5G采用Polar码,华为到底有何收益?正方:Polar码是编码界新星,是由土耳其毕尔肯大学(bilkent)Erdal Arikan教授于2008年首次提出,其论文从理论上第一次严格证明了在二进制
2016-11-22 10:43:19
08414-90016 (May 1973) The 8414A Polar Display is a discontinued product. This manual is provided for information only.
2018-11-02 10:19:09
8000 - 8000 SERIES / DIP REED RELAYS - List of Unclassifed Manufacturers
2022-11-04 17:22:44
阻抗计算基本知识
2019-06-11 22:50:43
阻抗控制計算目的: 學會使用Polar si9000對特殊信號線的阻抗計算舉例 :1. 差分信號線的阻抗計算以 E03為例,E03 USB2.0 D+ , D- 要求有90歐姆的阻抗匹配,依照此要求
2015-03-02 16:55:10
SI-8000E - Full-Mold, Separate Excitation Switching Type - Sanken electric
2022-11-04 17:22:44
SI-8000E_10 - Full-Mold, Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000E_11 - Full-Mold, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000FD - Surface Mount, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000FFE - Full-Mold, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000GL - Series Compact Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000GL_10 - Compact, Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000GL_11 - Compact, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000HD - Surface-Mount, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000HFE - Full-Mold, Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000HFE_10 - Full-Mold, Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000HFE_11 - Full-Mold, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000JD - Surface-Mount Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000JD_11 - Surface-Mount, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000JF - Full-Mold, Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000JF_10 - Full-Mold, Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000JF_11 - Full-Mold, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000Q - Surface Mount, Current Mode Cntrol Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000S - Full-Mold, Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000SD - Surface Mount, Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000SD_10 - Surface Mount, Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000SD_11 - Surface Mount, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000S_10 - Full-Mold, Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000S_11 - Full-Mold, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000TFE_11 - Full-Mold, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000TM - DC/DC Step-Down Converter IC - Sanken electric
2022-11-04 17:22:44
SI-8000TM_12 - Surface-Mount, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000W_11 - Surface-Mount, Separate Excitation Step-down Switching Mode - Sanken electric
2022-11-04 17:22:44
SI-8000Y - Current Mode Control Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-8000Y_11 - Full-Mold, Separate Excitation Step-down Switching Mode Regulator ICs - Sanken electric
2022-11-04 17:22:44
SI-E8000 - High Voltage Silicon Rectifier Diodes - Diotec Semiconductor
2022-11-04 17:22:44
SI-E8000-3600-1.8 - High voltage rectifiers - Semikron International
2022-11-04 17:22:44
SI-E8000-3600-1.8_06 - High voltage rectifiers - Semikron International
2022-11-04 17:22:44
SI-E8000-3600-4 - High voltage rectifiers - Semikron International
2022-11-04 17:22:44
SI-E8000-3600-4_06 - High voltage rectifiers - Semikron International
2022-11-04 17:22:44
TSOP163. SI 4420 / 4421 无线收发芯片 TSOP16外围器件很少,只要两三颗小电容和一个10M Cystal, 对其精度无特殊要求,总成本低(具备自动频率控制,可确保收发器自动调整
2011-12-07 16:30:46
本人刚开始学习AD,哪位大神有si4438m的封啊,感觉自己画很麻烦。。。
2014-08-15 16:09:27
Cognex DM8000-ECABLE-30广州方桐经销美国康耐视Cognex系列手持条码扫描设备,部分型号列表:Cognex DMR-8500-0200、Cognex DMR-8500-0100
2012-04-27 20:25:23
A Guide on how to istall, launch and use Keysight VEE Pro 8.0 and Keysight VEE Express 8.0 and a description for new features of version 8.0.
2019-10-18 13:48:04
Description and technical specifications for the Keysight VEE Pro 8.0 & Keysight VEE Express 8.0.
2019-10-25 11:00:49
、具有强大的功能计算能力。接下来介绍一下Polar SI9000 软件的安装及破解流程1. 下载Polar SI9000 软件地址:SI9000百度网盘下载2. 解压并运行setup.exe启动安装
2015-03-05 14:56:39
PROTEUS 8.0仿真时把示波器关掉了,然后就打不开了。其它版本,如7.5,7.8版本可以右键选最后一个打开,但8.0不知怎么打开。求解释·············
2015-05-14 15:04:28
proteus8.0怎么使用?
2021-10-11 08:23:19
应用程序:此示例代码使用 M031 SPI驱动 SI4463 实现无线发送和接收数据。
BSP 版本: M031 BSP CMSIS V3.03.000
硬件: NuMaker-M
2023-08-29 07:47:34
分享一個計算阻抗的軟件-polar Si900
2016-04-30 23:05:41
最近市面上有几款平板比较火 联想P8华为M3 我个人想了解下华硕ZenPad S 8.0 这款,和前几款相比 在配置 体验 口碑 上怎么样?华硕的这款平板很少提到 但是中关村的评分不低 我不太懂,贴吧都是水军,想来此一求真相,来几位指点迷津的,互相交流,能有进步,那是极好的!!!
2017-01-11 21:58:38
请教,在双层板设计中,如USB 90R的特征阻抗用polar中的哪个模型计算?谢谢。
2018-01-28 10:32:50
使用M031来驱动SI4463
2023-06-27 06:49:16
`一,首先给大家介绍一下Polar软件,Polar是专业计算阻抗的软件,其版本包括:Si6000,Si8000,及Si9000.二,其次给大家介绍常见的几种阻抗模型:特性阻抗,差分阻抗,共面性阻抗
2011-11-16 15:58:21
当使用 AD8000 设计带宽为 1000M 的放大器电路时,必须使用 AD8000 的 IBIS 模型进行 SI/PI 仿真。AD8000是否有可用的IBIS型号?如果是这样,请发送给我。如果没有,是否有其他具有类似参数的芯片提供用于仿真的 IBIS 模型?
2025-03-24 06:08:40
阻抗计算软件Polar_si9000资料 听在华为工作的同事推荐的
2016-06-29 10:53:51
polar Si8000m是全新的边界元素法场效解算器,建立在我们熟悉的早期Polar阻抗设计系统易于使用的用户界面之上。 Si8000m增加了强化建模技术,可以预测
2008-04-21 10:41:29
1596 Bi-polar&Non-polar aluminum electrolytic capacitor-双极和无极铝电解电容器NP47uf50v
2022-04-26 09:58:31
Si3216应用电路:Figure 12. Si3216(M) Typical Application Circuit Using Discrete Line Interface CircuitTable 14. Si3216(M) External Component Values
2009-09-28 12:13:07
13 Polar F11手表使用手册(用户说明书)
尊敬的客户:恭喜你购买了新款Polar F11 健身心率表!Polar F11 心率表能够帮助你实现自己的健身目标。Polar F11 心率表具
2010-01-20 14:46:53
9 海尔 彩智星1000M 8000 手机USB驱动程序 For Win98.rar
2010-01-22 15:52:37
5 华硕 M4A78-VM IN(SI)主板英文版说明书.zip
2010-02-03 14:06:40
0 华硕 P5G41-M SI主板英文版说明书.zip
2010-02-03 14:36:36
0 使用polar 工具计算阻抗!以一个四层板为例,四层板的一般叠层为 top gnd02 power03 bottom从四层板的叠层来看是由两个信号层加平面层组成。详细计算步骤如
2010-04-05 06:47:27
44 PowerBuilder 8.0基础篇源程序
2010-04-12 15:33:24
4 ASUS华硕 P7H55-M SI主板BIOS 0904版
2010-08-23 16:20:41
0 CSR和Bluegiga为Polar公司的Team2心率监测系统提供蓝牙技术
无线技术提供商CSR公司日前宣布,其BlueCore蓝牙芯片为Polar公司的Team2心率监测系统提供无线链接。该系统由多达2
2008-10-29 09:35:50
1099 Si8000m 8.0版 现在内置了阻抗图形技术
8.0版有哪些新增功能? 新内置高灵敏度图形技术粗略和精细“阻抗目标”搜索建立多电介质PCB模型28种单
2009-10-08 08:27:20
1363 一台8000m3球罐的声发射检验
摘 要:将两台德国Vallen公司AMSY-5型36通道声发射检测系统并联,对8000m3球罐进行了声发射检测,为目前国
2009-10-22 16:35:54
1273 Polar Instruments,制造商和OEM的高速PCB设计工具的制造商,宣布扩充Si8000m和Si9000e PCB传送线现场解决工具的生产力;XFE“Xhatch Flex Enhancement”是最容易使用第二代现场解决工具,具
2010-10-14 10:33:03
1465 Polar v6阻抗计算软件下载
2011-01-21 10:11:27
344 2012-09-08 10:50:31
0 UG8.0_UG NX 8.0版下载
2012-09-20 15:45:49
0 si8000m是全新的边界元素法场效解算器,建立在我们熟悉的早期POLAR阻抗设计系统易用使用的用户界面之上。si8000m增加了强化建模技术,可以预测多电介质PCB的成品阻抗,同时考虑了密集差分
2012-11-05 11:56:02
510 本文选用低功耗芯片Si1000组建一个无线M-Bus通信系统,并对Si1000的低功耗性能问题及在软硬件上的实现进行了分析。
2013-01-08 09:15:18
6162
muRATA公司出品的SN8000/SN8000UFL Wi-Fi Module User Manual用户手册。
2015-10-29 11:00:36
13 本文主要以 Proteus8.0 版本的功能及使用为基础,主要介绍工程的创建、编译
器的配置、基本调试等一些基本问题,并探讨 Proteus8.0 的一些新特点新功能,最后与
Proteus7.0 做出对比得出结论。
2015-11-09 16:16:39
0 學會使用Polar si9000對特殊信號線的阻抗計算
2016-05-11 11:08:05
0 GA_高斯近似_LDPC_POLAR(极化码)_构造
2016-06-08 16:34:58
22 Si7106JN 20V19A6.5mΩ适用于电子烟航模无人机!
2017-08-02 09:15:19
8 PaloAlto 8.0 Configuration and Management
2017-09-05 09:33:29
3 上传的是Polar软件中的SI900版本Polar是专业计算阻抗的软件其版本包括:Si6000Si8000及Si9000.亲测可用。相比较SI8000增加了过孔效应计算和灵敏度测试。实乃高速PCB设计必备良物。
2018-09-07 08:00:00
0 已经公开的3518族公开专利进行人工阅读分析,结合Polar码、编解码的中英文关键词,以及极化信道可靠度、信息比特、冻结比特、特有的生成矩阵等Polar码特性,通过阅读摘要、权利要求、说明书,以及
2018-09-12 16:37:36
5691 今年7月26日,在深圳华为总部迎来了一场特别的颁奖仪式,华为创始人任正非亲自给被誉为“Polar码之父”的Erdal Arikan教授颁发荣誉奖牌,本次颁奖源于Erdal Arikan教授在
2018-10-11 07:11:02
4611 Polar Chain的目标是利用区块链技术做一个更高效、更稳定、更为科学合理的边缘计算平台。遵从区块链“人人平等”的原旨,Polar Chain收集带宽、计算、存储等闲散资源,使每个人都成为边缘
2019-08-01 10:57:12
1748
SI24R1+AT2401C+16M晶振可以代替NRF24L01P+RFX2401C+16M晶振,更低的成本
2020-03-09 11:30:49
3277 查看Si1147-M01-EVB的参考设计。 http://www.elecfans.com/soft/有成千上万的参考设计,可帮助您使项目栩栩如生。
2021-01-13 15:30:03
0 查看Si1143-M01-EVB的参考设计。 http://www.elecfans.com/soft/有成千上万的参考设计,可帮助您使项目栩栩如生。
2021-01-14 22:15:02
2 CMV8000ES-1E5C1PA QA CMV8000ES-1E5M1PA QA (issued 2020-Aug)
2021-02-21 10:58:56
1 SI4432.SI4463.SI4438和LORA方案对比
2021-05-08 10:27:59
33 View the reference design for SI-8000FFE_Typical Application. http://www.elecfans.com/soft/ has
2021-08-11 17:23:49
11 详解怎样使用Polar_Si9000软件计算阻抗及如何设计层叠结构
2023-02-14 10:49:20
0 MS5351M瑞盟通用频率综合器兼容SI5351
2022-12-07 15:53:29
3 PolarSi8000阻抗计算基本知识
2022-12-30 09:20:42
9 SI8000扩展运用注意事项
2022-12-30 09:20:51
2 SI8000软件运用操作
2022-12-30 09:20:52
3 Polar码又被称作极化码,是一种前向纠错编码(FEC)方案,由土耳其教授ErdalArıkan在2008年提出。它是一种线性块码,被认为是实现信道容量的一种方法,特别是在高信噪比(SNR)的情况下
2024-04-19 08:20:02
2106
