Converter封装24 ld S/B or B/B CerDIPAD767SD/883B产品描述Microprocessor-Compatible 12-Bit D/A Converter封装24
2020-01-10 09:41:41
CerDIP5962-9581501HXA产品描述Dual Channel, 12-Bit, 40 MSPS MCM A/D Converter with DC-Coupled Analog
2019-09-07 07:49:02
Discriminator封装14 ld CerDIP GLASS SEAL5962-8850902XA产品描述Quad 12-Bit Microprocessor-Compatible D/A Converter封装28
2019-09-18 09:54:16
Multiplying D/A Converter封装28 ld LCC5962-8865901XA产品描述12-Bit Ultrahigh Speed Multiplying D/A Converter封装28
2019-09-07 08:02:49
converter sampling rateLTC2151CUJ-12#PBF&a d converter specificationsLTC2152CUJ-12#PBF&a/d
2020-10-09 09:33:32
JLCC5962-88659013A产品描述12-Bit Ultrahigh Speed Multiplying D/A Converter封装28 ld LCC5962-8865901XA产品描述12-Bit
2020-01-10 09:03:06
module (EVM) allows for the evaluation of device ADC12DJ3200. The ADC12DJ3200 is a low-power, 12-bit
2018-08-03 07:46:44
ADS7823E250 - 12-Bit, Sampling A/D Converter with I2C INTERFACE - Burr-Brown Corporation
2022-11-04 17:22:44
ADS7823E2K5 - 12-Bit, Sampling A/D Converter with I2C INTERFACE - Burr-Brown Corporation
2022-11-04 17:22:44
ADS7823EB2K5 - 12-Bit, Sampling A/D Converter with I2C INTERFACE - Burr-Brown Corporation
2022-11-04 17:22:44
HI5810 - CMOS 10 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
HI5810JIB - CMOS 10 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
HI5810KIB - CMOS 10 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
HI5810KIJ - CMOS 10 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
HI5810KIP - CMOS 10 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
HI5812 - CMOS 20 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
HI5812KIJ - CMOS 20 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
HI5813 - CMOS 3.3V, 25 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
HI5813JIB - CMOS 3.3V, 25 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
HI5813JIJ - CMOS 3.3V, 25 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
HI5813KIB - CMOS 3.3V, 25 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
HI5813KIJ - CMOS 3.3V, 25 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold - Intersil Corporation
2022-11-04 17:22:44
LTC1282BC - 3V 140ksps 12-Bit Sampling A/D Converter with Reference - Linear Technology
2022-11-04 17:22:44
LTC1282BCN - 3V 140ksps 12-Bit Sampling A/D Converter with Reference - Linear Technology
2022-11-04 17:22:44
LTC1282BCSW - 3V 140ksps 12-Bit Sampling A/D Converter with Reference - Linear Technology
2022-11-04 17:22:44
因为种种原因没有代理,也不能到学校下载,哪位好心帮忙下个资料.a cmos 8-bit high speed a A/D converter ic ieee 1985
2021-06-25 07:28:26
The ADS8506 is a complete low power, single 5-V supply, 12-bit sampling analog-to-digital
2008-08-01 01:03:0418 The ADS8504 is a complete 12-bit sampling A/D converter using state-of-the-art CMOS structures.
2008-08-08 00:52:5220 The ADS8508 is a complete 12-bit sampling analog-to-digital (A/D) converter using state-of-the-art
2008-08-08 00:54:1229 The ADS7883 is a 12-bit, 3-MSPS analog-to-digital converter (ADC). The device includes a capacitor
2008-08-19 22:48:1116 The MAX1211 is a 3.3V, 12-bit analog-to-digital converter (ADC) featuring a fully differential
2008-10-09 14:58:088 It contains a 12-bit shift register and 12 output drivers. Display data is serially written into the internal 12-bit shift register on the rising
2008-10-28 13:36:119 The ADS7844 is an 8-channel, 12-bit sampling analog-to-digital converter (ADC
2008-12-18 15:21:4019 The ADS8344 is an 8-channel, 16-bit sampling analog-to-digital converter (ADC
2008-12-18 20:17:2423 The ADS801 is a low power, monolithic 12-bit, 25MHzanalog-to-digital converter utilizing a small
2008-12-18 20:23:3018 The ADS7818 is a 12-bit sampling analog-to-digitalconverter (A/D) complete with sample/hold
2008-12-18 20:51:2126 The ADS7841 is a 4-channel, 12-bit sampling analogto-digital converter (ADC) with a synchronous
2008-12-19 19:18:1665 The AD574A is a complete 12-bit successive-approximationanalog-to-digital converter with 3-state
2008-12-21 15:37:1150 and 12-bit output.With over 69dB of spurious free dynamic range and worstcase frequency resolution of 0.009Hz, the NCO12 provide
2009-01-06 16:27:008 The HI5800 is a monolithic, 12-bit, sampling Analog-to-Digital Converter fabricated in the HBC10
2009-01-08 18:28:2216 12-Bit, +3.3V, 130MSPS, High Speed D/A ConverterThe ISL76161 is a 12-bit, 130MSPS (Mega-Samples
2009-01-18 22:20:1315 The ADuC814 is a fully integrated 247 kSPS, 12-bit data acquisitionsystem incorporating a high
2009-09-04 09:53:4017 The AD73291 is an 8-channel, 12-bit plus sign successiveapproximation ADC designed on the iCMOS
2009-09-09 08:16:0510 Layout Tips for 12-Bit A/D Converter Application:This Application Note originally started
2009-09-18 09:29:310 The AD5516 is a 16-channel, 12-bit voltage-output DAC. Theselected DAC register is written to via
2009-09-21 08:58:3411 self-calibrating (correctinglinearity and zero errors) 13-bit (12-bit + sign) analogto-digital converter (ADC) and sample-and-hol
2009-10-12 08:08:5210 The AD6652 is a mixed-signal IF to baseband receiver consisting of dual 12-bit 65 MSPS ADCs
2009-10-24 11:29:0844 The AD7298 is a 12-bit, high speed, low power, 8-channel, successive approximation ADC
2009-12-07 15:52:3619 The AD7170 is a very low power 12-bit analog-to-digital converter (ADC). It contains a precision
2009-12-07 16:18:3929 The ADS7862 is a dual 12-bit, 500kHz analog-to-digital converter (A/D) with 4 fully differential
2010-06-01 16:56:4616 The ADS7861 is a dual, 12-bit, 500kHz, Analog-to-Digital (A/D) converter with four fully
2010-06-01 17:10:3216 The TLV2553 is a 12-bit switched-capacitor successive-approximation analog-to-digital converter
2010-06-04 15:32:0222 The TLV2553 is a 12-bit, switched-capacitor, successive-approximation, analog-to-digital converter
2010-06-04 15:35:2314 The THS1230 is a CMOS, low power, 12-bit, 30 MSPS analog-to-digital converter (ADC) that operates
2010-06-05 16:52:5024 The THS1215 is a CMOS, low power, 12-bit, 15 MSPS analog-to-digital converter (ADC) that operates
2010-06-05 17:13:5025 The THS1209 is a CMOS, low-power, 12-bit, 8 MSPS analog-to-digital converter (ADC). The speed
2010-06-05 17:17:3318 The THS12082 is a CMOS, low-power, 12-bit, 8 MSPS analog-to-digital converter (ADC). The speed
2010-06-05 17:42:3931 The THS1207 is a CMOS, low-power, 12-bit, 6 MSPS analog-to-digital converter (ADC). The speed
2010-06-05 17:51:0625 The THS1206 is a CMOS, low-power, 12-bit, 6 MSPS analog-to-digital converter (ADC). The speed
2010-06-05 17:54:0827 The ADS8512 is a complete low-power, single 5-V supply, 12-bit sampling analog-to-digital
2010-06-06 14:32:5717 The ADS807 is a high-speed, high dynamic range, 12-bit pipelined Analog-to-Digital (A/D) converter
2010-06-06 14:49:0413 The ADS804 is a high-speed, high dynamic range, 12-bit, pipelined Analog-to-Digital
2010-06-06 14:51:2435 The ADS803 is a high-speed, high dynamic range, 12-bit pipelined Analog-to-Digital (A/D) converter
2010-06-06 14:53:3330 The ADS802 is a low-power, monolithic 12-bit, 10MHz Analog-to-Digital (A/D) converter utilizing
2010-06-06 14:55:4720 The ADS800 is a low power, monolithic 12-bit, 40MHz Analog-to-Digital (A/D) converter utilizing
2010-06-06 14:58:2116 The ADS7924 is a four-channel, 12-bit, analog-to-digital converter (ADC) with an I2C™
2010-06-06 15:01:4641 The ADS7882 is a 12-bit 3-MSPS A-to-D converter with 2.5-V internal reference. The device includes
2010-06-06 15:04:2827 The TLV5614IYZ is a quadruple, 12-bit, voltage output digital-to-analog converter (DAC
2010-06-08 10:20:4513 The TLV5613 is a 12-bit voltage output digital-to-analog converter (DAC) with a 8-bit
2010-06-08 10:24:1825 The THS5661A is a 12-bit resolution digital-to-analog converter (DAC) specifically optimized
2010-06-08 10:37:5330 The DAC8043 is a 12-bit current output multiplying digital-to-analog converter (DAC
2010-06-08 10:45:2135 The DAC7822 is a dual, CMOS, 12-bit, current output digital-to-analog converter (DAC). This device
2010-06-08 10:48:376 The DAC7821 is a CMOS 12-bit current output digital-to-analog converter (DAC). This device operates
2010-06-08 10:50:1135 The DAC7728 is a low-power, octal, 12-bit digital-to-analog converter (DAC). With a 5V reference
2010-06-08 10:57:4112 The DAC7718 is a low-power, octal, 12-bit digital-to-analog converter (DAC). With a 5V reference
2010-06-08 11:00:5313 The DAC7716 is a high-accuracy, quad-channel, 12-bit digital-to-analog converter (DAC
2010-06-08 11:03:109 The DAC7678 is a low-power, voltage-output, eight-channel, 12-bit digital-to-analog converter (DAC
2010-06-08 11:09:2026 DESCRIPTIONThe DAC7624 and DAC7625 are 12-bit quad voltageoutput digital-to-analog converters
2010-06-08 11:11:4819 DESCRIPTIONThe DAC7621 is a 12-bit digital-to-analog converter(DAC) with guaranteed 12-bit
2010-06-08 11:14:0537 DESCRIPTIONThe DAC7613 is a 12-bit, voltage output digital-to-analog converter with guaranteed
2010-06-08 11:28:2322 The DAC7565 is a low-power, voltage-output, four-channel, 12-bit digital-to-analog converter (DAC
2010-06-08 11:38:5026 The DAC7564 is a low-power, voltage-output, four-channel, 12-bit digital-to-analog converter (DAC
2010-06-08 11:40:2932 The DAC5662A is a monolithic, dual-channel 12-bit high-speed digital-to-analog converter (DAC
2010-06-08 11:58:5923 The DAC2932 is a dual 12-bit, current-output digital-to-analog converter (DAC) designed to combine
2010-06-08 12:00:5312
This 12-bit to 24-bit multiplexed D-type latch is designed for 1.65-V to 3.6-VCC operation.
2010-07-30 16:53:437
This 12-bit to 24-bit multiplexed D-type latch is designed for 1.65-V to 3.6-V VCC operation.
2010-07-30 16:57:1713 This 12-bit to 24-bit registered bus exchanger is designed for 1.65-V to 3.6-V VCC operation.
2010-08-21 16:16:2025 This 12-bit to 24-bit bus exchanger is designed for 1.65-V to 3.6-V VCC operation.
2010-08-21 16:18:0430 12-Bit Thermometer Using an 8-Bit µC and Assembler
This application note explains how to implement
2009-03-31 22:25:39730 This application note explains how to implement a 12-bit digital thermometer using a low-cost
2009-04-17 10:18:351321 to automatically control the conversion the MAX190 12-bit SAR analog-to-digital converter (ADC). The delay between conversions can be programed
2009-05-08 10:03:36739 analog-to-digital converter (ADC). It contains a precision 12-bit Σ-Δ ADC and an on-chip oscillator. C
2009-12-01 16:20:39680 The AD9230 is a 12-bit monolithic sampling analog-to-digital converter optimized for high performance, low power, and ease of use.
2017-10-11 09:20:1114 The AD9432 is a 12-bit, monolithic sampling analog-to-digital converter (ADC) with an on-chip
2017-10-11 11:21:517 The AD9433 is a 12-bit, monolithic sampling analog-to-digital converter (ADC) with an on-chip track-and-hold circuit and is designed for ease of use.
2017-10-11 11:24:053 The AD9634 is a 12-bit, analog-to-digital converter (ADC) with sampling speeds of up to 250 MSPS.
2017-10-11 12:58:1110 AD9207: 12-Bit, 6 GSPS, JESD204B/C Dual Analog-to-Digital Converter Preliminary Data Sheet
2021-01-27 21:51:237 AD9228: Quad, 12-Bit, 40/65 MSPS Serial LVDS 1.8 V A/D Converter Data Sheet
2021-01-28 14:17:2510 电子发烧友网为你提供ADI(ADI)AD7927: 8-Channel, 200 kSPS, 12-Bit ADC with Sequencer in 20-Lead TSSOP Data
2023-10-12 18:50:13
查看更多
