怎样用Arduino制作水位指示器
454398 来源:工程师吴畏 2019-08-02 16:43 次阅读
Arduino水位指示器如何工作?
该Arduino水位指示器使用超声波传感器Ping传感器来确定水箱中的水位。 Ping传感器使用声纳测量距离。从该单元发射超声波(远高于人类听觉)脉冲,并且通过测量回波返回所需的时间来确定到目标的距离。 Ping传感器的输出是可变宽度脉冲,对应于到目标的距离。然后将其输入微控制器,确定水位并通过一系列LED显示。
以下项目可以是如果您有一个或直接连接到面板上的ATmega 328微控制器,则可以连接到Arduino板。您还可以查看Jeff的Maker Pro教程,了解如何将超声波传感器连接到Arduino。
Arduino水位指示器代码
将提供的草图复制粘贴到Arduino IDE中并找到“int d = 18;”行并将“18”更改为 坦克的深度,单位为厘米。
//Coded by MATHEW VARGHESE
//Note that the numbering of arduino pins are different from microcontroller pinout
int d = 18; //Enter depth of your tank here in centimeters
int trig = 11; // Attach Trig of ultrasonic sensor to pin 11
int echo = 10; // Attach Echo of ultrasonic sensor to pin 10
int pin1 = 2;//Highest level
int pin2 = 3;
int pin3 = 4;
int pin4 = 5;
int pin5 = 6;
int pin6 = 7;//Lowest evel
void setup() {
pinMode (pin1, OUTPUT);// Set pins to output for controlling I/O
pinMode (pin2, OUTPUT);
pinMode (pin3, OUTPUT);
pinMode (pin4, OUTPUT);
pinMode (pin5, OUTPUT);
pinMode (pin6, OUTPUT);
void loop()
{ digitalWrite(pin1, LOW);//Resetting the LEDs to off state
digitalWrite(pin2, LOW);
digitalWrite(pin3, LOW);
digitalWrite(pin4, LOW);
digitalWrite(pin5, LOW);
// Establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, in, cm; //‘in’ is inches and ‘cm’ is centimeter
// The PING is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(trig, OUTPUT);
digitalWrite(trig, LOW);
delayMicroseconds(2);
digitalWrite(trig, HIGH);
delayMicroseconds(5);
// The same pin is used to read the signal from the PING: a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(echo, INPUT);
duration = pulseIn(echo, HIGH);
// Convert the time into a distance
in = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
delay(100);// To save battery,remove if felt inconvenient
if (in 《 6 * d / 7)// Else is included to light only one led at a level and thus save battery charge
digitalWrite(pin1, HIGH);
else if (in 《 5 * d / 6)
digitalWrite(pin2, HIGH);
else if (in 《 4 * d / 6)
digitalWrite(pin3, HIGH);
else if (in 《 3 * d / 6)
digitalWrite(pin4, HIGH);
else if (in 《 2 * d / 6)
digitalWrite(pin5, HIGH);
else if (in 《 1 * d / 6)
long microsecondsToInches(long microseconds)
// According to Parallax‘s datasheet for the PING, there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second)。 This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PI.。.
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
建立连接
按照附带的Fritzing图表在PCB或面包板上填充电路。这是在运行Arduino的面包板上的ATMEga328。您可以按照Mayoogh Girish的教程在面包板上使用ATMega328制作您自己的Arduino板。如果您使用的是Arduino板,您可以按如下方式连接LED和超声波传感器。
上传代码
将Arduino水位指示器的代码直接刻录到Arduino板或ATMega328P微控制器上。
将超声波传感器连接到水箱上
固定Ping传感器,使其直接面向水箱中的水。带 指示LED的主控板可以在任何舒适的位置固定在家中。任何多芯 电缆(以太网电缆)都可用于连接Ping传感器和 电路的其余部分。请记住,不要增加组件之间的长度 超过20mts。
现在只需连接电池,您的非接触式Arduinowater水平指示器即可使用。
  • 指示器
  • Arduino
    浅谈架空暂态特征型远传故障指示器
    新品—架空暂态特征型远传故障指示器—深圳鼎信生产厂家 型号:JY -DX 一、背景 随着电力系统的不断发展,对架空线路的安全运行和故障快速定位的要求越来越高。传统的故障指示器大多只能提供就地指示
    的头像 发表于 12-04 16:35 268次阅读
    线路故障指示器为什么变成红色
    线路故障指示器变成红色,通常是因为检测到了线路中的特定电气量变化,这些变化与线路故障紧密相关。具体来说,以下是一些导致线路故障指示器变红的主要原因: 1. 短路或接地故障 短路故障 :当线路中发
    的头像 发表于 09-24 11:04 700次阅读
    线路故障指示器如何复位
    线路故障指示器是一种用于监测电力线路故障的设备,它可以帮助电力维护人员快速定位故障点,从而提高故障处理的效率。复位线路故障指示器是故障处理过程中的一个重要步骤,确保设备能够恢复正常工作状态。以下
    的头像 发表于 09-24 11:01 528次阅读
    线路故障指示器工作原理是什么
    线路故障指示器是一种用于检测和定位电力系统中故障的设备,它能够帮助电力维护人员快速准确地找到故障点,从而提高电力系统的可靠性和安全性。 线路故障指示器的工作原理概述 1. 基本概念 线路故障指示器
    的头像 发表于 09-24 10:54 2307次阅读
    线路故障指示器怎么判断故障点
    线路故障指示器在判断故障点时,主要通过检测线路中的电气量变化来实现。以下是一些具体的判断方法和步骤: 一、工作原理 线路故障指示器一般具备电流采集、电场测量和无线通信功能。当线路出现短路或接地故障
    的头像 发表于 09-24 10:52 1240次阅读
    在现代系统设计中启用LED和LCD指示器应用简介
    电子发烧友网站提供《在现代系统设计中启用LED和LCD指示器应用简介.pdf》资料免费下载
    发表于 09-11 09:22 0次下载
    在现代系统设计中启用LED和LCD<b class='flag-5'>指示器</b>应用简介
    使用电源正常状态指示器实现输出放电功能
    电子发烧友网站提供《使用电源正常状态指示器实现输出放电功能.pdf》资料免费下载
    发表于 08-29 09:45 0次下载
    使用电源正常状态<b class='flag-5'>指示器</b>实现输出放电功能
    怎样用THS3201实现输出功率可调?
    怎样用THS3201实现输出功率可调?
    发表于 08-26 08:28
    怎样用Arduino测试锂电池容量
    本文详细介绍了如何用Arduino测量锂电池的容量。并附有电路图和Arduino的程序代码。
    的头像 发表于 07-30 09:14 1157次阅读
    <b class='flag-5'>怎样用</b><b class='flag-5'>Arduino</b>测试锂电池容量
    L60系列0.230英寸(5.9毫米)防水面板安装指示器
    电子发烧友网站提供《L60系列0.230英寸(5.9毫米)防水面板安装指示器.pdf》资料免费下载
    发表于 07-24 12:26 0次下载
    利用Arduino的数字水位指示器电路设计
    随着科技的不断发展,数字化技术在各个领域的应用越来越广泛。在液位监测领域,数字水位指示器作为一种先进的监测设备,因其高精度、高可靠性和智能化等特点,受到了广泛的关注和应用。
    的头像 发表于 06-22 17:48 1177次阅读
    利用<b class='flag-5'>Arduino</b>的数字<b class='flag-5'>水位</b><b class='flag-5'>指示器</b>电路设计
    VL53L8CX TOF开发(4)----运动指示器
    VL53L8CX传感内置了一个固件功能,可以检测场景中的运动。这个运动指示器是基于连续帧之间来计算的。使用插件vl53l8cx_plugin_motion_indicator可以使用这个选项
    的头像 发表于 06-19 10:43 1546次阅读
    VL53L8CX TOF开发(4)----运动<b class='flag-5'>指示器</b>
    内置超级电容模块的故障指示器有哪些特性?
    出现位置,从而及时排除故障。而应用在故障指示器中还有一个重要配件是续航的电池,在传统的故障指示器中使用的续航产品是一次性锂电池或者比较小容量的充电电池。但是这存在
    的头像 发表于 06-04 09:39 567次阅读
    内置超级电容模块的故障<b class='flag-5'>指示器</b>有哪些特性?
    stm32f100怎样用重映射功能?
    的是stm32f100c8t6b芯片,现在想用将PB1映射为TIM1_CH3N,在调用GPIO_PinAFConfig(GPIOB,GPIO_PinSource1,GPIO_AF_TIM1)时, GPIO_PinAFConfig和GPIO_AF_TIM1都没定义,stm32f100
    发表于 05-07 06:06
    电力电缆故障指示器|误差探讨|行波故障定位的选项
    以往电力电缆故障指示器误差过大的原因可能有以下几点:  1. 设备自身问题:故障指示器设备本身可能存在制造或设计上的缺陷,导致其指示精度不够。 2. 安装环境影响:故障指示器可能受到安
    的头像 发表于 03-28 10:49 1042次阅读
