电子发烧友App
硬声App
电子发烧友网>模拟技术>AD技术>ADC Input Translator
收藏
查看更多
超宽带系统中ADC前端匹配网络设计
为了取得较好的信号带内平坦度,引入了ADC 前端匹配电路的设计,特别是对于non-input buffer的ADC在高负载抗混叠滤波器应用场景下,前端匹配电路的设计在超宽带的应用中就更显得尤为重要。本文将以ADS58H40为例介绍ADC前端匹配电路的设计。
2013-03-27 10:58:223744
ADC_DAC在vhdl coading中做什么能增加相同输入的输出
to ADC im getting the same signal through DAC. Now for the same input signal i want the amplitude
2019-01-29 11:04:22
ADC_DELSIG快速滤波器串扰
ADC conversions. Either switch the input quickly with hardware control or Stop the ADC while
2019-03-11 14:31:25
ADC到16个或更多引脚?
or more ADC input pins. I was hoping to use one or two ADC's and then multiplex the input internally.
2019-01-29 11:54:32
ADC前端匹配电路的设计,不看肯定后悔
2021-04-19 09:32:26
ADC工作不对
DSPIC33FJ128GP802 to convert 4 input lines. I am trying to avoid DMA for now. I've set up the ADC
2019-05-15 14:18:28
ADC读取流量为0V
is that when I hit the low end of the pot, 0V, my ADC value is appearing to underflow(?).0V input results
2018-10-08 16:27:50
ADC读数出错
am using an ADCINCVR to measure an input signal of 0-5V.I am able to get the ADC working, but am
2019-04-01 09:10:05
ADC通道混淆
= 63; // ADC Conversion Clock //AD1CHS0: A/D Input Select Register AD1CHS0bits.CH0SA = 0; // MUXA +ve
2019-04-19 13:14:47
ADC配置和使用
sampling of up to 8 external signals through a front-end multiplexer. The ADC has configurable input, reference prescaling, and sample resolution (8, 9, and
2022-01-21 06:25:49
ADC采集电源电压的相关资料推荐
1、说明利用SDK3.4现成的ADC驱动采集电池电压2、操作8x5x采用“GPIO输入通道”对电源电压进行ADC采样硬件实现方式为:电源不接触GPIO Input channel,如该GPIO连接
2021-12-28 06:07:40
input与imread读入图像的问题
目前的图片读入是:I = imread('E:\Image Processing\20x.tif');由于这个程序是给不懂Matlab的人使用的,而且每次读入的图像都不一样,所以我想利用input
2013-10-14 15:27:28
input驱动程序编写流程
1 input子系统简介2 input驱动程序编写流程3 input_event结构体
2021-01-13 06:49:35
C4_INPUT
C4_INPUT - I/O Modules - Crydom Inc.,
2022-11-04 17:22:44
CS32A010 关于ADC采样问题
adc_channel_config(ADC1, ADC_INPUT_CHANNEL_0, ADC_INPUT_CHANNEL_1); //while
2023-05-05 15:26:52
GPIO的input和外部中断学习
上一篇成功点亮的LED,本篇将学习GPIO的input和外部中断说一次引脚的初始化配置本次是PA4,PA5.各接一个LED,初始化为高电平,设置为低电平时点亮LED。PA0是设置位外部中断模式
2022-01-11 07:23:12
LIS3DH中的ADC规格是否可用?
in the LIS3DH available?I'm particularly interested in input voltage range, input current, and recommended capacitance for ADC inputs.
2018-11-12 10:37:22
N79E715的ADC问题,这个IC的ADC只能一次使用一个吗,每次配置第二个ADC之后读取会出错怎么解决?
这个IC 的ADC只能一次使用一个吗,每次配置第二个ADC之后读取会出错。 Trigger_ADC_Convertion(); Set_ADC_Input_Mode(E_CHANNEL0
2023-06-14 12:32:48
PIC16LF18324 ADC输入高于Vref +
greater resolution over using the 3.3V Vdd.I assume when the ADC input is above the 2.048V Vref+
2019-06-12 06:41:25
PIC32MX ADC采样率很低
, different input pins for the ADC, different voltage references and playing around with the clock settings
2018-09-19 15:26:33
STM8L ADC输入绘图电流
in correct. It seems I've got a volt drop/ current flow across R1 on the input to the ADC pin.Could anyone
2018-11-06 10:28:33
ad74412r的CURRENT INPUT EXTERNALLY POWERED模式下adc值异常的原因?
ad74412r的其他模式下,工作正常,adc值读取符合预期。 但是在CURRENT INPUT EXTERNALLY POWERED模式下adc值异常,当外接电源输出1-4ma时(即
2023-12-01 06:02:45
arduino中的easydriver,a3967中的 sequences the translator中sequence怎么翻译,translator大概是命令解释器
Step Input (STEP).A low-to-high transition on theSTEP input sequences the translator and advances
2016-07-09 22:25:52
easydriver步进电机驱动器这里的translator怎么翻译The A 3967 SLB is a complete microstepping motor driver with built - in translator.
2016-06-26 22:36:20
linux input子系统的input core、input drivers和event handles
linux input子系统简单介绍
2019-04-01 16:06:58
linux驱动-Input输入子系统
以前,看过国嵌关于input子系统的视频课程,说实话,我看完后脑子里很乱,给我的印象好像是input子系统驱动是一个全新的驱动架构,疑惑相当多。前几天在网上,看到有很多人介绍韦东山老师的linux
2015-05-21 00:05:01
rk3288平台上的adc驱动使用步骤与方法
wake_lock;struct input_dev *input;struct delayed_work adc_poll_work;struct iio_channel *chan;struct
2022-05-11 10:16:29
不同的adc位值出现在LED上
of the adc input, even when their is no input same process repeats on leds. i am dubugging it for 3 days
2019-07-04 12:41:13
不稳定的ADC
嗨,我在PSoC3上玩ADC,我有CY8CKIT-030。我的问题是,即使我把输入GPIO(P4.6)连接到VSSA,RAWEVE也非常粗糙。它在30位和40位之间跳跃,我期望一个更稳定的值。是否有
2019-05-27 13:53:59
介绍下input子系统
文章目录前言input子系统按键检测C代码微信公众号前言这是前3篇:嵌入式Linux i.MX开发板嵌入式Linux NFS嵌入式Linux 交叉编译工具链嵌入式Linux LED GPIO本篇介绍
2021-11-04 08:14:06
使用DelSig ADC构建警告
just have the ADC on the schematic with 2 analog pins feeding the input terminals.All the settings
2019-07-10 11:29:07
在哪里可以做ADC VREF设置?
for sharing the experiences. i haveconfigured the port P1[2] as ADC input. where can i do ADC Vref settings?? Thank you :)
2019-07-17 15:43:52
如何只将MUX A输入连接到ADC
翻译 以下为原文 Chip is PIC24FV32KA304. I'd like to connect a single input (say AN12) to the ADC so I
2019-06-28 08:05:39
如何将带符号的ADC值转换为十进制值?
! 以上来自于百度翻译 以下为原文Hello! I am using PSoC CY8C29466's DelSig and Triple input incremental ADC. Both ADC
2019-04-23 10:24:25
如何计算ADC吞吐量?
frequency is half of input clock ADCCON3bits.VREFSEL = 0; ADC0TIMEbits.ADCDIV = 1; // ADC0 clock
2018-11-21 15:48:12
如何设置ADC参考
你好,我尝试使用ADC∑-Δ,它将模拟信号转换为0~5伏之间的振幅。我不知道如何设置ADC参考:事实上,当我选择输入范围VSS-VDDA时,参考值自动设置为1.25 V,这对我来说不是正确的值,因为
2019-07-24 13:16:43
对特权FPGA控制ADC TLC549逻辑代码疑问
Editor的AD采集一节时,对其中的一段代码不是很理解,希望大家帮帮忙,在下不胜感激。module tlc549(clk,rst_n,adc_data,adc_cs_n,adc_clk);input clk
2016-12-26 15:19:50
怎么使用ADC Delsig来测量系统中车载电池的电池容量
accurately measure a voltage input range of Vssa to Vdda when the reference voltage for the ADC is set
2019-03-26 16:29:22
有人尝试使用PGA模块连接ADC核心吗?
嗨,有没有其他人尝试使用PGA模块连接ADC核心?我想设置过采样的ADC核心,但我没有发现任何过采样PGAX输入的信息。有人能帮助我吗?谢谢!脱土霉素78 以上来自于百度翻译 以下为原文 Hi
2018-10-23 15:44:02
有可能使用CapSense_ADC来测量DieTemp吗?
the DieTemp output connection to a CapSense_ADC input connection, as the CapSense_ADC component
2018-08-18 02:22:55
设计bit DSM ADC将maximum input amplitude做到-2dB实际仿真测试却是-5dB的原因?
最近设计了一款多bit DSM ADC。在Simulink中通过优化NTF带外增益,将maximum input amplitude做到了-2dB左右。但是实际电路中,仿真测试maximum
2021-06-24 07:19:56
迅为i.MX6ULL终结者Linux INPUT子系统实验Input子系统
文章目录1 input子系统简介2 input驱动程序编写流程3 input_event结构体1 input子系统简介input 子系统就是管理输入的子系统,和 pinctrl 和 gpio 子系统
2021-01-11 10:41:40
高速直接RF采样GSPS ADC的时钟解决方案包括BOM及框图
zone input signal frequencies. ADC12J4000 is a 12-bit, 4-GSPS RF sampling ADC with 3-dB input
2018-09-28 08:36:34
ADC0831 ADC0832 ADC0834 ADC083
The ADC0831 series are 8-bit successive approximation A/Dconverters with a serial
2008-04-09 11:46:0799
增加ADC603的输入范围
The ADC603 is a 10MHz, 12-bit analog-to-digital converterwith a ±1.25V input range. Many
2009-06-13 10:53:3211
Respond to the input equipment
The ways to program the respond to the input equipment in Visual C++ programlanguage are introduced
2009-08-31 10:37:503
AD7760,pdf datasheet (ADC with
The AD7760 is a high performance, 24-bit Σ-Δ analog-to-digital converter (ADC). It combines wide
2009-09-10 15:53:4722
ADC Input Noise: The Good,The
ADC Input Noise: The Good,The Bad, and The Ugly.Is No Noise Good Noise? IntroductionAll
2009-09-23 19:16:084
ADC14DS105,pdf datasheet (Dual
The ADC14DS105CISQ and ADC14DS105AISQ are highperformanceCMOS analog-to-digital converters capable
2009-10-10 09:34:533
ADC12081,pdf datasheet (12-Bit
The ADC12081 is a monolithic CMOS analog-to-digital convertercapable of converting analog input
2009-10-10 10:00:0811
ADC10040/ADC10040Q,pdf datashe
The ADC10040 is a monolithic CMOS analog-to-digital convertercapable of converting analog input
2009-10-10 10:21:1911
ADC10080,pdf datasheet (10-Bit
The ADC10080 is a monolithic CMOS analog-to-digital convertercapable of converting analog input
2009-10-10 10:25:2910
ADC10065,pdf datasheet (10-Bit
The ADC10065 is a monolithic CMOS analog-to-digital convertercapable of converting analog input
2009-10-10 10:29:4911
ADC1175-50,pdf datasheet (8-Bi
while consuming just125 mW (typ). The ADC1175-50 uses a unique architecturethat achieves 6.8 Effective Bits at 25 MHz input and
2009-10-10 10:34:218
ADC12H030/ADC12H032/ADC12H034/
Converters withserial I/O and configurable input multiplexers. TheADC12034/ADC12H034 and ADC12038/ADC12H038 have4 and 8 cha
2009-10-10 10:48:4412
ADC08831/ADC08832,pdf datashee
The ADC08831/ADC08832 are 8-bit successive approximationAnalog to Digital converters with 3-wire
2009-10-12 08:19:3014
ADC0831/ADC0832/ADC0834/ADC083
2009-10-12 08:37:5349
ADC12130/ADC12132/ADC12138,pdf
converterswith serial I/O and configurable input multiplexer. TheADC12132 and ADC12138 have a 2 and an 8 channel multiplexer,
2009-10-12 09:07:4416
TL092,pdf(Dual JFET-Input Operational Amplifier)
The TL092 JFET-input operational amplifier is similar in performance to the MC3403 family
2010-09-18 03:35:5018
Input and Output Capacitor Sel
ABSTRACTWhen designing with switching regulators, application requirements determine howmuch input
2010-11-16 17:05:4536
Pads Translator 2005
Pads Translator 2005可以将Protel的原理图、PCB及库文件转换成PADS格式的软件,蛮好用的。
2010-11-26 11:17:25452
High-Speed ADC Sets Input Comm
Abstract: The input common-mode voltage range (VCM) is important in the design of communication
2009-04-16 16:46:49545
2009-04-25 09:29:05539
设置高速ADC的共模输入电压范围--High-Speed A
设置高速ADC的共模输入电压范围--High-Speed ADC Sets Input Common-Mode Range Abstract: The input common-mode
2009-06-09 20:41:431378
ADC的本质与特性 - 1
adc
皮特派发布于 2022-12-07 11:30:38
ADC的本质与特性 - 2
adc
皮特派发布于 2022-12-07 11:32:56
简化精密测量的高输入阻抗ADC
High input impedance and a wide input range are twohighly desirable features in a precision
2012-01-16 11:33:3141
MAX14595 High-Speed, Open-Drain Capable Logic-Level Translator
The MAX14595 is a dual-channel, bidirectional logic-level translator designed specifically for low
2012-01-23 09:18:502256
PCB Translator_CAMCAD转换器
资料说明介绍 PCB Translator_CAMCAD转换器3.95版本,里面含CAMCAD_3.9.5a_crack文件,可以对软件进行破解 (需要安装PCB Translator后才能进行破解) 针对PCB设计文件的RSI转换器能够转换PCB设计和生
2012-11-03 09:38:26373
MAX31913 Industrial,Octal,Digital Input Translator/Serializer
MAX31913工业接口串行转换用于工业过程中,需要的5V CMOS兼容信号,通过微控制器和楼宇自动化。
2013-04-01 10:23:411154
ADC高精度采集
ADC
橙群微电子发布于 2023-02-24 09:37:18
模数转换ADC
ADC
jf_06209345发布于 2023-03-17 20:17:58
ADC单通道转换示例
ADC
jf_06209345发布于 2023-03-17 20:18:22
Molex_Telecommunications_Input_O
Molex Telecommunications Input Output for AMC
2016-02-17 14:39:3919
低功耗的8/16通道24位的高度集成的ADC ad7173-8数据表
Low power, 8-/16-channel, highly integrated multiplexed analog-to-digital converter (ADC
2017-09-27 09:17:096
分享解决No input file specified问题的方法
解决No input file specified问题的方法是, 修改php.ini中的cgi.fix_pathinfo参数的值为1。
2018-02-09 08:41:2730890
驱动之路-input子系统
一、input子系统系统框架Linux内核实现了一套input子系统,很多输入设备,比如说按键、键盘、鼠标、触摸屏等等都可以利用input子系统提供的接口来编写驱动,这样可以帮驱动
2019-04-02 14:33:04325
S Translator 服务关闭 收集的所有信息同时销毁
IT之家 11 月 4 日消息 三星又要杀死一个自家服务,该公司本周早些时候宣布,将于 2020 年 12 月 1 日关闭 S Translator 服务,该服务是作为谷歌和微软翻译服务的替代品推出
2020-11-04 13:58:481305
三星将于12月1日关闭翻译服务S Translator
在过去的两年中,三星关闭了各种应用程序和服务,包括MirrorLink、S Voice和PlayGalaxy。现在,该公司宣布将关闭另一项翻译服务:S Translator。但是,有一个替代品可用于语言翻译。
2020-11-04 17:43:111967
SCP-INPUT-EVALZ Demo Manual
2021-01-27 18:47:109
LTC2311-12: 12-Bit + Sign, 5Msps Differential Input ADC with Wide Input Common Mode Range Data Sheet
2021-01-28 00:43:330
UG-1870: Evaluating the AD7606C-18 8-Channel DAS with 18-Bit, 1 MSPS Bipolar Input, Simultaneous Sampling ADC
2021-01-29 08:09:035
AD7606C-18: 8-Channel DAS with 18-Bit, 1 MSPS Bipolar Input, Simultaneous Sampling ADC Data Sheet
2021-01-29 08:12:038
UG-1770: Evaluating the AD7383 Dual, Simultaneous Sampling, 16-Bit, 4 MSPS, SAR ADC, Pseudo Differential Input User Guide
2021-01-29 09:14:070
SCP-INPUT-EVALZ SCP-INPUT-EVALZ评估板
电子发烧友网为你提供ADI(ti)SCP-INPUT-EVALZ相关产品参数、数据手册,更有SCP-INPUT-EVALZ的引脚图、接线图、封装手册、中文资料、英文资料,SCP-INPUT-EVALZ真值表,SCP-INPUT-EVALZ管脚等资料,希望可以帮助到广大的电子工程师们。
2021-07-09 21:00:04
嵌入式Linux input
2021-11-01 16:31:042
扬声器电视遥控器IR Translator开源
电子发烧友网站提供《扬声器电视遥控器IR Translator开源.zip》资料免费下载
2022-11-11 14:49:350
​SAS数据集的input输入方式
SAS input输入方法用于读取原始数据。原始数据可以来自外部源或来自流数据。
2023-05-19 14:50:301753
AD7606BBCHIPS: 8-Channel DAS with 16-Bit, 800 kSPS Bipolar Input, Simultaneous Sampling ADC Data Sheet AD7606BBCHIPS: 8-Channel DAS with 16-
Sampling ADC Data Sheet相关产品参数、数据手册,更有AD7606BBCHIPS: 8-Channel DAS with 16-Bit, 800 kSPS Bipolar Input
2023-10-13 18:46:03
MAX13046E-MAX13047E: Single- and Dual-Bidirectional Low-Level Translator Data Sheet MAX13046E-MAX13047E: Single- and Dual-Bidirectional Low-
电子发烧友网为你提供ADI(ADI)MAX13046E-MAX13047E: Single- and Dual-Bidirectional Low-Level Translator Data
2023-10-16 19:20:43
python中input怎么输入3个值
在 Python 中,可以使用 input() 函数来获取用户的输入。如果你想要输入多个值,可以根据具体的需求使用以下方法。 方法一:使用多个 input 函数 最简单的方法是使用多个 input
2023-11-23 15:31:022356
input函数会将接收的数据以什么类型返回
nput函数会将接收的数据以字符串类型返回。 input函数是Python内置函数之一,它用于从用户处获取输入。当程序运行到input函数时,程序会暂停执行,等待用户输入数据。用户输入数据后,按下回
2023-11-30 10:09:12837
电器上INPUT是接电源线的吗
INPUT通常是指电器的输入端,用于连接电源线或其他电源设备。电器的INPUT通常是通过插头或插座进行连接。INPUT的目的是将电器与电源进行连接,以实现电器的正常运行。 首先,我们来看
2024-02-23 14:15:04635
已全部加载完成
