电子发烧友App
硬声App
电子发烧友网>模拟技术>AD技术>Design Guidelines for High-Per
收藏
查看更多
432W High-Efficiency Single-Phase Synchronous Buck Converter Reference Design
design: (98.4% Peak)High power density: 432W/9.56 Sq. InchesProgrammable current limit with Hiccup ModePrecision voltage reference accuracy of +/-1.5%`
2015-04-15 09:39:48
7V/350mW准谐振非隔离型反激式设计
描述PMP20457 is a high line 190-253VAC input to 7V/350mW power supply in a small form-factor
2018-12-26 15:31:03
Design And Application Guide For High Speed MOSFET Gate Drive Circuits
Design And Application Guide For High Speed MOSFET Gate Drive CircuitsThe main purpose
2009-03-27 16:04:24
2009-03-31 13:52:49
Design Note for DN06018/D
Design Note for DN06018/D12V or 24Vin DC, Constant Current LED Driver Key
2009-11-19 17:23:03
Design and Preparation High Eff iciency Thin2Film Transformer at 200MHz
Design and Preparation High Eff iciency Thin2Film Transformer at 200MHzAbstract :A novel microwave
2009-08-08 09:42:31
HIGH CURRENT OFF LINE POWER SUPPLY
Design Engineers are constantly pushed to reduce thespace and cost of the power supply
2009-05-12 11:01:35
A 1.9 GHz Low Noise Amplifier optimised for high IP3 using BFP540
Infineon’s BFP540 is a high performance, lowcost silicon bipolar transistor housed in a
2009-05-12 13:30:36
Antenna Design and RF Layout Guidelines
本帖最后由 lee_st 于 2017-10-31 09:01 编辑 Antenna Design and RF Layout Guidelines
2017-10-21 20:22:36
2017-09-28 12:26:33
Designing High-Performance Video Systems with the AXI Interconnect
to build the design around.Together, the AXI interconnect and AXI MIG implement a high
2012-01-26 18:57:03
Disturbance Observer and Feedforward Design for a High-Speed Direct-Drive Positioning Table(高速直流驱动定位表的扰动观测器和前馈设计)
Disturbance Observer and Feedforward Design for a High-Speed Direct-Drive Positioning Table(高速直流驱动定位表的扰动观测器和前馈设计).pdf
2017-10-04 11:12:58
EMC Design Guidelines For Electronic Modules
EMC Design Guidelines For Electronic ModulesThe objective of this document is to incorporate EMC
2009-12-17 15:43:19
HIP5061 HIGH EFFICIENCY, HIGH PERFORMANCE,HIGH POWER CONVERTER
IntroductionAs the complexity of sophisticated, modern day equipmentgrows, the need for high
2009-05-12 11:13:19
I2S Master bits_per_sample != bits_per_chan情况下工作不正常怎么解决?
(datasheet要求SCK频率为WS的64倍)。现象:使用逻辑分析仪抓包发现每个channel的sck数量始终等于代码中定义的采样深度(bits_per_sample),与通道深度无关
2023-02-16 06:33:09
LabVIEW Development Guidelines
2015-07-01 10:56:50
NVIDIA上海/北京/深圳 招聘 Physical Design Engineer
Hi AllNVIDIA目前在上海北京深圳招聘Physical Design Engineer的职位,职位描述如下,感兴趣的朋友可以发送简历到tracyw@nvidia.com
2014-06-18 10:43:09
NVIDIA招聘Sr. Physical Design Engineer
design for NVIDIA GPU and Mobile chipsParticipate invarious aspects of physicaldesign, including full
2014-05-23 16:34:03
OPA1602AIDGKR
OPA1602 DUAL, SOUNDPLUS HIGH-PER
2023-04-06 19:04:43
PCB设计规范 PCB Design Guidelines Application Note
PCB设计规范 PCB Design Guidelines Application Note 英文资料  [hide][/hide]
2009-12-09 13:48:56
PCI Express Board Design Guidelines
PCI Express Board Design GuidelinesThis document provides practical, common guidelines
2011-01-28 17:40:18
PCIE板设计规则--PCI Express Board Design Guidelines
PCI Express  Board Design Guidelines -PCIE板设计规则
2009-03-26 22:27:19
Reference Design - High Efficiency Two-Phase Synchronous Buck Delivers 300W
at 300KHz (per phase) delivers small size and greater than 96% efficiency.特性Efficiency approaches 97
2015-04-20 09:55:23
Synthesiable High Performance SDRAM Contoller
Synthesiable High Performance SDRAM ContollerSynchronous DRAMs are available in speed grades above
2009-12-17 17:02:58
TRIPLE GALVANIC INSULATED HIGH SIDE DRIVING
TRIPLE GALVANIC INSULATED HIGH SIDE DRIVINGWITH TD310The TD310 is a triple MOS or IGBT driver
2009-05-12 09:50:07
[分享] PADS VX.2.2
`下载:http://www.dongeasy.com/hardware-design/pcb-design-guidelines/27975.html`
2017-08-27 08:45:31
ad18.0.11下载及破解教程,下载从速
`[url=]http://www.dongeasy.com/hardware-design/pcb-design-guidelines/44199.html[/url]`
2018-01-30 19:29:44
springer 2011 classic book]Operational Amplifiers: Theory and Design, 2nd
have been added.Operational Amplifiers – Theory and Design, Second Edition presents high
2012-01-04 15:21:48
使用RS-485驱动器的差分高速数字输出模块的设计包括BOM及层图
描述The differential Pulse Train Output (PTO) module TI Design illustrates the design of a
2018-09-20 08:47:11
分享:Cadence OrCAD and Allegro 17.20.033 Hotfix
`http://www.dongeasy.com/hardware-design/pcb-design-guidelines/13192.html`
2018-02-02 15:45:18
分享:PADS VX2.3下载(含破戒)
http://www.dongeasy.com/hardware-design/pcb-design-guidelines/50421.html
2018-03-26 08:44:16
用于36V电动工具的具有PFC和LLC的230V、400W高效电池充电器
`描述The design is a 400-W high efficiency battery charger power supply designed to charge wide range
2015-04-27 15:40:47
用于可编程逻辑控制器的高速数字输出PLC模块
描述This high speed digital output module TI Design for programmable logic controllers (PLCs
2018-09-25 09:05:49
精确的相电流检测48V三相逆变器包括BOM及层图
描述The TIDA-00913 reference design realizes a 48V/10A 3-phase GaN inverter with precision in-line
2018-10-19 15:34:32
薄款小型高频负载点电压调节器包括BOM及原理图
unique converter topology enables high efficiency while operating at 2 MHz per phase. This design
2018-09-18 08:59:29
高速PCB设计英文原版(High-Speed_Board_Design_Techniques)
2012-10-12 16:28:25
TMS320DM648 pdf datasheet
) are the highest-performance fixed-point DSP generation in the TMS320C6000™ DSP platform. The DM647/DM648 devices are based on the third-generation high-per
2008-08-07 20:42:3551
TMS320DM647 pdf datasheet
2008-08-07 21:22:3921
Measurement guidelines for DVB
Measurement guidelines for DVB-T system introductionMeasurement guidelines for DVB-Tsystem
2008-10-20 10:29:0135
RT9272 pdf datasheet (High Per
The RT9272 is a high efficiency step-up DC-DC converterspecifically designed for dual panel mobile
2008-12-12 20:56:0416
RT9270 pdf datasheet (High Per
The RT9270 is a high performance, low noise, fixedfrequency step up DC-DC Converter.
2008-12-12 21:07:408
EL7155 pdf datasheet (High Per
The EL7155 high performance pin driver with 3-state issuited to many ATE and level-shifting
2009-01-16 20:13:4425
EL7156 pdf datasheet (High Per
The EL7156 high performance pin driver with three-state issuited to many ATE and level-shifting
2009-01-16 20:14:5422
Design and Calculation of the
Design and Calculation of the Elastomer in High Precise Shear Beam Load Cell Abstract
2009-01-21 12:06:5111
Design And Application Guide For High Speed MOSFET Gate Drive Circuits ABSTRACTThe main purpose
2009-03-23 18:33:4350
PCI Express  Board Design Guidelines THIS DOCUMENT IS PROVIDED “AS IS” WITH NO WARRANTIES
2009-03-24 12:26:260
The Design of Power Line in Hi
The Design of Power Line in High-Speed PCB
2009-03-24 14:09:190
Guidelines for Designing High-
of high-speed analog devices in the digital arena.System speeds of 150 MHz and higher have become common for digitallogic. Systems that w
2009-03-28 14:51:4535
High-speed Digital Design - Jo
High-speed Digital Design - Johnson & Graham.pdf
2009-04-23 23:19:160
使用AT73C500或AT73C501芯片组设计高精密固态电
The purpose of this application note is toprovide guidelines for design of high-precision,solid
2009-06-12 14:38:0018
CMOS Logic Circuit Design
This book is based on the earlier Kluwer title Circuit Design for CMOS/VLSIwhich was published
2009-07-21 10:19:1950
High-performance RF design for
High-performance RF design for PXI:PXI presents a significant opportunity for RF instrumentation.
2009-07-23 22:50:2511
Design and Realization of a High-Precision Numerical Control
The design adopts self-designed high accurate voltage source, Micro Control Unit (MCU
2009-08-18 10:56:1110
TI处理器TMS320DM368
Operating temperature range (C) -40 to 85, 0 to 85 Highlights High-Per
2022-12-14 14:40:50
TI处理器TMS320DM365
Operating temperature range (C) 0 to 85, -40 to 85 Highlights High-Per
2022-12-14 14:40:54
PCB Design Guidelines for SIRF
PCB Design Guidelines for SIRFstar III Implementation1介绍1. 1基本的PCB layout guidelinesA. SIRF 典型的参考设计方案是:4层,6层,双面贴片,标准FR4板B. 所有的元件尽量采用贴片
2009-09-20 18:04:510
High Speed PCB Design--Ride th
High Speed PCB Design--Ride the Wave WorkshopPost Route Analysis of a HighSpeed PCB DesignDesign/Analysis forPower Delivery System (PDS)
2009-09-26 18:30:580
FS8810双N管 sot23-6 Dual N-Channel High Density Trench MOSFET (20V, 7A)
• Advanced Trench Process Technology• High Density Cell Design for Ultra Low On-Resis
2022-12-20 18:24:35
AD587,datasheet,pdf(High Preci
a proprietary ion-implanted buried Zener diode and laser wafer trimming of high stability thin-film resistors, the AD587 provides outstanding per
2009-10-23 10:14:0928
High Power Class D Audio Power
IR2011S, high speed high voltage gate driver IC. The design contains protection functionsand house keeping power supplies for ease of use. Th
2009-11-12 15:59:5348
Application Note AN-4147 Desig
This article presents some design guidelines for the RCDsnubber of flyback converters. When
2009-11-12 16:04:3053
High-Speed Board Design Techni
High-Speed Board Design TechniquesThe most important factor in the design of many systems today
2009-11-22 19:48:0220
Design And Application Guide f
Design And Application Guide for High Speed MOSFET Gate Drive Circuits:The main purpose
2009-11-26 11:20:2615
Application Note AN-4147Design
Application Note AN-4147Design Guidelines for RCD Snubber of Flyback
2009-11-27 11:10:3026
Data Path Design in High Perfo
Data Path Design in High Performance Reconfigurable DSP Processor Abstract In this paper, the data
2010-02-05 08:18:5317
High Speed Measurements on Mod
High Speed Measurements on Modulated Signals:This paper deals with the design and construction
2010-03-03 08:39:1529
LED照明系统设计指南(英文资料)
LED照明系统设计指南(英文资料) This application note provides guidelines for the process ofdesigning high
2010-04-03 11:39:3759
TLC5540: 8-Bit High-Speed Anal
rates up to 40 megasamples per second (MSPS). Using a semiflash architecture and CMOS process, the TLC5540 is able to convert at high speeds
2010-06-02 09:01:0718
PCM4202,pdf(PCM4202: High Perf
The PCM4202 is a high-performance, stereo audio analog-to-digital (A/D) converter designed
2010-06-13 10:32:4531
ATF1508AS,ATF1508ASL,pdf(High-
Features• High-density, High-performance, Electrically-erasable ComplexProgrammable Logic
2010-06-30 22:24:1421
Guidelines for Completion of a
These guidelines are provided to assist registered applicants in accurately completing the Form
2010-07-09 13:36:2411
Evaluating Microstrip with Tim
In the world of high-speed digital design, clock rates are increasing at a dramatic pace. Gigabit
2010-07-11 17:42:098
Agilent J-BERT N4903B High-Per
) solutions for R&D and manufacturing. The J-BERT N4903B high-performance serial BERT is the flagship of Agilent’s N4900 ser
2010-08-11 08:56:5922
MAX11209/MAX11211pdf (high-re
The MAX11209/MAX11211 are ultra-low-power (< 300µA active current) high-resolution serial-output
2010-08-22 10:13:2719
Reference Design Ensures Dynam
in a printer. The reference design shows how to use a MAX15005 power-supply controller as a SEPIC circuit to obtain a high-variable output volt
2009-03-23 21:28:05884
Abstract: This application note will help the designer of a high-performance multichannel
2009-04-16 16:06:21949
MAX1452 Diagnostic Clip Circui
output to some predefined values, also referred to as output clipping, can serve as an important diagnostic tool. The MAX1455 low-cost high-per
2009-04-20 16:28:551512
Reference Design for a High-Cu
Reference Design for a High-Current Power Supply with Lossless Current Sensing Using the MAX5060 abstract: This reference design shows ho
2009-05-02 10:09:291330
Reference Design for a Signal-
a reference design for a signal-lamp LED driver that consists of six strings of 4 LEDs per string and delivers 350mA per string. Becaus
2009-06-30 08:13:31988
Reference Design for a High-In
Reference Design for a High-Input-Voltage, High-Output-Current Buck Controller Using the MAX15046
2009-11-08 17:43:051130
Layout Guidelines with Example
Layout Guidelines with Example Layout for the MAX16922 PMIC Abstract: This application note
2010-02-21 09:59:452073
什么是cps (chip per second)
什么是cps (chip per second)  英文缩写: cps (chip per second) 中文译名: 码片速率单位,每秒码片
2010-02-22 17:23:291238
RCD电路设计指南
This article presents some design guidelines for the RCD snubber of flyback converters. When
2011-10-28 17:19:59172
High-speed Digital Design 中文版
电子发烧友网站提供《High-speed Digital Design 中文版.txt》资料免费下载
2012-05-03 16:08:550
ATMEL的ASIC设计资料(原版)
Introduction The Atmel ASIC Design Guidelines constitute a general set of recommendations intended
2012-05-24 15:58:130
[Johnson & Graham]1_High-speed Digital Design 中文版
电子发烧友网站提供《[Johnson & Graham]1_High-speed Digital Design 中文版.txt》资料免费下载
2012-09-23 02:15:490
High-Speed_Digital_System_Design
高速数字系统设计High-speed digital system design
2016-02-23 11:58:0120
2016-12-17 20:59:4362
Step-by-Step Design Process for the MAX16833 High-Voltage High-Brightness LED Driver, Part 2
Abstract: This application note details a step-by-step design process for the MAX16833 high
2017-03-31 16:58:559
ATBTLC1000硬件设计指南
This document details the hardware design guidelines for a customer to design the Atmel ATBTLC1000 IC onto their board.
2017-09-12 16:17:420
EE-418: ADSP-2156x Board Design Guidelines for Dynamic Memory Controller
2021-01-30 13:53:231
基于4455-LED-434-PER射频收发器的
View the reference design for 4455-LED-434-PER. http://www.elecfans.com/soft/ has thousands of reference designs to help bring your project to life.
2021-09-10 11:42:1311
PCB PDN design guidelines (PCB电源完整性设计指导) ------PCB叠放准则
PCB PDN design guidelines (PCB电源完整性设计指导) ------PCB叠放准则在本博客中,将来自不同来源的许多准则收集在一起。 它们在这里汇总以供参考。 优质的PDN设计并不需要满足所有要求。 而是应根据特定PCB电路的特性制定详细的设计准则。...
2022-01-06 12:19:3211
PCB PDN design guidelines (PCB电源完整性设计指导) ------组件选择和放置准则
PCB PDN design guidelines (PCB电源完整性设计指导) ------组件选择和放置准则1.所有连接器应位于板的一个边缘或一个角。在大多数设计中,连接电缆的连接器可以构成
2022-01-06 12:20:322
PCB PDN design guidelines (PCB电源完整性设计指导) ------PCB平面图指南
PCB PDN design guidelines (PCB电源完整性设计指导) ------PCB平面图指南在开始进行PCB布局之前,必须注意正确放置组件。 较低等级的模拟,高速数字和噪声电路
2022-01-06 12:22:334
PCB PDN design guidelines (PCB电源完整性设计指导) ------PCB去耦准则
PCB PDN design guidelines (PCB电源完整性设计指导) ------PCB平面图指南一、 不带电源平面1.为每个有源设备至少提供一个“本地”去耦电容器,并为板上分布的每个
2022-01-06 12:25:339
PCB PDN design guidelines (PCB电源完整性设计指导) ------PCB布局指南
PCB PDN design guidelines (PCB电源完整性设计指导) ------PCB布局指南1.携带高速数字信号或时钟的走线长度应最小化。高速数字信号和时钟通常是最强的噪声源。这些
2022-01-06 12:27:337
V853 PER1开发板PCB文件
V853_PER1开发板PCB文件,使用allegro进行设计
2022-10-21 15:14:020
VersaClock 7 PCB Layout Guidelines 手册
2023-01-10 19:06:045
VersaClock 7PCBLayout Guidelines 手册
2023-06-30 19:51:320
已全部加载完成
