电子发烧友App
硬声App
电子发烧友网>测量仪表>设计测试>12-Bit Thermometer Using an 8-
收藏
查看更多
dac7571 pdf datasheet (12-BIT
The DAC7571 is a low-power, single channel, 12-bit· Power-On Reset to Zero buffered voltage output
2008-08-06 15:40:1321
ADS7883 pdf datasheet (12-Bit,
The ADS7883 is a 12-bit, 3-MSPS analog-to-digital converter (ADC). The device includes a capacitor
2008-08-19 22:48:1116
鼎阳高分辨率数字示波器 SDS2000X HD系列 12-bit垂直分辨率 500 MHz
全带宽下12-bit高分辨率,体验豪华的小信号分析能力· 12-bit高分辨率ADC采样,更好地呈现波形细节。相比于普通的8-bit示波器256级量化等级,12-bit示波器可达到4096级,是普通
2022-02-24 17:02:49
MAX1211 pdf datasheet (12-Bit,
The MAX1211 is a 3.3V, 12-bit analog-to-digital converter (ADC) featuring a fully differential
2008-10-09 14:58:088
MSC7171 pdf datasheet (12-Bit
It contains a 12-bit shift register and 12 output drivers. Display data is serially written into the internal 12-bit shift register on the rising
2008-10-28 13:36:119
ADS7844 pdf datasheet (12-Bit,
The ADS7844 is an 8-channel, 12-bit sampling analog-to-digital converter (ADC
2008-12-18 15:21:4019
ADS801 pdf datasheet (12-Bit,
The ADS801 is a low power, monolithic 12-bit, 25MHzanalog-to-digital converter utilizing a small
2008-12-18 20:23:3018
ADS7818 pdf datasheet (12-Bit
The ADS7818 is a 12-bit sampling analog-to-digitalconverter (A/D) complete with sample/hold
2008-12-18 20:51:2126
ADS7841 pdf datasheet (12-Bit,
The ADS7841 is a 4-channel, 12-bit sampling analogto-digital converter (ADC) with a synchronous
2008-12-19 19:18:1665
ADS1286 pdf datasheet (12-Bit
The ADS1286 is a 12-bit, 20kHz analog-to-digitalconverter with a differential input and sample
2008-12-19 19:20:1235
AD574A pdf datasheet (12-Bit A
The AD574A is a complete 12-bit successive-approximationanalog-to-digital converter with 3-state
2008-12-21 15:37:1150
HSP45102 pdf datasheet(12-Bit
and 12-bit output.With over 69dB of spurious free dynamic range and worstcase frequency resolution of 0.009Hz, the NCO12 provide
2009-01-06 16:27:008
80C88 pdf datasheet (CMOS 8-/1
The Intersil 80C88 high performance 8-/16-bit CMOS CPU ismanufactured using a self-aligned silicon
2009-01-08 18:27:4112
HI5800 pdf datasheet (12-Bit,
The HI5800 is a monolithic, 12-bit, sampling Analog-to-Digital Converter fabricated in the HBC10
2009-01-08 18:28:2216
ISL76161 pdf datasheet (12-Bit
12-Bit, +3.3V, 130MSPS, High Speed D/A ConverterThe ISL76161 is a 12-bit, 130MSPS (Mega-Samples
2009-01-18 22:20:1315
SIGLENT鼎阳/SDS2000X HD高分辨率示波器12-bit
2022-07-22 10:08:35
ADUC814,pdf datasheet (12-Bit
The ADuC814 is a fully integrated 247 kSPS, 12-bit data acquisitionsystem incorporating a high
2009-09-04 09:53:4017
AD7329,pdf datasheet (12-Bit P
The AD73291 is an 8-channel, 12-bit plus sign successiveapproximation ADC designed on the iCMOS
2009-09-09 08:16:0510
Layout Tips for 12-Bit A/D Con
Layout Tips for 12-Bit A/D Converter Application:This Application Note originally started
2009-09-18 09:29:310
AD5516,pdf datasheet (12-Bit V
The AD5516 is a 16-channel, 12-bit voltage-output DAC. Theselected DAC register is written to via
2009-09-21 08:58:3411
LM12L458,pdf datasheet (12-Bit
self-calibrating (correctinglinearity and zero errors) 13-bit (12-bit + sign) analogto-digital converter (ADC) and sample-and-hol
2009-10-12 08:08:5210
AD6652,pdf datasheet (12-Bit,
The AD6652 is a mixed-signal IF to baseband receiver consisting of dual 12-bit 65 MSPS ADCs
2009-10-24 11:29:0844
AD7298,pdf datasheet (12-Bit S
The AD7298 is a 12-bit, high speed, low power, 8-channel, successive approximation ADC
2009-12-07 15:52:3619
AD7170,pdf datasheet (12-Bit L
The AD7170 is a very low power 12-bit analog-to-digital converter (ADC). It contains a precision
2009-12-07 16:18:3929
10-/12-Bit ADCs in 6-Lead SC70
10-/12-Bit ADCs in 6-Lead SC70GENERAL DESCRIPTIONThe AD7910/AD7920 are, respectively, 10-bit
2010-04-07 10:14:5315
DS18B20 pdf,datasheet
Thermometer provides 9 to 12-bit (configurable) temperature readings which indicate the temperature o
2010-04-26 10:45:1057
ADS7862 (Dual 500kHz,12-Bit, 2
The ADS7862 is a dual 12-bit, 500kHz analog-to-digital converter (A/D) with 4 fully differential
2010-06-01 16:56:4616
ADS7861 (Dual, 500kSPS,12-Bit,
The ADS7861 is a dual, 12-bit, 500kHz, Analog-to-Digital (A/D) converter with four fully
2010-06-01 17:10:3216
TLV2553-Q1,pdf (12-Bit 200-ksp
The TLV2553 is a 12-bit switched-capacitor successive-approximation analog-to-digital converter
2010-06-04 15:32:0222
TLV2553,pdf (12-Bit, 200 KSPS,
The TLV2553 is a 12-bit, switched-capacitor, successive-approximation, analog-to-digital converter.
2010-06-04 15:35:2314
TLV2543C/TLV2543,pdf (12-Bit A
The TLV2543C and TLV2543I are 12-bit, switched-capacitor, successive-approximation
2010-06-04 16:40:2546
TLC2558,pdf (12-Bit, 400 KSPS,
The TLC2558 and TLC2554 are a family of high-performance, 12-bit low power, 1.6 us, CMOS
2010-06-05 15:16:1023
TLC2554,pdf(5-V, 12-Bit, 400 K
2010-06-05 16:12:5433
TLC2543-Q1,pdf(12-Bit Analog-t
The TLC2543 is a 12-bit, switched-capacitor, successive-approximation, analog-to-digital
2010-06-05 16:35:1410
TLC2543,pdf(12-Bit Analog-to-D
The TLC2543C and TLC2543I are 12-bit, switched-capacitor, successive-approximation
2010-06-05 16:41:2738
THS1230,pdf(3.3-V, 12-Bit, 30-
The THS1230 is a CMOS, low power, 12-bit, 30 MSPS analog-to-digital converter (ADC) that operates
2010-06-05 16:52:5024
THS1215,pdf(3-3-V, 12-Bit, 15
The THS1215 is a CMOS, low power, 12-bit, 15 MSPS analog-to-digital converter (ADC) that operates
2010-06-05 17:13:5025
THS1209,pdf(THS1209: 12-Bit, 2
The THS1209 is a CMOS, low-power, 12-bit, 8 MSPS analog-to-digital converter (ADC). The speed
2010-06-05 17:17:3318
THS12082,PDF(12-Bit, 8 MSPS, S
The THS12082 is a CMOS, low-power, 12-bit, 8 MSPS analog-to-digital converter (ADC). The speed
2010-06-05 17:42:3931
THS1207,pdf(12-Bit, 4 Analog I
The THS1207 is a CMOS, low-power, 12-bit, 6 MSPS analog-to-digital converter (ADC). The speed
2010-06-05 17:51:0625
THS1206,pdf(THS1206: 12-Bit, 6
The THS1206 is a CMOS, low-power, 12-bit, 6 MSPS analog-to-digital converter (ADC). The speed
2010-06-05 17:54:0827
ADS8512 ,pdf(12-Bit, 40kSPS, L
The ADS8512 is a complete low-power, single 5-V supply, 12-bit sampling analog-to-digital
2010-06-06 14:32:5717
ADS807,pdf(ADS807: 12-Bit, 53M
The ADS807 is a high-speed, high dynamic range, 12-bit pipelined Analog-to-Digital (A/D) converter.
2010-06-06 14:49:0413
ADS804,pdf(ADS804: 12-Bit, 10M
The ADS804 is a high-speed, high dynamic range, 12-bit, pipelined Analog-to-Digital
2010-06-06 14:51:2435
ADS803,pdf(ADS803: 12-Bit, 5MH
The ADS803 is a high-speed, high dynamic range, 12-bit pipelined Analog-to-Digital (A/D) converter.
2010-06-06 14:53:3330
ADS802,pdf(12-Bit, 10MHz Sampl
The ADS802 is a low-power, monolithic 12-bit, 10MHz Analog-to-Digital (A/D) converter utilizing
2010-06-06 14:55:4720
ADS800,pdf(12-Bit, 40MHz Sampl
The ADS800 is a low power, monolithic 12-bit, 40MHz Analog-to-Digital (A/D) converter utilizing
2010-06-06 14:58:2116
ADS7924,pdf(2.2V, 12-Bit, 4-Ch
The ADS7924 is a four-channel, 12-bit, analog-to-digital converter (ADC) with an I2C™
2010-06-06 15:01:4641
ADS7882,pdf(12-Bit, 3-MSPS, Lo
The ADS7882 is a 12-bit 3-MSPS A-to-D converter with 2.5-V internal reference. The device includes
2010-06-06 15:04:2827
DAC5578,DAC6578,DAC7578,pdf(8/10/12-Bit, 8-Channel, Ultra-Lo
The DAC5578, DAC6578, and DAC7578 are low-power, voltage-output, eight-channel, 8-/10-/12-bit
2010-06-07 15:12:1256
TLV5614IYZ,PDF(12-Bit, Quad Ch
The TLV5614IYZ is a quadruple, 12-bit, voltage output digital-to-analog converter (DAC
2010-06-08 10:20:4513
TLV5613,pdf(12-Bit Parallel Di
The TLV5613 is a 12-bit voltage output digital-to-analog converter (DAC) with a 8-bit
2010-06-08 10:24:1825
THS5661A,pdf(12-Bit, 125 MSPS,
The THS5661A is a 12-bit resolution digital-to-analog converter (DAC) specifically optimized
2010-06-08 10:37:5330
DAC8043,pdf(CMOS 12-Bit Serial
The DAC8043 is a 12-bit current output multiplying digital-to-analog converter (DAC
2010-06-08 10:45:2135
DAC7822,pdf(Dual 12-Bit, Paral
The DAC7822 is a dual, CMOS, 12-bit, current output digital-to-analog converter (DAC). This device
2010-06-08 10:48:376
DAC7821,pdf(12-Bit, Parallel I
The DAC7821 is a CMOS 12-bit current output digital-to-analog converter (DAC). This device operates
2010-06-08 10:50:1135
DAC7728,pdf(Octal, 12-Bit, Low
The DAC7728 is a low-power, octal, 12-bit digital-to-analog converter (DAC). With a 5V reference
2010-06-08 10:57:4112
DAC7718,pdf(Octal, 12-Bit, Low
The DAC7718 is a low-power, octal, 12-bit digital-to-analog converter (DAC). With a 5V reference
2010-06-08 11:00:5313
DAC7716,pdf(Quad, 12-Bit, High
The DAC7716 is a high-accuracy, quad-channel, 12-bit digital-to-analog converter (DAC
2010-06-08 11:03:109
DAC7678,pdf(12-bit, Octal-Chan
The DAC7678 is a low-power, voltage-output, eight-channel, 12-bit digital-to-analog converter (DAC
2010-06-08 11:09:2026
DAC7624,DAC7625,pdf(12-Bit Qua
DESCRIPTIONThe DAC7624 and DAC7625 are 12-bit quad voltageoutput digital-to-analog converters
2010-06-08 11:11:4819
DAC7621,pdf(12-Bit, Parallel I
DESCRIPTIONThe DAC7621 is a 12-bit digital-to-analog converter(DAC) with guaranteed 12-bit
2010-06-08 11:14:0537
DAC7613,pdf(12-Bit, Voltage Ou
DESCRIPTIONThe DAC7613 is a 12-bit, voltage output digital-to-analog converter with guaranteed
2010-06-08 11:28:2322
DAC7574,pdf(Quad 12-Bit Low Po
The DAC7574 is a low-power, quad channel, 12-bit buffered voltage output DAC. Its on-chip precision
2010-06-08 11:30:2838
DAC7565,pdf(12-Bit, Quad, Ultr
The DAC7565 is a low-power, voltage-output, four-channel, 12-bit digital-to-analog converter (DAC
2010-06-08 11:38:5026
DAC7564,pdf(12-Bit, Quad, Ultr
The DAC7564 is a low-power, voltage-output, four-channel, 12-bit digital-to-analog converter (DAC
2010-06-08 11:40:2932
DAC7558,pdf(12-Bit Octal Ultra
The DAC7558 is a 12-bit, octal-channel, voltage output DAC with exceptional linearity
2010-06-08 11:42:1628
DAC7553,pdf(12-Bit Dual Ultral
The DAC7553 is a 12-bit, dual-channel, voltage-output DAC with exceptional linearity
2010-06-08 11:46:3321
AC7552,pdf(12-Bit Dual Ultralo
The DAC7552 is a 12-bit, dual-channel, voltage-output DAC with exceptional linearity
2010-06-08 11:47:4433
DAC5662A,PDF(Dual, 12-Bit, 275
The DAC5662A is a monolithic, dual-channel 12-bit high-speed digital-to-analog converter (DAC
2010-06-08 11:58:5923
SN74ALVCH162260,pdf(12-BIT TO
This 12-bit to 24-bit multiplexed D-type latch is designed for 1.65-V to 3.6-VCC operation.
2010-07-30 16:53:437
SN74ALVCH16260,pdf(12-BIT TO 2
This 12-bit to 24-bit multiplexed D-type latch is designed for 1.65-V to 3.6-V VCC operation.
2010-07-30 16:57:1713
SN74ALVCH162268,pdf(12-BIT TO
This 12-bit to 24-bit registered bus exchanger is designed for 1.65-V to 3.6-V VCC operation.
2010-08-21 16:12:4020
SN74ALVCH16269,pdf(12-BIT TO 2
2010-08-21 16:14:0925
SN74ALVCH16270,pdf(12-BIT TO 2
2010-08-21 16:16:2025
SN74ALVCH16271,pdf(12-BIT TO 2
This 12-bit to 24-bit bus exchanger is designed for 1.65-V to 3.6-V VCC operation.
2010-08-21 16:18:0430
SN74ALVCHR16269A,pdf(12-BIT TO
2010-08-21 16:32:4233
12-Bit Thermometer Using an 8-Bit µC and Assembler This application note explains how to implement
2009-03-31 22:25:39730
12-Bit Sampling A/D Converter
to automatically control the conversion the MAX190 12-bit SAR analog-to-digital converter (ADC). The delay between conversions can be program
2009-04-16 17:40:401267
12位采样A / D转换器可节省电力-12-Bit Samp
to automatically control the conversion the MAX190 12-bit SAR analog-to-digital converter (ADC). The delay between conversions can be programed
2009-05-08 10:03:36739
AD7170: 12-Bit Low Power ΣW
AD7170: 12-Bit Low Power Σ−Δ ADC  The AD7170 is a very low power 12-bit
2009-12-01 16:20:39680
AD674B/AD774B完整的12位模数转换器
The AD674B and AD774B are complete 12-bit successiveapproximation analog-to-digital converters
2017-09-29 14:37:054
双8/10/12位高带宽的乘法DAC并行接口ad5428/AD5440/ad5447数据表
The AD5428/AD5440/AD54471 are CMOS, 8-, 10-, and 12-bit, dual-channel, current output digital-to-analog converters (DACs), respectively.
2017-10-13 09:39:368
双8/10/12位高带宽的乘法DAC串行接口AD5429/AD5439/AD5449数据表
The AD5429/AD5439/AD54491 are CMOS, 8-, 10-, and 12-bit, dual-channel, current output digital-to-analog converters (DAC), respectively.
2017-10-13 09:42:293
3V并行输入双12位/10位数模转换器AD7396/AD7397数据表
The AD7396/AD7397 series of dual, 12-bit and 10-bit voltageoutput digital-to-analog converters
2017-10-14 15:13:594
ADuCM420: Precision Analog Microcontroller, 12-Bit Analog Input/Output with MDIO Interface, Arm Cortex-M33 Data Sheet
2021-01-27 20:20:178
AD9207: 12-Bit, 6 GSPS, JESD204B/C Dual Analog-to-Digital Converter Preliminary Data Sheet
2021-01-27 21:51:237
AD9209: Quad, 12-Bit, 4 GSPS RF ADC Preliminary Data Sheet
2021-01-27 21:53:230
LTC2311-12: 12-Bit + Sign, 5Msps Differential Input ADC with Wide Input Common Mode Range Data Sheet
2021-01-28 00:43:330
AD7938-6: 8-Channel, 625 kSPS, 12-Bit Parallel ADCs with a Sequencer Data Sheet
2021-01-28 11:03:131
AD9228: Quad, 12-Bit, 40/65 MSPS Serial LVDS 1.8 V A/D Converter Data Sheet
2021-01-28 14:17:2510
AD7938/AD7939: 8-Channel, 1.5 MSPS, 12-Bit and 10-Bit Parallel ADCs with a Sequencer Data Sheet
2021-01-28 14:50:281
LTC2666: Octal 16-Bit/12-Bit ±10V VOUT SoftSpan DACs with 10ppm/°C Max Reference Data Sheet
2021-03-10 14:03:399
AD9005B:12-BIT,10MSPS A/D Convoluter数据Sheet
2021-04-30 16:43:0014
鼎阳科技为工程师提供从70MHz到4GHz带宽的12-bit示波器可选项
2023年9月26日,鼎阳科技发布两款高分辨率示波器,分别是SDS3000X HD以及新款SDS1000X HD。一直以来,鼎阳科技的12-bit高分辨率示波器凭借其4096级量化等级,波形还原
2023-09-27 09:57:40498
8-气流、12/16-比位伏 ADI
电子发烧友网为你提供ADI(ADI)8-气流、12/16-比位伏相关产品参数、数据手册,更有8-气流、12/16-比位伏的引脚图、接线图、封装手册、中文资料、英文资料,8-气流、12/16-比位伏真值表,8-气流、12/16-比位伏管脚等资料,希望可以帮助到广大的电子工程师们。
2023-10-08 16:14:02
AD7927: 8-Channel, 200 kSPS, 12-Bit ADC with Sequencer in 20-Lead TSSOP Data Sheet AD7927: 8-Channel, 200 kSPS, 12-Bit ADC with Sequencer in
电子发烧友网为你提供ADI(ADI)AD7927: 8-Channel, 200 kSPS, 12-Bit ADC with Sequencer in 20-Lead TSSOP Data
2023-10-12 18:50:13
AD9207: 12-Bit, 6 GSPS, JESD204B/JESD204C Dual ADC Data Sheet AD9207: 12-Bit, 6 GSPS, JESD204B/JESD204C Dual ADC Data Sheet
电子发烧友网为你提供ADI(ADI)AD9207: 12-Bit, 6 GSPS, JESD204B/JESD204C Dual ADC Data Sheet相关产品参数、数据手册,更有AD9207
2023-10-16 19:02:55
AD9082: MxFE® Quad, 16-Bit, 12 GSPS RF DAC and Dual, 12-Bit, 6 GSPS RF ADC Data Sheet AD9082: MxFE® Quad, 16-Bit, 12 GSPS RF DAC and Dual, 1
电子发烧友网为你提供ADI(ADI)AD9082: MxFE® Quad, 16-Bit, 12 GSPS RF DAC and Dual, 12-Bit, 6 GSPS RF ADC Data
2023-10-17 18:35:16
鼎阳科技发布8GHz带宽12-bit高分辨率示波器
鼎阳科技近日发布了其最新款示波器——SDS7804A,这款示波器以其8GHz的带宽和12-bit的高分辨率特性,为国产示波器树立了全新的标杆。这款高性能示波器不仅具备高精度的12-bit ADC,还拥有1Gpts的存储深度,使其在捕获和分析信号时具有出色的性能。
2024-01-29 10:19:34216
已全部加载完成
