AP43770主要特性_功能框图表和典型应用电路
电子工程师 来源:陈翠 2019-08-04 10:45 次阅读
Diodes公司的45W USB PD 3.0适配器评估板由三部分组成:1)电流模式PWM控制器AP3108L,提供具有频率折回的DCM/CCM PWM开关,以提高效率;2)同步整流控制器APR346;3) USB Type-C供电控制器AP43770,它和USB Type-C规范发布1.3和USB供电(PD)规范Rev3.0 V1.2兼容。 AP43770以20mV/步分辨率和50mA/步电流分辨率支持PPS APDO,用来电源管理。它也支持移动市场的高通快速充电4(Qualcomm Quick Charge 4)。评估板满足DOE 6 和CoC Tier 2效率要求,无负载待机功耗小于30mW,主要用在USB PD 3.0墙上适配器和USB PD 3.0汽车充电器。本文介绍了AP3108L主要特性,功能框图表和典型应用电路,以及AP43770主要特性,功能框图表和典型应用电路。同时还介绍了45W USB PD 3.0适配器评估板EV2主要特性和电源指标,电路图,变压器指标和材料清单。
1.AP3108L
The AP3108L is a Current Mode PWM controller specially designed for offline power supply that requires ultra-low standby power, high- power density and comprehensive protection. The AP3108L coordinating with Diodes’ secondary side controller, such as the AP4320, can be applied in the situation that requires for constant CC and constant CV.
The maximum switching frequency of the AP3108L is set at 65kHZ. The switching frequency can be modulated through green mode, in which it will smoothly decrease along with the decreasing load. This will cause the minimum switching frequency to be clamped at about 22kHz to avoid audible noise.
The AP3108L provides an inner high-voltage start-up function through HV pin which can save the use of the external start-up resistor, reducing the standby loss. The HV pin also realizes X-CAP discharge function. This is a useful function for power saving when an X-CAP is connected to a system, for it will discharge the X-CAP when the AC line voltage is off automatically without the need for extra discharge resistors.
The AP3108L integrates a VCC LDO circuitry, allowing the LDO to regulate the wide range VCC_IN, which is rectified from auxiliary winding to an acceptable value. This makes the AP3108L a good choice in wide range output voltage application.
There are also versatile system protections provided by AP3108L, such as secondary side OVP, secondary side UVP, constant output current limit, cycle-by-cycle current limit, brown-out protection, programmable external OTP, etc.
AP3108L主要特性:
 Current Mode Control
 High-Voltage Startup
 Embedded VCC LDO to Guarantee Wide Range Output Voltage
 Constant, Low Output Current in Output Short Situation
 Low VCC Charge Current Reduces Standby Power in Output Short Situation
 Non-Audible-Noise Green-Mode Control
 Internal Slope Compensation
 Soft Start During Startup Process
 Frequency Fold Back for High Average Efficiency
 Constant Over Current Protection(COCP)
 VCC Maintain Mode
 X-CAP Discharge Function
 Precise Secondary Side OVP and UVP
 Programmable External OTP
 Brown-Out Protection
 Overload Protection
 FOCP and SSCP Protection
 Useful Pin Fault Protection
 SSOP-9 (Type CJ) is Available
 Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
 Halogen and Antimony Free. “Green” Device (Note 3)
AP3108L应用:
 Switching AC-DC Adapter/Charger
 Open Frame Switching Power Supply
图1.AP3108L典型应用电路
图2. AP3108L功能框图
2.AP43770
The AP43770 is a USB Type-C power delivery controller dedicated to power source applications with legacy capability. It is compliant with USB Type-C specification release 1.3 and USB power delivery (PD) specification Rev3.0 V1.2.
The AP43770 can support PPS APDO with 20mV/step resolution and 50mA/step current resolution for power management. In addition, it supports Qualcomm Quick Charge 4 for mobile market. What’s more, cable-loss compensation and SOP’command for e-Marker detection are embedded too.
In consideration of customer applications, the AP43770 supports options for non-PD protocols like BC 1.2, QC4/4+,QC3.0/QC2.0, and other legacy protocols with auto-detection. It maintains backwards compatibility with the existing environment. There are rich power-features embedded on the chip and they can be configured through CC channel.
AP43770主要特性:
 Compliant with USB PD Rev3.0 V1.2
 USB-IF PD3.0/PPS Certificated TID = 1090017
 Qualcomm QC4 and QC4+,QC3.0, QC2.0 Built-in
 Support VOUT 20mV/Step from 3.3V to 20V
 Support Current Limit 50mA/Step up to 6A
 OTP(One-Time-Programmable ) for Main Firmware
 MTP (Multi-Time-Programmable ) for System Configuration
 USB PD Transceiver with High Noise Immunity
 Built-In CC/CV Controller
 Support e-Marker Cable Detection
 Built-In VCONN Switch with OCP Protection
 Cable Compensation for Different Load Condition
 Programmable for Configuration through CC Line
 Support OCP/SCP/OTP/UVP with Auto-Restart
 Built-In 5V/1.8V LDO
 Low Standby Current : 550μA
 Maximum 32V Input Voltage Rating
 Support Non-USB PD Protocol Options
 BC 1.2 Legacy Built-In
 TID(11090017) for USB PD 3.0 PPS Compliance Test
 Package: TSSOP-16
AP43770应用:
• AC Adapters
• Car Chargers
• USB PD Converter
• Power Hubs
• Power Banks
图3.AP43770功能框图
图4. AP43770典型应用电路图
The 45W USB PD 3.0 Adaptor Evaluation Board EV2 is composed of three main parts. The AP3108L offers DCM/CCM PWM switching with frequency fold-back for improving efficiency. The APR346 is a Synchronous Rectification Controller, and the AP43770T16 is a USB 3.0 protocol decoder which is based on monitoring CC1 & CC2 signals for interpreting desired voltage and current setting, and then feedback the information to primary side AP3108L controller to provide well regulated voltage and current as well as related power protections. The 45W USB PD 3.0 Power Brick board passed the USB IF Compliance Test (TID: 11090056), at June 2018.
45W USB PD 3.0适配器评估板EV2主要特性:
1.1系统主要特性:
 SSR Topology Implementation with an Opto-coupler for Accurate Step Voltage Controlling
 USB PD 3.0 Compliance
 Meet DOE 6 and CoC Tier 2 Efficiency Requirements
 《30mW No-Load Standby Power
1.2. AP3108L主要特性:
 Current Mode PWM Controller
 Frequency shift function changes frequency per line loading
 Frequency fold back for high average efficiency
 Integration of high-voltage start-up circuit to enable low standby power
 Integration of 100V LDO, X-cap discharge for minimal system BOM components
 Constant load output current during output short circuit
 Rich Protection Functions: Precise Secondary Side OVP, UVP, OLP, BNO,FOCP, SSCP, External Programmable OTP
1.3. APR346主要特性:
 Synchronous rectification operating at DCM, CCM and QR mode for flyback topology
 Eliminate Resonant Ringing Interference
 Fewest External Components used
1.4. AP43770T16-13主要特性:
 Type-C USB PD DFP (Downstream Facing Port)
 USB PD2.0, PD 3.0,PPS,QC4 Protocol Decoding
 10-Bit DAC for Vbus 3 ~ 20 voltage and 7 bits DAC for current monitoring
 Built in shunt regulator for constant voltage and constant current
 Support E-marker cable detection
 Programmable OVP/UVP/OCP/OTP
 Internal Discharge MOS
 Internal Vbus Load Switch Driver
 3V- 30V operation voltage without external regulator
 Package 16-Pin TSSOP
 USB PD 3.0 PPS IC Compliance Certified – TID #11090017, 07/12/2018
45W USB PD 3.0适配器评估板EV2应用:
 USB PD 3.0 Wall Adaptor
 USB PD 3.0 Car Charger
主要电源指标(CV&CC模式):
图5.45W USB PD 3.0适配器评估板EV2外形图(正面)
图6.45W USB PD 3.0适配器评估板EV2外形图(背面)
图7.45W USB PD 3.0适配器评估板EV2电路图
45W USB PD 3.0适配器评估板EV2材料清单:
变压器设计指标:
图8.45W USB PD 3.0适配器评估板EV2 PCB布局图:左:顶层;右:底层
图9.样板的连接图
  • 适配器
    TPS92310典型用电路图及拓扑图
    本文介绍了TPS92310主要特性,方框图,典型用电路图,隔离和非隔离拓扑的电路
    发表于 03-28 16:58 3809次阅读
    TPS92310<b class='flag-5'>典型</b>应<b class='flag-5'>用电路</b>图及拓扑图
    用电子元器件学习+实战书籍(图表细说典型电路与失效分析)
    的教学参考书。 《图表细说元器件及实用电路》(超值版)详细介绍了电子元器件基础知识及其实用电路的分析方法,内容包括电阻、电容、电感、变压器、二极管、三极管、放大器、集成电路等元器件的基
    发表于 03-19 15:31
    典型栅极驱动电路框图
    典型栅极驱动电路框图
    发表于 11-05 23:14 1037次阅读
    <b class='flag-5'>典型</b>栅极驱动<b class='flag-5'>电路</b><b class='flag-5'>框图</b>
    IDT无线充电P9038发送器方案(P9038主要特性,功能框图及应用电路
     摘要:本文主要介绍了P9038主要特性功能框图以及典型的应
    发表于 12-13 08:54 4460次阅读
    IDT无线充电P9038发送器方案(P9038<b class='flag-5'>主要</b><b class='flag-5'>特性</b>,<b class='flag-5'>功能</b><b class='flag-5'>框图</b>及应<b class='flag-5'>用电路</b>)
    LT8607的主要特性,功能框图,多种应用电路解析
    和可同步频率200kHz到2.2MHz,主要用在通用降压转换器和低EMI降压转换器.本文介绍了LT8607主要特性,功能框图,多种应
    发表于 02-11 06:03 2084次阅读
    LT8607的<b class='flag-5'>主要</b><b class='flag-5'>特性</b>,<b class='flag-5'>功能</b><b class='flag-5'>框图</b>,多种应<b class='flag-5'>用电路</b>解析
    DRV8802-Q1主要特性 功能框图和应用电路
    AEC-Q100规范,工作温度–40℃到125℃,主要用在汽车HVAC,汽车阀门和汽车娱乐系统.本文介绍了DRV8802-Q1主要特性,功能框图
    发表于 04-12 16:00 2383次阅读
    DRV8802-Q1<b class='flag-5'>主要</b><b class='flag-5'>特性</b> <b class='flag-5'>功能</b><b class='flag-5'>框图</b>和应<b class='flag-5'>用电路</b>
    一文详解UCC28780主要特性_功能框图典型用电路
    模式可提高轻负载效率,具有低输出波纹和减轻可听见噪音.主要用在笔记本电脑,平板电脑,TV,机顶盒和打印机的高密度AC/DC适配器,USB供电,直接和快速移动充电器,AC/DC或DC/DC辅助电源.本文介绍了UCC28780主要特性
    的头像 发表于 06-16 00:15 2.1w次阅读
    一文详解UCC28780<b class='flag-5'>主要</b><b class='flag-5'>特性</b>_<b class='flag-5'>功能</b><b class='flag-5'>框图</b>及<b class='flag-5'>典型</b>应<b class='flag-5'>用电路</b>图
    一文解析TPS657051的特性_功能_应用电路
    本文介绍了TPS657051/52主要特性, 功能框图, 应用电路和TPS657051/2EVM-522 评估模块
    的头像 发表于 05-12 09:05 5936次阅读
    一文解析TPS657051的<b class='flag-5'>特性</b>_<b class='flag-5'>功能</b>_应<b class='flag-5'>用电路</b>
    ad8367中文资料汇总(ad8367引脚图及功能框图_特性参数及应用电路
    本文首先介绍了AD8367主要特点及特性参数,其次介绍了AD8367引脚及功能与它的原理框图,最后介绍了AD8367封装信息及三款应用电路
    发表于 05-16 10:27 3.7w次阅读
    ad8367中文资料汇总(ad8367引脚图及<b class='flag-5'>功能</b><b class='flag-5'>框图</b>_<b class='flag-5'>特性</b>参数及应<b class='flag-5'>用电路</b>)
    AD8452主要特性_框图以及应用电路
    本文介绍了AD8452主要特性,框图,应用电路,评估板AD8452-EVALZ主要特性,
    的头像 发表于 05-11 10:33 7849次阅读
    AD8452<b class='flag-5'>主要</b><b class='flag-5'>特性</b>_<b class='flag-5'>框图</b>以及应<b class='flag-5'>用电路</b>
    NCP51705主要特性_内部框图以及应用电路
    本文介绍了NCP51705主要特性,内部框图,低边开关配置图和应用电路,以及NCP51705 Mini 评估板和NCP51705 Mini SMD评估板
    的头像 发表于 05-11 10:20 4509次阅读
    NCP51705<b class='flag-5'>主要</b><b class='flag-5'>特性</b>_内部<b class='flag-5'>框图</b>以及应<b class='flag-5'>用电路</b>
    ISO224主要特性以及应用电路
    本文介绍了ISO224主要特性框图,应用电路以及评估模块ISO224EVM主要特性
    的头像 发表于 04-05 17:41 1.2w次阅读
    ISO224<b class='flag-5'>主要</b><b class='flag-5'>特性</b>以及应<b class='flag-5'>用电路</b>
    MAX40056主要特性以及应用电路
    本文介绍了MAX40056主要优势和特性框图,应用电路,以及评估板MAX40056 EVK主要特性
    发表于 04-05 11:25 5794次阅读
    MAX40056<b class='flag-5'>主要</b><b class='flag-5'>特性</b>以及应<b class='flag-5'>用电路</b>
    MAX86150的优势特性以及典型用电路
    本文介绍了MAX86150主要优势和特性,简化框图功能框图典型
    发表于 04-05 22:11 5785次阅读
    MAX86150的优势<b class='flag-5'>特性</b>以及<b class='flag-5'>典型</b>应<b class='flag-5'>用电路</b>图
    智能LED灯驱动器FL7701的主要特性指标及应用电路
    振荡器的频率段LED状语从句:电流,主要用在LED装饰照明和低功率LED照明。本文介绍了FL7701主要特性,方框图,状语从句:有没有电解电容的应
    的头像 发表于 03-30 09:50 5353次阅读
    智能LED灯驱动器FL7701的<b class='flag-5'>主要</b><b class='flag-5'>特性</b>指标及应<b class='flag-5'>用电路</b>
