在国外LBS+ar游戏《Pokemon Go》引起的全球AR社交狂潮背后,越来越多的中国互联网公司也将他们的AR技术研究成果公布出来,正式开启他们LBS+AR产品的发行工作,这其中就包括了百度、腾讯、支付宝、新浪、UC这样的巨头型企业。
2016-12-22 12:41:531133 如果把实用的 LBS 与最具想象力的 AR 结合,那将会产生怎样的化学反应?异常火爆的Pokémon GO 便是 LBS+AR 在游戏行业内的成功应用,两者的结合为用户带来了一种全新的游戏体验。当宠物小精灵IP遇见AR+LBS,一个超级巨浪产生了,而且在短时间内席卷了全球。
2017-02-07 13:41:302536 LBS06004 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS06308 - 63MHz SAW Filter 1MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS06701 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS07065 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS07073 - 69.99MHz IF SAW Filter 1.23MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS07101L_10 - 71MHz SAW Filter 0.22MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS07102 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS07103 - 71MHz SAW Filter 0.2MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS07202 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS07406 - 73.7MHz SAW Filter 1MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS08036 - 80MHz SAW Filter 0.1MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS09601 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS10402 - 103.7MHz SAW Filter 3MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS11003 - 110MHz SAW Filter 1MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS11401 - 114MHz SAW Filter 0.48MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS11503A - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS11504A - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS11519 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS11520 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS11526 - 115MHz SAW Filter 0.22MHz Bandwidth - List of Unclassifed Manufacturers
2022-11-04 17:22:44
LBS11526 - 115MHz SAW Filter 0.22MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS11531 - 115MHz SAW Filter 1.8MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS11601 - 116MHz SAW Filter 1MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS12010 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS12033 - 120MHz SAW Filter 1MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS12202 - 122.75MHz SAW Filter 2.5MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS13002 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS13004 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS13503_10 - 135.4MHz SAW Filter 4MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS138A - 138.625 MHz SAW filter technical specification - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14021 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14025 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14026 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14027 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14028 - 140MHz SAW Filter 1MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14031 - 140MHz SAW Filter 0.25MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14032 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14037 - SAW Filter - List of Unclassifed Manufacturers
2022-11-04 17:22:44
LBS14037 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14039 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14040 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14048 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14054 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14099 - 140MHz IF SAW Filter 3MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS140A27 - 140MHz SAW Filter 7MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS14302 - 143.625MHz SAW Filter 0.5MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS15001 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS15701 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS16014 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS17601 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS20502 - 204.8MHz SAW Filter 1.2MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS23301 - 233MHz SAW Filter 4MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS32201 - SAW Filter Technical Specification - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS32202 - SAW Filter Technical Specification - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS33792 - SAW filter technical specification - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS35001 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS35002L - SAW Filter Technical Specification - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS37602 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS40960A - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS4224 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS5401 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS7032 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS7033 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS7034 - SAW Filter Electrical Characteristic - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS70A14 - 70MHz SAW Filter 2MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS70A33 - 70MHz SAW Filter 2MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS70A40 - 70MHz SAW Filter 1MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
LBS83006 - 830MHz SAW Filter 10MHz Bandwidth - SIPAT Co,Ltd
2022-11-04 17:22:44
CH1LBS - CIT SWITCH - CIT Relay & Switch
2022-11-04 17:22:44
MCH0603LBS - Military Grade High Voltage Chip Resistors - List of Unclassifed Manufacturers
2022-11-04 17:22:44
时容性,又如何用电容去抵消电容性分量呢?只能使输出的电容分量加大,而这些电容分量的电流又必须由逆变器提供,使逆变器输出的有功分量减小,所以带载的能力就减弱了。STS、LBS及双总线作用是什么?STS(静...
2021-11-15 06:40:54
基于PEX8311和FPGA来实现PCIe标准1x传输。1、系统介绍FPGA和PEX8311之间通过LBS(LocalBus)来连接、发送和接收命令及数据,其中FPGA主要控制LBS的运行,本文通过设计一
2015-01-29 14:09:17
` 宝马X5升级透镜+LBS极亮白氙气灯今日分享作业:宝马X5车主,因为需要夜间行驶,原车车灯非常差劲,每次开夜车都提心吊胆的,驾驶感非常疲劳,在了解了车略轩的灯光升级工艺好后,直接升级透镜和LBS
2016-06-05 12:29:13
1月9日消息,全球领先的物联网开发和云服务商机智云与知名企业凯立德、赛亿签署战略合作协议,同时宣布启动联合实验室,三方将联袂搭建物联网LBS生态平台,打造为物联网行业开发者提供一站式位置服务的整体
2017-01-17 13:37:30
本文介绍了LBS 系统的发展现状,在J2ME 和蓝牙GPS 技术的基础上,设计开发了LBS 系统,实现自主定位与地图创建,详细介绍了系统的软件体系结构和客户端功能实现。关键词:LBS
2009-06-18 09:31:3530 本文对兴趣点(Point of Interest, POI)数据在位置服务(Location Based Service,LBS)行业的应用现状进行了分析,指出POI 数据更新中存在的问题。借鉴一些地图社区的自由共享理念,本文
2010-01-11 14:07:5521 LBS的车载导航应用 中国移动车e行终端
近来GPS导航产品又衍生出新的名词:LBS导航。采用这种技术的导航设备可以提供更高质量的导航服务和各种附加服务,支持LBS技术的
2009-11-06 16:56:45973 基于LBS的嵌入式GIS研究
ITS 是国家“十五”期间科技发展的重点领域,已列入《国家国民经济和社会发展“十五”规划》。科技部已启动国家ITS“十五”示范工程,首都
2010-02-04 09:38:49947 2011年的一个重要趋势就是定位系统(LBS)将进一步涵盖室内定位。LBS和导航需求正越来越倾向于室内,而OEM厂商也看
2010-12-29 09:26:45928 以GIS和移动通信技术为基础的LBS系统具有用户访问方式多样、数据格式不统一的特点,为此提出利用XML、移动Agent构建分布式LBS系统的解决思路,重点解决用户如何访问系统及系统如何处理
2011-03-30 22:04:0528 GIS 是LBS 的位置定位、导航及地图表达的基础技术支撑。针对LBS 的固定服务端与移动终端的信息交互需求,提出了平台GIS 与移动GIS 的概念;针对移动GIS ,提出了嵌入式、软件插件组合技术
2011-05-14 15:30:0128 LBS系统 可对移动终端定位并提供各种与位置相关的业务。但是其信息的迂回查询将导致网络拥塞,严重影响服务质量。而近年来迅速发展的移动Agent可以在异构的网络环境中自由移动,
2011-07-25 16:23:020 lbs是什么意思 (Location Based Service,简称LBS)基于位置的服务,它是通过电信移动运营商的无线电通讯网络(如GSM网、CDMA网)或外部定位方式(如GPS)获取移动终端用户的位置信息(地理坐标,或
2012-09-17 11:23:4642843 传统的基于位置信息的服务(LBS)的隐私保护需要LBS提供者(简称LSP)与用户之间通过第三方作为中介来进行信息交换,但这种模式极易遭到攻击者攻击。为此提出一种基于K-匿名机制
2013-01-31 14:30:3416 在国外LBS+ar游戏《Pokemon Go》引起的全球AR社交狂潮背后,越来越多的中国互联网公司也将他们的AR技术研究成果公布出来,正式开启他们LBS+AR产品的发行工作,这其中就包括了百度、腾讯、支付宝、新浪、UC这样的巨头型企业。
2016-12-21 15:45:11563 移动大数据环境下,传统基于位置服务LBS技术面临来自系统扩展性、性能等方面的挑战。首先针对LBS应用的特点,提出了基于Storm的查询框架。然后结合基于Storm的LBS查询框架,设计并实现了并行
2017-11-23 14:35:570 本文主要介绍了基于LBS的Android校园服务APP客户端的设计,校园LBS系统由移动终端系统、后台服务系统所构成。后台的服务系统又可以分为后台数据服务系统、数据库和后台管理系统3部分组成。本系统服务器端采用的数据库是MySQL,它具有开源、免费等优点,适合于处理中小型数据。
2017-12-27 14:54:193383 由于位置感知移动电子设备的繁荣,位置服务(LBS)几乎在所有的社会和商业领域广泛流行.虽然LBS给个人和社会带来了巨大利益,但也给用户的隐私造成了严重威胁.因为用户享受LBS的同时需要向不可
2018-01-24 15:48:171 随着科技的发展,人类活动的范围越来越广阔,越来越不具有确定性,这种范围的扩大和目的的不确定性为基于位置的服务(location-based service,LBS)带了无限商机,针对LBS系统中动态
2018-04-03 11:22:160 LBS,基站定位服务,它是通过运营商的移动网络基站定位终端设备的位置信息(经纬度坐标),为企业用户提供定位服务。
2019-08-25 10:24:006489 罗德与施瓦茨的R&S TS-LBS是一个可以测试GNSS和基于网络LBS的测试系统。该系统是由一台用来模拟基站的R&S CMW500 和一台模拟GNSS信号的R&S SMBV100A组成。R&S
2019-10-14 17:06:212451 基于位置的服务(Location Based Service,LBS),通过关键技术支持和保障,为用户提供需要的与位置相关的信息服务,正成为各学科领域的研究热点和经济增长点。LBS有很多应用领域
2019-12-13 17:48:332 设备大量普及的背景下,对于传统的餐饮业既是机遇也是挑战。本文利用Android平台,结合LBS技术设计并实现了基于LBS的移动订餐系统。
2019-12-17 16:09:475 基于地理信息的移动通信服务(Location based service),是指在移动通信平台上提供的地理信息服务。作为LBS的一种运用实例,PTGRP(Public
2020-01-17 17:36:0211 增强现实的关键技术之一是开发超紧凑、轻重量、低功耗的近眼显示解决方案。激光束扫描(Laser Beam Scanning;LBS)技术可以满足这些关键技术的要求,让实现小体积、轻重量、全天候可穿戴的AR智能眼镜成为可能,并能让其显示高分辨率,大FOV,全彩画面。
2022-05-09 10:05:592508 ./oschina_soft/gitee-node-lbs.zip
2022-06-09 11:18:123 应用“物联网+LBS”技术的医疗废物信息管理模式适合在医疗机构推广应用,特别是基层医疗机构。利用信息管理平台,卫生监督和环保部门能够实现对各基层医疗机构医疗废物收集、转运和销毁等相关信息进行全过程实时监督和追踪,节约检查过程中产生的人力物力成本,达到监管全覆盖,有序推进医疗废物处置工作规范化。
2023-04-13 10:50:42387 SUM概述GNSS虹科Safran与是德科技(Keysight)联手推进基于全球导航卫星系统(GNSS)技术的5G定位服务(LBS),利用虹科Safran先进的全球导航卫星系统(GNSS)仿真功能
2023-09-23 08:07:52331
查看更多
