电子发烧友App
硬声App
电子发烧友网>模拟技术>AD技术>Design a Low-Jitter Clock for
收藏
查看更多
20位1 MSPS隔离模拟输入数据采集参考设计包括BOM及组装图
描述TIDA-01037 is a 20-bit, 1 MSPS isolated analog input data acquisition reference design
2018-10-11 15:18:30
A Low-Noise-Amplifier at 1.9 GHz using BFP405
The design emphasis has been on achieving a low noisefigure. A circuit description, schematic, pcb
2009-05-12 14:10:12
A Low-Noise-Amplifier at 900 MHz using SIEGET BFP420
This application note describes a low noise amplifier at 900MHz usingSIEMENS SIEGET?25 BFP420.
2009-05-12 13:43:24
A Low-Noise-Amplifier shows good Noise Figure performance at 1.9 GHz using BF
2009-05-12 13:36:57
A Low-Noise-Amplifier with good IP3outperformance at 1.9 GHz using BFP420
This application note describes a low noise amplifier at 1.9GHz using SIEMENSSIEGETa25 BFP420.
2009-05-12 13:33:19
Design Note for DN06009/D
Design Note for DN06009/D5W,CCCV Cell Phone Battery ChargerThis circuit presents a very simple, low
2009-11-20 09:04:04
Design of low-voltage low-power CMOS operational amplifier cells
分享一本书:Design of low-voltage low-power CMOS operational amplifier cells
2021-06-22 07:01:47
Low_Power_Design
Low_Power_Design分享给大家
2013-05-13 06:48:53
ADC采样可以从I/O线中获得多少抖动
IC running on a extremely low jitter clock and the D input be tied to the FPGA CS pin, I have
2019-05-17 14:04:07
Advanced Design System(ADS)使用指南教程
) TutorialThis tutorial describes how to analyze a stepped impedance filter using Advanced Design System(ADS
2008-07-21 11:48:17
CDC5801ADBQ
CDC5801A LOW-JITTER CLOCK MULTIP
2023-04-06 12:11:18
CDC5801ADBQR
2023-04-06 17:09:51
FPGA的多时钟系统设计 Multiple Clock System Design
FPGA的多时钟系统设计 Multiple Clock System Design Clk1and Clk2are the clock which running at different frequency[/hide]
2009-12-17 15:46:09
Multiple Clock System Design Look Step by StepPossible Assign Option–Tpd?? NO! NO! Tpdcan
2008-09-11 09:20:30
Nvidia Shanghai Hiring---ASIC Design Engineer
multi-disciplinarygroup environment -Knowledge on video, or network, or layout, or low-power design
2012-07-06 14:30:34
PCI Express Board Design Guidelines
PCI Express Board Design GuidelinesThis document provides practical, common guidelines
2011-01-28 17:40:18
SMBus Design Using Low Power Microcontroller
`描述This design utilizes existing Launchpad evaluation kits and BoosterPack plug-in modules
2015-03-23 10:02:29
[UPF]低功耗(Low Power Design)and UPF介紹 精选资料分享
低功耗(Low Power Design)and UPF介紹一、低功耗設計策略(Lower-power design strategies)1.1、動態和靜態功耗(Dynamic
2021-07-27 07:26:56
Low Voltage Power MOSFETs Design, Performance and Applications》
`求书《Low Voltage Power MOSFETs Design, Performance and Applications》,这本书里主要讲了什么内容?`
2021-06-22 08:07:36
关于 DDR时序约束常见的ERROR问题
The specified design element actually exists in the original design. 2. The specified object is spelled
2020-09-21 10:48:02
单个外部振荡器到多个GTP
to the other unused GTPs. I've got two separate 100MHz low-jitter clocks, of which one is going
2019-05-23 08:51:32
如何计算输出时钟的DISCRETE JITTER
ALL How DISCRETE JITTER is calculated for output clock if I0 and I1 both connected to BUFGCTRL? I get 335ns DJ while source clock has 80ps P-P JITTER.
2019-03-22 09:30:34
求书:Design and Implementation
求书:Low-Voltage CMOS Operational Amplifiers: Theory, Design and Implementation
2021-06-22 06:11:30
直方图简化随机抖动分析
The Keysight 53310A's fast histograms make it easy to get complete view of clock jitter. The shape
2019-04-18 16:38:14
请问GUI的输入抖动值是否有问题?
estimate for the output jitter of a PLL in S6.The datasheet says to reference the wizard.Here's our
2019-06-14 08:31:44
请问PLL jitter的区别是什么
There are four kinds of PLL jitter:1.period jitter2.short term jitter3.long term
2021-06-24 06:48:21
高速时的抖动,噪声和信号完整性Jitter, Noise, and Signal Integrity at High-Speed
side by a clock recovery circuit (CRC). The CRC also tracks and reduces low-frequency jitter
2019-02-15 11:53:51
DS1080CL pdf
The DS1080CL is a low-jitter, crystal-based clock gen-erator with an integrated phase-locked loop
2008-06-30 12:50:5014
MAX3679 pdf datasheet (Low-Jit
The MAX3679 is a low-jitter precision clock generator with the integration of three LVPECL and one
2008-12-25 17:37:297
ISL12082 pdf datasheet (Low Po
CompensationThe ISL12082 device is a low power real time clock withtiming and crystal compensation, clock/calendar, power failindicator,
2009-01-18 22:23:5614
ISL12030 pdf datasheet (Low Po
is a low power real time clock with50/60 AC input for timing synchronization, clock/calendarregisters, single periodic or polled
2009-01-19 11:28:5816
2009-01-19 11:34:306
ISL12022 pdf datasheet (Low Po
real time clock with anembedded Temp sensor for oscillator compensation,clock/calendar, power fail, low battery monitor, brownout
2009-01-19 12:01:2316
ISL12023 pdf datasheet (Low Po
SavingThe ISL12023 device is a low power real time clock with anembedded Temp sensor for oscillator compensation,clock/calendar,
2009-01-19 12:15:149
W83116WG pdf Datasheet(V11 Low Power Clock Gen for Intel CK50
The W83116WG-511 is a low power clock synthesizer for Intel CK505 compatible platform, which has
2009-01-20 14:37:47138
MAX3671 pdf datasheet (Low-Jit
The MAX3671 is a low-jitter frequency synthesizer that accepts two reference clock inputs
2009-02-08 18:59:4213
MAX3673 pdf datasheet (Low-Jit
The MAX3673 is a low-jitter frequency synthesizer that accepts two reference clock inputs
2009-02-11 18:02:1021
MAX3629 pdf datasheet (Precisi
The MAX3629 is a low-jitter precision clock generator optimized for network applications.
2009-02-11 18:03:229
DS4625 pdf datasheet (3.3V Dua
The DS4625 is a dual-output, low-jitter clock oscillator capable of producing frequency output pair
2009-03-31 11:03:0214
循环过滤器配置为MAX3670低抖动PLL频率参考时钟发生器
Abstract: The MAX3670 low-jitter clock generator is a monolithic phase-locked loop (PLL) that uses
2009-04-22 11:23:1320
MAX3627,pdf,datasheet (+3.3V,
The MAX3627 is a low-jitter, precision clock generator optimized for network applications.
2009-05-02 09:43:5826
TI音频接口 ICDIR9001
One-Chip Digital Audio Interface Receiver (DIR) Including Low-Jitter Clock-
2022-12-01 14:49:08
TI时钟发生器LMK5B12204
采用网络同步和 BAW 技术的超低抖动时钟发生器 Function Clock network synchronizer, Ultra-low jitter clock generator
2022-12-02 13:47:14
TI时钟发生器CDC421A212
212.5MHz 全集成式固定频率低抖动晶振时钟发生器 Function Low-jitter clock generator Number of outputs 1
2022-12-02 13:47:26
Low-Power Digital Vlsi Design An Overview
Low-Power Digital Vlsi Design:An Overview:
2009-07-25 16:41:210
MAX3679/MAX3679A,pdf datasheet
The MAX3679A is a low-jitter precision clock generator with the integration of three LVPECL and one
2009-08-17 00:11:3924
AD9511,pdf datasheet (Five Outputs)
The design emphasizes low jitter and phase noise to maximize data converter performance. Other applications with demanding phase noise and
2009-09-15 09:31:0211
AD9512,pdf datasheet (Five Out
The AD9512 provides a multi-output clock distribution in a design that emphasizes low jitter
2009-09-15 09:32:3618
AD9513,pdf datasheet (Three Ou
The AD9513 features a three-output clock distribution IC in a design that emphasizes low jitter
2009-09-15 09:34:1615
AD9514,pdf datasheet (Three Ou
The AD9514 features a multi-output clock distribution IC in a design that emphasizes low jitter
2009-09-15 09:35:5313
AD9515,pdf datasheet (Delay Ad
The AD9515 features a two-output clock distribution IC in a design that emphasizes low jitter
2009-09-15 09:37:3417
AD9520-5,pdf datasheet (Clock
The AD9520-51 provides a multioutput clock distribution function with subpicosecond jitter
2009-09-15 14:28:3417
AD9522-5,pdf datasheet (Clock
The AD9522-51 provides a multioutput clock distribution function with subpicosecond jitter
2009-09-15 14:39:1512
MAX3624,pdf,datasheet (Low-Jit
The MAX3624 is a low-jitter precision clock generatoroptimized for networking applications.
2009-09-18 08:54:3717
MAX3637,pdf,datasheet(Wide Fre
for the next generation of network equipment that demands low-jitter clock generation and distribution for robust high-speed data transmission. T
2009-10-16 08:55:5928
MAX3639,pdf,datasheet (Program
2009-10-16 10:09:2439
LMK04000,datasheet,pdf(Low-Noi
The LMK04000 family of precision clock conditioners provideslow-noise jitter cleaning, clock
2009-10-20 13:59:5522
The Design of a Clock Synchron
continuousdataow embedded systems This paper describes the design of aglobal clock subsystem which is an essential component of
2009-11-30 11:37:359
MAX9150,pdf,datasheet (low-vol
The MAX9150 low-jitter, 10-port, low-voltage differential signaling (LVDS) repeater is designed
2009-12-19 10:28:2136
TSW1000: ADS5500 and CDC7005
Processing™ solutions by coupling the CDC7005 low-jitter clock   synchronizer chip with the industry leading 14-bit ADS5500 ADC dev
2010-06-04 11:38:0417
Low Power IC Design of the Wir
Low Power IC Design of the Wireless Monitoring System of the Orthopedic Implants:Abstract—A low
2010-06-09 07:43:0921
JITTER ANALYSIS USING THE 5412
JITTER ANA
2010-07-08 15:32:548
Frequency agile jitter measure
This application note focuses on jitter measurements of componentsand equipment that make up
2010-07-15 23:59:1028
Understanding Jitter and Wande
Welcome to the second edition of Agilent TechnologiesUnderstanding Jitter and Wander Measurements
2010-07-19 15:09:2821
Jitter Generation and Jitter M
With the 81134A it is easy toadd jitter to any kind of dataor clock signal. This is veryuseful
2010-07-21 20:04:249
什么是jitter,jitter是什么意思?
什么是jitter,jitter是什么意思?在数据网络中,抖动(jitter)是通过一个网络的反应时间的可变性测量标准。一个非常小量的抖动对使用语音和
2008-11-27 08:42:1915932
DS3112 LRCLKx Low Speed Clock
This application note describes how the device recovers the low-speed clock signals from the high-speed multiplexed signal for the three modes of operat
2009-04-18 11:56:08701
设计一个低抖动时钟的高速数据转换器-Design a Low
Abstract: High-speed applications using ultra-fast data converters in their design often require
2009-04-25 10:14:56680
2009-05-08 10:44:25757
用DSP实现抖动(Jitter)测量的方法
用DSP实现抖动(Jitter)测量的方法 近年来,抖动(Jitter)已经成为通信工程师非常重视的信号特征。在数字系统中,时钟频率正在变
2009-08-17 17:04:54990
Aperture Jitter Calculator for
and applications of the Maxim Jitter Calculator provided as part of the ADC design tools. This document assumes that the reader h
2009-09-18 08:38:101200
MAX24188 pdf( low-cost IEEE 1588 clock )
The MAX24188 is a flexible, low-cost IEEE 1588 clock designed to be the central 1588 time base
2011-08-24 10:37:5018
AD9557,pdf datasheet (Dual-Input Multiservice Line Card Adaptive Clock Translato)
The AD9557 is a low loop bandwidth clock multiplier that provides jitter cleanup
2011-10-29 17:10:4431
DS1080L数据资料
The DS1080L is a low-jitter, crystal-based clock generatorwith an integrated phase-locked loop (PLL
2012-05-30 10:47:1620
MAX31180,pdf datasheet
The MAX31180 is a low-jitter, crystal-based clock generatorwith an integrated phase-locked loop
2013-01-07 11:07:1930
Low-Sensitivity_Bandpass_Filter_Design_with_Tuning_Method
This Application Note covers the design of a Sallen-Key bandpass biquad. It gives a design with low component and op amp sensitivities。
2016-02-22 14:13:480
Low-Sensitivity, Highpass_Filter_Design_with_Parasitic_Compensation
Low-Sensitivity, Highpass Filter Design with Parasitic Compensation
2016-02-22 14:28:3517
RF放大器设计 Low Noise Amplifier Design
RF放大器设计 Low Noise Amplifier Design 030724
2017-03-05 15:25:101
Low Jitter与SSCG功率时钟发生器SL16020DC
The SL16020DC is a low power dissipation spread spectrum clock generator using SLI proprietary low jitter PLL.
2017-09-11 12:53:3411
Low Jitter与SSCG功率时钟发生器SL16010DCT
The SL16010DC is a low power dissipation spread spectrum clock generator using SLI proprietary low jitter PLL. The SL16010DC provides two output clocks.
2017-09-11 13:37:454
1.65GHz的时钟输出分频器和延迟Fanout Buffer调整ad9508数据表
The AD9508 provides clock fanout capability in a design that emphasizes low jitter to maximize
2017-10-19 13:26:2014
1.2千兆赫时钟分配IC锁相环核心分频器延迟调整八输出AD9510数据表
loop (PLL) core. The design emphasizes low jitter and phase noise to maximize data converter performance.
2017-10-19 13:29:0112
1.2千兆赫时钟分配IC锁相环核心分频器延迟调整五输出ad9511数据表
2017-10-19 13:31:124
1.2千兆赫时钟分配IC 1.6GHz输入分频器延迟调整五输出ad9512数据表
2017-10-19 13:33:506
800兆赫时钟分配IC分频器延迟调整三输出ad9513数据表
The AD9513 features a three-output clock distribution IC in a design that emphasizes low jitter and phase noise to maximize data converter performance
2017-10-19 13:36:0311
1.6千兆赫时钟分配IC分频器延迟调整三输出ad9514数据表
The AD9514 features a multi-output clock distribution IC in a design that emphasizes low jitter and phase noise to maximize data converter performance.
2017-10-19 13:38:1113
1.6千兆赫时钟分配IC分频器延迟调整两个输出ad9515数据表
The AD9515 features a two-output clock distribution IC in a design that emphasizes low jitter and phase noise to maximize data converter performance.
2017-10-19 13:40:236
低压CMOS输出低抖动时钟发生器ad9523-1数据表
The AD9523-1 provides a low power, multi-output, clock distribution function with low jitter
2017-10-19 14:18:0210
抖动器和时钟发生器的6分或13的LVCMOS输出ad9524数据表
The AD9524 provides a low power, multi-output, clock distribution function with low jitter performance, along with an on-chip PLL and VCO.
2017-10-19 14:19:5710
四锁相环四输入多行卡自适应时钟转换器ad9554-1数据表
The AD9554-1 is a low loop bandwidth clock translator that provides jitter cleanup
2017-10-19 14:48:094
四输入多行卡自适应具有帧同步的时钟转换器ad9558数据表
The AD9558 is a low loop bandwidth clock multiplier that provides jitter cleanup
2017-10-19 14:50:556
双锁相环四输入多行卡自适应时钟转换器ad9559数据表
The AD9559 is a low loop bandwidth clock multiplier that provides jitter cleanup
2017-10-19 14:52:586
降低Clock Uncertainty流程
Discrete Jitter是由MMCM/PLL引入的,其具体数值可通过点击图2中Clock Uncertainty的数值查看,如图5所示。通常,VCO的频率越高,引入
2018-11-12 14:40:005091
基于示波器抖动分析的jitter分类及其特点
整个jitter可以分为RJ(随机性Jitter)和DJ(确定性jitter)两大类。它们的分类主要跟根据是否有界,也就是是否有最大值来区分。RJ在分布上是高斯分布,其没有边界的也就是没用最大值
2020-05-14 15:37:169309
ADCLK854: 1.8 V, 12-LVDS/24-CMOS Output, Low Power Clock Fanout Buffer Data Sheet
2021-01-28 02:20:390
AD9540: 655 MHz Low Jitter Clock Generator Data Sheet
2021-01-28 15:37:316
已全部加载完成
