电子发烧友App
硬声App
电子发烧友网>模拟技术>AD技术>Dynamic Testing of High-Speed
收藏
查看更多
High Speed IO用户手册
1 IР概述 High Speed l0 IP适用于PH1A(PH1A60、PH1A90、PH1A180、PH1A400)系列器件和PH1A100系列器件,它主要由时钟缓冲、IOL以及延迟单元等原语
2023-08-09 07:43:37
high-speed-selectIO
请问有用过high-speed-selectIO的大佬吗?|生成的例化模板中端口为bg_pin_nc怎么处理的呢?我实现这一步就报错了,想问问应该怎么改?
2022-09-23 11:42:21
high speed counter
high speed counter schematic
2020-12-21 16:50:04
A Practical Guide to High-Speed Printed-Circuit-Board Layout
By John Ardizzoni, (john.ardizzoni@analog.com)Despite its critical nature in high-speed circuitry
2015-01-23 11:01:23
Design And Application Guide For High Speed MOSFET Gate Drive Circuits
Design And Application Guide For High Speed MOSFET Gate Drive CircuitsThe main purpose
2009-03-27 16:04:24
2009-03-31 13:52:49
Disturbance Observer and Feedforward Design for a High-Speed Direct-Drive Positioning Table(高速直流驱动定位表的扰动观测器和前馈设计)
Disturbance Observer and Feedforward Design for a High-Speed Direct-Drive Positioning Table(高速直流驱动定位表的扰动观测器和前馈设计).pdf
2017-10-04 11:12:58
Jitter, Noise, and Signal Integrity at High-Speed
Jitter, Noise, and Signal Integrity at High-Speed-Mike PengLi
2015-10-26 15:03:11
Keysight 88000 HS-100高速和灵敏度阵列测试系统
High-speed and ultra-precise testing of current and new FPD technologies
2019-10-24 11:05:12
使用接收器容差测试来评估高速设备的性能应用笔记
Using Receiver Tolerance Testing to Assess the Performance of High-Speed Devices
2019-10-23 10:23:32
机身测试(AN 1270-8)
Hundreds of strain and stress points on an airframe and wings are measured with a high-speed
2019-01-25 14:10:05
经典著作【ANALOG DEVICES】高速设计技术
of Feedback Capacitancen High-Speed Current-to-Voltage Converters, andthe Effects of Inverting Input
2018-11-22 09:34:39
高速I/O连接和总线中的抖动表征和测试的完整解决方案
Complete solutions for characterization and test of jitter in high-speed digital transmission systems, high-speed I/O connections, and buses.
2019-11-05 14:21:20
高速时的抖动,噪声和信号完整性Jitter, Noise, and Signal Integrity at High-Speed
and analysis for the high-speed link system and its subsystems. Testing requirements andmethods for link
2019-02-15 11:53:51
Dynamic Testing Method for Yar
Dynamic Testing Method for Yarn Tension Ahshmct Various dynamic test devices of tam tension
2009-01-21 11:58:1315
High-Speed Circuit Board Signa
High-Speed Circuit Board Signal Integrity:Characteristics and Construction of Printed Wiring Boards
2009-02-17 10:21:140
High-Speed Interconnect -高速接口I
业界功能最为齐全的高速接口IC产品线-High-Speed Interconnect (8th edition)
2009-03-23 21:36:0615
High Speed/Low Loss, CAF Resis
High Speed/Low Loss, CAF Resistant, Lead-Free SolutionTypical Engineering Values
2009-03-24 13:09:290
Ground and VCC Bounce of High-
Ground and VCC Bounce of High-Speed Integrated Circuits The purpose of this paper is to give
2009-03-30 00:16:5030
High-speed Digital Design - Jo
High-speed Digital Design - Johnson & Graham.pdf
2009-04-23 23:19:160
高速微控制器用户指南:High-Speed Microcon
高速微控制器用户指南:High-Speed Microcontroller User’s Guide 1. INTRODUCTION..92. ORDERING INFORMATION103.
2009-05-11 09:40:3020
High-Speed Differential Signal
High-Speed Differential Signaling in Cyclone Devices From high-speed backplane applications
2009-05-14 10:42:2321
电压基准滤波器
LOW OUTPUT IMPEDANCE AT HIGH FREQUENCY FOR DRIVING DYNAMIC LOADS SUCH AS HIGH-SPEED
2009-05-31 10:03:0123
AD9260,pdf datasheet (High Spe
The AD9260 is a 16-bit, high-speed oversampled analog-to-digital converter (ADC) that offers
2009-09-10 10:05:4113
High Speed PCB Design--Ride th
High Speed PCB Design--Ride the Wave WorkshopPost Route Analysis of a HighSpeed PCB DesignDesign/Analysis forPower Delivery System (PDS)
2009-09-26 18:30:580
Interfacing to High Speed ADCs
Interfacing to High Speed ADCs via SPI:This application note describes how to use the SPI port
2009-09-30 19:43:3915
High-Speed Audio Ripping,Encod
High-Speed Audio Ripping,Encoding and Playback: Entertainment Systems Get a Makeover:The way
2009-09-30 20:00:0328
TJA1051 High-speed CAN transce
The TJA1051 is a high-speed CAN transceiver that provides an interface between aController Area
2009-11-10 13:43:1521
TJA1042 High-speed CAN transce
The TJA1042 is a high-speed CAN transceiver that provides an interface between aController Area
2009-11-10 13:47:2851
High-Speed Board Design Techni
High-Speed Board Design TechniquesThe most important factor in the design of many systems today
2009-11-22 19:48:0220
High Speed Measurements on Mod
High Speed Measurements on Modulated Signals:This paper deals with the design and construction
2010-03-03 08:39:1529
TLC5540: 8-Bit High-Speed Anal
The TLC5540 is a high-speed, 8-bit analog-to-digital converter (ADC) that converts at sampling
2010-06-02 09:01:0718
ADS8317,pdf ( High-Speed, 2.7V
range from 2.7V to 5.5V. It requires very little power, even when operating at the full data rate. At lower data rates, the high speed o
2010-06-03 14:59:3839
High-Speed ADC THS1041and FPGA
ABSTRACTThe Texas Instruments THS1041 is a 10-bit, 40-MSPS, high-speed analog-to-digitalconverter
2010-06-06 17:01:154
Clamp function of high-speed A
IntroductionThe THS1041 from Texas Instruments (TI) is a 10-bit, 40-MSPS, CMOS high-speed
2010-06-06 17:03:405
TSW1250EVM: High-Speed LVDS De
The TSW1250 includes a High-Speed LVDS Deserializer and Analysis System which provide
2010-06-12 09:41:4610
A DSP Architecture for High-Sp
) architecture for high-speed fast Fourier transforms (FFTs) in orthogonal frequency division multiplexing (OFDM) systems. T
2010-06-27 22:47:2312
高速串行信号的信号完整性和物理层测量与分析
高速串行信号的信号完整性和物理层测量与分析-High Speed Design Testing Solutions Agenda􀂃High-Speed Serial Test
2010-06-29 16:18:3126
CD74HC125-Q1,pdf(High-Speed CM
which, when HIGH, puts the output in the high-impedance state.
2010-07-15 14:49:3511
CD74HC564,pdf(High-Speed CMOS
The ’HC534, ’HCT534, ’HC564, and ’HCT564 are high speed Octal D-Type Flip-Flops manufactured
2010-07-25 18:35:2612
CD74HCT573,pdf(High-Speed CMOS
The ’HC533, ’HCT533, ’HC563, and CD74HCT563 are high speed Octal Transparent Latches manufactured
2010-07-30 12:28:4719
CD74HC40103-Q1,PDF(High-Speed
The CD74HC40103 is manufactured with high-speed silicon-gate technology and consists of an 8-stage
2010-08-09 22:20:3526
CD74HC4017-Q1,pdf(High-Speed C
The CD74HC4017 is a high-speed silicon-gate CMOS 5-stage Johnson counter with ten decoded outputs.
2010-08-10 17:08:3720
CD74HC138-Q1,pdf(High-Speed CM
The CD74HC138 is a high-speed silicon-gate CMOS decoder well suited to memory address decoding
2010-08-12 00:12:5117
CD74HC4543,pdf(High-Speed CMOS
The CD74HC4543 high-speed silicon-gate device is a BCD to 7-segment latch/decoder/driver designed
2010-08-12 15:11:5021
TS3USB221,pdf(High-Speed USB 2
The TS3USB221 is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-08-14 00:34:1928
TS3USB30,pdf(High-Speed USB 2.
The TS3USB30 is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-08-14 00:37:0212
TS3USB31,pdf(High-Speed USB 2.
The TS3USB31 is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-08-14 00:38:3919
SN74LV4046A,pdf(High-Speed CMO
The SN74LV4046A is a high-speed silicon-gate CMOS device that is pin compatible with the CD4046B
2010-08-20 18:27:0622
UA9638,pdf(Dual High-Speed Dif
The uA9638C is a dual high-speed differential line driver designed to meet ANSI Standard EIA
2010-09-04 17:28:4613
TS3USB221A-Q1,pdf(High-Speed U
The TS3USB221A is a high-bandwidth switch specially designed for the switching of high-speed USB
2010-09-09 23:54:0323
TS3USB221E,pdf(HIGH-SPEED USB
The TS3USB221E is a high-bandwidth switch specially designed for the switching of high-speed USB
2010-09-10 00:00:2632
TS3USB31E,pdf(High-Speed USB 2
The TS3USB31E is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-09-10 00:07:5515
THS4631,pdf(High-Voltage High
The THS4631 is a high-speed, FET-input operational amplifier designed for applications requiring
2010-09-11 22:06:2831
THS3001,pdf(420-MHz High-Speed
The THS3001 is a high-speed current-feedback operational amplifier, ideal for communication
2010-09-11 23:14:1245
OPA2832,pdf(dual, low-power, high-speed, fixed-gain amplifier)
The OPA2832 is a dual, low-power, high-speed, fixed-gain amplifier designed to operate on a single
2010-09-12 23:31:1611
PGA870,pdf(High-Speed, Fully D
The PGA870 is a wideband programmable-gain amplifier (PGA) for high-speed signal chain and data
2010-09-18 23:49:1327
ADP3654,pdf (High Speed, Dual,
The ADP3654 high current and dual high speed driver is capable of driving two independent N-channel
2010-09-20 09:22:1534
TL714,pdf(HIGH-SPEED DIFFERENT
The TL714C is a high-speed differential comparator fabricated with bipolar Schottky process
2010-09-23 19:34:3222
TPS2811-Q1,pdf(Dual High-Speed
The TPS2811 dual high-speed MOSFET driver is capable of delivering peak currents of 2 A into highly
2010-09-27 21:46:3216
TLE2021-EP,pdf(Excalibur High-Speed Low-Power Precision OP A
The TLE202x and TLE202xA devices are precision, high-speed, low-power operational amplifiers using
2010-12-13 21:20:4846
INL/DNL Measurements for High-
for high-speed, high dynamic performance data converters, they gain significance when it comes to high-resolution imaging applications. The
2009-04-16 15:53:381891
Defining and Testing Dynamic P
for high-speed data converters (in this case analog-to-digital converter or short ADCs) used in communications, instrumentation and data acqu
2009-04-16 15:56:19462
2009-04-16 15:58:39397
High-Speed ADC Sets Input Comm
receivers that include baseband-sampling, high-speed ADCs. A VCM is especially important for single-supply, low-voltage circuits with DC-couple
2009-04-16 16:46:49545
DS3112 LRCLKx Low Speed Clock
This application note describes how the device recovers the low-speed clock signals from the high-speed multiplexed signal for the three modes of operat
2009-04-18 11:56:08701
High-Speed Pulse Generator Has
Abstract: As integrated circuits (ICs) speed up, the rise/fall times of most pulse and function
2009-04-20 11:17:561455
High-Speed Random-Data Generat
Abstract: A handful of components are integrated into a circuit that creates a high-quality random
2009-04-20 15:05:49916
2009-04-20 15:09:34947
高速微型存储器接口时序-High-Speed Micro M
Abstract: This application note addresses external memory interfacing with Maxim high-speed
2009-04-23 15:35:10918
High-Speed I²C for the MA
Abstract: This application note provides a much-needed working high-speed I2C example.
2009-04-24 15:02:48832
2009-04-25 09:29:05539
Interfacing the MAX5195 High-S
of the MAX5195 high-speed digital-to-analog converter (DAC) to design a reliable resistor network for interface this LVPECL-based high-speed DAC to
2009-04-25 10:08:30824
内核层/微分非线性测量高速模拟数字转换器(ADCs)-INL
2009-04-25 10:23:34811
2009-04-29 09:29:03757
高速ADC输入共模范围-High-Speed ADC Set
2009-05-01 10:49:50905
2009-05-01 11:06:44527
高速ADC集输入共模范围-High-Speed ADC Se
2009-05-08 10:29:39605
2009-05-08 10:41:03701
内核层/微分非线性测量高速模拟数字转换器( ADCs )-I
2009-05-08 10:55:401351
设置高速ADC的共模输入电压范围--High-Speed A
设置高速ADC的共模输入电压范围--High-Speed ADC Sets Input Common-Mode Range Abstract: The input common-mode
2009-06-09 20:41:431378
高速模数转换器(ADC)的INL/DNL测量
not be the most important parameters for high-speed, high dynamic performance data converters, they gain significan
2009-08-21 09:40:221915
ADP3629: High Speed, Dual, 2
ADP3629: High Speed, Dual, 2 A MOSFET Driver The ADP3629/ADP3630/ADP3631 are dual, high current
2009-10-31 11:20:30678
ADP3630: High Speed, Dual, 2
ADP3630:  High Speed, Dual, 2 A MOSFET Driver The ADP3629/ADP3630/ADP3631 are dual, high
2009-10-31 11:22:45646
ADP3631: High Speed, Dual, 2
ADP3631:  High Speed, Dual, 2 A MOSFET Driver The ADP3629/ADP3630/ADP3631 are dual, high
2009-10-31 11:25:21652
ADP3629:  High Speed, Dual, 2 A MOSFET Driver, inverting A/B input pins The ADP3629/ADP3630
2009-11-09 11:21:03671
2009-11-09 11:23:34577
2009-11-09 11:26:34623
MAX9643 (a high-speed 60V precision unidirectional)
The MAX9643 is a high-speed 60V precision unidirectionalcurrent-sense amplifier ideal for a wide
2011-09-26 11:58:5912
High-speed Digital Design 中文版
电子发烧友网站提供《High-speed Digital Design 中文版.txt》资料免费下载
2012-05-03 16:08:550
MAX11190数据资料
approximationanalog-to-digital converter (ADC). This highperformancedual ADC includes high-dynamic rangesample-and-holds and a high-speed seri
2013-08-23 16:25:1516
High Speed Converter Evaluation Platform_HSC-ADC-EVALC
ADI high Speed Convert FPGA Evaluation Platform
2015-11-24 16:40:150
High-Speed_Digital_System_Design
高速数字系统设计High-speed digital system design
2016-02-23 11:58:0120
PCB制作,A Practical Guide to High-Speed Printed-Circuit-Board Layout
2016-12-17 15:03:580
2016-12-17 20:59:4362
Designing High Speed Active Filt
Designing High Speed Active Filters
2017-03-24 15:32:380
ADS7-V2EBZ High Speed Evaluation Board
2021-02-19 15:25:308
MAX33076E: High-Speed Quad RS-422/RS-485 Receivers with ±65V Fault Protection, ±25V CMR, and ±25kV ESD Protection Data Sheet MAX33076E: Hi
电子发烧友网为你提供ADI(ADI)MAX33076E: High-Speed Quad RS-422/RS-485 Receivers with ±65V Fault Protection
2023-10-13 18:34:17
MAX22195: High-Speed, Octal, Industrial Digital Input with Parallel Output Data Sheet MAX22195: High-Speed, Octal, Industrial Digital Input
电子发烧友网为你提供ADI(ADI)MAX22195: High-Speed, Octal, Industrial Digital Input with Parallel Output Data
2023-10-17 19:15:17
已全部加载完成
