关于PCB 邮票孔、PCB 邮票孔设计要求 一、PCB 邮票孔是什么? 邮票孔 是 指主板面板上的孔,用于将组成阵列的小型 PCB连接在一起,可以轻松地从PCB上移除组件。 邮票孔是穿孔的,当你向下
2023-11-07 10:52:00
1599 ![](https://file1.elecfans.com/web2/M00/AC/CA/wKgaomVJpbGATSsBAAEZv0CFy_E190.png)
240-032-1-9PCB - Micro-D Filter Connectors - Glenair, Inc.
2022-11-04 17:22:44
240-032-6-9PCB - Micro-D Filter Connectors - Glenair, Inc.
2022-11-04 17:22:44
36.6*28.4*19.2 PCB板屏蔽罩
2023-03-29 21:30:28
PCB-1TR - Printed Circuit Board Fuses - List of Unclassifed Manufacturers
2022-11-04 17:22:44
PCB-2 - Printed Circuit Board Fuses - List of Unclassifed Manufacturers
2022-11-04 17:22:44
PCB-B-18-T-25 - LIF FLEX CIRCUIT CONNECTOR - Adam Technologies, Inc.
2022-11-04 17:22:44
PCB LAYOUT REFERENCE RULER 12"
2023-03-29 20:13:22
CONN MMCX JACK STR PCB
2023-03-23 02:45:15
CONN SMA JACK STR 50OHM PCB
2023-04-04 17:02:20
PCB.SMAFSTJ.A.HT
2023-03-28 13:48:32
PCB2421 - 1K dual mode serial EEPROM - NXP Semiconductors
2022-11-04 17:22:44
PCB80C39 - SINGLE-CHIP 8-BIT CMOS MICROCOMPUTER - NXP Semiconductors
2022-11-04 17:22:44
PCB80C552 - Single-chip 8-bit microcontroller - NXP Semiconductors
2022-11-04 17:22:44
PCB83C552 - Single-chip 8-bit microcontroller - NXP Semiconductors
2022-11-04 17:22:44
KIT EVAL PCB FOR AD10200
2023-03-30 11:47:21
KIT EVAL PCB FOR AD10242
2023-03-30 11:47:22
AD6600PCB - Dual Channel, Gain-Ranging ADC with RSSI - Analog Devices
2022-11-04 17:22:44
AD6622PCB - Four-Channel, 75 MSPS Digital Transmit Signal Processor TSP - Analog Devices
2022-11-04 17:22:44
AD6630PCB - Differential, Low Noise IF Gain Block with Output Clamping - Analog Devices
2022-11-04 17:22:44
BOARD EVAL AD6645-MIL/PCB
2023-03-22 19:55:37
AD9481-PCB - 8-Bit, 250 MSPS 3.3 V A/D Converter - Analog Devices
2022-11-04 17:22:44
AD9853-45PCB - Programmable Digital OPSK/16-QAM Modulator - Analog Devices
2022-11-04 17:22:44
AD9889PCB - High Performance HDMI/DVI Transmitter - Analog Devices
2022-11-04 17:22:44
AH1-PCB - High Dynamic Range Amplifier - List of Unclassifed Manufacturers
2022-11-04 17:22:44
AM9157A-4PCB - Multimode DMA Controller - Advanced Micro Devices
2022-11-04 17:22:44
ECG001B-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
ECG002C-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
ECG002F-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
ECG005B-PCB - InGaP HBT Gain Block - List of Unclassifed Manufacturers
2022-11-04 17:22:44
ECG005B-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
ECG006B-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
ECG006C-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
ECG006F-PCB - InGaP HBT Gain Block - List of Unclassifed Manufacturers
2022-11-04 17:22:44
ECG006F-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
ECG008B-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
ECG040B-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
ECG055B-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
ECG055C-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
FA1-NARP-PCB-8
2023-03-29 21:50:37
CONN FAKRA PLUG R/A 50 OHM PCB
2023-04-06 13:38:42
2023-03-23 02:47:01
2023-04-06 13:38:42
FA1-NCRP-PCB-8
2023-03-29 18:00:32
2023-04-06 13:38:46
FA1-NDRP-PCB-8
2023-03-29 18:00:50
2023-04-06 13:38:46
2023-03-23 02:47:01
2023-04-06 13:38:46
2023-03-23 02:47:01
2023-04-06 13:38:46
2023-03-23 02:47:01
2023-04-06 13:38:46
2023-03-23 02:47:01
2023-04-06 13:38:46
2023-03-23 02:47:01
2023-04-06 13:38:46
2023-03-23 02:47:01
2023-04-06 13:38:46
2023-03-23 02:47:01
2023-04-06 13:38:46
2023-03-23 02:47:01
2023-04-06 13:38:46
2023-03-23 02:47:01
2023-04-06 13:38:50
FM4-NZRP-PCB-1
2023-03-29 21:36:57
HMC1023PCB - 3-AXIS MAGNETIC SENSOR - Honeywell Solid State Electronics Center
2022-11-04 17:22:44
HMJ7-PCB - High Dynamic Range FET Mixer - WJ Communication. Inc.
2022-11-04 17:22:44
HMJ9-PCB - The Communications Edge - WJ Communication. Inc.
2022-11-04 17:22:44
RP34-8R-3PCB - COMPACT PLASTIC CONNECTOR FOR AC ADAPTER - Hirose Electric
2022-11-04 17:22:44
SCG002B-PCB - InGaP HBT Gain Block - WJ Communication. Inc.
2022-11-04 17:22:44
MOD USB SERIAL 3.3V EMBEDDED PCB
2022-11-04 17:22:44
MOD USB SERIAL 5V EMBEDDED PCB
2022-11-04 17:22:44
TTL-232R-PCB - TTL to USB Serial Converter PCB - Future Technology Devices International Ltd.
2022-11-04 17:22:44
VG101-PCB - Cellular-band Variable Gain Amplifier - WJ Communication. Inc.
2022-11-04 17:22:44
WJZ1020H-PCB - Broadband Surface Mount Mixer - TriQuint Semiconductor
2022-11-04 17:22:44
WJZ2020-PCB - Broadband Surface Mount Mixer - WJ Communication. Inc.
2022-11-04 17:22:44
在PCB板子过回焊炉容易发生板弯及板翘,大家都知道,那么如何防止PCB板子过回焊炉发生板弯及板翘?
2019-09-10 09:36:04
PCB的定义:印刷电路板
PCB的英文全称:Printed Circuit Board
PCB的中文名称:印刷电路板
PCB的图片如下:
2009-09-30 08:59:37
1620 软PCB板入门基础,软PCB板介绍
2011-04-09 18:02:24
9325 本内容详细解释了PCB和PCB LAYOUT的相关术语,为PCB LAYOUT设计人员提供了方便
2011-11-09 16:01:29
3185 PCB设计相关经验分享及PCB新手在PCB设计中应该注意的问题
2013-09-06 14:59:47
0 本文详细介绍什么是pcb打样,对pcb打样是什么意思作全面的讲解,对您全面了解pcb打样加工有帮助。
2014-04-22 22:32:59
16884 本文开始介绍了pcb油墨的概念与pcb油墨的特性,其次阐述了PCB油墨的种类,最后介绍了pcb油墨使用注意事项以及PCB油墨在PCB制程中的作用。
2018-03-12 14:44:42
9087 AD封装转ALLEGRO封装时,要把所有封装放到一张PCB上或者分批次的放到PCB上,把PCB转成ALLEGRO格式的,然后再用ALLEGRO导出PCB封装
2018-04-05 17:06:00
47055 ![](https://file.elecfans.com/web1/M00/4E/B0/o4YBAFrEldKADFmnAAAQMPFy0_w706.jpg)
PCB抄板,业界也常被称为电路板抄板、电路板克隆、电路板复制、PCB克隆、PCB逆向设计或PCB反向研发,关于PCB抄板的定义,业界和学术界有多种说法,但是都不太完整。
2019-04-18 15:16:38
5217 本文首先介绍了PCB打样的概念,其次介绍了PCB打样详细流程,最后介绍了PCB打样厂家。
2019-05-17 17:01:48
6319 本视频主要详细介绍了pcb干膜有哪些,分别是单面PCB、双面PCB、3-4层PCB、6-8层PCB、10层以上的PCB。
2019-05-28 17:37:23
4570 PCB拼板是PCB厂经常要做的事情,进行拼板需要注意哪些事项?PCB拼板有哪些要则?
2019-05-31 09:36:54
32396 铝PCB的优点及铝PCB的应用。
2019-07-29 08:58:12
2346 PCB板抄板是指根据原有的PCB板实物得到原理图和板图(PCB图)的过程。其目的是进行后期的开发。后期开发包括安装元器件、深层测试、修改电路等。因为不属于PCB板抄板的范畴又与之相关,因此仅做介绍不再详述。
2020-09-25 17:25:04
6425 众所周知,印刷电路板( PCB )是几乎所有电子和机电设备不可或缺的一部分。根据应用要求,有几种类型的 PCB 以各种配置和层数制成。 PCB 可以带有或不带有金属芯。金属芯 PCB 大多由铝制
2020-10-15 22:11:19
2129 PCB抄板,业界也常被称为电路板抄板、电路板克隆、电路板复制、PCB克隆、PCB逆向设计或PCB反向研发,关于PCB抄板的定义,业界和学术界有多种说法,但是都不太完整,如果要给PCB抄板下一个准确
2022-02-18 16:26:53
11105 PCB翘曲就是PCB形状改变了,具体的如下图所示,很明显的PCB翘曲。
2023-01-10 16:40:56
2694 在设计2层PCB时,实际上不需要考虑PCB在工厂的结构问题。但是,当电路板上的层数为四层或更多时,PCB的堆叠是一个重要因素。
2023-07-19 16:19:13
2030 ![](https://file1.elecfans.com/web2/M00/8D/30/wKgaomS3nGGAfu28AADZp35wwf0172.jpg)
今天是关于:PCB过孔、5种PCB过孔类型、PCB过孔处理工艺 一、PCB过孔是什么意思? PCB过孔用于在多层PCB的各层、走线、焊盘等之间 建立电气连接 。如果用过孔连接多层板可以减小 PCB
2023-07-25 19:45:01
4747 ![](https://file1.elecfans.com/web2/M00/8E/60/wKgaomTE0cWACr2pAAAQYMav-_I799.jpg)
PCB 覆铜:PCB 层中填充铜的区域。该层可以是 PCB 叠层的顶部、底部或任何内部,并且PCB覆铜可以用作接地、参考或将特定组件或电路与该层的其余元素隔离。
2023-08-28 11:24:50
1212 ![](https://file1.elecfans.com/web2/M00/A1/89/wKgaomTsFBSAZclfAAAapMHfC5Q848.jpg)
一站式PCBA智造厂家今天为大家讲讲PCB四层板都有哪四层?pcb四层板结构介绍。多层PCB是电子信息技术向高速、多功能、大容量、小体积、薄、轻量化方向发展的结果。对于PCB板的生产来说,层数越多
2023-10-17 09:19:43
2897 PCB邮票孔的尺寸通常为0.020英寸或直径0.5毫米,会根据 PCB设计的而变化。PCB 邮票孔的尺寸由用于制造 PCB的材料厚度决定。
2023-11-19 12:41:26
1278 ![](https://file1.elecfans.com/web2/M00/AF/2F/wKgaomVZklSAQNwMAAAZyqdfDII831.jpg)
