data capture hardware via the high-speed FMC+ connector.High-Speed Data Converter Pro Software
2018-08-03 07:46:44
1 IР概述
High Speed l0 IP适用于PH1A(PH1A60、PH1A90、PH1A180、PH1A400)系列器件和PH1A100系列器件,它主要由时钟缓冲、IOL以及延迟单元等原语
2023-08-09 07:43:37
请问有用过high-speed-selectIO的大佬吗?|生成的例化模板中端口为bg_pin_nc怎么处理的呢?我实现这一步就报错了,想问问应该怎么改?
2022-09-23 11:42:21
high speed counter schematic
2020-12-21 16:50:04
By John Ardizzoni, (john.ardizzoni@analog.com)Despite its critical nature in high-speed circuitry
2015-01-23 11:01:23
Design And Application Guide For High Speed MOSFET Gate Drive CircuitsThe main purpose
2009-03-27 16:04:24
2009-03-31 13:52:49
Disturbance Observer and Feedforward Design for a High-Speed Direct-Drive Positioning Table(高速直流驱动定位表的扰动观测器和前馈设计).pdf
2017-10-04 11:12:58
Jitter, Noise, and Signal Integrity at High-Speed-Mike PengLi
2015-10-26 15:03:11
you'll need to install and maintain today's high-speed, multi-service transmission networks.
2019-07-12 07:46:19
我很高兴为您带来下一期TI信号链基础知识,由我曾经工作过的最有才华的RF /高速系统公司之一 - 罗伯特·凯勒(Robert Keller)撰写。请享用。随着模数转换器(ADC)的采样率和输入频率
2017-04-26 12:04:25
high-speed amplifier, the LMH3401 to drive the high-speed analog-to-digital converter (ADC), the ADS54J60
2018-07-13 00:50:56
amplifier, the LMH6401, to drive the high-speed analog-to-digital converter (ADC), the ADS54J60
2018-09-04 09:02:25
of Feedback Capacitancen High-Speed Current-to-Voltage Converters, andthe Effects of Inverting Input
2018-11-22 09:34:39
material, a common approach used by most of the high-speed I/O standards for cost-effective
2019-02-15 11:53:51
The DG2302 is a high-speed, 1-bit, low power, TTLcompatiblebus switch. Using sub-micron CMOS
2008-09-28 22:19:16
15 High-Speed Circuit Board Signal Integrity:Characteristics and Construction of Printed Wiring Boards
2009-02-17 10:21:14
0 业界功能最为齐全的高速接口IC产品线-High-Speed Interconnect (8th edition)
2009-03-23 21:36:06
15 Ground and VCC Bounce of High-Speed Integrated Circuits
The purpose of this paper is to give
2009-03-30 00:16:50
30 High-speed Digital Design - Johnson & Graham.pdf
2009-04-23 23:19:16
0 高速微控制器用户指南:High-Speed Microcontroller User’s Guide
1. INTRODUCTION..92. ORDERING INFORMATION103.
2009-05-11 09:40:30
20 High-Speed Differential Signaling in Cyclone Devices
From high-speed backplane applications
2009-05-14 10:42:23
21 The AD9260 is a 16-bit, high-speed oversampled analog-to-digital converter (ADC) that offers
2009-09-10 10:05:41
13 Interfacing to High Speed ADCs via SPI:This application note describes how to use the SPI port
2009-09-30 19:43:39
15 High-Speed Audio Ripping,Encoding and Playback: Entertainment Systems Get a Makeover:The way
2009-09-30 20:00:03
28 with a high-speed serial interface.Unlike the conventional practice of specifying performance ata single sample rate only, the ADC104S021 is ful
2009-10-12 10:34:00
20 with a high-speed serial interface.Unlike the conventional practice of specifying performance ata single sample rate only, the ADC104S101 is ful
2009-10-12 10:37:12
12 The TJA1051 is a high-speed CAN transceiver that provides an interface between aController Area
2009-11-10 13:43:15
21 The TJA1042 is a high-speed CAN transceiver that provides an interface between aController Area
2009-11-10 13:47:28
51 High-Speed Board Design TechniquesThe most important factor in the design of many systems today
2009-11-22 19:48:02
20 High Speed Measurements on Modulated Signals:This paper deals with the design and construction
2010-03-03 08:39:15
29 The TLC5540 is a high-speed, 8-bit analog-to-digital converter (ADC) that converts at sampling
2010-06-02 09:01:07
18 range from 2.7V to 5.5V. It requires very little power, even when operating at the full data rate. At lower data rates, the high speed o
2010-06-03 14:59:38
39 ), a high-speed 10-bit ADC, an on-chip reference, and a high-speed serial interface. The device contains an on-chip control register allowi
2010-06-06 15:33:50
24 ABSTRACTThe Texas Instruments THS1041 is a 10-bit, 40-MSPS, high-speed analog-to-digitalconverter
2010-06-06 17:01:15
4 IntroductionThe THS1041 from Texas Instruments (TI) is a 10-bit, 40-MSPS, CMOS high-speed
2010-06-06 17:03:40
5 The TSW1250 includes a High-Speed LVDS Deserializer and Analysis System which provide
2010-06-12 09:41:46
10 The CD74HC125 contains four independent 3-state buffers, each having its own output enable input
2010-07-15 14:49:35
11 The ’HC534, ’HCT534, ’HC564, and ’HCT564 are high speed Octal D-Type Flip-Flops manufactured
2010-07-25 18:35:26
12
The ’HC533, ’HCT533, ’HC563, and CD74HCT563 are high speed Octal Transparent Latches manufactured
2010-07-30 12:28:47
19 The CD74HC40103 is manufactured with high-speed silicon-gate technology and consists of an 8-stage
2010-08-09 22:20:35
26 The CD74HC4017 is a high-speed silicon-gate CMOS 5-stage Johnson counter with ten decoded outputs.
2010-08-10 17:08:37
20 The CY74FCT399T is a high-speed quad 2-input register that selects four bits of data from either
2010-08-10 21:51:22
9 The CY74FCT399T is a high-speed quad 2-input register that selects four bits of data from either
2010-08-11 15:32:43
21 The CD74HC138 is a high-speed silicon-gate CMOS decoder well suited to memory address decoding
2010-08-12 00:12:51
17 The CD74HC4543 high-speed silicon-gate device is a BCD to 7-segment latch/decoder/driver designed
2010-08-12 15:11:50
21 The TS3USB221 is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-08-14 00:34:19
28 The TS3USB30 is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-08-14 00:37:02
12 The TS3USB31 is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-08-14 00:38:39
19 The SN74LV4046A is a high-speed silicon-gate CMOS device that is pin compatible with the CD4046B
2010-08-20 18:27:06
22 The uA9638C is a dual high-speed differential line driver designed to meet ANSI Standard EIA
2010-09-04 17:28:46
13 The TS3USB221A is a high-bandwidth switch specially designed for the switching of high-speed USB
2010-09-09 23:54:03
23 The TS3USB221E is a high-bandwidth switch specially designed for the switching of high-speed USB
2010-09-10 00:00:26
32 The TS3USB31E is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-09-10 00:07:55
15 The THS4631 is a high-speed, FET-input operational amplifier designed for applications requiring
2010-09-11 22:06:28
31 The THS3001 is a high-speed current-feedback operational amplifier, ideal for communication
2010-09-11 23:14:12
45 The OPA2832 is a dual, low-power, high-speed, fixed-gain amplifier designed to operate on a single
2010-09-12 23:31:16
11 The PGA870 is a wideband programmable-gain amplifier (PGA) for high-speed signal chain and data
2010-09-18 23:49:13
27 power MOSFETs. The driver uses the industry-standard footprint but adds high speed switching performance.
The wide input voltag
2010-09-20 09:22:15
34 The TL714C is a high-speed differential comparator fabricated with bipolar Schottky process
2010-09-23 19:34:32
22 voltage range, high-speed, low quiescent current, and tiny TSSOP-8 packaging enable use in a variety of applications.
Input common-mod
2010-09-24 22:24:20
15 voltage range, high-speed, low quiescent current, and tiny TSSOP-8 packaging enable use in a variety of applications.
Input common-mod
2010-09-24 22:26:10
19 The TPS2811 dual high-speed MOSFET driver is capable of delivering peak currents of 2 A into highly
2010-09-27 21:46:32
16 The TLE202x and TLE202xA devices are precision, high-speed, low-power operational amplifiers using
2010-12-13 21:20:48
46 for high-speed, high dynamic performance data converters, they gain significance when it comes to high-resolution imaging applications. The
2009-04-16 15:53:38
1891 ![](https://file1.elecfans.com//web2/M00/A4/C3/wKgZomUMNZWAX-P0AAAuBc3bp_c403.gif)
Abstract: As integrated circuits (ICs) speed up, the rise/fall times of most pulse and function
2009-04-20 11:17:56
1455 ![](https://file1.elecfans.com//web2/M00/A4/C7/wKgZomUMNaiAdGmsAAAhof_QDac539.gif)
Abstract: A handful of components are integrated into a circuit that creates a high-quality random
2009-04-20 15:05:49
916 ![](https://file1.elecfans.com//web2/M00/A4/C8/wKgZomUMNaqALaLZAAAoYtb2eCs862.gif)
2009-04-20 15:09:34
947 ![](https://file1.elecfans.com//web2/M00/A4/C8/wKgZomUMNaqANwjLAAAhof_QDac363.gif)
Abstract: This application note addresses external memory interfacing with Maxim high-speed
2009-04-23 15:35:10
918 ![](https://file1.elecfans.com//web2/M00/A4/CC/wKgZomUMNb6AanzSAAAPcB2L7FU471.gif)
Abstract: This application note provides a much-needed working high-speed I2C example.
2009-04-24 15:02:48
832 ![](https://file1.elecfans.com//web2/M00/A4/CE/wKgZomUMNcKAO2nBAACeAYgcnvQ541.jpg)
receivers that include baseband-sampling, high-speed ADCs. A VCM is especially important for single-supply, low-voltage circuits with DC-couple
2009-04-25 09:29:05
539 ![](https://file1.elecfans.com//web2/M00/A4/CF/wKgZomUMNcaAU-RUAABT3i5oBfQ061.gif)
of the MAX5195 high-speed digital-to-analog converter (DAC) to design a reliable resistor network for interface this LVPECL-based high-speed DAC to
2009-04-25 10:08:30
824 ![](https://file1.elecfans.com//web2/M00/A4/CF/wKgZomUMNceALvREAAAVvbUdRRc725.gif)
2009-04-29 09:29:03
757 ![](https://file1.elecfans.com//web2/M00/A4/D3/wKgZomUMNdqABHDUAAAoYtb2eCs477.gif)
2009-05-01 10:49:50
905 ![](https://file1.elecfans.com//web2/M00/A4/D5/wKgZomUMNeOARreuAABT3i5oBfQ020.gif)
2009-05-01 11:06:44
527 ![](https://file1.elecfans.com//web2/M00/A4/D5/wKgZomUMNeOAA_6SAAAVvbUdRRc841.gif)
2009-05-08 10:29:39
605 ![](https://file1.elecfans.com//web2/M00/A4/DD/wKgZomUMNgKAKnHMAABT3i5oBfQ375.gif)
2009-05-08 10:41:03
701 ![](https://file1.elecfans.com//web2/M00/A4/DE/wKgZomUMNgOAIFUeAAAVvbUdRRc602.gif)
设置高速ADC的共模输入电压范围--High-Speed ADC Sets Input Common-Mode Range
Abstract: The input common-mode
2009-06-09 20:41:43
1378 ![](https://file1.elecfans.com//web2/M00/A5/00/wKgZomUMNoKAItgXAABT3i5oBfQ743.gif)
not be the most important parameters for high-speed, high dynamic performance data converters, they gain significan
2009-08-21 09:40:22
1915 ![](https://file1.elecfans.com//web2/M00/A5/3B/wKgZomUMN3-AUgc-AAAuBc3bp_c073.gif)
ADP3629: High Speed, Dual, 2 A MOSFET Driver
The ADP3629/ADP3630/ADP3631 are dual, high current
2009-10-31 11:20:30
678 ADC Input Translator
Abstract: Using resistor dividers to scale the differential inputs
2009-11-08 17:57:42
1873 ![](https://file1.elecfans.com//web2/M00/A5/59/wKgZomUMOAaAYGKPAABeKhsUNKs647.gif)
ADP3629: High Speed, Dual, 2 A MOSFET Driver, inverting A/B input pins
The ADP3629/ADP3630
2009-11-09 11:21:03
671 ![](https://file1.elecfans.com//web2/M00/A5/59/wKgZomUMOAaAGFgOAAAbUJLLf7Q075.png)
ADP3630: High Speed, Dual, 2 A MOSFET Driver
2009-11-09 11:23:34
577 ![](https://file1.elecfans.com//web2/M00/A5/59/wKgZomUMOAaAZKMCAAAbUJLLf7Q778.png)
ADP3631: High Speed, Dual, 2 A MOSFET Driver
2009-11-09 11:26:34
623 ![](https://file1.elecfans.com//web2/M00/A5/59/wKgZomUMOAaAKBYFAAAbUJLLf7Q201.png)
The MAX9643 is a high-speed 60V precision unidirectionalcurrent-sense amplifier ideal for a wide
2011-09-26 11:58:59
12 电子发烧友网站提供《High-speed Digital Design 中文版.txt》资料免费下载
2012-05-03 16:08:55
0 approximationanalog-to-digital converter (ADC). This highperformancedual ADC includes high-dynamic rangesample-and-holds and a high-speed seri
2013-08-23 16:25:15
16 ADI high Speed Convert FPGA Evaluation Platform
2015-11-24 16:40:15
0 高速数字系统设计High-speed digital system design
2016-02-23 11:58:01
20 The 74VHC164 is an advanced high-speed CMOS device fabricated with silicon gate CMOS technology.
2016-11-21 15:40:34
3 PCB制作,A Practical Guide to High-Speed Printed-Circuit-Board Layout
2016-12-17 15:03:58
0 Designing High Speed Active Filters
2017-03-24 15:32:38
0 will:
Learn about Linear Technology’s new LTC2274 high-speed ADC, with JESD204 compliant serial interface
2018-06-22 09:17:00
2549 Firefly-RK3288 开发板上的 AD 接口分为:高速 ADC 流接口 (High-speed ADC Stream Interface)、温度传感器 (Temperature Sensor)、 逐次逼近ADC (Successive Approximation Register)。
2019-11-27 09:16:06
2021 ![](https://file.elecfans.com/web1/M00/AE/D3/o4YBAF3d1niAeDM6AAGZea56zx4907.png)
AIO-3288C 开发板上的 AD 接口分为:高速 ADC 流接口 (High-speed ADC Stream Interface)、温度传感器 (Temperature Sensor)、
2019-12-16 15:27:52
1399 AIO-3288J 开发板上的 AD 接口分为:高速 ADC 流接口 (High-speed ADC Stream Interface)、温度传感器 (Temperature Sensor)、
2019-12-26 14:34:05
1492 ADS7-V2EBZ High Speed Evaluation Board
2021-02-19 15:25:30
8 电子发烧友网为你提供ADI(ADI)MAX33076E: High-Speed Quad RS-422/RS-485 Receivers with ±65V Fault Protection
2023-10-13 18:34:17
![](https://www.elecfans.com/uploads/190218/2927106-1Z21P94211255.png)
电子发烧友网为你提供ADI(ADI)MAX22195: High-Speed, Octal, Industrial Digital Input with Parallel Output Data
2023-10-17 19:15:17
