MAX9610 - 1μA, μDFN/SC70, Lithium-Ion Battery, Precision Current-Sense Amplifier - Maxim Integrated Products
2022-11-04 17:22:44
Current Sense Amplifier 1 Circuit 6-µDFN(2x2)
2023-03-23 08:24:15
HIGH-SIDE CURRENT-SENSE AMP
2023-03-27 13:31:11
2023-03-27 13:47:19
2023-03-27 13:23:39
2023-03-27 13:29:38
2023-03-27 13:22:19
2023-03-28 02:08:43
2023-03-27 12:05:58
2023-03-27 12:18:47
2023-03-27 13:38:24
2023-03-27 13:29:35
x 1.6mm WLP package (0.69mm max height). MAX8989关键特性 PA Step-Down Converter 25µs (typ
2011-06-06 09:47:14
MAX9611 - High-Side, Current-Sense Amplifiers with 12-Bit ADC and Op Amp/Comparator - Maxim Integrated Products
2022-11-04 17:22:44
MAX9922 - Ultra-Precision, High-Side Current-Sense Amplifiers - Maxim Integrated Products
2022-11-04 17:22:44
MAX9923 - Ultra-Precision, High-Side Current-Sense Amplifiers - Maxim Integrated Products
2022-11-04 17:22:44
the ESD-protection diodes. This circuit protects a particular high-side current-sense amplifier (MAX
2011-08-21 16:49:34
High-Side Current Sensing: Difference Amplifier vs. Current-Sense Amplifier本文原文的PDF下载 §01 高端电流检测 在
2021-12-30 07:03:09
= 280mA, COUT = 22µF, RSENSE = 0.33Ω.Figure 3. PSSR with incorrect current-sense configuration.The
2022-09-20 21:35:32
, Capacitor, and Sense Resistor的值。在SLUA605应用笔记里,BQ24650的Fast-chargecurrent Max 4A. 请确认BQ24650是否支持20A Charge Current?如何配置?
2019-03-27 09:23:06
The MAX9928/MAX9929 low-cost, uni-/bidirectional, high-side, current-sense amplifiers are ideal
2008-08-18 12:55:0240 The MAX4069–MAX4072 low-cost, bidirectional, highside,current-sense amplifiers are ideal
2008-09-11 23:37:2139 The MAX4069–MAX4072 low-cost, bidirectional, highside,current-sense amplifiers are ideal
2008-09-11 23:38:5862 , Current-Sense Amplifiers)
The MAX9928/MAX9929 low-cost, uni-/bidirectional, high-side, current-sense amplifiers are ideal for monitoring b
2008-10-01 11:21:5838 The MAX9938 high-side current-sense amplifier offersprecision accuracy specifications of VOS less
2008-10-01 23:14:4615 adapter. It integrates a battery disconnect switch, current-sense circuit, PMOS pass element, and thermal-regulation circuitry, while elimin
2008-10-09 08:24:4518 or ACadapter. It integrates a battery disconnect switch, current-sense circuit, PMOS pass element, and thermalregulationcircuitry,
2008-10-24 13:41:0428 ) that is ideal for conditioning a variety of wide dynamic range signals such as those found in motor current-sense, medical instrumentation, and sonar da
2008-11-27 11:38:2526 The MAX9610 high-side current-sense amplifier offers precision accuracy specifications of VOS less
2008-12-02 23:11:0610 wireless infrastructure equipment. Each controller includes a high-side current-sense amplifier with programmable gains of 2, 10, and 25 to mon
2008-12-10 11:48:4029 in cellular base stations. Each device includes a high-side current-sense amplifier with programmable gains of 2, 10, and 25 to monitor LDMOS drain c
2009-03-02 14:47:0523 for automotive interior dome, map, and courtesy light applications. An EEPROM-programmable LED current-sense reference simplifies productio
2009-03-14 19:30:0729 The MAX9922/MAX9923 ultra-precision, high-side current-sense amplifiers feature ultra-low offset
2009-03-31 11:00:3319 current-sense amplifiers are available in space-saving packages. They feature buffered voltage outputs that eliminate the need for gain-set
2009-05-29 11:10:1919 voltages. The MAX16065/MAX16066 can also accurately monitor (±2.5%) one current channel using a dedicated high-side current-sense amplifier. The
2009-08-22 08:21:5316 The ADM4073 is a low cost, high-side, current-sense amplifier ideal for small portable applications
2009-08-25 14:52:2616 Ultraprecise Current Sense Amplifi er Dramatically Enhances Effi ciency and Dynamic Range:Accurate
2009-09-23 22:55:428 MAX9610高精度高边电流检测放大器的VOS小于500µV (最大值)、增益误差小于0.5% (最大值)。器件具有1µA超低静态电源电流。MAX9610采用微型1mm x 1.5mm µDFN封装
2023-01-06 09:37:18
The MAX16070/MAX16071 can also accurately monitor (±2.5%) one current channel using a dedicated high-side current-sense amplifier. The MAX16070 m
2009-11-16 08:31:2218 The MAX9634 high-side current-sense amplifier offers precision accuracy specifications of VOS less
2009-11-16 16:10:3536 The MAX9934** high-precision low-voltage high-side current-sense amplifier is ideal for both
2009-11-16 17:59:1516 The MAX9918/MAX9919/MAX9920 are single-supply high-accuracy current-sense amplifiers with a high
2009-11-26 09:46:4551 The MAX4373/MAX4374/MAX4375 low-cost micropower high-side current-sense supervisors contain
2010-01-01 18:11:0441 LEDs or similar. The LED current is set with the external sense resistor (RS) and is directly regulated by the feedback pin (FB)
2010-10-01 23:45:3923 LEDs or similar. The LED current is set with the external sense resistor (RS) and is directly regulated by the feedback pin (FB)
2010-10-01 23:50:1322 MAX9928, MAX9929 -0.1V至+28V输入范围、微功耗、单/双向电流检测放大器
2008-10-01 11:26:19628 Monitoring
The MAX9928/MAX9929 are low-cost, bidirectional current-sense amplifiers.
These dev
2008-10-01 12:03:59956 DS2741 Current Monitor and Accumulator with Integrated Sense Resistor
DS2741概述
The DS2741 current monitor/accumulator is a complete current-s
2008-10-22 10:23:04850 MAX9610 高精度电流检测放大器、1µA、µDFN/SC70封装、用于锂离子电池
MAX9610 概述
2008-12-02 23:16:21806 Abstract: This circuit modifies a standard 32V high-side current monitor to measure load current
2009-04-24 14:57:201111 Abstract: Using a current-sense amplifier, a high-side MOSFET driver, and a latching voltage
2009-04-29 11:10:25589 Abstract: This application note describes the use of a current-sense amplifier to monitor the load
2009-04-29 11:12:11840 and charge-termination accuracy of the MAX1737 lithium-ion (Li+) battery charger. The MAX1737 current-sense is more accurate than stated in the data sheet, b
2009-04-30 10:35:471439 current-sense amplifier and differential amplifier are combined to produce a single output voltage that indicates magnitude and direction o
2009-04-30 11:55:211107 current-sense amplifier and differential amplifier are combined to produce a single output voltage that indicates magnitude and direction o
2009-05-04 08:45:241051 current sense amplifiers to work at up to 300V. The MAX471 and MAX472 are complete bi-directional high-side current sense
2009-05-04 08:51:062013 to a high-side current-sense amplifier. This modification enables that amplifier to sense currents down to 0V common-mode inputs. The circuit c
2009-05-06 11:12:161148 current sense amplifiers to work at up to 300V. The MAX471 and MAX472 are complete bi-directional high-side current sense
2009-05-06 11:29:051593 Abstract: The MAX4374 high-side current sense amplifier with two internal comparators is used
2009-05-06 11:36:341002 In recent years, tight tolerances for current sharing have made discrete current-sense circuit designs a formidable challenge. This applica
2009-05-06 11:38:061053 regulator by using a MAX4173H current-sense amplifier. Additional Information:
Quick View Data Sheet for the MAX16
2009-05-06 11:40:32940 Abstract: Using a current-sense amplifier, a high-side MOSFET driver, and a latching voltage
2009-05-06 11:41:48782 Abstract: This circuit modifies a standard 32V high-side current monitor to measure load current
2009-05-06 11:47:041809 to a high-side current-sense amplifier. This modification enables that amplifier to sense currents down to 0V common-mode inputs. The circuit c
2009-05-07 08:54:422023 regulator by using a MAX4173H current-sense amplifier. Additional Information:
2009-05-07 10:11:371033 the use of a current-sense amplifier along with an optocoupler to extend the operating voltage range up to 1,000 volts for high
2009-07-18 10:36:131117 current-sense amplifier, a circuit can be designed with a voltage range to 28V. All that is needed is a
2009-08-31 17:39:251447 MAX9918, MAX9919, MAX9920 -20V至+75V输入范围、高精度单/双向电流检测放大器
概述
The MAX9918/MAX9919/MAX9920 are single-supply, high-accuracy current-sense ampli
2009-11-26 09:49:112475 current-sense supervisors contain a high-side current-sense amplifier, bandgap reference, and comparator with latching outp
2010-01-01 18:14:331401 It consists of a charge-pump voltage doubler (U1), a current-sense amplifier (U2), and two n-channel MOSFETs. The sense-resistor value determi
2010-11-08 08:21:521328
A combination current-sense amplifier and multiplier (MAX4211F) senses both the current through a
2010-12-04 11:37:211196 You can shut down a current-sense amplifier by connecting an NMOS transistor in its ground path
2010-12-12 12:04:211483 The MAX4372 low-cost, precision, high-side current-sense amplifier is available in a tiny
2011-09-19 11:22:0942 for use with the MAX16946 remoteantenna regulator and current-sense amplifier (CSA), ensuring that automobile antenna-detection subsystems meet th
2012-02-06 11:33:0264 The MAX9928/MAX9929 low-cost, uni-/bidirectional,high-side, current-sense amplifiers are ideal
2012-05-09 12:02:3123 The MAX4073 low-cost, high-side current-sense amplifierfeatures a voltage output that eliminates
2012-09-27 16:51:3425 Abstract: This application note discusses differences between current-sense
2012-12-04 11:09:1565 is programmableby means of an external current-sense resistor. TheMAX16824 features three PWM inputs
2013-01-24 15:57:2131 MAX44285 Dual-Channel, High-Precision, High-Voltage, Current-Sense Amplifier.
2014-02-07 22:01:042182 Current- Feedback Op Amp Applications Circuit Guide
2017-03-24 16:20:241 current-sense amplifier and differential amplifier are combined to produce a single output voltage
2017-04-07 09:22:407 The MAX4069–MAX4072 low-cost, bidirectional, highside, current-sense amplifiers are ideal
2017-10-14 11:11:4210 LTC2066/LT1389 Demo Circuit - Precision Ultralow Power High Side Current Sense
2021-02-01 14:38:281 LTC2063 Demo Circuit - Low Power 4-20mA Current Loop Sense Amplifier
2021-02-03 11:55:1617 LT1997-3 Demo Circuit - Single Supply Current Sense
2021-02-19 10:42:130 LTC3829 Project - 3-Phase, Single Output Synchronous Step-Down Supply with Vout Remote Sense & Inductor DCR Current Sensing (7-14V to 1.5V @ 60A)
2021-02-22 13:14:258 电子发烧友网为你提供Maxim(Maxim)MAX9610TELT+T相关产品参数、数据手册,更有MAX9610TELT+T的引脚图、接线图、封装手册、中文资料、英文资料,MAX9610TELT+T真值表,MAX9610TELT+T管脚等资料,希望可以帮助到广大的电子工程师们。
2022-11-22 19:38:43
电子发烧友网为你提供Maxim(Maxim)MAX9610FELT+T相关产品参数、数据手册,更有MAX9610FELT+T的引脚图、接线图、封装手册、中文资料、英文资料,MAX9610FELT+T真值表,MAX9610FELT+T管脚等资料,希望可以帮助到广大的电子工程师们。
2022-11-22 19:49:34
电子发烧友网为你提供Maxim(Maxim)MAX9610EVKIT+相关产品参数、数据手册,更有MAX9610EVKIT+的引脚图、接线图、封装手册、中文资料、英文资料,MAX9610EVKIT+真值表,MAX9610EVKIT+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-02-06 20:14:44
9UMS9610 数据表
2023-04-19 19:48:130 电子发烧友网为你提供Maxim(Maxim)MAX9610FEXK+相关产品参数、数据手册,更有MAX9610FEXK+的引脚图、接线图、封装手册、中文资料、英文资料,MAX9610FEXK+真值表,MAX9610FEXK+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-08-24 18:49:08
电子发烧友网为你提供Maxim(Maxim)MAX9610TEXK+相关产品参数、数据手册,更有MAX9610TEXK+的引脚图、接线图、封装手册、中文资料、英文资料,MAX9610TEXK+真值表,MAX9610TEXK+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-08-24 18:53:27
电子发烧友网为你提供ADI(ADI)MAX44284: 36V, Input Common-Mode, High-Precision, Low-Power Current-Sense
2023-10-13 18:35:03
电子发烧友网为你提供ADI(ADI)MAX22205: 65V, 7.6A High Current Single H-Bridge with Integrated Current Sense
2023-10-13 19:22:07
电子发烧友网为你提供ADI(ADI)MAX22204: 65V, 3.8A Stepper Motor Driver with Integrated Current-Sense and 128
2023-10-13 19:22:27
麒麟9610A和高通8155性能对比 算力:麒麟9610A和高通8155的算力都达到了200k DMIPS。这意味着它们在处理计算密集型任务方面具有相似的性能。 工艺制程:麒麟9610A采用了国产
2023-10-16 14:49:234468 电子发烧友网为你提供ADI(ADI)MAX40080: Precision, Fast Sample-Rate, Digital Current-Sense Amplifier Data Sheet
2023-10-16 18:38:32
电子发烧友网为你提供ADI(ADI)MAX49921: 0 to 70V, High-Precision Current-Sense Amplifier Data Sheet相关产品参数、数据手册
2023-10-16 18:57:04
电子发烧友网为你提供ADI(ADI)MAX9634: nanoPower, 4-Bump UCSP/SOT23, Precision Current-Sense Amplifier Data
2023-10-16 19:17:55
Current Sense Data Sheet相关产品参数、数据手册,更有MAX22203: 65V, 3.8A Dual Brushed or Single Stepper Motor Driver
2023-10-17 18:41:06
查看更多
