a.c.or AC
alternating current交流电
ACEC
advisory committee on electromagnetic compatibility电磁兼容顾问委员会
ADSL
asymmetric DSL非对称数字用户环路
AE
auxiliary equipment辅助设备
AF
audio frequency音频
AM
amplitude modulation调幅
AN
access network接入网
ANE
access network equipment 接入网设备
CDMA
code division multiple access码分多址
CDN
coupling/decoupling network 耦合/去耦网络
CIGRE
international conference on large HV electric systems 国际大电网会议
CISPR
international special committee on radio interference 国际无线电干扰特别委员会
CPE
customer premises equipment 用户驻地设备
CRT
cathode ray tube 阴极射线管
d.c.or DC
direct current 直流电
dpf
dedicated power feed 专用供(馈)电
DSL
digital subscriber loop 数字用户环路
EFT/B
electrical fast transient /burst 电气快速瞬变/突发
EIRP
equivalent isotropically radiated power 等效全向辐射功率
EMC
electromagnetic compatibility 电磁兼容性
emf
electro-morive force 电动势
EMF
electro-magnetic field 电磁场
EPR
earth potential rise 地电位升高
ERP
effective radiated power 有效辐射功率
ESD
electrostatic discharge 静电放电
EUT
equipment under 受试设备
GDT
gas discharge tube 气体放电管
GV
high voltage 高电压
ICNIRP
international commission on non-ionizing radiation protection 国际非电离辐射保护委员会
IEC
international electrotechnical commission 国际电工委员会
ISDN
integrated services digital network 综合业务数字网
ISM
industrial, scientific and medical (equipment) 工业的,科学的和医学的(设备)
ITE
information technology fquipment 信息技术设备
ITU-T
international telecommunication union-telecommunication standardization sector
国际电信联盟电信标准局
LCL
longitudinal conversion loss 纵向转换损耗
LCTL
longitudinal conversion transfer loss 纵向转换传输损耗
LE
local exchange 本地交换
LEMP
lightning electromagnetic pulse 雷电电磁脉冲
LI
line interface 线路接口
LPS
lightning protection system 雷电保护系统
LPZS
lightning protection zone 雷电保护区
LT
line termination 线路终端
MDF
main distribution frame 总配线架
MOV
metal-oxide varistor 金属氧化压敏电阻
n.a.
not applicable 不可用
NT
network termination 网络终端
OATS
open area test site 开阔试验场
o/c
open circuit 开放电路
pfv
power feeding voltage 供电电压
PNI
public network interface 公用网接口
PRBS
pseudo random bit sequence 伪随机比特序列
PSTN
public switched telephone network 公用交换电话网
PTC
positive temperature coefficient(resistor) 正温度系数
RF
radio frequency 无线电频率
RFI
radio frequency interference 射频接口
RFT
remote feeding telecommunications circuit 远供通信电路
RFT-G
remote feeding telecommunications circuit-current limited 远供通信电路-限电流
RFT-V
remote feeding telecommunications circuit-voltage limited 远供通信电路-限电压
RSE
remote switching fquipment 远端交换设备
SA
specific absorption 比吸收能
SA
semi-conductor arrester 半导体避雷器
SAA
semi-conductor arrester assembly 半导体避雷器组件
SAR
specific absorption rate 吸收率
SAP
specific absorption power 吸收功率
SELV
safety extra low voltage 安全超低电压
SLIC
subscriber line interface circuit 用户线路接口电路
SPD
surge protective device 浪涌保护元件
SPL
sound pressure level 声压级
SSA
solid state arrester 固体避雷器
TCE
telecommunication centre equip电信中心设备
TDMA
time division multiple access 时分多址
TN
trunk network 干线网
TNV
telecommunication network voltage 电信网电压
RSD
universal serial bus 通用串联总线
RPS
uninterruptible power supply 不间断电源
VDSL
very high speed DSL 调整用户数字环路
VDU
visual display unit 视频显示单元
UIC
international union of railway 国际铁路联盟
xDSL
digital subscriber loop x数字用户环路
电磁兼容(EMC)术语缩写
- 电磁兼容(96984)
EMC十问十答,带你了解电磁兼容的“前世今生”
电磁兼容性EMC,是指设备或系统在其电磁环境中符合要求运行并不对其环境中的任何设备产生无法忍受的电磁干扰的能力。以下是常见的电磁兼容EMC十问十答,通过下面的问答,能够帮助你更加了解关于电磁兼容EMC的知识。
2014-09-02 19:43:22
1871
小智科普丨教你懂得什么是EMC(电磁兼容)
EMC(电磁兼容)一直是电路设计和PCB设计中的难题。EMS是指设备在电磁环境中可以正常工作并且不对其它的设备造成干扰。
2022-12-29 13:45:47
1844
什么是电磁兼容性(EMC)?
“电磁兼容性(EMC)”主要分为两种,一种是设备本身的电磁噪声对其他设备或人体带来的影响(电磁干扰,EMI:Electromagnetic Interference, Emission),另一种
2023-07-10 09:42:39
1105
EMC电磁兼容常见的问题概述
我们活动的空间无处不充斥着电磁波,而当今各行业又广泛应用电子技术,所以,电子设备没有解决电磁波干扰问题,就不能兼容工作。那么对于EMC电磁兼容常见的问题我们应该怎么解决呢?
2019-07-25 07:55:08
电磁干扰排查及故障解决的电磁兼容技术-免费下载
。可参照的特性曲线、附录等。 目录译者序作者简介前言引言第1章 EMI/EMC基础知识的复习1.1 术语1.2 电磁干扰(EMI)/电磁兼容(EMC术语) 1.3 度量单位:贝尔 1.4 信号时域
2008-12-25 11:49:56
电磁兼容 综述 电磁兼容基本术语和定义的应用与解释
直播报名:http://t.elecfans.com/live/719.html相关课程:http://t.elecfans.com/topic/45.html电磁兼容 综述 电磁兼容基本术语和定义的应用与解释《资料来自网络》
2019-01-16 22:59:19
电磁兼容(EMC)设计内容
电磁兼容性EMC是指设备或系统在其电磁环境中能正常工作且不对该环境中任何事物构成不能承受电磁骚扰的能力。要使产品具有良好的电磁兼容性,需要专门考虑与电磁兼容相关的设计内容。电磁兼容设计一般包含
2016-01-14 11:17:12
电磁兼容EMC整改
[sup]由于产品设计阶段没有进行电磁兼容(EMC)设计或者考设计虑不周全,以及市场对产品的电磁兼容(EMC)要求越来越严格。企业在进行产品电磁兼容(EMC)认证的过程中往往会出现部分电磁兼容
2019-03-13 17:56:25
电磁兼容半电波暗室经验总结
; Laboratory const ruction ; Semi2anechoic chamber随着国内外越来越多的电磁兼容指令、 规范、标准的制定和强制性执行,电气和电子产品的电磁兼容性( EMC)问题日益受到
2019-05-30 07:27:53
电磁兼容和瞬态电磁脉冲辐射介绍
已制定了六十多项EMC国家标准,其中基础标准为GB4365-1995电磁兼容术语;GB/T6113-1995无线电干扰和抗扰度测量设备规范。
2019-07-23 07:11:17
电磁兼容的介绍
电磁兼容(EMC)一般指电气及电子设备在共同的电子环境中能执行各自功能的共存状态,即要求在同一电磁环境中的上述各种设备都能正常工作又互不干扰,达到“兼容”状态。换句话说,电磁兼容是指电子线路、设备
2018-03-28 10:53:48
电磁兼容的设计要点与屏蔽技术
之中,它必然受到外界的电磁骚扰,同时它本身又作为骚扰源去骚扰别的设备。电磁兼容设计就是针对电磁干扰来进行的,它与可靠性一样,要保证设备或系统在存在电磁干扰的情况下可靠地工作,就必须对它进行电磁兼容
2019-05-30 06:11:41
电磁兼容简介
电磁兼容性(EMC)是指设备或系统在其电磁环境中符合要求运行并不对其环境中的任何设备产生无法忍受的电磁干扰的能力。因此,EMC包括两个方面的要求:一方面是指设备在正常运行过程中对所在环境产生的电磁
2017-09-19 09:53:57
电磁兼容(EMC)应用术语缩写
电磁兼容(EMC)应用术语缩写1. a.c.or AC alternating current交流电 2. ACEC advisory committee on electromagnetic
2009-03-23 16:59:02
电磁兼容(EMC)设计典型电路汇总
`相关推荐:电磁兼容(EMC)设计、故障诊断、整改技术和经典案例(二)EMC工程师大都是半路出家,一般都是从硬件工程师为了产品研发需求转向对EMC的学习。随着各种标准的完善和发达国家对出口产品
2019-02-27 14:18:45
电磁兼容(EMC)设计典型电路汇总
相关推荐:电磁兼容(EMC)设计、故障诊断、整改技术和经典案例(二)EMC工程师大都是半路出家,一般都是从硬件工程师为了产品研发需求转向对EMC的学习。随着各种标准的完善和发达国家对出口产品电磁兼容
2021-07-13 10:32:47
【EMC家园】电磁兼容(EMC)专用术语(中英文对照),实用!
):electromagnetic compatibility(EMC) GJB,军标GJB72-1985《电磁干扰与电磁兼容性名词术语》“设备(分系统、系统)在共同的电磁环境中能一起执行各自的功能的共存状态。即:该
2016-01-04 17:07:30
【下载】《 EMC电磁兼容设计与测试案例分析(第2版)》
相关推荐:http://t.elecfans.com/topic/45.html?elecfans_trackid=bbs_toptxt内容简介 《EMC电磁兼容设计与测试案例分析(第2版)》以
2018-01-16 18:02:29
【下载】《EMC电磁兼容设计与测试案例分析(第2版)》
`内容简介 《EMC电磁兼容设计与测试案例分析(第2版)》以EMC:案例分析为主线,通过案例描述、分析来介绍产品设计中的EMC技术,向读者介绍产品设计过程中有关EMC:的实用设计技术与诊断技术
2017-09-25 17:19:55
一文看懂电磁兼容EMC和电磁干扰EMI
是电磁兼容(ElectromagneticCompatibility,缩写为EMC)。在国家标准GB/T4365-1995中对电磁兼容严格的定义是:设备或系统在其电磁环境中能正常工作且不对该环境中
2017-12-01 15:47:16
一文看懂电磁兼容EMC和电磁干扰EMI
的各种电子、电气设备都能正常工作,并且不干扰其他设备的正常工作,这就是电磁兼容(ElectromagneticCompatibility,缩写为EMC)。在国家标准GB/T4365-1995中
2018-03-13 15:01:48
什么是电磁兼容(emc)标准
什么是电磁兼容(emc)标准为了规范电子产品的电磁兼容性,所有的发达国家和部分发展中国家都制定了电磁兼容标准。电磁兼容标准是使产品在实际电磁环境中能够正常工作的基本要求。之所以称为基本要求,也就是说
2009-03-23 17:40:37
什么是电磁兼容EMC
一.EMC是什么EMC是electromagnetic compatibility 电磁兼容的简写主要由电磁干扰EMI(eletromagnetic interference)和电磁抗扰度EMS(electromagnetic susceptibility)组成
2021-09-17 09:16:03
什么是电磁兼容标准?
什么是电磁兼容标准?为了规范电子产品的电磁兼容性,所有的发达国家和部分发展中国家都制定了电磁兼容标准。电磁兼容标准是使产品在实际电磁环境中能够正常工作的基本要求。之所以称为基本要求,也就是说,产品
2019-08-23 06:38:12
什么是电磁兼容设计?
当前,日益恶化的电磁环境,使我们逐渐关注设备的工作环境,日益关注电磁环境对电子设备的影响,从设计开始,融入电磁兼容设计,使电子设备更可靠的工作。那么,谁知道什么是电磁兼容设计吗?
2019-08-07 08:04:23
怎么提高对电磁兼容的防范能力?
电磁兼容性(EMC)法规旨在确保在各种场所使用的各种不同类型的电气和电子设备在彼此和谐共处,互不干扰。尽管随着各种强制标准的实施,EMC获得较好的改善,但业界专家依然认为EMC问题不容乐观,他们甚至
2019-08-01 07:42:24
接地连续对EMC的影响-AIT-电磁兼容整改案例
接地连续对EMC的影响-AIT-电磁兼容整改案例接地连续对EMC的影响-AIT-电磁兼容整改案例[hide][/hide]
2010-02-26 11:07:46
清华大学电磁兼容培训教材
相关推荐:http://t.elecfans.com/topic/45.html?elecfans_trackid=bbs_toptxt清华大学电磁兼容培训教材主要内容1.1 电磁兼容名词术语及单位
2012-03-23 10:33:05
计算机中的电磁兼容情况
电磁兼容的英文名称为Electromagnetic Compatibility ,简称EMC。电磁兼容技术涉及的频率范围宽达0-400GHz,研究对象除传统设施外,涉及芯片级,直到各型舰船、航天飞机、洲际导弹,甚至整个地球的电磁环境。本文章主要介绍计算机中的电磁兼容情况。
2019-05-31 08:22:48
请问谁有实践电磁兼容设计的EMC资料?
RT:有事求助原子哥,求一份EMC资料。盘古开发板出品的 实践电磁兼容设计这个PDF。我找了遍了网上,也只找到这2个,不全啊。实践电磁兼容设计-目录.pdf (134.31 KB )。内空看起来很好。如果坛里哪位朋友有目录全套的PDF,也可以联系我本人。QQ:63915185
2019-07-30 04:36:11
电磁兼容(EMC)专用术语
电磁兼容(EMC)专用术语
电磁环境 electromagnetic environment在于给定场所的所有电磁现象的总和。电磁噪声 electromagnetic noise额定电流是指在规定频率及电压下,环
2008-08-03 11:35:28
379
电磁兼容(EMC)应用术语缩写
电磁兼容(EMC)应用术语缩写
1. a.c.or AC alternating current交流电 2. ACEC advisory committee on electromagnetic compatibility电磁兼容顾问委员会 3. ADSL
2009-03-23 16:58:52
1138
什么是电磁兼容(emc)标准
什么是电磁兼容(emc)标准
2009-03-23 17:41:01
1751
电磁兼容(EMC)专业术语表
电磁兼容(EMC)专业术语表
1.电磁环境 electromagnetic environment
存在于给定场所的所有电磁现象的
2009-03-23 17:43:25
740
电磁兼容术语 (中英文对照表)
电磁兼容术语 (中英文对照表)
1.电磁环境 electromagnetic environment 存在于给定场所的所有电磁现象的总和。 2.电磁噪声 electromagnetic
2009-10-07 08:40:42
2602
电磁兼容EMC认证及其标准
电磁兼容EMC认证及其标准随着电子电器设备的广泛使用,电磁干扰对环境的影响日益严重,以至实际应用中的各类电器的电磁干扰和相互不兼容时有发生。工业、科学、
2009-10-10 16:03:09
1212
电磁兼容(EMC)专用术语
电磁兼容(EMC)专用术语
2010-02-21 11:14:49
848
电磁兼容(EMC)术语缩写中英文对照
电磁兼容(EMC)术语缩写中英文对照
a.c.or ACalternating current交流电ACEC advisory committee on electromagnetic compatibility电磁兼容顾问委员会AD
2010-02-21 11:15:48
5585
电磁兼容性—EMC
电磁兼容性EMC(Electro Magnetic Compatibility),是指设备或系统在其电磁环境中符合要求运行并不对其环境中的任何设备产生无法忍受的电磁干扰的能力。国际电工委员会(IEC)对EMC的定义是:指在不损害信号所含信息的条件下,信号和干扰能够共存。
2011-09-22 12:43:21
EMC电磁兼容测试及其电路设计
本专题为你详细讲述EMC电磁兼容的含义、EMI原理、电磁兼容测试、电磁兼容电路设计、EMC元器件选型、PCB设计思路以及EMC设计方案等方面的知识技巧与设计要点,希望对大家进行电磁兼容电路设计能有所启发。
2012-07-19 18:02:01
第5章-电磁兼容技术
从电磁兼容基本概念入手,介绍了电磁兼容的基本概念、发展历史、常用术语以及电磁兼容标准;在电磁兼容的电磁原理中,介绍了相关的电磁基本原理,电磁辐射与散射,传导耦合以及瞬态干扰;阐述了电磁兼容预测技术,包括干扰源、敏感源以及耦合途径的数学模型,预测流程和步骤,以及相关的电磁兼容预测软件。
2016-06-03 16:16:53
34
emc电磁兼容是什么_电磁炉emc起什么作用
EMC是Electro Magnetic Compatibility的缩写,中文翻译为电磁兼容性,是指设备或系统在其电磁环境中符合要求运行并不对其环境中的任何设备产生无法忍受的电磁干扰的能力。
2018-05-03 17:00:03
30012
电磁兼容(EMC)行业前景如何_电磁兼容(EMC)行业发展趋势分析
EMC对人民生活、工业化生产和世界贸易均有重要影响,电磁兼容技术的研究不仅为保护电磁环境,使电磁应用与电磁环境协调发展,同时也是小编国电气、电子装置和系统与国际标准接轨的必然趋势。本文主要介绍电磁兼容(EMC)行业前景如何及发展趋势分析,具体的跟随小编一起来了解一下。
2018-05-03 18:15:56
24691
EMC电磁兼容指令介绍 EMC和EMI和EMS的异同
EMC电磁兼容是Electromagnetic Compatibility的缩写,世界电工委员会(IEC)标准对EMC电磁兼容的界说是指:设备或体系在地点的电磁环境中能符合要求运转并不对其环境中的任何设备发生无法忍受的电磁搅扰的才能。
2019-01-04 17:06:26
3001
电磁兼容EMC的检测标准
电磁兼容EMC检测标准有哪些?电磁兼容性(EMC)是指设备或系统在其电磁环境中符合要求运行并不对其环境中的任何设备产生无法忍受的电磁干扰的能力。因此,EMC包括两个方面的要求:一方面是指设备在正常
2020-05-28 09:38:07
2558
医疗机械电磁兼容EMC整改的要点有哪些
医疗机械电磁兼容EMC整改的要点;系统功能测试,满足现场功能需要后,进行电磁兼容测试,电磁兼容测试容易出问题是静电、群脉冲、浪涌、射频场传导辐射等等测试!
2020-05-31 10:09:10
1269
电磁兼容EMC的概念
电磁兼容性(EMC)是通过限制无意间产生,传播和接收电磁能量的电气设备和系统在其电磁环境中正常工作的能力,这些电磁能量可能会导致不必要的影响,例如电磁干扰(EMI)甚至物理损坏操作设备。EMC的目标是在共同的电磁环境中正确操作不同的设备,它也是电气工程相关分支的名称。
2020-06-15 10:12:06
1771
电磁兼容与电磁兼容性有什么区别
电磁兼容性(Electromagneticcompatibility,EMC),《电磁干扰和电磁兼容性术语》中给出的电磁兼容性定义为:设备、分系统、系统在共同的电磁环境中能一起执行各自功能的共存状态。
2020-07-28 15:30:37
2347
何谓EMC?什么是Electromagnetic Compatibility(电磁兼容性)?
,以此作为起点。相关的英语缩写较多,EMC也是其中之一,下面将列出一些相似的缩写。如果不能很好地理解各个术语的意义,在使用时,某些情况下可能会存在无法准确传递信息、无法沟通的情况。 何谓EMC EMC是ElectromagneticCompatibility(电磁兼容性)的缩写,
2020-11-26 21:30:17
4573
什么是EMC/EMI电磁兼容性?
EMC的中文意思是电磁兼容,电磁兼容的内容非常广泛,主要是测试电子产品在运行过程中是否超过人体以及周围环境所能承受的辐射值。
2020-10-21 11:07:39
19482
浅谈EMC电磁兼容设计—概念篇
EMC电磁兼容,是指电子、电气设备或系统在预期的电磁环境中,按设计要求正常工作旳能刀,也定电丁、电以西以小2H门N由要的技术性能。
2021-11-06 20:51:00
17
EMC概述:什么是电磁兼容性(EMC)?
2023-02-14 09:26:29
2164
电磁兼容(EMC)是什么?
电磁兼容(EMC)是什么?它指设备或系统在其电磁环境中符合要求运行并不对其环境中的任何设备产生无法忍受的电磁干扰的能力。因此,EMC包括两个方面的要求:一方面是指设备在正常运行过程中对所在环境产生
2023-03-15 16:02:18
1405
EMC电磁兼容实验室-深圳EMC检测机构
电磁兼容emc检测:电磁兼容实验室是为了进行电磁兼容试验而建立的一类特殊的实验室。首先解释一下电磁兼容的基本概念:指电磁系统、分系统在各自的电磁环境中能正常工作而不因受到电磁干扰降低工作性能的能力
2023-01-06 15:35:20
726
电磁兼容EMC测试是什么?
摘要: 电磁兼容(Electromagnetic Compatibility,EMC)测试是一种评估电子设备在其使用环境中对电磁干扰(Electromagnetic Interference,EMI
2023-12-12 09:23:50
362
电磁兼容emc是什么意思
目录 1.1 什么是电磁兼容(EMC) 1.2 各种各样的“干扰” 1.3 电磁兼容三要素 1.4 什么是分贝 1.5 天线 1.1 什么是电磁兼容(EMC) 电磁兼容(Electro
2024-03-15 17:35:32
125
