cypress公司的EZ-PD™ CCG3PA是高度集成的USB Type-C端口控制器,和最新的USB Type-C和PD标准兼容.器件采用Cypress公司的M0S8技术和32位ARM® Cortex™-M0处理器,64KB闪存,完整的Type-C USB-PD收发器,Type-C端口所需的所有端电阻,用于电压(VBUS)稳压的反馈控制电路和系统级ESD保护.主要用在PC电源适配器,移动充电器,汽车充电器和电源柜应用.本文介绍了EZ-PD™ CCG3PA主要特性,逻辑框图和内部框图,多种应用电路以及评估板CY4532 EZ-PD CCG3PA EVK(主板和电源板)主要特性,电路图,材料清单和PCB设计图.
EZ-PD™ CCG3PA is Cypress’s highly integrated USB Type-C port controller that complies with the latest USB Type-C and PDstandards and is targeted for PC power adapters, mobile chargers, car chargers, and power bank applications. In such applications,CCG3PA provides additional functionalities and BOM integration advantages. CCG3PA uses Cypress’s proprietary M0S8 technologywith a 32-bit ARM® Cortex™-M0 processor, 64KB flash, a complete Type-C USB-PD transceiver, all termination resistors required fora Type-C port, an integrated feedback control circuitry for voltage (VBUS) regulation and system-level ESD protection. It is availablein 24-pin QFN and 16-pin SOIC packages.
EZ-PD™ CCG3PA主要特性:
Type-C Support and USB-PD Support
■ Supports USB PD3.0 Version 1.1 Spec including ProgrammablePower Supply Mode
■ Configurable resistors RP and RD
■ Supports one USB Type-C port and one Type-A port
2x Legacy/Proprietary Charging Blocks
■ Supports QC 4.0, Apple charging 2.4A, AFC, BC 1.2
■ Integrates all required terminations on DP/DM lines
Integrated Voltage (VBUS) Regulation and CurrentSense Amplifier
■ Analog regulation of secondary side feedback node (directfeedback or opto coupler)
■ Integrated shunt regulator function for VBUS control
■ Constant current or constant voltage mode
■ Supports low-side current sensing for constant current control
System-Level Fault Protection
■ On-chip OVP, OCP, UVP, and SCP
■ Supports OTP through integrated ADC circuit
32-bit MCU Subsystem
■ ARM Cortex-M0 CPU
■ 64-KB Flash
■ 8-KB SRAM
Clocks and Oscillators
■ Integrated oscillator eliminating the need for external clock
Power
■ 3.0V to 24.5V operation (30-V tolerant)
■ Deep Sleep: 5 μA, Sleep: 3 mA
System-Level ESD Protection
■ On CC, VBUS, and DP/DM pins
■ ± 8-kV Contact Discharge and ±15-kV Air Gap Discharge basedon IEC61000-4-2 level 4C
Packages
■ 24-pin QFN and 16-pin SOIC
■ Supports extended industrial temperature range(–40℃ to +105℃)
图1.EZ-PD™ CCG3PA逻辑框图
图2.EZ-PD™ CCG3PA内部框图
图3.EZ-PD™ CCG3PA带光耦反馈控制的PC电源适配器应用电路图
图4.EZ-PD™ CCG3PA带直接反馈控制的手机电源适配器应用电路图
图5.EZ-PD™ CCG3PA汽车充电器应用电路图
图6.EZ-PD™ CCG3PA电源柜应用电路图
The CY4532 EZ-PD™ CCG3PA Evaluation Kit (EVK) is based on the CCG3PA product family of Cypress’s USB Type-C microcontrollers. This EVK is intended to be an evaluation vehicle for USB Type-C Power Adapter (PA) and USB Type-C Power Bank (PB) applications. The kit can be configured for a PA or PB application using a combination of firmware, jumper settings on the kit hardware, and external accessories. The following paragraphs provide a brief description of both applications:
USB Type-C Power Adapter (PA): To charge a device such as a mobile phone or notebook which supports battery charging through the Type-C interface. The device can be connected to the Type-C port on the CY4532 EVK’s Main Board to be charged as per the USB Power Delivery (PD) protocol. This application requires a DC input to be supplied to the EVK.
In addition to charging through the USB Type-C port, the EVK also supports charging through a USB Type-A port to enable battery charging of legacy devices. The CY4532 EVK supports Battery Charging (BC) 1.2, Qualcomm Quick Charge (QC) 3.0, Apple 2.4A charging and Samsung Adaptive Fast Charging (AFC) charging protocols on the USB Type-A port.
USB Type-C Power Bank (PB): This application is similar to the PA application. Here, a 1-Cell or 2-Cell Lithium-ion battery, which is connected to the CY4532 EVK acts as the power source to support charging on USB Type-C and USB Type-A ports. In addition, the battery can be charged using a USB Type-C Power Adapter connected to the USB Type-C port of the EVK’s Main Board.
In addition to the applications described above, the CY4532 Power Board can be used as a Programmer for Cypress EZ-PD CCGx Products supporting Configuration Channel (CC) bootloading. Refer to 5. for more details.
评估板CY4532 EZ-PD CCG3PA EVK包括:
The CY4532 EZ-PD CCG3PA EVK consists of the following contents:
CY4532 EZ-PD CCG3PA EVK Power Board
CY4532 EZ-PD CCG3PA EVK Main Board (pre-mounted on the CY4532 EVK Power Board)
12 V 24 W DC Power Adapter
Quick Start Guide
图7.评估板CY4532 EZ-PD CCG3PA EVK架构图
图8.CY4532 电源板框图
图9.CY4532 电源板连接器图
图10.CY4532 EVK主板框图
图11.CY4532 EVK主板连接器/跳线设定图
图12.CY4532 EVK主板电路图(1)
图13.CY4532 EVK主板电路图(2)
图14.CY4532 EVK主板电路图(3)
CY4532 EVK主板材料清单(BOM):
图15.CY4532 EVK主板PCB设计图(1)
图16.CY4532 EVK主板PCB设计图(2)
图17.CY4532 EVK主板PCB设计图(3)
图18.CY4532 EVK主板PCB设计图(4)
图19.CY4532 EVK主板PCB设计图(5)
图20.CY4532 EVK主板PCB设计图(6)
图21.CY4532 EVK电源板电路图(1)
图22.CY4532 EVK电源板电路图(2)
图23.CY4532 EVK电源板电路图(3)
图24.CY4532 EVK电源板电路图(4)
图25.CY4532 EVK电源板电路图(5)
图26.CY4532 EVK电源板电路图(6)
CY4532 EVK电源板材料清单(BOM):
图27.CY4532 EVK电源板PCB设计图(1)
图28.CY4532 EVK电源板PCB设计图(2)
图29.CY4532 EVK电源板PCB设计图(3)
图30.CY4532 EVK电源板PCB设计图(4)
图31.CY4532 EVK电源板PCB设计图(5)
图32.CY4532 EVK电源板PCB设计图(6)
详情请见:
和
document.pdf
CY4532_EZ_PD_CCG3PA_EVALUATION_KIT_GUIDE.pdf
查看更多
