Abstract: This document covers the three most popular topologies of voltage references. These include bandgap and buried zener topologies in three-terminal series voltage references and zener topologies in two-terminal shunt voltage references. Also demystified are the definitions of common voltage reference parameters. The first considerations in choosing a voltage reference are output voltage and initial accuracy. Often overlooked, however, are the various other data-sheet parameters that can assume major importance in specific applications. The following discussion of voltage-reference basics will help you better understand the performance parameters associated with the most common voltage-reference topologies: the two-terminal shunt and the three-terminal series designs. Two-Terminal (Shunt) ReferenceAs its name implies, the shunt reference operates in parallel with its load (Figure 1). It can be viewed as a voltage-controlled current sink in which the controlling voltage is applied to its input terminal. With no load applied, the shunt reference sinks just enough current so that the voltage drop across R1 produces the desired output voltage (VIN - IREFR1 = VREF). If, for example, VIN = 6.0V and the desired VREF is 5.0V, the reference IREF creates a 1.0V drop across R1. The reference then makes IREF adjustments as necessary to maintain 5.0V across its input.![]() Figure 1. The shunt reference is connected in parallel with its load. Now apply a load to the reference. IREF no longer equals IR1, because load current (IL) produces part of the voltage drop across R1. The reference automatically reduces its sink current by the amount IL. Thus, the total current through R1 doesn't change (IREF + IL equals the original IR1). IR1 is shunted between reference and load, hence the name "shunt reference." A shunt reference regulates the output voltage by adjusting its sink current to oppose changes in load current. Three-Terminal (Series) ReferenceThe series reference operates in series with its load (Figure 2). It can be viewed as a voltage-controlled resistance in which VOUT controls an internal resistance between the reference's input and output terminals. A series reference regulates by creating a voltage drop between its input and output, which is equal to the product of the load current and the controlled internal resistance. With no load applied, the series reference draws a small amount of current (IQ) through the internal resistance (R) to drop a voltage between input and output necessary to produce the correct VOUT.![]() Figure 2. A series reference (its regulating part) is connected in series with its load. As load current increases, the reference maintains the desired output voltage by changing R as required to produce the correct drop between input and output. Applying Ohm's Law, one notes that to maintain a constant drop between input and output, R must decrease as IOUT increases. Parameter-Measurement Units for ReferencesThe units that specify parameters such as accuracy differ among the various manufacturers. For specifying accuracy, the units in common usage include parts per million (ppm), percentage (%), and voltage (V). All are acceptable, but to make "apples-to-apples" comparisons you must be able to convert one unit to any other. These relationships are clarified below.The most common means for stating reference accuracy is a percent of the nominal value, which isn't even a unit. It probably follows the convention for expressing tolerance on resistors, capacitors, and inductors. Typical percent-accuracy specifications for references are 1%, 1.5%, 2%, 5%, etc. Although percent accuracy is fine for comparing one reference with another, it does not provide specific information on how much the reference voltage deviates. What really matters is the variation in volts. To determine the voltage deviation of a reference specified in percent accuracy, you multiply the nominal output voltage of the reference by the percent accuracy and divide by 100. For example, a 2.5V reference accurate to ±1.5% has a deviation of Because the reference error can be above or below nominal, the total deviation is twice this value, or 75mV. The total output voltage variation equals the nominal voltage plus or minus the error voltage: Knowing these voltage limits for the reference gives you specific design boundaries for the circuitry supported by the reference. Another reference-accuracy unit found in data sheets is parts per million, more commonly abbreviated "ppm." This unit is typically used to specify temperature coefficients and other parameters that change very little under varying conditions. For a 2.5V reference, 1ppm is one-millionth of 2.5 volts, or 2.5 microvolts. If the reference is accurate to within 10ppm (extremely good for any reference), its output tolerance is as follows:
Converting this to voltage accuracy,
Converting to percent, Use of the term "bits" as a unit, as in "16-bit reference," is somewhat confusing. Does it represent an actual measurement of accuracy, or does it mean the reference is accurate enough for a 16-bit ADC? A 16-bit reference could be accurate to 1LSB or 2LSBs, so it cannot necessarily be considered sufficient for a 16-bit system. On the other hand, a reference "accurate to 16 bits" is specified with hard numbers. If the unit is specified by an actual measurement, then "accurate to 16 bits" is simply the value of the parameter divided by the claimed bit accuracy expressed in decimal form. For example, a 2.5V reference, claimed to be 16-bit accurate (another extremely accurate tolerance for any reference), should deviate by no more than the decimal equivalent of 16 bits: 216 = 65536. Therefore, 1 bit is 1/65536 of the total value. In this case, 2.5/65536 ≈ 38µV. If we assume 1-bit accuracy (± 1LSB), the output voltage can be 1 bit higher or lower than nominal, i.e., ±38µV. Converting to voltage accuracy,
Typical Parameters of Importance for ReferencesInitial accuracy speaks for itself. If you take a part off the shelf, connect it in a test circuit, and measure the output voltage, the measured value should be within the initial-accuracy tolerance specified in the data sheet. This spec is usually for room temperature only, and it provides a starting point for most of the other specifications.Temperature coefficient is the deviation of reference output voltage due to a change in the ambient or package temperature. Depending on the device structure and the way its output voltage is trimmed during the initial calibration, this output-voltage deviation can be positive (increasing with increasing temperature) or negative (decreasing with increasing temperature). By analogy, consider a simple resistive voltage divider (Figure 3A). Voltage at the common point (VOUT) is a fraction of the applied voltage VIN, equal to the ratio of the values of the two resistors. Both resistors change with temperature by the same percentage, maintaining a constant ratio, so VOUT also remains constant. ![]() Figure 3. This simple resistor-divider analogy represents a voltage reference unloaded (A) and loaded (B). Note that current flowing through the resistors varies with the temperature and any leakage current from the common point of the divider (positive or negative) changes VOUT (Figure 3B). At room temperature, this change is usually compensated for by trimming one of the resistors (changing its value). However, if this variation of leakage current with temperature differs from the variation in divider current due to changes in the resistor values with temperature, the result is a change in VOUT with temperature. The VOUT change is called the temperature coefficient, or tempco. Although this analogy simplifies the more complex mechanism inside a reference circuit, it conveys the idea of a device tempco. Temperature hysteresis is the change in output voltage with a cycle of temperature variation. To measure, take a reference operating in a typical application, rated (as an example) for the extended operating temperature range (-40°C to +85°C), and record the output voltage at room temperature (+25°C). Cool the reference to -40°C, and then heat it to +25°C. Measure and record the output voltage again. The difference in these measurements (if any) is the temperature hysteresis. Conversely, you can measure at +25°C, heat the device to its maximum temperature (+85°C), and then cool it back to +25°C, measuring again. Any difference in these two room-temperature measurements also represents the temperature hysteresis. The deviation can be positive or negative. After many temperature cycles, one might deduce that the reference output voltage can be way off. Because temperature hysteresis is both positive and negative, however, the deviations resulting from a series of temperature cycles tend to cancel each other out, producing a final average output voltage very close to the nominal value. Line regulation, a measure of the change in output voltage due to a change in input voltage, is important if the input voltage changes while the reference is operating. Typical units are ppm/V and %/V. Line regulation is a DC parameter and is specified typically at DC. It measures the change in output voltage for two (or more) different DC input voltages, and it has little meaning if the input voltage varies rapidly, as for a voltage transient. In general, line regulation deteriorates inversely with the rate at which the line voltage changes. For applications likely to have line transients, reference-input capacitors are recommended to minimize the resulting variations. Load regulation is a measure of the change in output voltage due to a change in the reference load current. This parameter is important if the reference load current changes while the reference is operating. Again, load regulation is a DC parameter and is specified typically at DC. It measures the change in output voltage for two (or more) different DC load currents, and it has little meaning if the load current varies rapidly. In general, load regulation deteriorates inversely with the rate at which the load current changes. Output capacitors are recommended to stabilize the output voltage in applications subject to load-current transients. Typical units of measure are ppm/mA, %/mA, and percent change from no load to full load. Long-term drift (stability) is important if the reference must remain accurate for days, weeks, or years of continuous operation. It simply measures the variation in output voltage over a long period of time at some specified condition of steady-state operation. Long-term drift is a measure of the maximum and minimum output-voltage deviations over an extended time period, rather than a measure of deviation between "time A" and "time B." All other conditions (temperature, input voltage, load current, etc.) must be held constant if this measurement is to accurately reflect drift in the reference. Typical units are "ppm per 1000 hours." Supply current is self-descriptive, but consider these variations: For a series reference, the term "no-load current" is usually specified in the data sheet and often used interchangeably with the term "quiescent current." Because it designates the actual current drawn by an unloaded reference, no-load current does not specify the current drawn by that reference when loaded. Typical shunt references do not specify no-load current in the data sheet. Instead, they often list a minimum operating current (IMO). This parameter specifies the minimum current a reference must draw to maintain regulation. Note that a shunt reference must draw at least the minimum operating current under full-load conditions. Its series resistor (R1) must therefore accommodate the maximum load current plus the minimum operating current (Figure 4). In some applications, the minimum operating current (called "regulation current" in some data sheets) is disregarded, because it is so much smaller than the load current. ![]() Figure 4. Current flow is the key for analyzing the operation of a shunt reference. Ground current: Often specified for a series reference, ground current measures the operating current at a given load. A series reference is in series with the load, so a measure of current flowing into the reference input yields the sum of load current and operating current. Ground current is often measured to determine the operating current for a series reference with load. Dropout voltage (VDO): very important in battery-operated equipment, applies only to the series reference. It is the minimum difference between input and output voltage that allows the reference to maintain its specified accuracy (VOUT + VDO = minimum input voltage). Battery voltage declines as the battery discharges, and to maximize useful life in the battery the reference must maintain an accurate output voltage while powered by the lowest-possible battery voltage. Thus, a lower dropout voltage allows continued operation at a lower battery voltage. Load capacitance: The ability of a reference to drive capacitive loads can be very important. Because typical references incorporate feedback control, their stability can be compromised by the zero introduced by a capacitive load; this can produce a large phase shift in the control loop that creates positive feedback at a particular frequency. Read the data sheet carefully for information on the range of load capacitance allowed. Some manufacturers refer to this limitation only in the text of the data sheet and not in the parameter tables. Noise: Although noise is apparent at a reference output, it is nonetheless often overlooked. A reference's noise, which is a random signal generated by active and passive devices inside the IC, affects its accuracy. For example, a 1mVp-p output noise voltage limits initial DC accuracy to no better than 1mV. For a 1.2V reference, this noise level alone limits initial accuracy to approximately 1%. Reference data sheets typically show noise in two frequency bands: low-frequency noise, ranging from 0.1Hz to 10Hz and specified in µVp-p, and wideband noise, ranging from 10Hz to 1kHz and specified in µVrms. Designating noise in two bands allows circuit designers to distinguish between wideband noise, which they can filter with practical capacitor values, and low-frequency noise, which they cannot. Also, if a capacitor large enough to filter the low-frequency noise were used, it is possible that the reference would be unstable with such a large capacitor placed at its output. AC line regulation: Although AC line regulation is not usually designated in a specification table, it directly influences the performance of the voltage reference. In most applications, the supply voltage to the reference has voltage spikes present. These spikes tend to be spread over a wide frequency range. The accuracy of the voltage reference is inversely proportional to the frequency of the input voltage variation. Because the AC line regulation is typically not specified, the reference data sheet should at least contain a graph showing the typical AC line regulation versus frequency. This graph would indicate the sensitivity of the reference to input system noise and could be used to determine the input filtering required. As the noise frequency increases, the input filtering must further reduce the input system noise in order for the reference to achieve its rated accuracy. AC load regulation/output impedance: The AC load regulation is another important parameter that is often left out of the specification table of a voltage reference. This parameter is important if the load current drawn from the reference is changing constantly. The accuracy of the reference is usually inversely proportional to the load variation frequency. A graph showing the AC load regulation or AC output impedance versus frequency should be contained in the reference data sheet. This graph should show what output filtering is required with the known output load variations in order to achieve the rated accuracy of the voltage reference. Line transient response: This parameter is typically shown as an oscilloscope screen shot displaying a step change in the input voltage and the resulting change and correction in the output voltage. This screen shot displays the recovery time of the reference in returning to a specified accuracy after such an event occurs. For this parameter, it is important to note the input and output capacitor values used. These capacitors have a tremendous effect on the performance of the reference. Load transient response/output settling time: This parameter is typically shown as an oscilloscope screen shot displaying a step change in the output current and the resulting change and correction in the output voltage. This screen shot displays the recovery time of the reference in returning to a specified accuracy after such an event occurs. For this parameter, it is important to note the input and output capacitor values used. These capacitors have a tremendous effect on the performance of the reference. Turn-on/turn-off settling time: The turn-on settling time is a measure of how quickly the output voltage of the reference stabilizes after an initial power-up. The output only needs to be stable and may not necessarily have reached the specified accuracy of the reference. Typically, this parameter is specified with an output voltage error greater than the specified accuracy, and it should always be given in the conditions of the parameter. This parameter is highly dependent on the input and output capacitor values used and the load applied to the reference. Turn-off time, on the other hand, is a simple measure of how long it takes for the output voltage of the reference to reach virtually zero volts. Likewise, this parameter is highly dependent on the input and output capacitor values used and the load applied to the reference. ConclusionVoltage references are often chosen in haste. Before making a decision, the designer will look at the price, the initial accuracy highlighted on the data sheet, and frequently nothing else. Make sure that you compare apples to apples when comparing references. When evaluating a specification listed on several data sheets, be sure that all are expressed in the same units. Determine what parameters are important for your application, and look beyond the initial-accuracy specifications.AppendixPopular Voltage-Reference TypesTwo-Terminal Shunt or Zener ReferenceA zener reference is based on the zener principle, in which the current in a reverse-biased diode begins to flow at a certain voltage threshold and then increases dramatically with an increase in voltage. A resistor in series with the diode establishes a constant current, allowing the zener to achieve a stable reference voltage. The zener reference behaves like a typical shunt or two-terminal reference. It can also be used as a voltage clamp.
Three-Terminal Series and Buried (Subsurface) Zener References
Three-Terminal Series (Bandgap) Reference Making a compromise between cost and outstanding performance (low-noise operation and accuracy), the bandgap reference has become one of the most popular voltage references available. It compensates for the effect of temperature by subtracting the negative-tempco voltage of a forward-biased base-emitter junction from a positive-tempco PTAT (proportional to absolute temperature) voltage. The PTAT voltage is generated by measuring and amplifying the voltage difference between two forward-biased diode junctions.
A similar article appeared in the April 2000 issue of EDN |
Understanding Voltage-Referenc
- Voltage(37193)
正确的布局和元件选择是控制EMI的关键
正确的布局和元件选择是控制EMI的关键
Abstract: Understanding the physics of voltage regulator topologies
2009-08-21 09:42:37
1346
![](https://skin.elecfans.com/images/2021-soft/eye.png)
![](https://file1.elecfans.com//web2/M00/A5/3B/wKgZomUMN4CAcl86AAAPTOxWMpA824.gif)
Understanding Delta-Sigma Data Converters, 2nd Edition 中文翻译出版
`Understanding Delta-Sigma Data Converters, 2nd Edition 中文翻译版《Delta-Sigma 数据转换器从入门到精通》已经出版了,在京东、天猫、当当都有销售,敬请关注!`
2021-07-30 15:34:08
VOLTAGE QUADRUPLER USING TD310
VOLTAGE QUADRUPLER USING TD310The TD310 is a triple MOS or IGBT driver whichintegrates all
2009-05-12 09:57:13
ADC读数怎么计算
the voltage measured using the ADC on a c8051. The ref voltage I know is 2.4volts and it is using a 12bit
2018-09-26 17:24:35
Demo Read Voltage VI程序(Tutorial子模板)
初学labview,刚刚在做一个VI程序模拟温度测量,需要使用Demo Read Voltage子程序来仿真电压测量,说是在(Tutorial子模板)下,找了很多也找不到Tuorial模板,求大神指导,非常感谢!!!
2013-10-30 21:08:53
LTspice中 Voltage Controlled Switches的使用方法 精选资料分享
2021-07-09 06:20:15
What does "voltage2" mean in ad9361 evaluation linux system?
voltage2", what does it mean? Which voltage does it mean in ad9361 board? I appreciate any useful information.
2018-08-03 08:40:45
[ARM和linux的经典书籍].Understanding.the.Linux.Kernel.3rd.Edition
necessary for the relatively slow disks.The third edition of Understanding the Linux Kernel takes you
2017-11-07 15:19:39
《Low Voltage Power MOSFETs Design, Performance and Applications》
`求书《Low Voltage Power MOSFETs Design, Performance and Applications》,这本书里主要讲了什么内容?`
2021-06-22 08:07:36
【加急!】关于Demo Read Voltage的问题
各位大神,Demo Read Voltage到底是怎么个情况?我用的是LabVIEW 2013,在实例练习时,碰到一个Demo Read Voltage的东东,找遍了每一个犄角旮旯,都木有找
2014-03-18 10:00:11
怎么选择线性稳压器与开关稳压器
powered device, the question sometimes arises of whether a Linear Voltage Regulator or a Switching
2018-10-24 09:45:34
求Demo Read Voltage子VI程序,
求Demo Read Voltage子VI程序,我用的是13版本,范例里没有,上网查看说是新版本,这个子VI淘汰了。论坛了有人问过一样的问题,但没有资源~~
2015-01-10 12:30:56
详细介绍LTspice的Voltage source器件设置
LTspice的Voltage source是我们必须了解的一个器件,任何一个仿真都会用到。下面详细介绍这个器件的设置。首先,设置一个直流电压,如下,直接输入DC value即可,Series
2021-12-31 06:17:35
请教大家关于Analog supply voltage和Digital supply voltage的区别
各位前辈:在选择一款陀螺仪,有如下两个指标:Analog supply voltage 5VDigital supply voltage 3.3V因为根据使用条件,只能提供3.3v的电压,不知道是不是能用所以想请问大家这两个电压分别代表什么意思?多谢!!!!
2017-06-05 17:05:12
请问LM337IMP的Dropout Voltage是多少?
请问LM337IMP的Dropout Voltage是多少? 应该一般是有这个参数的,跟输出电流相关,有个最小最大管压降什么的,但是datasheet里面没有。这边用-3.3V输入并不能输出-3V,用-5V输入才能输出-3V
2019-07-12 08:10:34
请问Output Voltage Range和Output Saturation Voltage有什么关系?
Voltage Range,但是读到一个参数Output Saturation Voltage。
请看下面的数据:
Output Saturation Voltage的字面意思是输出饱和电压。第一眼
2023-11-20 08:14:25
请问一下BAND GAP voltage是多少伏?
在ACMP中有看到一种模式,参考的电压是BAND GAP VOLTAGE,但是这个电压多少伏,手册里好像没有说。
我想了解一下。谢谢……
2023-08-24 07:10:36
请问如何在现有项目中从G031F6更改为G031F8以获得更大的闪存大小?
我的项目扩展了,我需要超过 32k 的闪存。在 CubeMX 中,无法更改 Mcu Referenc。可以不生成新项目来更改Mcu吗?谢谢
2023-01-05 06:15:57
谁能提供Demo Voltage Read.vi
谁能提供Demo Voltage Read.vi正在学Labview,用8.5的,看8.2的教程,但找不到这个模块。
2012-10-31 12:10:51
Modeling voltage-controlled an
Modeling voltage-controlled and temperature-dependent resistorsAnalog Behavioral Modeling (ABM) can
2008-05-12 22:27:55
![](https://skin.elecfans.com/images/2021-soft/load.png)
Adaptive Voltage Control in Po
Adaptive Voltage Control in Power Systems
1 The Voltage Control Problem in Power Systems
2008-11-03 21:22:26
LM393 DUAL VOLTAGE COMPARATOR
The LM393 series consists of two independent precision voltage comparators with an offset voltage
2008-12-12 00:31:17
43
VFC32 pdf datasheet (Voltage-t
The VFC32 voltage-to-frequency converter providesan output frequency accurately proportional
2008-12-18 20:56:47
31
7812CT Voltage Regulator, +12
These voltage regulators are monolithic integrated circuits designedas fixed–voltage regulators
2009-01-19 17:17:44
14
LVT (Low Voltage Technology) a
LVT (Low Voltage Technology) and ALVT (Advanced LVT)Philips Semiconductors has introduced two low
2009-03-30 00:19:38
13
ADM1184,pdf datasheet (0.8% Ac
is required on the VCC pin to power the device.Four precision comparators monitor four voltage rails. Each comparator has a 0.6 V referenc
2009-08-25 10:30:57
22
A New High Gain Low Voltage 1.
A New High Gain Low Voltage 1.45GHz CMOS Mixer:Abstract—A new architecture of CMOS downconversion
2009-09-08 20:41:48
9
Understanding the Effect of Cl
Understanding the Effect of Clock Jitter on High Speed ADCs:Digitizing high speed signals to a high
2009-09-23 22:58:32
9
浅谈参考电压(Voltage Reference)
浅谈参考电压(Voltage Reference) 大多数的模拟电路,都需要参考用的电压、电流、或是『时间』。参考电压提供一个准则,如DAC或ADC的LSB大小、稳压器(Regulator)的输出电压位准、电池
2009-10-04 09:28:23
31
ADP3605,datasheet,pdf(Voltage
a regulated output voltage withminimum voltage loss and requires a minimum number of externalcomponents. In addition, the ADP3605 does not
2009-10-23 08:52:43
17
Understanding Modern Power MOS
Understanding Modern Power MOSFETs:• Explain what a board designer needs to know
2009-11-26 11:10:16
8
High Voltage Isolated/Non-Isol
High Voltage Isolated/Non-Isolated Power Supply Reference Designs:
2009-11-28 16:39:49
5
Understanding the Data Sheet:
Understanding the Data Sheet: PowerMOS:Allmanufacturers of powerMOSFETs provide a data sheetfor
2009-11-29 17:21:59
17
Understanding Forward vs Backw
Understanding Forward vs Backward:Crosstalk can be a difficult phenomenon for PCBdesigners to grasp
2010-01-15 10:34:02
Voltage-Output DAC
Voltage-Output DAC
GENERAL DESCRIPTIONThe AD5532 is a 32-channel voltage-output 14-bit DAC withan
2010-04-07 10:23:46
17
MLV Series Low Voltage Pressur
MLV Series Low Voltage Pressure Sensors
The MLV Series Compensated Sensor is based on All Sensors
2010-05-14 16:59:57
11
Bipolar Voltage Outputs for th
ABSTRACTA method for generating a symmetrical, bipolar, output swing voltage from
2010-06-08 10:14:00
8
DAC8560,pdf(16-Bit, Ultra-Low
includes a 2.5V, 2ppm/°C internal reference (enabled by default), giving a full-scale output voltage range of 2.5V. The internal referenc
2010-06-09 10:48:10
43
Understanding VNA Measurement
•Comprehensive understanding of the Agilent VNA: how it operates, how to optimize
2010-07-16 23:28:52
6
TCA6408,pdf(Low-Voltage 8-Bit
特性
Operating Power-Supply Voltage Range of 1.65 V to 5.5 V
Allows Bidirectional
2010-08-08 22:23:44
TL7660,pdf(CMOS VOLTAGE CONVER
The TL7660 is a CMOS switched-capacitor voltage converter that perform supply-voltage conversions
2010-09-13 19:12:11
13
XTR111,pdf(Precision Voltage-t
The XTR111 is a precision voltage-to-current converter designed for the standard 0mA–20mA or 4mA
2010-09-26 00:20:33
80
Low Cost, Two-Chip, Voltage -C
Low Cost, Two-Chip, Voltage -Controlled Amplifier and Video Switch
2010-10-02 09:20:02
27
UA7905,pdf(NEGATIVE-VOLTAGE RE
This series of fixed-negative-voltage integrated-circuit voltage regulators is designed
2010-10-23 00:14:26
35
UA78L12A,pdf(POSITIVE-VOLTAGE
This series of fixed-voltage integrated-circuit voltage regulators is designed for a wide range
2010-10-23 22:09:19
21
UA78L08A,pdf(POSITIVE-VOLTAGE
2010-10-23 22:21:40
15
UA78L08,pdf(POSITIVE-VOLTAGE R
2010-10-23 22:24:07
7
UA7824,pdf(POSITIVE-VOLTAGE RE
2010-10-23 22:44:08
7
UA7810,pdf(POSITIVE-VOLTAGE RE
2010-10-23 22:53:23
10
MC79L05A,pdf(NEGATIVE-VOLTAGE
This series of fixed negative-voltage integrated-circuit voltage regulators is designed for a wide
2010-10-23 23:24:46
14
TL7757,pdf(SUPPLY-VOLTAGE SUPE
The TL7757 is a supply-voltage supervisor designed for use in microcomputer and microprocessor
2010-10-23 23:56:40
11
TPS65193,pdf(Dual High-Voltage
The TPS65193 is dual high-voltage scan driver to drive an amorphous-silicon-gate (ASG) circuit
2010-11-03 22:49:48
7
BQ24351,pdf(OVER-VOLTAGE AND O
failures of the charging circuit. The IC continuously monitors the input voltage and the battery voltage. In case of an input over-voltag
2010-11-10 14:34:45
12
BQ24308,pdf(OVER-VOLTAGE AND O
failures of the charging circuit. The IC continuously monitors the input voltage, the input current and the battery voltage. In case of a
2010-11-10 14:49:00
24
Analog ICs for Low Voltage Sys
Analog ICs for Low Voltage Systems
Abstract: This article about low-voltage ICs discusses
2008-09-11 22:28:12
1451
![](https://file1.elecfans.com//web2/M00/A4/64/wKgZomUMNACAMf_iAAAivGxN-Fs677.gif)
Understanding the Effects of C
Understanding the Effects of Clock Tolerances on 50/60Hz Noise Rejection in High Performance Sigma
2008-10-06 13:56:41
447
![](https://file1.elecfans.com//web2/M00/A4/69/wKgZomUMNBWAEK63AAAdktiyLho392.gif)
What is voltage stability?
Recently lEEE/CIGRE task force [1] proposed various definitions
2008-11-03 21:14:55
1385
![](https://file1.elecfans.com//web2/M00/A4/71/wKgZomUMNDqACkSmAABW0Y8jug4837.jpg)
Dual, Voltage-Output DAC Consu
Dual, Voltage-Output DAC Consumes Miniscule Power
The dual, voltage-output DACs shown
2008-11-24 10:19:58
882
![](https://file1.elecfans.com//web2/M00/A4/7A/wKgZomUMNGGACPWGAAAlVc-UekQ992.gif)
Voltage Reference Vastly Reduc
Abstract: Using a shunt reference and op amp, a low-power, low-voltage series reference can
2009-02-02 15:57:54
1996
![](https://file1.elecfans.com//web2/M00/A4/8D/wKgZomUMNLaAM9c4AAAUM-GTvzs470.gif)
Controlling a Variable Voltage
Abstract: Semiconductor topic: Many linear and switched-mode power supplies and voltage regulators
2009-02-22 14:23:04
1406
![](https://file1.elecfans.com//web2/M00/A4/98/wKgZomUMNOWAM_idAAAVZ9poQnE654.gif)
A Quick Guide To Voltage Refer
Abstract: This application note discusses the three basic voltage reference topologies
2009-02-22 14:26:57
1154
![](https://file1.elecfans.com//web2/M00/A4/98/wKgZomUMNOWASecOAAAJsdiKebU991.gif)
理解物理拓扑结构的稳压器是用于EMI和EMC设计
2009-04-21 11:45:05
1316
![](https://file1.elecfans.com//web2/M00/A4/C9/wKgZomUMNbGATlauAAAPTOxWMpA654.gif)
Dual Voltage Tracking Circuit
Abstract: This note describes a dual tracking controller for a single I/O voltage and two core
2009-04-23 14:16:23
880
![](https://file1.elecfans.com//web2/M00/A4/CC/wKgZomUMNb2AK7IaAABFms8PrFw133.gif)
2009-04-23 17:44:28
1174
![](https://file1.elecfans.com//web2/M00/A4/CD/wKgZomUMNcCASUKCAABFms8PrFw557.gif)
正确的布局和元件选择控制电磁干扰
Proper Layout and Component Selection Controls EMI
2009-04-30 10:44:39
709
![](https://file1.elecfans.com//web2/M00/A4/D4/wKgZomUMNd6AQPJ_AAAPTOxWMpA695.gif)
正确的布局和元件选择控制电磁干扰
Abstract: Understanding the physics of voltage regulator topologies is important
2009-05-04 09:13:22
1063
![](https://file1.elecfans.com//web2/M00/A4/D6/wKgZomUMNeeAL71hAAAPTOxWMpA754.gif)
可调参考电压源:Adjustable Voltage Ref
可调参考电压源:Adjustable Voltage References
Adjustable voltage reference circuits are shown in Figures 19, 20, 21, 22. The two ci
2009-05-16 16:10:41
3131
![](https://file1.elecfans.com//web2/M00/A4/E9/wKgZomUMNi6AS0gCAACwExLH0zk543.jpg)
Understanding the ATE SPI (Ser
Understanding the ATE SPI (Serial Peripheral Interface)
Abstract: Most Maxim® ATE
2009-10-02 21:45:49
1370
![](https://file1.elecfans.com//web2/M00/A5/4A/wKgZomUMN8GAZjvRAAAjbbIJe2U652.gif)
Minimize Voltage Offsets in Pr
Minimize Voltage Offsets in Precision Amplifiers
Abstract: Voltage-offset errors in precision
2009-10-03 08:49:35
1110
![](https://file1.elecfans.com//web2/M00/A5/4A/wKgZomUMN8GAS1j_AAAMlxziK_M933.gif)
How to Use High-Voltage and Hi
How to Use High-Voltage and High-Current-Drive Op Amps in 4–20mA Current-Loop Systems
Abstract
2010-02-21 11:45:05
1576
![](https://file1.elecfans.com//web2/M00/A5/78/wKgZomUMOJOARy8eAAAXZ5WSvYA248.gif)
绝版经典:中文版数字信号处理understanding Digital s
电子发烧友网站提供《绝版经典:中文版数字信号处理understanding Digital s.txt》资料免费下载
2014-03-31 22:44:04
绘图案例【Circuit Simulation】Voltage
绘图案例【Circuit Simulation】Voltage Controlled Oscillator
2016-02-16 11:24:26
Transient_Voltage_Suppressors_SMBJ_Series_C8834
Transient_Voltage_Suppressors_SMBJ_Series_C8834,感兴趣的小伙伴们可以看看。
2016-08-03 17:55:44
ESD Protection for Mixed-Voltage IO in Low-Voltage Thin-Oxide CMOS
2017-10-17 11:28:32
12
LTC2949: Current, Voltage, and Charge Monitor for High Voltage Battery Packs Data Sheet
2021-01-28 12:49:20
8
LTC6990: Voltage Controlled Silicon Oscillator
2021-02-04 08:04:02
3
LTC3649 Demo Circuit - High Voltage Synchronous Buck Regulator with Output Voltage Control (10-60V to 5V @ 4A)
2021-02-04 09:01:06
3
使用Voltage-controlled Voltage Source仿真放大器
在上篇《活学活用 LTspice 进行电路设计 — 用 Behavioral Voltage Sources 创建任意波形》中,我们向大家介绍了如何使用 Behavioral Voltage
2023-04-20 09:43:05
1107
Voltage-controlled Voltage Source (VCVS) 具有 4 个端⼦。左侧的 2 个端子为输入端子 (控制端子),可输出与输入电压差成比例的电压。因此,如果比例常数大于
2023-06-06 09:35:40
521
![](https://file1.elecfans.com/web2/M00/89/3B/wKgZomR-jayAFzsOAADOdPc68MQ260.jpg)
MAX16132-MAX16135: Low-Voltage, Precision, Single/Dual/Triple/Quad-Voltage μP Supervisors Data Sheet MAX16132-MAX16135: Low-Voltage, Precisi
电子发烧友网为你提供ADI(ADI)MAX16132-MAX16135: Low-Voltage, Precision, Single/Dual/Triple/Quad-Voltage
2023-10-13 18:38:22
![](https://www.elecfans.com/uploads/190218/2927106-1Z21P94211255.png)
MAX6069: 1μA WLP Precision Shunt Voltage Reference Data Sheet MAX6069: 1μA WLP Precision Shunt Voltage Reference Data Sheet
电子发烧友网为你提供ADI(ADI)MAX6069: 1μA WLP Precision Shunt Voltage Reference Data Sheet相关产品参数、数据手册,更有
2023-10-16 18:45:26
