电子发烧友App
硬声App
电子发烧友网>测量仪表>设计测试>Cable-Loss Solutions
收藏
查看更多
贸泽开售Skyworks Solutions的高科技陶瓷带通滤波器
贸泽电子即日起开售Skyworks Solutions的高科技陶瓷带通滤波器。
2021-11-10 15:15:362581
D6F-CABLE2
CABLE FOR D6F MASSFLOW SENSOR
2023-03-22 08:10:58
D6F-W CABLE
CABLE FOR D6F FLOW SENSOR 8"
2023-03-28 04:38:45
DAQ 创建仿真设备 只有RTSI cable ?
我安装的是 DAQ 8.6.1 如下创建 NI-DAWmx Simulated Device但是只有RISI cable请问是怎么回事啊 ?谢谢啦!
2014-11-21 09:27:59
Flash Programming Solutions for the TMS320F28xxx DSCs
Flash Programming Solutions for the TMS320F28xxx DSCsFlash programming is a process that occurs
2010-02-26 14:30:09
Lattice_Wireless_Solutions
2012-08-14 12:29:27
MBT 2009 LOSS/ANOTHER CRUSADE
; Trust, reported a fourth quarter 2009 net loss of $24.1 million, with the full year loss for 2009
2010-01-29 11:03:48
PNA-X J10有没有办法提高功率?
to +33, and the loss to Port 1 would be about 6dB, so I could only get +27 to the DUT(minus cable loss). Is there a way of boosting the power any higher?
2018-12-05 15:42:12
Real Analog Solutions for Digital Designers
2017-01-08 14:58:51
SimpleLink™ Wi-Fi® Family CC3100 / CC3200 Internet-on-a-chip™ Solutions
2016-02-24 11:29:23
Smart Sensor solutions for the automotive industry
Smart Sensor solutions for the automotive industrySmart Sensor solutions for the automotive
2009-10-06 14:50:57
Solid State Control solutions for three phase 1 HP motor
Solid State Control solutions for three phase 1 HP motorIn all kinds of manufacturing, it is very
2009-05-12 09:35:29
USB y-cable简介
Y-Cable带有一个标准USB接口,一个Micro USB插头,一个OTG接口,接口易于扩展。Y-Cable既是一根USB数据线,又能作为OTG数据线使用,所有它最基本的功能就是USB充电
2018-09-25 16:48:46
Xilinx不再支持Parallel Cable II吗
Parallel Cable III。这是正确的吗?我没有找到任何相关信息。我没有多少钱,而且更喜欢使用带有PCI卡(并行端口)的并行电缆来代替我的PC为Digilent XUP USB编程器支付90欧元,为
2019-01-17 07:47:26
xilink的板子。impact 检测不到设备 显示Can not find cable, check cable setup
device was found.AutoDetecting cable. Please wait.*** WARNING ***: When port is set to auto detect
2015-12-16 12:29:34
xilinx USB Cable JTAG无法用!
驱动正常。ISE 14.7版本 iMPACT上可以下载程序 XPS上 下载时,却提示无JTAG。Failed to Open JTAG Cable Cable target is not connected to the host请问这是什么问题 如何解决
2020-02-22 10:17:44
【求助】自制xilinx下载线。cannot find cable,check cable setup
,电脑能够识别下载线,设备管理器中显示xilinx USB cable。如下图但在使用IMPCT更新CPLD固件的时候遇到了问题,如下图IMPCT的console中错误信息如下图有人遇到过这样
2015-09-16 09:45:24
使用Filter solutions设计滤波器,为什么电感会是负数的值?
2016-12-22 19:15:01
使用Starterkit附带的USB-Cable可行吗?
的USB-Cable,但是Altium Designer没有检测到板(作为物理设备)。在我没有成功搜索互联网之后,我想知道这是否可行?我是否必须在电路板上设置任何跳线,或其他任何可以使其工作的跳线?如果有人可以帮助我,我会很高兴。谢谢。
2019-08-27 06:14:36
光纤元件的回波损耗测量(解决方案简介815-1)
This Solutions Brief discusses the significance of return loss, the design of a return loss test
2019-01-24 08:06:10
双界面读卡器+ OTG Cable应用芯片
双界面读卡器+ OTG Cable应用芯片,需要的加QQ 4303529
2014-08-07 12:51:19
如何使用Filter_solutions软件设计低通滤波器
开始接触 Filter Solutions 这一无源滤波器设计软件,记录一下笔记Filter_solutions版本2019版一:Filter_solutions的开发模式介绍1.1 快速开发模式
2021-12-28 06:11:42
如何在WLAN模式下设置外部丢失
analyzer with WLAN option and is trying to set a Cable loss dB Offset in the WLAN mode. My setup
2019-07-24 06:40:14
无法在Linux中访问Platform Cable USB II
image.I have run the setup using "sudo xsetup" and selected to install cable drivers
2018-12-11 11:18:55
结合预测框和目标框之间的归一化距离来提出距离-IoU (DIoU) Loss
1、IoU深入解析  边界框回归是目标检测的关键步骤,在现有方法中,虽然-norm loss 被广泛用于边界框回归,但它不是针对评估指标量身定制的,即 Intersection over Union
2022-11-14 15:46:01
请教Filter Solutions
请教哪里可以下载Filter Solutions 的仿真软件
2022-07-15 08:22:55
请问有懂cable双绞线通信的吗?
有懂cable双绞线通信的吗?
2019-02-14 02:21:09
镃心耗埙新算法 A New Core Loss Model For Iron Powder Material
镃心耗埙新算法 A New Core Loss Model For Iron Powder MaterialThe total core loss of a material can
2009-10-31 08:47:31
长的电缆测量如何影响测试结果?
如何减少或消除这种影响?需要更多校准步骤?谢谢... 以上来自于谷歌翻译 以下为原文Hi experts, We know that the measurement cable should
2018-11-16 10:51:16
PADS Routing Solutions使用教程
PADS Routing Solutions 拥有一套高效的运行程序以及它本身的任意角度和对角线布线算法,因此它能轻松有效地进行高密度、高质量的设计。选择这些可以满足你的需求的工具:
2008-05-11 23:06:090
EIA 364 108
EIA STANDARD TP-108Impedance, Reflection Coefficient,Return Loss, and VSWR Measured inthe Time
2008-08-10 20:34:3516
High Speed/Low Loss, CAF Resis
High Speed/Low Loss, CAF Resistant, Lead-Free SolutionTypical Engineering Values
2009-03-24 13:09:290
USB Cable & Connector Class Sp
Universal Serial Bus Cable & Connector Class Specification INTRODUCTION.1.1 PURPOSE.
2009-04-11 19:29:52241
CDMA摩托罗拉设备对基站做ATP技术操作资料
一.检查接地及8935的接地二.加电三.Load code/data四.测cable loss五.TX的校准六.ATP七. 驻波比测试。八.GPS和SPAN九.校准文件和ATP报告的保存。十.说
2009-06-23 14:31:2720
Solutions For Adaptor and ATX
Solutions For Adaptor and ATX power:
2009-07-03 16:29:1531
Dashboard Solutions
Dashboard Solutions:CAN ASSP3+Features􀂄Product Family􀂄78K/0 CPU Core•8-bit
2009-10-06 14:43:539
电缆的屏蔽与接地 (Cable Shield and gro
电缆的屏蔽与接地 (Cable Shield and ground):摘要 西门子通信电缆的屏蔽与接地关键词西门子系统、屏蔽、接地Key Words Siemens cable Shield Ground1 骚扰源的传输径411 导线的传导扰4
2009-10-07 09:12:5488
LMH0074,pdf datasheet (SMPTE 2
cable (orany media with similar dispersive loss characteristics). Theequalizer operates over a wide range of data rates from 12
2009-10-14 10:59:4528
LMH0344,pdf datasheet (3 Gbps
cable (or anymedia with similar dispersive loss characteristics). The equalizeroperates over a wide range of data rates from 125
2009-10-14 11:01:4820
Tools and Solutions for the 16
It has always been Microchip’s goal to provide great silicon solutions to our customers. However
2009-11-16 14:29:1010
Analytical Loss Model of Power
Abstract—An accurate analytical model is proposed in this paperto calculate the power loss
2009-11-26 11:16:5210
Cable Shielding Against E Fiel
Cable Shielding Against E Field:For good electric field shielding, it is necessary to minimize
2009-11-29 17:20:5015
Current Sensing Solutions for
Current Sensing Solutions for Power Supply Designers:While often considered a minor overhead
2009-12-04 17:49:2425
Apple Component AV Cable
2009-12-10 14:41:5029
Agilent Technologies Solutions
When it comes to providing solutions for designing, testing, and manufacturingdevices using
2010-03-03 10:33:198
HDMI connector and cable assem
HDMI connector and cable assembly This Product Specification covers the mechanical, electrical
2010-03-06 10:55:1935
VSWR/Return Loss Conversion Ta
VSWR/Return Loss Conversion Table Professional Wireless Products
2010-03-25 09:16:5914
Return Loss Headromm
Return Loss Headromm return loss is related to the impedance of a cable.To understand return loss we must first discuss inpedance.
2010-03-31 09:57:2015
External Serial ATA Cable (ESA
External Serial ATA Cable (ESATA)外部用SATA 线缆Product Introduce(产品介绍):ESATA is external SATA II style
2010-04-08 15:39:2734
汽车电子解决方案 Automotive Solutions
Automotive Solutions Overview Automotive Electronics Market Drivers
2010-04-16 16:09:0630
Fairchild LED Power Solutions
Fairchild LED Power Solutions LED Lighting 电源拓扑
2010-05-13 14:20:040
Product Bulletin WiMAX RF Chipset Solutions
Complete RF Front Ends Texas Instruments (TI) offers complete RF front-end solutions for the 2.5
2010-07-06 17:38:1340
Remote End-to-End Cell Loss Te
Launch Pad togetherwith the new remote cell loss macrotest. The remote cell loss macro testis available as standard o
2010-07-09 18:06:107
Polarization Dependent Loss Me
AbstractThe measurement of Polarization Dependent Loss hasgained a great deal of attention among
2010-07-15 23:43:1426
汽车用解决方案 (Automotive Solutions)
SolutionsAmplifiersDesign Resources New analog and mixed-signal solutions from NationalSemiconductor help automotive OEMs di
2010-11-21 12:21:4022
Reduced Termination Loss by Ac
Reduced Termination Loss by Active Synthesis of Output Impedance Abstract: In high-speed trans
2008-10-06 12:34:521186
Turn-On Switching Loss of An A
/5 controller IC. Due to the turn-off nature of the diode, turn-on switching loss of the main switch (Q1) depends on the switching frequency, th
2009-04-29 11:41:241721
Low-Loss LED Driver Improves a
Low-Loss L
2009-06-27 23:23:591523
Integrated Solutions Make Anal
Integrated Solutions Make Analog Filter Design Easy Abstract: This application note explains
2009-11-08 17:40:42931
2009-11-08 17:40:59995
什么是CM (Cable Modem)
什么是CM (Cable Modem)  英文缩写: CM (Cable Modem) 中文译名: 电缆调制解调器 分
2010-02-22 10:42:271339
什么是CATV (Cable TeleVision)
什么是CATV (Cable TeleVision)  英文缩写: CATV (Cable TeleVision) 中文译名: 有线电视、电缆电视 分  类: 电信设备
2010-02-22 11:06:321099
什么是Cable Telephony
什么是Cable Telephony  英文缩写: Cable Telephony 中文译名: 有线电视电话 分  类: 网络与交换 解  释: 指能
2010-02-22 17:27:05861
Cable MODEM,Cable MODEM的原理是什么?
Cable MODEM,Cable MODEM的原理是什么? modem的概念 我们常说的Modem,其实是Modulator(调制器)与Demodulator(解调器
2010-03-23 10:24:342961
Cable Modem,Cable Modem是什么意思
Cable Modem,Cable Modem是什么意思 Cable Modem是一种通过有线电视网络进行数据高速接入的设备。Cable Modem在两个不同的方向上发送和接收数
2010-04-06 10:51:106968
Siemens Medical Solutions USA
双方缔结旨在实现新一代超声波影像设备的战略联盟 加州芒廷维尤和加州圣克拉拉2010年9月7日电 /美通社亚洲/ -- Siemens Medical Solutions USA, Inc. 和美国国家半导体
2010-09-08 11:00:13658
Nano WiReach数据资料
Typical applications: Adding WiFi to serial embedded devices Replacing LAN cable using WiFi Adding SSL security to M2M solutions.
2011-09-29 17:13:5619
一种改进的简单的电缆仿真模型
Abstract: Nonideal cable dispersive effects can affect system performance. This application note
2012-10-23 15:19:1272
滤波器设计软件Filter+Solutions10.0
电子发烧友网站提供《滤波器设计软件Filter+Solutions10.0.zip》资料免费下载
2013-03-22 17:53:22120
(Oppenheim)Signals and Systems Solutions(2nd edition)习题答案
2015-12-24 15:04:340
Real_Analog_Solutions_for_Digita_Designers
Real Analog Solutions for Digital Designers嵌入式系统的模拟电路设计,一位技术大牛写的,很实用
2015-12-29 10:53:040
Connecting_Real_People_with_Real_Solutions
Connecting Real People with Real Solutions
2016-01-19 14:11:425
MIPI+Test+Solutions+Overview_Web
MIPI+Test+Solutions+Overview_Webinar
2016-07-22 15:31:1335
Real.Analog.Solutions.for.Digita
Real.Analog.Solutions.for.Digital.Designers
2016-12-28 09:33:360
斯坦福学者提出GIoU,目标检测任务的新Loss
作者做了一系列的实验(针对分割任务和分类任务有一定 loss 的调整设计,不过论文中没有详细给出)结果是 IoU loss 可以轻微提升使用 MSE 作为 loss 的表现,而 GIoU 的提升幅度更大,这个结论在 YOLO 算法和 faster R-CNN 系列上都是成立的
2019-03-11 09:09:357872
Smoke Detection Solutions Frequently Asked Questions
2021-01-28 00:03:317
Solutions For Rapid Prototyping: Answering the Needs of Practicing Engineers
2021-01-28 16:22:340
LTC4412HV: 36V, Low Loss PowerPath Controller in ThinSOT Data Sheet
2021-01-29 08:48:057
LTC4412: Low Loss PowerPath Controller in ThinSOT Data Sheet
2021-01-29 08:50:058
ADMV4530 Board Loss
ADMV4530 Board Loss
2021-01-30 13:19:211
X-WARE IoT PLATFORM Solutions
2021-02-03 13:42:220
HMC815B Return Loss
HMC815B Return Loss
2021-02-04 09:25:070
HMC815B Return Loss
HMC815B Return Loss
2021-03-06 09:10:303
AD9877:混合信号端集顶盒,Cable Modder数据Sheet
2021-04-15 11:46:141
AD9879:混合信号前端盒子,Cable Modder数据Sheet
2021-04-19 20:46:182
CABLE-SMBus-3PINZ、CABLE-SMBus-5PINZ:并行端口到I2C接口电缆评估板数据表
2021-05-16 16:14:121
EVAL-ADUC-CABLE1Z EVAL-ADUC-CABLE1Z评估板
电子发烧友网为你提供ADI(ti)EVAL-ADUC-CABLE1Z相关产品参数、数据手册,更有EVAL-ADUC-CABLE1Z的引脚图、接线图、封装手册、中文资料、英文资料,EVAL-ADUC-CABLE1Z真值表,EVAL-ADUC-CABLE1Z管脚等资料,希望可以帮助到广大的电子工程师们。
2021-08-31 14:00:03
GWU2X Cable驱动安装指南
电子发烧友网站提供《GWU2X Cable驱动安装指南.pdf》资料免费下载
2022-09-19 09:35:366
Pango USB Cable Ⅱ说明书
电子发烧友网站提供《Pango USB Cable Ⅱ说明书.pdf》资料免费下载
2022-09-26 09:21:432
Loss计算详细解析
分类损失(cls_loss):该损失用于判断模型是否能够准确地识别出图像中的对象,并将其分类到正确的类别中。
2023-01-13 14:38:311794
NLP类别不均衡问题之loss大集合
  NLP 任务中,数据类别不均衡问题应该是一个极常见又头疼的的问题了。最近在工作中也是碰到这个问题,花了些时间梳理并实践了下类别不均衡问题的解决方式,主要实践了下“魔改”loss(focal loss, GHM loss, dice loss 等),整理了下。所有的 Loss 实践代码在这里。
2023-01-31 16:52:24536
NLP类别不均衡问题之loss合集
NLP 任务中,数据类别不均衡问题应该是一个极常见又头疼的的问题了。最近在工作中也是碰到这个问题,花了些时间梳理并实践了下类别不均衡问题的解决方式,主要实践了下“魔改”loss(focal loss, GHM loss, dice loss 等),整理了下。所有的 Loss 实践代码在这里:
2023-02-23 14:10:44367
大模型训练loss突刺原因和解决办法
PaLM和GLM130b之前的解决办法是找到loss spike之前最近的checkpoint,更换之后的训练样本来避免loss spike的出现。
2024-01-09 14:20:27356
IGT Solutions宣布 CEO 继任计划
新德里2024年2月15日 /美通社/ -- 全球人工智能驱动的 BPM 和数字服务与解决方案提供商 IGT Solutions 今天宣布,任命凯蒂•施泰因 (Katie Stein) 为公司
2024-02-18 10:12:06330
已全部加载完成
