CAN4550-Q1汽车CAN FD控制器解决方案
电子工程师 来源:陈翠 2019-08-04 10:37 次阅读
TI公司的CAN4550-Q1是集成了收发器的汽车控制器局域网络(CAN)灵活数据速率(FD)控制器,支持数据速率高达标8Mbps,满足ISO11898-1:2015高速CAN数据链接层的指标,满足ISO11898–2:2016高速CAN指标.器件通过串行外设接口(SPI)提供CAN总线和系统处理器间接口,支持经典CAN和CAN FD.CAN4550-Q1提供CAN FD收发器功能:差分发送数据到总线和从总线差分接收数据.器件包括许多保护特性,使得设备和CAN总线鲁棒性.CAN总线工作时有两个逻辑状态:隐性和显性.在隐性总线状态,总线通过每个节点的接收器高阻抗内部输入电阻偏压到共通节点的2.5V,隐性状态等效于逻辑高电平,可是空闲状态.而在显性总线状态,总线由一个或多个驱动器驱动,电流通过端电阻,在总线上产生差分电压.显性状态等效于逻辑低电平.CAN4550-Q1满足汽车应用的规范AEC Q100,工作温度–40℃到125℃,工作模式包括正常,待机,睡眠和故障等,3.3V-5V输入/输出逻辑支持微处理器.主要用在人体电子学和照明,信息娱乐和集群和工业运输.本文介绍了CAN4550-Q1主要特性,功能框图和简化电路,CAN收发器框图,SPI和数字IO框图,典型CAN应用电路以及评估模块TCAN4550 EVM主要特性,电路图和材料清单.
The TCAN4550-Q1 is a CAN FD controller with anintegrated CAN FD transceiver supporting data ratesup to 8 Mbps. The CAN FD controller meets thespecifications of the ISO11898-1:2015 high speedcontroller area network (CAN) data link layer andmeets the physical layer requirements of theISO11898–2:2016 high speed CAN specification. TheTCAN4550-Q1 provides an interface between theCAN bus and the system processor through serialperipheral interface (SPI), supporting both classicalCAN and CAN FD, allowing port expanision or CANsupport with processors that do not support CAN FD.
The TCAN4550-Q1 provides CAN FD transceiverfunctionality: differential transmit capability to the busand differential receive capability from the bus. Thedevice supports wake up via local wake up (LWU)and bus wake using the CAN bus implementing theISO11898-2:2016 Wake Up Pattern (WUP).The device includes many protection featuresproviding device and CAN bus robustness. Thesefeatures include failsafe mode, internal dominantstate timeout, wide bus operating range and a timeoutwatchdog as examples.
The TCAN4550-Q1 is a CAN FD controller with an integrated CAN FD transceiver supporting data rates up to 8Mbps. The CAN FD controller meets the specifications of the ISO 11898-1:2015 high speed Controller AreaNetwork (CAN) data link layer and meets the physical layer requirements of the ISO 11898-2:2016 High SpeedController Area Network (CAN) specification providing an interface between the CAN bus and the CAN protocolcontroller supporting both classical CAN and CAN FD up to 5 megabits per second (Mbps). The TCAN4550-Q1provides CAN FD transceiver functionality: differential transmit capability to the bus and differential receivecapability from the bus. The device includes many protection features providing device and CAN bus robustness.
The device can also wake up via remote wake up using CAN bus implementing the ISO 11898-2:2016 Wake UpPattern (WUP). Input/Output support for 3.3 V and 5 V microprocessors using VIO pin for seamless interface. TheTCAN4550-Q1 has a Serial Peripheral Interface (SPI) that connects to a local microprocessor for the device ’sconfiguration; transmission and reception of CAN frames. The SPI interface supports clock rates up to 18 MHz.
The CAN bus has two logical states during operation: recessive and dominant.In the recessive bus state, the bus is biased to a common mode of 2.5 V via the high resistance internal inputresistors of the receiver of each node. Recessive is equivalent to logic high. The recessive state is also the idlestate.
In the dominant bus state, the bus is driven differentially by one or more drivers. Current flows through thetermination resistors and generates a differential voltage on the bus. Dominant is equivalent to logic low. Adominant state overwrites the recessive state.During arbitration, multiple CAN nodes may transmit a dominant bit at the same time. In this case the differentialvoltage of the bus will be greater than the differential voltage of a single driver.
CAN4550-Q1主要特性:
• AEC Q100: qualified for automotive applications
– Temperature grade 1: –40℃ to 125℃ TA
• CAN FD controller with integrated CAN FDtransceiver and serial peripheral interface (SPI)
• CAN FD controller supports both ISO 11898-1:2015 and Bosch M_CAN Revision 3.2.1.1
• Meets the requirements of ISO 11898-2:2016
• Supports CAN FD data rates up to 8 Mbps with upto 18 MHz SPI clock speed
• Classic CAN backwards compatible
• Operating modes: normal, standby, sleep, andfailsafe
• 3.3 V to 5 V input/output logic support formicroprocessors
• Wide operating ranges on CAN bus
– ±58 V bus fault protection
– ±12 V common mode
• Integrated low drop out voltage regulator suppling5 V to CAN transceiver and up to 70 mA forexternal devices
• Optimized behavior when unpowered
– Bus and logic terminals are high impedance(No load to operating bus or application)
– Power up and down glitch free operation
CAN4550-Q1应用:
• Body electronics and lighting
• Infotainment and cluster
• Industrial transportation
图1.CAN4550-Q1简化电路:MCU CLKIN
图2.CAN4550-Q1简化电路:晶体
图3.CAN4550-Q1功能框图
图4.CAN收发器框图
图5.CAN4550-Q1 SPI和数字IO框图
图6.CAN4550-Q1典型CAN应用:3.3VuC和晶体
图7.CAN4550-Q1典型CAN应用:3.3VuC和MCU时钟
评估模块TCAN4550 EVM
This user’s guide describes the TCAN4550 evaluation module (EVM). This EVM helps designers evaluatedevice performance, support fast development, and analyze Controller Area Network with Flexible Datarate (CAN FD) systems using TCAN4550 CAN FD physical layer transceiver devices.
The TCAN4550 EVM provides the user with the ability to evaluate the TI TCAN4550 CAN FD Controllerwith integrated CAN transceiver devices. Any MCU or SPI controller with an I/O voltage of 3.3 V or 5 Vmay be connected to the EVM through a standard interface header. The EVM features a polarity-protectedand EMC-filtered supply voltage that allows the EVM to operate from an external voltage from 6 V to 24 V.
A dual-channel LDO creates a 5-V, general-purpose voltage rail to source the LEDs and supporting ICs,and a variable VIO voltage rail that can be set to 5 V or 3.3 V to match the MCU signal level requirements.
The VIO or 5-V rail is also designed to source the supply voltage for the connected MCU to evaluate sleepmode and wake-up events.
评估模块TCAN4550 EVM主要特性:
• CAN FD controller with integrated CAN transceiver
• Operates from a battery voltage input VBAT (6 V to 24 V)
• Polarity protected and EMC filtered supply voltage
• Dual-channel LDO
– Selectable VIO (5-V, or 3.3-V) supply rails
– General-purpose 5-V supply rail
– Error monitoring and current-sense features
• CAN bus header and industry-standard DB-9 connector
TVS diode pad (not populated)
• CAN bus transient signal injection/monitoring header
• CAN bus termination with disconnect headers
• Common-mode choke (bypassed with 0-Ω resistors by default)
• Status LEDs
• MCU interface header (SPI, GPIO, VIO, and 5-V)
• Reset push-button switch
• Configuration DIP switches for support of multiple use pins
• Crystal oscillator (40 MHz)
• External clock input and output SMA connectors
• High-voltage Inhibit and Wake signal header
• WAKE push-button switch
图8.评估模块TCAN4550 EVM MCU接口(SPI/GPIO)特性
图9.评估模块TCAN4550 EVM外形图(正面)
图10.评估模块TCAN4550 EVM外形图(背面)
图11.评估模块TCAN4550 EVM电路图
评估模块TCAN4550 EVM材料清单:
  • 控制器
  • 汽车CAN
    贸泽推出集成CAN FD 控制器和收发的TI TCAN4550系统基础芯片
    CAN FD 控制器。TCAN4550器件支持最高达5Mbps的数据传输速率,最高18 MHz的SPI时钟速度,是业界首款集成了CAN
    的头像 发表于 02-18 07:17 4557次阅读
    一文浅析汽车CAN-FD总线的通信应用
    泊车等基本或高阶的功能,涉及到 ADAS 域控制器与感知传感、底盘、动力等执行控制器控制交互。2.2 方案设计对于 2.1 章节所描述的
    发表于 02-14 14:22
    Microchip宣布提供业界第一款外部CAN灵活数据速率(CAN FD控制器MCP2517FD
    Microchip日前宣布,开始提供业界第一款外部CAN灵活数据速率(CAN FD控制器。采用MCP2517FD,设计人员能够很快从
    的头像 发表于 10-19 06:31 2w次阅读
    CAN FD控制器MCP2517FD的主要特性 PCB正面布局
    microchip公司的MCP2517FD是成本效益和小占位尺寸的CAN FD(灵活数据速率)控制器,具有和微处理(MCU)接口的SPI接
    发表于 05-25 01:25 1.3w次阅读
    <b class='flag-5'>CAN</b> <b class='flag-5'>FD</b><b class='flag-5'>控制器</b>MCP2517<b class='flag-5'>FD</b>的主要特性 PCB正面布局
    带SPllnterface的外部CAN FD控制器MCP2517FD的英文数据手册
    MCP2517FD是一种低成本、占地面积小的FD控制器,可以很容易地添加到具有可用SPI接口的微控制器中。因此,CAN
    发表于 07-10 08:00 35次下载
    带SPllnterface的外部<b class='flag-5'>CAN</b> <b class='flag-5'>FD</b><b class='flag-5'>控制器</b>MCP2517<b class='flag-5'>FD</b>的英文数据手册
    MCP2517FD CAN FD控制器的详细资料和数据手册免费下载
    MCP2517FD是一种成本低廉、占地面积小的CAN FD控制器,可以容易地添加到具有可用SPI接口的微控制器中。因此,可以容易地将
    发表于 09-21 08:00 213次下载
    MCP2517<b class='flag-5'>FD</b> <b class='flag-5'>CAN</b> <b class='flag-5'>FD</b><b class='flag-5'>控制器</b>的详细资料和数据手册免费下载
    新能源汽车市场增长,CAN FD需求猛增
    (TI)在本月发布了业界首款集成CAN FD控制器和收发的SBC:TCAN4550-Q1,意在减少车载网络的设计量和复杂性,缩短
    发表于 07-07 10:19 1315次阅读
    汽车应用中升级到或扩展CAN FD时 不用再修改MCU了!
    以往,在升级至或扩展CAN FD功能时,设计师不得不在其设计中整合多个分立的组件或彻底修改微控制器,不仅耗时,而且成本高昂。为此,TI公司推出了新款汽车系统基础芯片(SBC)TCAN
    的头像 发表于 07-02 08:41 7758次阅读
    CAN FD 如何使非汽车应用受益
    由于汽车领域对带宽的更高要求,CAN控制器局域网)规范被扩展为灵活的数据速率,新的迭代称为 CAN FD
    的头像 发表于 07-19 11:35 926次阅读
    <b class='flag-5'>CAN</b> <b class='flag-5'>FD</b> 如何使非<b class='flag-5'>汽车</b>应用受益
    STM32设备上的CAN FD
    本文件的目的如下所述: •概述具有灵活数据速率(CAN-FD)协议的控制器局域网(CAN)。 •描述CAN-FD相对于经典CAN
    发表于 08-28 10:34 8次下载
    CAN FD嵌入式控制器开发硬件设计
    CAN FD作为一种性能可靠、功能完善、成本合理的远程网络通信控制方式,集成CAN/CAN FD
    的头像 发表于 08-01 10:41 932次阅读
    <b class='flag-5'>CAN</b> <b class='flag-5'>FD</b>嵌入式<b class='flag-5'>控制器</b>开发硬件设计
    TCAN4550-Q1汽车控制器区域网灵活数据速率(CAN FD)系统基础芯片数据表
    电子发烧友网站提供《TCAN4550-Q1汽车控制器区域网灵活数据速率(CAN FD)系统基础芯片数据表.pdf》资料免费下载
    发表于 06-19 14:55 0次下载
    TCAN<b class='flag-5'>4550-Q1</b><b class='flag-5'>汽车</b><b class='flag-5'>控制器</b>区域网灵活数据速率(<b class='flag-5'>CAN</b> <b class='flag-5'>FD</b>)系统基础芯片数据表
    TCAN4550汽车控制区域网灵活数据速率(CAN FD)控制器数据表
    电子发烧友网站提供《TCAN4550汽车控制区域网灵活数据速率(CAN FD)控制器数据表.pd
    发表于 07-08 09:38 0次下载
    TCAN<b class='flag-5'>4550</b><b class='flag-5'>汽车</b><b class='flag-5'>控制</b>区域网灵活数据速率(<b class='flag-5'>CAN</b> <b class='flag-5'>FD</b>)<b class='flag-5'>控制器</b>数据表
    MSPM0G350x-Q1具有CAN-FD接口的汽车类混合信号微控制器数据表
    电子发烧友网站提供《MSPM0G350x-Q1具有CAN-FD接口的汽车类混合信号微控制器数据表.pdf》资料免费下载
    发表于 08-01 11:30 0次下载
    MSPM0G350x-<b class='flag-5'>Q1</b>具有<b class='flag-5'>CAN-FD</b>接口的<b class='flag-5'>汽车</b>类混合信号微<b class='flag-5'>控制器</b>数据表
    MSPM0G310x-Q1汽车类具有CAN-FD接口的混合信号微控制器数据表
    电子发烧友网站提供《MSPM0G310x-Q1汽车类具有CAN-FD接口的混合信号微控制器数据表.pdf》资料免费下载
    发表于 08-01 11:35 0次下载
    MSPM0G310x-<b class='flag-5'>Q1</b><b class='flag-5'>汽车</b>类具有<b class='flag-5'>CAN-FD</b>接口的混合信号微<b class='flag-5'>控制器</b>数据表
