAT从站控制器解决方案,AX58100已集成两个可同时支持光纤和铜线网络应用的高速以太网PHY并支持
2018-09-06 14:16:13
使用IPort-1模块怎么给嵌入式设备增加网络接口
通信相互转换的产品,无疑是一个较好方案。为此,本文提出了一种使用IPort-1模块给用户嵌入式设备增加网络接口实现方案。用户可以在完全不了解网络协议和控制接口的情况下,给自己的嵌入式设备增加网口而不需要修改原有的硬件电路,因而是一种方便易行的嵌入式设备网络解决方案。
2019-10-09 06:11:38
信创平台WIFI6模组替代AX201及AX101系列
YM2201 是一款高度集成的 M.2 模块,支持双流 802.11ax 解决方案,具有以下特性 多用户 MIMO(多输入、多输出)解决方案,带有无线局域网(WLAN)PCI Express 网络
2024-03-15 15:24:20
千兆网络接口在S3C2440A系统中的应用方案
网络驱动程序实现AX88180内部寄存器编程,实现对以太网数据的发送和接收,从而完成网络与系统之间的数据传输。AX88180与88E1111之间采用RGMII接口方式互连,负责数据传送底层协议的实现
2019-04-17 07:00:07
基于Ax88796的SA1110以太网接口设计
摘要:讨论嵌入式微处理器SA1110与以太网控制器Ax88796在实际应用中的硬件连接问题;给出软件设计方面的一些注意事项,为SA1110的网络应用提供一种参考。关键词:嵌入式 SA1110
2019-06-18 05:00:13
基于VxWorks的网络接口设计
了VxWorks下的网络接口,包括硬件设计和软件实现两个部分。1 硬件设计核心CPU采用三星公司的S3C44B0。S3C44B0采用ARM7TDMI内核,它通过提供全面的、通用的片上外设,大大减少了系统电路除处理器
2018-12-04 10:40:49
如何使用多个网络接口
概览在计算机或嵌入式控制器上有多个以太网适配器,尤其是有线和无线适配器共存,正在变得越来越普遍。 如某个网络接口配置不当,或配置时未考虑到整个网络布局,多个以太网网络接口的系统可能会导致网络
2019-07-16 08:53:35
如何去实现一种高性能网络接口设计?
传统网络接口处理流程包括哪些步骤?如何去实现一种高性能网络接口设计?
2021-05-20 06:41:48
如何用Ax88796实现SA1110的以太网接口
本文讨论嵌入式微处理器SA1110与以太网控制器Ax88796在实际应用中的硬件连接问题;给出软件设计方面的一些注意事项,为SA1110的网络应用提供一种参考。
2021-06-04 06:35:03
怎么实现基于AVR单片机的通用USB接口模块设计?
2021-06-07 06:26:10
怎么实现嵌入式WEB传感器的网络接口设计?
本文介绍了嵌入式WEB传感器的体系结构,提出了网络接口中TCP/IP协议栈的几种实现方式,着重探讨了基于TCP/IP协议栈芯片W3100A的网络接口实现,最后分析了嵌入式WEB传感器的WEB功能的实现
2021-06-04 06:19:31
怎样去设计TNETll00B和OMAP5912的接口
什么是无线网卡模块TNETll00B?怎样去设计TNETll00B和OMAP5912的接口
2021-05-27 07:19:57
手机网络控制wifi模块怎么实现
是,手机234G网络无限距离都可以跟模块通信,还可以通过微信控制,这种通信是怎么实现的呢?涉及到哪些方面?这是不是云端通信?云端服务器又是怎么实现的?恳请大神解答!
2017-06-23 10:33:49
AX5043开发433M数传模块资料,谢谢!
求用AX5043开发433M数传模块资料,谢谢!
2015-04-25 11:32:26
请问CH9374b如何实现蓝牙接口的KVM?如果用ESP32模块可以实现吗?
您好,我想通过CH9374b实现2口KVM,用的蓝牙键盘,请问CH9374b如何实现蓝牙接口的KVM?如果用ESP32模块可以实现吗?
2022-10-11 08:15:56
请问使用AX88772B需要另外配置EEPROM吗
請問使用AX88772B需要另外配置EEPROM嗎?Kernel有支援嗎?
2022-01-06 07:09:14
请问如何实现基于IP模块的PCI接口设计?
如何实现基于IP模块的PCI接口设计?
2021-04-20 06:28:50
请问怎样去设计VxWorks的网络接口
VxWorks下的网络接口的硬件如何去设计?VxWorks下的网络接口的软件系统如何实现
2021-04-27 07:10:28
通过FPGA实现温控电路接口及其与DSP通信接口的设计
芯片和 DAC的通信接口四个部分。(1) 与温度传感器的通信接口本方案的温度传感器采用DS18B20,它通过硬件非常简单的 1-wire总线通信,由于硬件简单所以通信协议比较复杂。要实现与它的通信接口
2020-08-19 09:29:48
采用AX88796C实现低功耗以太网接口模块设计
摘要:为了实现低功耗以太网接口电路的设计,同时满足兼容多种微处理器的目的,采用低功耗并支持SPI及NonPCI总线的以太网控制器AX88796C作为核心芯片,提出了一种低功耗以太网接口模块的设计方案
2019-06-21 05:00:09
采用FPGA实现以太网MII接口扩展设计
方法可以实现单片机系统接入因特网:一种方法是利用NIC (网络控制/网卡)实现网络接口,由单片机来提供所需的网络协议;另外一种方法是利用具有网络协议栈结构的芯片和PHY(物理层的接收器)来实现网络接口,主控
2019-04-30 07:00:16
采用PM3388和FPGA实现网络接口设计
和配置统计两大功能:第一、接收MAC层处理子模块发送过来的数据片,完成MAC帧重组和十路数据合路处理,再根据MAC帧封装的三层协议类型实现数据包的分类处理,按照不同的处理要求把数据包分别送B接口、F接口
2019-04-29 07:00:07
AX88796B pdf datasheet
2008-08-05 10:40:1047
AX88782/AX88783 pdf datasheet
AX88783是一款双端口以太网交换器,第三个端口为Non-PCI/SRAM-like主机接口AX88742也是一款双端口以太网交换器,但第三个端口则为32-bit/33MHz PCI主机接口。内建的第二层交换器支持non
2008-08-05 10:43:2889
AX88796L pdf datasheet (3-in-1
The AX88796 Fast Ethernet Controller is a high performance and highly integrated local CPU bus
2008-12-25 19:39:3516
AX88796/AX88796B pdf datasheet
2008-12-25 19:41:5043
基于AX88796的嵌入式网络设备驱动程序设计
摘要:论述了嵌人式Unux网络设备驱动程序的体系结构,即:协议接口层、网络设备接口层、设备驱动功能层、网络设备和网络媒介层;介绍了s3C2410X处理器与以太网控制器Ax887%的接口
2009-01-09 17:56:2036
81533B Keysight 是德 光头接口模块
和 81533B 接口模块可与 815xx 光学头和 8153、8163 和 8164&nb
2022-09-27 14:50:22
基于AX88796 的以太网接口的设计与实现
随着以太网技术的飞速发展,对以太网接口技术的要求也越来越高。本文给出了一种基于AX88796 网卡芯片的以太网接口的设计与实现方法,详细论述了其工作原理以及与嵌入式操作
2009-06-09 10:57:0141
基于MMC2107的网络接口设计与实现
实现基于MMC2107的嵌入式系统的网络连接,文章在简要介绍网络接口控制器RTL8019AS的基础上,给出了MMC2107微控制器与网络接口控制器RTL8019AS的接口电路设计和软件设计流程。关
2009-06-16 11:44:2429
基于神经网络故障诊断平台的接口模块开发
该文介绍了基于自组织神经网络的针对某型雷达的故障诊断平台接口模块实现过程。利用Delphi 实现分类样本的录入工作及平台的图形用户界面功能,将复杂的网络计算与分类过程
2009-08-15 08:06:329
多种通信网络接口转换模块的研制
多种通信网络接口转换模块的研制:针对大系统中共存的多种通信网络和同种网络多种接口互相通信的需要,采用LPC2368 SOC 结合RTL-RTX 实时操作系统,研制一个支持多种通信网
2009-10-04 14:04:1915
智能传感器接口模块的设计与实现
IEEE145112 标准为网络化智能传感器描述了传感器与网络适配器(NCA P) 或微处理器之间的硬件和软件接口。智能传感器接口模块(ST IM ) 包括传感器接口电路, 信号调理和转换, 标定, 线性
2009-11-16 14:24:0316
基于以太网的指纹门禁控制器设计与实现
设计了基于以太网和指纹识别的智能网络型门禁控制器。在ARM9 和Linux 操作系统(S3C2410)上采用FPS200 指纹传感器实现指纹图像的采集,以及采用以太网控制器芯片AX88796实现
2009-12-19 16:35:5541
基于AVR的网络用具接口的设计与实现
网络用具的网络接口是家用电子设备网络化的关键部件。讨论了通过AVR 单片机以及RTL8019AS 网络芯片把网络用具接入家庭网关的实现方法。为家庭网关和网络用具的通讯提供了一
2010-01-06 16:45:3220
基于单片机嵌入式网络接入模块的设计与实现
摘要:本文主要提出了一种基于普通单片机的网络接入模块的设计方案。网络接入模块是廉价的测控网络接入方案,它可以将具有RS-232等接口的测控设备简单又直接地连接在局域网
2010-07-06 23:43:3228
嵌入式模块接口性能测试系统的网络通信技术
 为适应工程中各类嵌入式模块接口性能测试的网络化趋势,设计了稳定可靠的通信机制,实现客户机/服务器模式的测试系统。基于解决网络通信问题的套接字网络编程,利用
2010-11-26 15:45:5325
基于AX88796的嵌入式WEB服务器构建
 在以太网控制器AX88796的基础上,提出了构建嵌入式WEB服务器的软硬件架构。采用混合TCP和UDP的方式实现HTTP协议,可通过客户机浏览器实现对服务器网页的访问控制。
2010-12-11 17:06:4827
基于ETX模块接口扩展基板电路的实现
ETX(Embedded Tecnology Extended)模块具有完整的PC功能和高效的CPU性能。通过扩展ETX模块的各种外设功能,实现的标准扩展接口有IDE、CF卡、VGA、USB、串口等扩展电路,使ETX广泛应用于各
2010-12-24 15:55:290
基于AX88796B网络接口模块的设计与实现
基于AX88796B网络接口模块的设计与实现 引言网络技术应用日益普及的今天,工业现场的仪器仪表、数据采集和控制设备也日趋网络化,工业自动化和网络的结合越
2008-08-05 10:39:22976
模块接口
模块接口模块接口卡是针对中高档的模块化路由器、交换机产品而言的,对于固定配置的路由器和交换机而言不涉及模块接口卡。通常网络
2010-01-07 14:11:10654
ISDN网络模块
ISDN网络模块 拨号连接由一个系列提供综合业务数字网(ISDN)主要速率接口(PRI)基本速率接口(BRI)的网络模块;集成数字调制解调器、模拟调制
2010-01-07 14:13:29880
亚信电子推出低功耗SPI或Non-PCI以太网控制器AX88
亚信电子推出低功耗SPI或Non-PCI以太网控制器AX88796C 亚信电子(ASIX Electronics)近日宣布其嵌入式网络系列新增一款针对嵌入式及工业以太网应用的网络控制芯片AX88796C,低
2010-03-12 10:09:13747
语音网络模块
语音网络模块 语音网络模块总是与语音接口卡一起使用,它们一起提供在单一模块里集成语音和数据,给用户带来极大的业务优势,比如:IP电话。在CISCO2600XM系
2010-01-07 14:14:11766
网络运动控制器和以太网接口模块
固高公司的基于网络的运动控制器主要是由网络接口模块和运动控制器组成。基于网络的运动控制器主要应用于那些执行元件与控制系统之间的距离较远和分散,为了减少系统联线、提
2011-07-06 18:16:0836
基于MPSoC的以太网接口设计与实现
阐述了设计中各模块实现功能和设计方法,通过仿真和FPGA验证结果表明,以太网接口数据通讯具有实时和高吞吐率。实现了多核系统与网络数据的信息传递,硬件设计结构简单、性能稳定
2011-12-23 14:30:2332
基于ARM嵌入式IPCamera的设计与实现
如何设计一款能够通过网络实现远程拍照和浏览照片的IPCamera?本文通过采用ARM9和USB摄像头实现IPCamera。IPCamera使用S3C2410、AX88796等元件来组成硬件平台,再将Linux系统移植到硬件平台上
2012-05-29 10:05:194477
基于FPGA的通信接口模块设计与实现
本文设计一个通信接口模块,通过光纤接口与中心机连接,实现对前端受控模块的远程控制和状态监测。
2012-09-03 15:59:184808
亚信电子推出针对嵌入式网络应用USB转以太网控制芯片AX88772C
近日,亚信电子针对嵌入式网络应用推出一款USB to LAN系列以太网控制芯片AX88772C,芯片支持Microsoft AOAC,接口符合USB 1.1/2.0规格,可满足嵌入式系统小型化与即插即用需求。
2013-05-20 15:31:014136
单片机实现PS_2键盘的接口设计及模块化编程
本文分析了PS/2键盘的接口和通讯协议,介绍了单片机实现PS/2键盘的接口设计,并以AT89C51为例,陪喝PC机标准PS/2键盘接口模块化编程实现了对键盘个个按键的扫描以及与PC机的通信。
2016-03-25 11:16:1525
ENC28J60 spi 接口 以太网 网络模块 提供 代码
ENC28J60 spi 接口 以太网 网络模块 提供 代码ENC28J60 spi 接口 以太网 网络模块 提供 代码ENC28J60 spi 接口 以太网 网络模块 提供 代码。
2016-05-17 17:47:5921
Ax88796手册
全为公司开发设计用的IC资料
2016-12-13 23:19:435
ax5031编程手册
接口。 连接到微控制器ax5031的ax5031可以很容易地连接到任何微控制器。微控制器与通过登记文件,是实施的ax5031ax5031,可连续通过一个行业访问标准串行外设接口(SPI)协议。复位可以通过寄存器文件执行。因此,由于对集成功率复位(POR)块没有专用复位引
2017-03-31 11:37:279
WIFI模块普及_WIFI模块通信接口介绍
WIFI模块普及_WIFI模块通信接口介绍。WIFI模块接口的作用是将串口数据转换成无线网络数据,从而可以实现串口设备连接无线网络。WiFi模块常用的通讯接口一般包含这几种:UART接口、SPI接口、I2C接口、I2S接口、SDIO接口、USB接口、RGMII接口、RMII接口等。
2017-10-19 12:26:5141
基于FPGA的高速DSP与液晶模块接口实现
2017-10-19 13:46:233
SIMATIC ET 200M接口模块产品信息
接口模块主要功能是提供不同的总线接口实现西门子自动化系统与网络的通讯,一般有PROFIBUS,CAN,DeviceNet等不同的接口形式。
2017-11-21 15:46:5156
使用硬件模块实现8051 MCU与I2C™串行EEPROM的接口
本文档内容介绍了基于使用硬件模块实现8051 MCU与I2C串行EEPROM的接口,供参考
2018-03-29 15:03:121
极低功耗的两款全新的神经网络内核AX2185和AX2145
Imagination公司日前基于其神经网络加速器(NNA)架构PowerVR 2NX推出了两款全新的神经网络内核AX2185和AX2145,其设计目的是在极小芯片面积上以极低功耗实现神经网络高性能计算。
2018-06-20 10:50:043674
简单介绍两款UART接口的WiFi模块
栈和IEEE802.11协议栈,能够实现用户串口到无线网络之间的转换。UART接口WiFi模块UART接口WiFi模块是基于UART接口的符合WiFi无线网络标准的嵌入式模块,内置无线网络协议IEEE802.11
2018-08-09 19:01:006699
多种通信网络接口转换模块的研究资料说明
针对大系统中共存的多种通信网络和同种网络多种接口互相通信的需要,采用LPC2368 soc结合RTL-RTX实时操作系统,研制一个支持多种通信网絡及接口互相转换的模块实现以太网、串口网、CAN
2019-07-18 16:37:0036
Imagination正式推出了两款神经网络内核AX2185和AX2145
Series2NX AX2185以高端智能手机、智能监控和汽车市场为目标,在这些市场中神经网络加速对诸如图像分类和驾驶辅助系统等领域可以产生重大影响。AX2185拥有8个全宽度计算引擎,每个时钟周期可处理2048个MAC(每秒4.1兆次运算)
2020-04-17 14:28:091832
使用STM32单片机实现传感器接口模块的设计资料说明
基于 STM32实现了电流型、电压型以及数字 IO 型传感器接口 模块;进行了接口模块的软件设计,说明了详细的固件代码设计。除传统串口外,提供以太网接口,嵌入 UDP协议 ,提供后期开发的便利接口
2020-09-24 08:00:002
什么是MPO接口模块,MPO接口模块的简介
什么是 MPO接口模块? MPO接口模块指的是接口类型为MPO的光模块,必须搭配MPO接口的跳线才能使用。MPO接口分为公头和母头,必须搭配使用。一般光模块接口类型为MPO公头,所以使用MPO
2021-09-07 18:03:2410933
对于不同接口的光模块,该如何连接传输
目前我们常见的光模块分为LC接口、SC接口和MPO接口,电口模块使用的是RJ45接口,光模块之间要实现信息交换就必须将两种光模块连接起来,连接两个模块的跳线需要匹配其接口才能插入进行传输。 一、相同
2021-09-07 18:05:147174
MELSEC iQ R EtherNet/IP网络接口模块用户手册(应用篇)
MELSEC iQ-R EtherNet/IP网络接口模块用户手册(应用篇) 产品规格书
2022-08-26 10:09:401
MELSEC Q EtherNet/IP网络接口模块用户手册
本手册是对 MELSEC-Q 系列对应 QJ71EIP71 型 EtherNet/IP 网络接口模块 ( 以下略称为 EtherNet/IP 模块 ) 的规格、投运步骤、功能及故障排除有关内容进行了说明的手册。
2022-08-26 10:41:172
AX5043-1 DVK2b 模块性能
AX5043-1 DVK2b 模块性能
2022-11-15 19:28:500
AX8052F1xx、AX-SFxx-1-xx、AX-SFxx-API-1-xx、AX-SIP-SFxx-1-xx 和 AX-SIP-SFxx-API-1-xx 的外部复位信号
2022-11-15 20:10:382
网络音频模块有什么功能特点
网络音频模块是一块ARM+DSP构架,专注于网络音频传输的控制模块,具有10/100M 以太网接口,可通过网络进行单向MP3音频流和双向语音传输。 网络音频模块使用了处理器构架加专业的双向音频
2023-05-16 10:23:04310
网络音频模块有哪些应用场景?
深圳锐科达电子有限公司专业从事网络音频产品、IP网络广播、IP网络对讲研发生产 网络音频模块是一种可以通过网络传输音频信号的控制模块,它有一个以太网接口,可以连接到互联网或局域网。网络音频模块可以
2023-05-16 10:24:36341
如何使用usb接口wifi模块网络摄像头_模块应用
智能家居、无线通讯网络连接每个家庭的居家安防安全或办公生活,如何使用USB接口WiFi模块网络摄像头的知识分享,需要先了解无线wifi模块产品应用、使用方法;wifi模块在传统的一些网络领域
2021-10-29 22:03:471867
海凌科新款WiFi6 AX3000路由模块简介
其实只需要海凌科新款WiFi6 AX3000 模块,这些问题都可以得到很好的改善和解决。
2023-09-11 09:37:32709
博途案例:模块更新与接口更改的实现方法
由于模块上的接口更改,翻译时不一定会生成错误消息。 因此,文档“jyyy_mm_tt SPS_HMI_Info_VASSV6”中描述了包括更改在内的受影响模块。 “接口匹配”视图比较模块(旧接口和新接口)。在这里,非参数化的模块输入和模块输出必须连接。
2023-10-26 10:51:531057
电口模块的应用:实现高速网络通信
电口模块可以适配各种不同的设备和网络环境,可以连接交换机、服务器、网卡等多种设备,在网络设备上,电口模块可以将光口转换为电口,满足网络设备RJ45接口(网线接口)不足的情况,电口模块用于连接服务器和存储设备,在100m的距离内实现大规模数据的传输和处理。用于构建局域网、广域网和连接服务器与存储设备。
2024-01-29 11:52:16161
已全部加载完成
