电子发烧友App
硬声App
电子发烧友网>电源/新能源>浅谈MIC29302WU不调压的问题
浅谈MIC29302WU不调压的问题
收藏
查看更多
MIC29302资料下载
MIC29302资料下载MIC29302A是一个大电流,低成本,低压差电压调节器, 它采用麦瑞半导体专有的超级βetaPNP进程与PNP旁路元件。 在3ALDO稳压器具有450mV (满负载)电压差
2021-11-12 06:33:29
MIC29302WU
IC REG LINEAR POS ADJ 3A TO263-5
2023-04-06 15:30:45
MIC29302WU-TR
3A大电流低压降调节器,可调电压 TO263-5
2023-03-27 18:40:12
WU100
WU100 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU101
WU101 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU103
WU103 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU105
WU105 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU106
WU106 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU200
WU200 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU201
WU201 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU202
WU202 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU203
WU203 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU205
WU205 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU206
WU206 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU207
WU207 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU208
WU208 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU209
WU209 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU300
WU300 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU301
WU301 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU303
WU303 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU304
WU304 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU305
WU305 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU306
WU306 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU307
WU307 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU308
WU308 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU309
WU309 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
WU400
WU400 - 10/15 Watts WU Series - List of Unclassifed Manufacturers
2022-11-04 17:22:44
浅谈FPGA在安全产品中有哪些应用?
浅谈FPGA在安全产品中有哪些应用?
2021-05-08 06:36:39
浅谈UWB与WMAN无线电系统的验证
浅谈UWB与WMAN无线电系统的验证
2021-06-02 06:07:49
浅谈三层架构原理
浅谈三层架构原理
2022-01-16 09:14:46
浅谈低成本智能手机的发展
浅谈低成本智能手机的发展
2021-06-01 06:34:33
浅谈射频PCB设计
浅谈射频PCB设计
2019-03-20 15:07:57
浅谈电子三防漆对PCB板的作用有哪些?
浅谈电子三防漆对PCB板的作用有哪些?
2023-04-14 14:36:27
AP62250WU-7
AP62250WU-7
2023-03-29 21:43:32
CC1310不调用库函数,怎么自定义ISR?
CC1310不调用库函数,怎么自定义ISR?如果不调用PIN_registerIntCb()注册中断服务函数的话,怎么自定义ISR?cc1310在IAR中能不能以类似这种格式#pragma
2016-03-09 11:05:11
CST92F30中的HalGpioSet()函数内部为什么还要调用HalGpioPinInit(),不调用可以吗?
2022-04-07 14:44:35
G6WU-1F
G6WU-1F - High-frequency Relay - Omron Electronics LLC
2022-11-04 17:22:44
G6WU-1P-R
G6WU-1P-R - High-frequency Relay - Omron Electronics LLC
2022-11-04 17:22:44
LM29302R
LM29302R
2023-03-29 21:35:47
SPX29302A
SPX29302A - 3A High Current, Low Dropout Voltage Regulator Adjustable, Fast Response Time - Sipex Corporation
2022-11-04 17:22:44
TARGET3001!用法篇-如何使用TARGET丰富的元器件库
SamacSys为例,点击它,稍等片刻,即可在浏览器中打开相应网页并自动搜索对应器件,同样可以看到有很多搜索结果,假如我们点击第二个MIC29302WU。 进入新的页面,我们还是首先确认这个元器件
2024-03-14 11:35:12
TC7WU04F
TC7WU04F - 3 INVERTER - Toshiba Semiconductor
2022-11-04 17:22:44
svpwm调压调频方法
大大大大神们,svpwm在程序里是怎么调压调频的啊
2013-06-03 10:07:57
什么是数码功放?浅谈数码功放
什么是数码功放?浅谈数码功放
2021-06-07 06:06:15
供应WU型网式吸油过滤器
印刷机滤油器(型号:WU):本型号过滤器适用于油泵吸油口处滤除油液中的杂质,用以保护油泵及其它液压元件,有效的控制液压系统污染,提高液压系统的清洁度。过滤器直接浸入油箱的油液中,由管路螺纹或法兰
2015-04-30 14:31:46
变压器的调压方式有哪几种?
常见的大功率级别的调压方式有哪些? 变压器调压又分为哪几种形式? 调压入合调压出合调压入分调压出分这几个概念分别是什么意思?
2024-02-21 15:11:53
可控硅交流调压模块和Buck交流调压模块的哪种电路效率更高?
可控硅交流调压电路和Buck交流调压电路那种效率更高?可控硅调压是通过调节可控硅调节导通角实现电压调节,这种方式是不是就类似在负载前面加一个无极可调电阻,不会根据电压变化动态调节功率;这种调压方法是不是只是通过调整“电阻值”,使用不同的电阻值调节分散的功率?
2020-03-14 13:13:53
手机硬件知识浅谈
手机硬件知识浅谈
2013-05-15 11:04:52
日本MIC & JATE检测认证
无线产品进入日本市场需要进行日本无线电的型号核准(主要针对RF部分),如MIC&JATE,现华夏准测实验室取得授权认可,在实验室完成测试并出具MIC&JATE的证书。更多的欢迎联系和咨询:*** 吴
2016-03-02 17:18:53
求芯片推荐
报告中需要一个电源方案比选,求一个性能方面和MIC29302相似的线性电源芯片
2014-04-16 14:47:49
求问调压器的使用方法
我现在需要使用一个调压器,型号是JKH—C1可控硅调压器,但以前没有接触过这类器件,。我想知道这个调压器的输入输出关系是怎么样的
2017-05-24 14:53:36
物联网WiFi模块: WLAN模块WiFi WU106
分享的这篇文章,介绍通过添加WU106 IoT UART WiFi模块的方式将产品、设备接入物联网的实现案例。物联网物联网,即通过装置在各类物体上的射频识别(RFID)、传感器、二维码等,经过接口
2017-10-25 18:36:32
请问gprs的音频部分运放用的什么?
gprs的音频部分运放用的什么?我的参考设计上用的是lm386,运放是否对电源也要求高?资料上写4-12V供电,我用的电源是外部5V接入mic29302输出4V。如果连接到mic29302的输出端,是否电压不够,如果直接接到5V,如果没有稳压芯片的话,害怕电压不稳定。应该怎么接合理?
2019-01-30 06:35:55
请问stm32驱动gprs模块,音频部分的音频放大用的什么?
2019-01-30 06:36:02
这个电路能稳压调压
这个电路这样能用吗能调压稳压吗
2017-03-17 14:56:20
MIC3975-5.0YMM-TR
MIC3975-5.0YMM-TR现货 2,000MIC3975-5.0YMM-TR芯片详细信息Source Content uid:MIC
2022-03-11 09:17:17
调频叶片及不调频叶片的安全准则
调频叶片及不调频叶片的安全准则案例一某电厂2台国产300MW机组驱动给水泵小汽轮机第4压力级叶片事故。1991年4月,6号小汽轮机第4压力级断叶11片,附近6片叶片变形严重,该小
2008-12-13 15:46:2415
线性稳压器 MIC29302WU-TR
制造商:  Microchip 产品种类:  低压差稳压器 RoHS:   YES安装风格:  SMD/SMT 封装 / 箱体:  TO-263-5 输出电压:  1.25 V to 25 V 输出电流:  3 A&nb
2022-11-17 16:48:57
浅谈MIC电路的偏置电阻
下图是典型的 MIC 应用电路以及MIC 内部的电路图。在MIC 内部,驻极体电容将声音信号变为电信号,并立即通过一级共源FET 放大输出。加电阻的目的是为了给 MIC 内部的FET 放大器
2009-07-14 23:27:40152
有载调压变压器的无冲击调压方法
有载调压变压器的无冲击调压方法 摘要: 提出以电力电子器件为分接开关的有载调压变压器无冲击调压方法。该方法考虑了调压绕组的改变引起的变比变化和漏
2009-11-18 17:43:500
XBLW 芯伯乐低压差大电流可调稳压器XBLW MIC29302
XBLW MIC29302是芯伯乐公司推出的一款低压差、大电流且精度高的电压调节器,以超βetaPNP进程与PNP旁路元件。满载条件下,该稳压器具有 370mV 电压差和极低的接地电流。专为大电流
2024-01-05 15:50:53
相控式交流调压电路
通过某种装置对交流电压的有效值进行调整叫做交流调压。交流调压的方式一般分为三种:相控式、斩波式、通断式。第一种的电路一般由晶闸管构成,通过改变控制角实现调压
2010-08-08 14:49:2477
接触调压器是什么?
接触调压器是什么? 调压器就是匝比连续可调的自藕变压器,当调压器电刷借助于手轮,主轴和刷
2007-11-16 17:20:235152
调压定时两用器
调压定时两用器:此电路具有调压,调光,调速,调温及定时等多种功能,适用于家用电器使用,调压范围在30-215V,定时在5-60分钟,控制功率可达800W。
2007-12-14 08:10:41598
巧修调压
巧修调压
2009-08-27 17:21:31776
mic29302/MIC29150/mic29300,pdf_High-Current Low-Dropout regul
The MIC29150/29300/29500/29750 are high current, high accuracy, low-dropout voltage regulators.
2011-03-15 17:30:02164
调压模块_什么是调压模块
调压模块将若干个晶闸管、移相触发电路、保护电路和电源封装集成为一个模块。三相交流一体化移相调压模块采用大规模集成电路设计。
2011-12-30 13:04:388705
SPX29302_低压差3A稳压器IC数据手册
SPX29302_低压差3A稳压器IC数据手册,感兴趣的小伙伴们可以瞧一瞧。
2016-11-10 11:17:0137
物联网WiFi模块WU105规格书介绍文档
2017-09-05 14:38:4015
IOT WLAN模块WiFi WU106
IOT WLAN模块WiFi WU106规格书介绍文档
2017-09-12 14:10:325
什么是变压器无载调压和有载调压_有什么区别
本文首先对无载调压和有载调压变压器做了简单介绍,其次介绍了变压器有载调压的特点及工作原理,最后阐述了变压器无载调压和有载调压的区别是什么。
2018-05-08 09:15:4349493
无载调压变压器有什么特点_无载调压变压器如何调压
变压器调压是通过改变其分接开关抽头位置来实现的,变压器调压主要有有载调压和无载调压,本文主要详细介绍的是无载调压变压器,首先介绍了无载调压变压器的特点,其次阐述了无载调压变压器范围、级数及连接方法,最后介绍了无载调压变压器的调压方法有什么,如何调压及故障原因分析,具体的跟随小编来了解一下吧。
2018-05-08 09:39:3610961
有载调压变压器调压操作有什么规定及操作注意
有载调压是变压器在带负荷运行时能通过转换分接头档位而改变电压的一种调压方式。电力电子元件开关具有可频繁通断、无电火花、寿命长的优点,因此可作为配电变压器的有载调压分接开关。本文首先介绍了有载调压
2018-05-08 10:02:1431176
有载调压变压器的优缺点_有载调压变压器的技术对策
本文主要介绍的是有载调压变压器,首先介绍了有载调压变压器的优点,其次介绍了有载调压变压器的缺点,最后阐述了有载调压变压器的技术对策有哪些,具体的跟随小编一起来了解一下吧。
2018-05-08 10:22:084828
有载调压变压器在哪一侧调压_有载调压变压器的作用
变压器的有载调压就是可以实现不断电进行电压调节,本文首先介绍了有载调压变压器的调压原理及如何理解变压器有载调压调压范围,其次阐述了有载调压变压器在哪一侧调压,最后介绍了有载调压变压器的作用是什么。
2018-05-08 11:22:5321372
WU106 EVB开发板使用的一般流程和方法详细概述
WU106 EVB评估板用于评测WU106模块和WG222模块。该EVB套件包括:1.WU106/WG222模块一个;2.WU106 EVB一个;3.一根WIFI天线。。
2018-06-07 08:00:0013
变压器的调压方式
本文首先介绍了变压器的无载调压和有载调压,其次介绍了电炉变压器的调压方式,分别是直接调压法和间接调压法。
2018-10-17 17:48:2830868
调压器怎么用
使用调压器时应首先看一下铭牌,搞清原方、副方、副方输出电压的调节范围和最大允许电流等。电源电压和工作电流不得超过调压器铭牌上所规定的额定值。
2018-10-21 10:19:0916801
浅谈调压缩机的运作原理及内部结构
关于空调压缩机,这属于制冷系统,一般用于空调及冰箱冷库之类的,属于制冷设备的心脏。空调压缩机根据不同的原理是可以进行分类,通常分类有容积型与速度型两类。容积型的空调压缩机相对来说较为常见,也是目前最普遍的压缩机当中的一种。
2018-11-29 10:16:5016307
MIC29302A电压调节器的性能特点
MIC29302A是一个大电流,低成本,低压差电压调节器, 它采用麦瑞半导体专有的超级βetaPNP进程与PNP旁路元件。 在3ALDO稳压器具有450mV (满负载)电压差和极低的接地电流。 专为
2019-06-14 14:52:2226139
感应调压器的内部原理及调压方式
感应调压器分为交流三相与单相两种。三相感应调压器的结构与三相绕线转子感应电动机类似,其区别在于感应调压器的转子的转动范围受到限制以及定、转子绕组是连接在一起的。三相感应调压器的内部原理接线如图2-28(a)所示,图中只画出其中一相。
2020-09-16 14:40:3116182
TPS546D24 C23动态调压
Wenhao Wu 根据PMBUS 1.3.1版本协议,第二节8.2部分,本文将简述如何通过VOUT_COMMAND进行动态输出电压调节的方法,该方法适用于linear格式的所有PMBUS设备
2020-10-20 14:02:46441
为什么要选择变压器有载调压呢?有什么作用呢?
一般情况下,无载调压变压器的价格是有载调压变压器的价格2/3;同时,无载调压变压器的体积也由于不具备有载调压部分而小很多。所以,在规程没有规定或者其他情况下会选择用无励磁调压变压器。
2020-11-03 15:21:4416006
常见的电源调压方式
我们有时候需要的电源电压不一定正合适,要么过高,要么过低;这就需要采取措施将电压调整到合适值。常见的调压方式有变压器变压(以及自耦变压器)、电阻降压(以及可变电阻器)、电容调压、电感调压、可控硅调压。五种方式哪种比较强?适合哪些地方?下面开始PK!
2021-01-23 11:23:4518218
基于MIC29302A_Typical Application直流到直流单输出电源的参考设计
View the reference design for MIC29302A_Typical Application. http://www.elecfans.com/soft/ has
2021-08-11 16:13:097
基于SPX29302_Typical Application直流到直流单输出电源的
View the reference design for SPX29302_Typical Application. http://www.elecfans.com/soft/ has
2021-09-09 10:02:1410
2021-09-09 10:05:1212
学习笔记:MIC29302A电压调节器
2021-11-07 17:51:0016
使用MIC29302构建LDO稳压器或低压差稳压器电路
在本项目中,我们将使用 MIC29302 构建LDO 稳压器或低压差稳压器电路。可以使用调节引脚上的高阻值或低阻值电阻来改变输出电压。
2022-08-23 16:27:001694
单相固态调压器原理
固态调压器沟通部分的调理是用的移相方法,类似于台灯的调理方法。简略的说:固态调压器和固态继电器不同的便是调压器输出与信号是线性的,固态继电器里则是开关型的。
2023-03-30 13:29:102630
固态调压调压范围
需要注意的是,调压范围会受到环境温度、负载变化等因素的影响,还会受到电源噪波的影响。在实际应用中,需要根据实际情况选择合适型号的固态调压器,确保其能够满足应用要求,同时要正确使用和维护固态调压器。
2023-03-30 14:10:141916
调速电机不调速的原因
调速电机的调速部分由电磁转差离合器和控制器组成。励磁电压由控制器的电位器调节,以改变离合器的速度。 调速电机在使用过程中有时会出现不调速现象,可从以下几个方面找出原因:
2022-04-02 14:24:162807
调压器的工作原理 调压器怎么接线?
调压器又称晶闸管电力调整器、电力调整器。
2023-08-15 14:35:532977
调压电路中为什么要用晶闸管交流调压电路?
调压电路中,有自耦调压器交流调压,为什么要用晶闸管交流调压电路? 晶闸管交流调压电路在调压电路中具有重要的应用,其原因主要有以下几点: 1. 具有大功率调压特性:晶闸管是一种高功率半导体器件,能够
2023-11-23 14:51:44737
调压电路中,有相控调压,为什么又要斩控式调压
调压电路中,有相控调压,为什么又要斩控式调压调压电路是一种用于稳定输出电压的电路,其主要功能是将输入电压调整到所需要的输出电压。相控调压和斩控式调压是两种不同的调压方式,它们各自具有一些特点
2023-11-23 14:51:471172
双向可控硅调压电路中的调压电容起什么作用
在双向可控硅调压电路中,调压电容起着至关重要的作用。调压电容主要用于滤波和稳压。 首先,调压电容在双向可控硅调压电路中起到了滤波的作用。由于受电网的波动、干扰以及负载变化等原因,调压电路中的电流
2023-12-21 14:13:46273
基于BUCK的PWM调压与模拟调压方案
在电压变换时,我们常常会用到调压,其中以 PWM 或模拟调压应用最广泛,本文给出一种简单可行的 FB 点调压方式。
2024-01-05 14:57:48391
已全部加载完成
