University, and I would like to know the power dissipation data for the XCR3032XL 32 Macrocell CPLD
2019-03-18 14:04:24
Hello,I have a 6i5SYH and I would like to know how to turn off the ethernet diode when the NUC
2018-11-14 11:42:57
i2s_apll_calculate_fi2s计算得到真实:real rate: 47999.961I (402) I2S: DMA Malloc info, datalen=blocksize=128
2023-03-14 06:22:51
, in a FBGA-60 package.I am only using VTEP on this part currently, but would like to test the part
2019-07-03 14:38:43
以上来自于谷歌翻译 以下为原文Hi all, I would like to know if there are a GPIB query command that would let me know
2019-09-29 09:00:59
to the expression of uncertainty measurement). I would like to someone clarify the specifications
2018-12-06 16:05:13
或者不会丢失任何东西?谢谢,我想了解更多信息。谢谢你,我等待你的回答。以上来自于谷歌翻译以下为原文Hi!I use Vmware and I would like to try
2018-09-11 16:33:41
以上来自于百度翻译 以下为原文 Dear all, I would like to get an information that whether PIC18F25K80 28pin SMD
2018-10-23 15:42:49
Right now I am using a measurement name for each s-parameter to save the data like
2018-12-11 16:18:03
任务)。解决这个问题最好的办法是什么?谢谢 以上来自于百度翻译 以下为原文I'm using PSOC5LP for real time application1)I would like
2018-09-21 09:36:33
嗨, 我想知道哪些工具可以用作编译器,IDE用于开发STM8L微控制器的固件。 #compilers#development-tools以上来自于谷歌翻译以下为原文 Hi, I would
2018-12-19 16:39:24
The use of AD9826 I am using AD9826 .The mode setting SHA. The signal Fre is 250KHz, I would like
2018-08-08 07:31:12
我想找到stm8s 105c的光谱表,这样我就可以看到I / O端口上的负载电流是多少。 查尔斯以上来自于谷歌翻译以下为原文 I would like to find the spect
2019-07-22 06:12:33
这是不是可能?我希望能够向FPGA发送数据和接收数据。谢谢,乔 以上来自于百度翻译 以下为原文Hello, I would like to interface to an FPGA and would
2018-11-15 14:08:43
like to know how two put two 1D array in a 2D array.i would like to have at end one arrays with two columns.i've got vee 9.0thanks for your help.regards
2019-03-13 15:59:52
step by step how to calculate the CRC? For instance, how would I calculate the CRC if I try to send
2019-07-17 08:15:16
nicely. I would like to take it a step further. I would like to log onto a web page and retrieve data form
2018-12-18 15:59:32
oscillator on the MHZXIN/OUT pins and the KHZIN/OUT pins. I would like to use a MEMS oscillator
2018-09-14 10:56:24
)points = pc.calculate(depth)Then I transform the vertex to ndarray:vtx = np.asarray(points.get_vertices
2018-10-12 11:50:22
致谢。以上来自于谷歌翻译以下为原文 I am new to programming in C after years of using Basic on PICs. I would like
2019-05-15 07:35:52
of time in the fieldfox to find an intermitent interference, so I would like to know if anyone can tell me
2018-11-13 10:19:05
为原文I would like to store some type of reference to the version of code im programming to boards so I
2018-09-18 14:32:35
divider), and the arduino will be running entirely different code. Ideally I would like to be able
2018-11-01 10:31:11
PIC32MX795F512Lmy device i/o's are connected with MIL connector pins,can any one help how to calculate output voltage on my I/O pin?
2019-04-18 06:14:54
, i would like to automatise a sweep measurement with the 81940A TLS (inside 8163B) and an external
2019-07-15 10:09:50
synthetizer . I would like to know how could i generate tone like piano notes with the wave dac8
2018-12-21 15:20:23
150 MHz除以2。所以我必须输入CKLYSHIFT到75兆赫。如果我想兼顾CPU的性能,我们应该怎么做?最好的问候, 以上来自于百度翻译 以下为原文Hello, I would like
2018-11-07 17:03:11
,我怎样才能使它合成。谢谢大家!以上来自于谷歌翻译以下为原文Good Day!I would like to know how can I have a persistent value on FPGA
2019-02-20 11:17:46
Hai Alli am new to Spartan 3ADSP,i woud like to know how can i calculate squareroot of a 64 bit
2019-05-13 06:26:47
if it would be possible to somehow do the calibration correction afterwards, and if so, how to calculate
2019-03-06 16:02:59
help. For my project, i would like to measure the S11 and S21 of a DUT. my DUT, are various thin
2019-10-16 10:36:29
我想知道如何将键盘和鼠标绑定到nvidia网格工作区?当我像游戏一样尝试全屏应用程序时,鼠标和键盘停止工作(仅点击工作)。以上来自于谷歌翻译以下为原文I would like to know how
2018-09-20 11:33:34
the following: I would like to save an array into non-volatile memory. I would like that memory to be reloaded when the power returns. Thanks for the help!
2019-07-24 13:39:00
with a DMM, numbers may be displayed as 10,0000150 (example). I would like to see the same figure
2019-03-01 11:24:45
running on 4 servers.I purchased an additional server with 2x k1 grids and I would like to add
2018-09-05 09:35:37
必须是GPO而不是I2C…CY8CMBR3102-SX1I适用于我的需要吗? 以上来自于百度翻译 以下为原文I would like to use a proximity detector
2018-12-06 15:05:11
您好我想从网页上阅读文本到VEE,我正在使用VEE Pro 9.2。可以这样做吗?任何帮助都会很棒! 以上来自于谷歌翻译 以下为原文Hello I would like to read text
2019-07-09 16:16:53
an external I2C mux to make three I2C channels. I would like to replace this HW with independent I2C output
2019-05-13 06:46:13
时钟拉伸,所以不应该是一个问题。我不知道我怎么能执行“释放一个PIN”,目前我正在切换针这样:你有什么想法,我做错了什么?非常感谢: 以上来自于百度翻译 以下为原文 Hi, i would like
2019-05-05 13:08:18
以下为原文 Hi Guys, I'm learning to use the I2C communications of my PIC18F46K22. I would like to read
2019-04-08 07:54:51
你好,我想克隆SPI主控组件,因为我想对它的行为做一些细微的修改。做这件事的最简单的方法是什么?雨果 以上来自于百度翻译 以下为原文Hi, I would like to clone
2019-04-28 13:23:34
提示吗?谢谢!以上来自于谷歌翻译以下为原文Hello! First of all, I would like to say I am beginner in FPGA. I have made
2019-06-14 14:24:06
in the Desktop", but those shorcuts have not been created, though. Now I would like to be able to execute all
2019-01-07 10:48:31
developing a system on Zynq.I would like to measure Hardware Usage(CPU)while developing on SDK or Plan Ahead. Any reply would be appreciatedthanks.
2019-03-18 14:08:04
and zero capacitance). Basically I would like the PIC32 GPIO connection to have the least possible
2019-04-19 14:21:27
to use SPC5 Studio as IDE for SPC56xP series microcontroller.I would like to get information
2019-06-17 15:18:21
获得没有时域的长度和速度因子?谢谢。 以上来自于谷歌翻译 以下为原文Hi, I want to know the delay of a circuit board trace it would
2018-10-10 17:14:07
的aci_gatt函数?)如果我要创建GATT字符串属性并更新它,我是否重新启动设备以更新其名称?以上来自于谷歌翻译以下为原文I would like to change the names of my
2018-09-20 09:50:41
normal Google Mail there, but it didn't seem to work. I would like to hear a few Answers, since i
2018-09-19 17:02:30
为原文I would like to measure the time between two rising edges to calculate speed with a hall effect
2018-12-27 15:30:40
?谢谢。 以上来自于谷歌翻译 以下为原文I have some 1-port simulations and I would like to calculate the shunt
2019-04-24 10:17:53
我很快就把这个过程交给生产人员,如果可能的话,我想取消这个步骤。 以上来自于百度翻译 以下为原文 I have saved an environment in IPE v3.30 and would
2019-06-21 11:41:51
I2C. I am using CY8CKIT-041 and would like to send the capsense trackpad data collected
2019-07-03 12:45:16
) using a PIC18F4523 running at 8MHZ.I would like to generate a control voltage, for the above regulator
2019-06-06 15:07:26
想测一下一个编解码的纠错性能,需要用到Generate Bits和Calculate BER 两个函数,怎么设置才对呀,直接连的话误码率一直是1,PS已经排除是编解码的问题,因为直接连接产生比特流和计算误码率两个函数误码率也是1求大神指点
2014-07-23 10:32:14
ends. But I would like to realize the following function. A start button, after starting the program
2019-07-05 11:08:16
(CY8C24794) in a project and would like to know if I can assign a PWM block to multiple outputs, i.e. I'd
2019-03-12 15:56:15
来自于谷歌翻译以下为原文 Hello,I would like to ask you for suggestion. I would like to monitor vibration
2019-03-21 14:00:53
/schurter-inc/1301.9314/486-3465-ND/2643951以上来自于谷歌翻译以下为原文Hello everyone! I would like to replace
2018-10-25 14:20:07
everyone I would like to know if it is possible to make the serial communication I2C with the PIC 16F628A
2018-12-21 15:43:23
to use the WICED board and they would also like to OCF compliant. I'm looking for a path to make this happen.
2018-10-17 16:16:21
, the problem never happens, so I would like to know if someone has a solution in bios for that.Thanks. Salutations.
2018-11-16 11:26:41
over a long period of time.Is my MSO7104B scope the right tool?I would like my final answer
2018-09-30 16:40:01
嗨,我想将几台摄像机连接到英特尔航空板,但它只有一个USB-OTG连接。我想知道是否有任何方法可以使这些连接可视化几个图像。谢谢。以上来自于谷歌翻译以下为原文Hi,I would like
2018-11-06 11:12:23
简要地看了和声引导加载程序,但我仍然觉得有必要开发一个在组装。谢谢你看一看。 以上来自于百度翻译 以下为原文 Hi Guys, I would like to develop a booloader
2018-11-16 15:13:21
with SCB.In circuit design, I would like to calculate in advance, so please let me know if there is any way. Thanks and regards,
2018-10-22 14:38:11
为原文 Hello Community,I am measuring several voltages and I would like to have a precise reference
2019-06-25 07:46:24
methods of configuration. I would like to be able to calculate approximate config times
2019-06-19 09:11:22
would like to know if it would be possible to use any of the CAN IP cores on it? I would like the CAN
2019-06-24 10:19:15
什么建议?BRjonnsi #mems #audio #microphone #waterproof以上来自于谷歌翻译以下为原文 I would like to make a waterproof
2018-11-06 10:08:36
). Can I get one from the expert team? I would like to trigger an eDMA request after an eMIOS channel
2018-11-06 10:14:22
for some housekeeping on the board.I can use USB to upgrade processor in the field and would also like
2019-06-05 07:25:44
有一个文档解释如何实现这一点,以及需要生成的文件的格式吗?多谢雨果埃利亚斯 以上来自于百度翻译 以下为原文Hi, I would like to know if it's possible
2019-07-09 08:25:12
使用PSoC 5。谢谢菲利普 以上来自于百度翻译 以下为原文I would like to us the SD flash as a data logger function. Does anyone
2019-03-28 11:15:25
锁相环设计仿真与应用:PLL Performance, Simulation, and Design3rd EditionI would like to thank the following people for their as
2008-08-16 10:14:53
74 in the garbage—is a tough challenge. When I asked TechRepublic members how they would troubleshoot a situation like this one, we rec
2008-10-28 22:58:43
11 The authors of this specification would like to recognize the following people who participated
2009-04-12 00:10:59
14 The authors of this specification would like to recognize the following people who participated
2009-04-13 00:50:53
399 (Pontifical Catholic University), Rio de Janeiro, Brazil. Many people at ICA helped to make this book possible. We would like to exp
2009-07-22 11:40:36
0 (Pontifical Catholic University), Rio de Janeiro, Brazil. Many people at ICA helped to make this book possible. We would like to exp
2009-07-22 11:44:49
0 that is required to carry a large amount of current. I would like to know how t
2009-12-29 09:23:04
0 1: MC: I would like to introduce our next speaker Juergen Flamm. He has been actively involved in electronic engineering at various
2010-04-05 06:23:27
0 SUMMARYAn electronic retina featuring DSP-like programmable analogue processing is addressed.
2010-07-01 16:15:55
2 We would like to welcome you as a user of the Allegro CX, a rugged, handheld fi eld PC
2010-11-24 11:37:59
0 How to Calculate the Wiper Voltage of a Digital Potentiometer
2008-10-01 12:08:38
881 ![](https://file1.elecfans.com//web2/M00/A4/68/wKgZomUMNBKAGj1fAAAGWdL-NzQ066.gif)
改进的石墨电池材料
A Splash Of Graphene Improves Battery Materials— Researchers would like to develop lithium-ion batteries using titanium dioxide, an inexpensiv
2010-03-03 09:01:37
629 child issleeping. Both you and your wife would like to watch amovie together.but you cant blast your 5.1HTS.
2011-06-07 15:59:46
158 将6LowPAN应用于物联网We would first like to thank the people that have collaborated with us on this book.
2017-09-25 14:21:47
0 LSR would like to announce a low-cost and lowpower consumption module which has all
2017-09-26 17:11:22
6 LSR would like to announce a low-cost and lowpower consumption module which has all of the BluetoothSmart functionalities.
2017-09-26 17:14:29
2 针对用于二维十字相控阵的类旋转不变技术估计信号参数( ESPRIT-like)算法用于相干源方向角估计时存在仰角和方位角配对困难的问题,提出一种基于接收信号矩阵联合对角化的改进二维
2017-12-22 14:23:14
1 今年的除夕,数位当红明星变身LIKE魔法使,给迷弟迷妹们上演了一场独一无二的“穿越大秀”。柳岩、陈妍希、yif、马伯骞、王竟力、周震南等明星爱豆纷纷推出亲自拍摄的LIKE短视频,燃爆网络。除了明星
2018-02-15 16:31:01
173 Intel and the HTML5 Hub would like to present a new series, called "Food for Thought". We have
2018-10-16 03:50:00
2105 avr单片机测量电机转速The simple concept that will be used here is similar like the cases that come
2021-11-14 21:06:00
17 MP3-Like Engineer user manual (SC)
2022-06-20 14:53:17
1 MP3-Like user manual (SC)
2022-06-20 14:50:59
1
