怎样用ESP32创建一个Web服务器 并将其连接到Wi-Fi获取IP地址
454398 来源:工程师吴畏 2019-07-26 09:15 次阅读
入门
客户端与客户端之间的连接webserver是使用HTTP协议建立的。 HTTP协议如下所示:HTTP/1.1 200 OK r nContent-Type:text/html r n r n“。
”HTTP/1.1 200 OK“表示服务器已接受请求并已回复“200 OK”,这是状态代码,后跟“ r n”,这是HTTP协议的约束。
“Content-Type:text/html r n“表示响应内容类型为HTML格式,后跟” r n“
在HTTP协议结束时,网络服务器将返回显示”Hello world“的网页。
代码
#include
const char* wifi_name = “Tenda_31BC98”; //Your Wifi name
const char* wifi_pass = “barcelona”; //Your Wifi password
WiFiServer server(80); //Port 80
void setup()
Serial.begin(115200);
// Let‘s connect to wifi network
Serial.print(“Connecting to ”);
Serial.print(wifi_name);
WiFi.begin(wifi_name, wifi_pass); //Connecting to wifi network
while (WiFi.status() != WL_CONNECTED) { //Waiting for the responce of wifi network
delay(500);
Serial.print(“。”);
Serial.println(“”);
Serial.println(“Connection Successful”);
Serial.print(“IP address: ”);
Serial.println(WiFi.localIP()); //Getting the IP address at which our webserver will be created
Serial.println(“Put the above IP address into a browser search bar”);
server.begin(); //Starting the server
void loop()
WiFiClient client = server.available(); //Checking for incoming clients
if (client)
Serial.println(“new client”);
String currentLine = “”; //Storing the incoming data in the string
while (client.connected())
if (client.available()) //if there is some client data available
char c = client.read(); //read a byte
Serial.print(c);
if (c == ’ ‘) //check for newline character,
if (currentLine.length() == 0) //if line is blank it means its the end of the client HTTP request
client.print(“”);
client.print(“
Hello World
break; //Going out of the while loop
else
currentLine = “”; //if you got a newline, then clear currentLine
else if (c != ’ ‘)
currentLine += c; //if you got anything else but a carriage return character,
delay(2000);
代码说明
首先,我们加入了Wi-Fi库,它将帮助我们创建网络服务器。然后我们存储了Wi-Fi名称和密码,以便我们可以连接到这个Wi-Fi网络。之后,我们定义了我们要将数据发送到的端口
在setu中p功能,我们使用上面提供的Wi-Fi信息ESP32连接到我们的Wi-Fi网络。如果与Wi-Fi网络的连接成功,则“连接成功”将显示在串行监视器上。否则,它将继续尝试,直到它将连接到Wi-Fi网络。
delay(500);
Serial.print(“。”);
Serial.println(“”);
以下命令将获取IP地址,我们将在串行监视器上显示它。
然后我们启动了服务器,以便我们可以获取数据并将数据发送到浏览器。
server.begin( );
在循环函数中,我们检查了是否有客户端发送了http请求。如果有任何客户端请求可用,它将存储在字符中并显示在串行监视器上。在请求结束时,我们将发送HTML命令,它将在网页上打印“Hello world”。
if (client)
Serial.print(c);
if (currentLine.length() == 0) //if line is blank it means it’s the end of the client HTTP request
client.print(“
client.print(“
Hello World
如何运行代码
使用您的Wi-Fi名称和密码更改代码中的Wi-Fi名称和密码。然后上传代码并打开串行监视器。串行监视器将显示IP地址,如下图所示。在浏览器中输入此IP地址。
输入IP地址后,网页将如下所示。
  • Web服务器
  • ESP32
    原来ESP32竟可《“芯”两》既做人体检测传感也做Wi-Fi数据传输
    今天将介绍ESP32如何"芯两",既做人体检测传感也做Wi-Fi数据传输模块;对于使用ESP32
    的头像 发表于 12-18 18:12 514次阅读
    原来<b class='flag-5'>ESP32</b>竟可《<b class='flag-5'>一</b>“芯”两<b class='flag-5'>用</b>》既做人体检测传感<b class='flag-5'>器</b>也做<b class='flag-5'>Wi-Fi</b>数据传输
    基于ESP32-C3FN4为核心自主研发的Wi-Fi+BT模块-RF-WM-ESP32B1
    WI-FI模组 - RF-WM-ESP32B1是基于ESP32-C3FN4为核心自主研发的Wi-Fi+BT模块,支持IEEE 802.11b/g/n (2.4 GHz
    的头像 发表于 11-07 09:45 236次阅读
    基于<b class='flag-5'>ESP32</b>-C3FN4为核心自主研发的<b class='flag-5'>Wi-Fi</b>+BT模块-RF-WM-<b class='flag-5'>ESP32</b>B1
    【AI技术支持】ESP32无线Wi-Fi常用调试API
    Wi-Fi常用调试API在使用esp32调试Wi-Fi功能时,由于场景和各种因素的影响,难免会遇到各种连接不上,Wi-Fi断连等问题。下面介
    的头像 发表于 10-26 08:00 611次阅读
    【AI技术支持】<b class='flag-5'>ESP32</b>无线<b class='flag-5'>Wi-Fi</b>常用调试API
    esp8266和esp32区别是什么
    以下是关于ESP8266和ESP32的主要区别: 处理和架构 : ESP8266 :使用T
    的头像 发表于 08-19 18:16 5424次阅读
    IR900 Wi-Fi联网的配置过程
    ”接口选择Wi-Fi接口: dot11radio1类型选择:动态地址( DHCP) 如果Wi-Fi路由没有开DHCP,请选择类型:静
    发表于 07-25 06:09
    ESP8266如何为应用程序选择正确的Wi-Fi模块吗?
    连接 4 站点 - 接入点/软AP同时具有站点模式(使主机能够在网络上充当站点) - Zeroconf DNS服务发现 - 次打开4T
    发表于 07-19 16:56
    如何将多个ESP连接到ESP并向服务器发送数据?
    。 该站模式 ESP 连接了传感。所有这些站模式 esp 收集传感数据并将数据发送到主
    发表于 07-19 06:49
    AT 0.60.0.0看不到我的Wi-Fi网络,为什么?
    Wi-Fi 网络并连接到它。当然,我的路由AP SSID已启用,我可以在其他设备上看到此网络。这不是什么大问题,但我认为它仍然是错误
    发表于 07-18 08:31
    为什么ESP8266没有检测到Wi-Fi的SSID?
    你好,我的ESP8266没有检测到我家Wi-Fi的SSID。我尝试打开我的 iPhone 热点,我可以正常查看和连接(我也成功连接到 MQTT)。相反,没有办法看到我家的
    发表于 07-09 06:44
    ESP826如何运行AP TCP服务器
    应该从平板电脑客户端获取命令进行进步处理。不涉及额外的路由。 现在,AP工作正常,平板电脑可以登录WLAN并获得正确的IP地址。但是客户
    发表于 07-09 06:27
    使用的是esp32官方的Wi-Fi例程,一直连接不上Wi-Fi怎么解决?
    使用的是esp32官方的Wi-Fi例程 一直连接不上Wi-Fi 日志: ESP-ROM:esp8
    发表于 07-02 07:21
    ESP32-S2如何找到send函数的底层接口函数?
    你好,我正在用ESP32-S2做一个项目,当有Wi-Fi时,通过Wi-Fi连接服务器;当没
    发表于 06-28 08:18
    请问ESP32-AT支持Wi-Fi漫游指令吗?
    请问 ESP32-AT 支持 Wi-Fi 漫游指令吗?我这边在 ESP-IDF 下面看到有 roaming 的示例,但是在 esp-at 中没有找到相关指令。
    发表于 06-27 07:13
    使用ESP32-C3的SoftAP模式创建Wi-Fi热点,ESP32-C3不输出任何日志,并且无法响应,为什么?
    问题描述: 我正在使用ESP32-C3的SoftAP模式创建Wi-Fi热点,并使用手机连接到该热点。当手机连接成功并熄屏
    发表于 06-07 08:26
    Wi-Fi HaLow和传统Wi-Fi的区别
    Wi-Fi HaLow和传统Wi-Fi的区别  Wi-Fi种无线网络技术,可以连接到互联网或局域网,为用户提供无线上网的便利。随着科技的
    的头像 发表于 02-02 15:28 1281次阅读
