如何训练Wekinator控制Arduino
454398 来源:工程师吴畏 2019-07-31 09:00 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
电路图
Arduino的引脚11连接到橙色LED的正极引线,通过220欧姆电阻将LED的负极引线连接到Arduino的地。类似地,通过220欧姆电阻将白色LED的正极引线连接到Arduino的引脚10和LED的负极引线连接到Arduino。
程序入门
首先,在Arduino IDE中加载下面为Arduino提供的代码。然后上传给定代码以在IDE中处理。
之后,打开Wekinator并将输入更改为1并输出为2并离开另一个选项。
点击“下一步”,会出现一个新窗口。现在从处理的输入窗口,单击橙色框,在Wekinator中,在输出-1框中输入1,然后开始录制半秒。
现在,单击处理中的白色框,在Wekinator中,在输出-1框中输入0并在输出-2框中输入1并开始记录半秒。
现在点击“Train”,然后点击“Run”。现在,当您点击橙色框时,连接到引脚11的LED将亮起,当您单击白色框时,连接到Arduino引脚10的LED将亮起。
Arduino代码
代码用注释解释。
#include //Including the library that will help us in receiving and sending the values from processing
ValueReceiver《2》 receiver; /*Creating the receiver that will receive up to 2 values.
Put the number of values to synchronize in the brackets */
/* The below two variables will be synchronized in the processing
and they should be same on both sides. */
int output;
int output1;
// Initializing the pins for led‘s
int orange_led = 11;
int white_led = 10;
void setup()
/* Starting the serial communication because we are communicating with the
Arduino through serial. The baudrate should be same as on the processing side. */
Serial.begin(19200);
pinMode(white_led, OUTPUT);
pinMode(orange_led, OUTPUT);
// Synchronizing the variables with the processing. The variables must be int type.
receiver.observe(output);
receiver.observe(output1);
void loop()
// Receiving the output from the processing.
receiver.sync();
// Matching the received output to light up led’s
if (output == 1)
digitalWrite(orange_led, HIGH);
else if (output == 0)
digitalWrite(orange_led, LOW);
if (output1 == 1)
digitalWrite(white_led, HIGH);
else if(output1 == 0)
digitalWrite(white_led, LOW);
处理代码(输入到Wekinator)
// Importing the library which will help us in communicating with the wekinator
import oscP5.*;
import netP5.*;
//creating the instances
OscP5 oscP5;
NetAddress dest;
float bx;
void setup() {
// Size of output window
size(400, 100, P3D);
// Starting the communication with wekinator. listen on port 9000, return messages on port 6448
oscP5 = new OscP5(this,9000);
dest = new NetAddress(“127.0.0.1”,6448);
void draw() {
// Creating the boxes in window
blocks();
// Send the OSC message to wekinator
sendOsc();
void mousePressed()
if (mouseX 》 25 && mouseX 《 75)
bx=1;
if (mouseX 》 325 && mouseX 《 375)
bx=2;
void sendOsc() {
OscMessage msg = new OscMessage(“/wek/inputs”);
msg.add((float)bx);
oscP5.send(msg, dest);
void blocks()
background(0);
fill(255, 155, 0);
rect(25, 25, 50, 50);
fill(255, 255, 255);
rect(325, 25, 50, 50);
处理代码(Wekinator的输出)
import vsync.*; // Importing the library that will help us in sending and receiving the values from the Arduino
import processing.serial.*; // Importing the serial library
// Below libraries will connect and send, receive the values from wekinator
import oscP5.*;
import netP5.*;
// Creating the instances
OscP5 oscP5;
NetAddress dest;
ValueSender sender;
// These variables will be syncronized with the Arduino and they should be same on the Arduino side.
public int output;
public int output1;
void setup()
// Starting the serial communication, the baudrate and the com port should be same as on the Arduino side.
Serial serial = new Serial(this, “COM10”, 19200);
sender = new ValueSender(this, serial);
// Synchronizing the variables as on the Arduino side. The order should be same.
sender.observe(“output”);
sender.observe(“output1”);
// Starting the communication with wekinator. listen on port 12000, return messages on port 6448
oscP5 = new OscP5(this, 12000);
dest = new NetAddress(“127.0.0.1”, 6448);
// Recieve OSC messages from Wekinator
void oscEvent(OscMessage theOscMessage) {
if (theOscMessage.checkAddrPattern(“/wek/outputs”) == true) {
// Receiving the output from wekinator
float value = theOscMessage.get(0).floatValue(); // First output
float value1 = theOscMessage.get(1).floatValue(); // Second output
// Converting the output to int type
output = int(value);
output1 = int(value1);
void draw()
// Nothing to be drawn for this example
  • Arduino
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    BTN9970/BTN9990电机控制盾牌:Arduino评估利器
    BTN9970/BTN9990电机控制盾牌:Arduino评估利器 在电子工程师的日常工作中,电机控制是一个常见且重要的领域。今天,我们就来深入探讨一下英飞凌(Infineon)的BTN9970
    的头像 发表于 12-21 11:35 898次阅读
    探索用于Arduino的TLE94112ES直流电机控制盾牌
    探索用于Arduino的TLE94112ES直流电机控制盾牌 引言 在电子工程领域,电机控制一直是至关重要的部分。对于Arduino开发者而言,一款功能强大且易于使用的电机
    的头像 发表于 12-18 16:35 546次阅读
    Arduino plc和termux esp
    的头像 发表于 12-06 06:41 2065次阅读
    贸泽电子开售全新Arduino UNO Q单板计算机
    贸泽电子开售全新Arduino UNO Q单板计算机。Arduino UNO Q单板计算机(SBC)将高性能计算与实时控制结合,提供理想的创新平台。
    的头像 发表于 11-08 09:50 1620次阅读
    在Ubuntu20.04系统中训练神经网络模型的一些经验
    本帖欲分享在Ubuntu20.04系统中训练神经网络模型的一些经验。我们采用jupyter notebook作为开发IDE,以TensorFlow2为训练框架,目标是训练一个手写数字识别的神经网络
    发表于 10-22 07:03
    高通宣布收购 Arduino,加速普及前沿边缘计算与 AI 技术
    UNO Q 是 Arduino 首款由高通 Dragonwing 平台驱动的“双大脑”开发板,它桥接了高性能计算与实时控制,能够“眨眼间实
    的头像 发表于 10-08 11:15 950次阅读
    高通宣布收购 <b class='flag-5'>Arduino</b>,加速普及前沿边缘计算与 AI 技术
    如何在 NuMaker-IoT-M467 板上使用 Arduino IDE 控制 Wi-Fi 模块?
    在NuMaker开发板上,有一个ESP-12F Wi-Fi模块;但是,Arduino IDE 中的 NuMaker UNO 包不提供该模块的相关控制。如果您希望在 Arduino IDE 中
    发表于 09-04 08:28
    如何用Arduino Nano/UNO R3开发板给另一个Arduino IDE不能下载的Arduino Nano/UNO R3开发板重新烧录引导程序bootlaoder
    本文介绍了如何用能够Arduino IDE下载的Arduino Nano/UNO R3开发板给另一个Arduino IDE不能下载的Arduino Nano/UNO R3开发板重新烧录
    的头像 发表于 08-08 20:16 4014次阅读
    如何用<b class='flag-5'>Arduino</b> Nano/UNO R3开发板给另一个<b class='flag-5'>Arduino</b> IDE不能下载的<b class='flag-5'>Arduino</b> Nano/UNO R3开发板重新烧录引导程序bootlaoder
    make sence成的XML文件能上传到自助训练模型上吗?
    发表于 06-23 07:38
    使用 ai cude 里面自带的案例训练UI显示异常的原因?怎么解决?
    案例的配置是默认的,显示训练ui更改显示异常
    发表于 06-23 06:21
    Arduino与LabVIEW联合编程指南
    Arduino编程并与LabVIEW上位机结合实现设备的远程控制与数据采集。
    发表于 06-19 15:54 3次下载
    k210在线训练的算法是yolo5吗?
    k210在线训练的算法是yolo5吗
    发表于 06-16 08:25
    OCR识别训练完成后给的是空压缩包,为什么?
    OCR识别 一共弄了26张图片,都标注好了,点击开始训练,显示训练成功了,也将压缩包发到邮箱了,下载下来后,压缩包里面是空的 OCR图片20几张图太少了。麻烦您多添加点,参考我们的ocr识别训练数据集 请问
    发表于 05-28 06:46
    免费分享Arduino入门+进阶(全套例程+书籍)
    创意,比如控制灯光、传感器、电机等。以下是Arduino入门+进阶学习资料1.Arduino编程语言说明(相关文件可在下文扫码领取)2.Arduino系列学习例程
    的头像 发表于 05-22 11:40 1350次阅读
    免费分享<b class='flag-5'>Arduino</b>入门+进阶(全套例程+书籍)
    《ESP32S3 Arduino开发指南》第二章 Arduino基础知识
    的发展,在Arduino出现以前,虽然也有很多公司在推广一些简单易用的可编程控制器,但是由于开发平台种类繁多,而且使用这些控制器基本上都需要对电子技术、数字逻辑、寄存器等内容进行多方面的了解和学习,才能
    发表于 05-13 09:28
