如何制作Arduino雷达
454398 来源:wv 2019-08-28 11:06 次阅读
第1步:材料和程序
此构建所需的材料包括:
- 1个伺服
- 1个超声波传感器
- 1个蜂鸣器
- 1面包板
- 1 UNO R3 Arduino
- 电线堆
制作此雷达所需的程序:
- Arduino IDE
- 处理3.4
要将上述程序下载到您的计算机上,请点击以下链接:
- https://www.arduino.cc/en/main/software
-https://processing.org/download/
第2步:Arduino代码
这是arduino代码,它基本上控制伺服和传感器的运动和输入。这是从youtube视频https://www.youtube.com/watch?v=JvmIutmQd9U复制而来,似乎与我的arduino板和计算机很好地配合。
// Includes the servo library
#include 。
// Defines Trig and Echo pins of the Ultrasonic Sensor
const int trigPin = 10;
const int echoPin = 11;
#define buzzerPin A0 //Defines the pin A0 as an output to buzzerPin
// Variables for the duration and the distance
long duration;
int distance;
Servo myServo; // Creates a servo object for controlling the servo motor
void setup() {
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
Serial.begin(9600);
myServo.attach(12); // Defines on which pin is the servo motor attached
void loop() {
// rotates the servo motor from 15 to 165 degrees
for(int i=15;i《=165;i++){
myServo.write(i);
delay(30);
distance = calculateDistance();// Calls a function for calculating the distance measured by the Ultrasonic sensor for each degree
Serial.print(i); // Sends the current degree into the Serial Port
Serial.print(“,”); // Sends addition character right next to the previous value needed later in the Processing IDE for indexing
Serial.print(distance); // Sends the distance value into the Serial Port
Serial.print(“。”); // Sends addition character right next to the previous value needed later in the Processing IDE for indexing
tone(buzzerPin, 10000 / distance);
// Repeats the previous lines from 165 to 15 degrees
for(int i=165;i》15;i--){
myServo.write(i);
delay(30);
Serial.print(i);
Serial.print(“,”);
Serial.print(“。”);
tone(buzzerPin, 10000 / distance); //Produces a different tone according to the distance the object is from the sensor
// Function for calculating the distance measured by the Ultrasonic sensor
int calculateDistance(){
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH); // Reads the echoPin, returns the sound wave travel time in microseconds
distance= duration*0.034/2;
return distance;
步骤3:处理代码
以下是我用于处理程序从超声波传感器获取信息的代码,并将其转换为它创建的显示。这是我从视频https://www.youtube.com/watch?v=JvmIutmQd9U复制的代码,该代码效果非常好,只需要进行一些调整。
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px ‘Helvetica Neue’; color: #000000; -webkit-text-stroke: #000000}
p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px ‘Helvetica Neue’; color: #000000; -webkit-text-stroke: #000000; min-height: 12.0px}
span.s1 {font-kerning: none}
import processing.serial.*; // imports library for serial communication
import java.awt.event.KeyEvent; // imports library for reading the data from the serial port
import java.io.IOException;
Serial myPort; // defines Object Serial
// defubes variables
String angle=“”;
String distance=“”;
String data=“”;
String noObject;
float pixsDistance;
int iAngle, iDistance;
int index1=0;
int index2=0;
PFont orcFont;
void setup() {
size (1200, 700); // ***CHANGE THIS TO YOUR SCREEN RESOLUTION***
smooth();
myPort = new Serial(this,“/dev/cu.usbmodem143401”, 9600); // starts the serial communication
myPort.bufferUntil(‘。’); // reads the data from the serial port up to the character ‘。’. So actually it reads this: angle,distance.
void draw() {
fill(98,245,31);
// simulating motion blur and slow fade of the moving line
noStroke();
fill(0,4);
rect(0, 0, width, height-height*0.065);
fill(98,245,31); // green color
// calls the functions for drawing the radar
drawRadar();
drawLine();
drawObject();
drawText();
void serialEvent (Serial myPort) { // starts reading data from the Serial Port
// reads the data from the Serial Port up to the character ‘。’ and puts it into the String variable “data”。
data = myPort.readStringUntil(‘。’);
data = data.substring(0,data.length()-1);
index1 = data.indexOf(“,”); // find the character ‘,’ and puts it into the variable “index1”
angle= data.substring(0, index1); // read the data from position “0” to position of the variable index1 or thats the value of the angle the Arduino Board sent into the Serial Port
distance= data.substring(index1+1, data.length()); // read the data from position “index1” to the end of the data pr thats the value of the distance
// converts the String variables into Integer
iAngle = int(angle);
iDistance = int(distance);
void drawRadar() {
pushMatrix();
translate(width/2,height-height*0.074); // moves the starting coordinats to new location
noFill();
strokeWeight(2);
stroke(98,245,31);
// draws the arc lines
arc(0,0,(width-width*0.0625),(width-width*0.0625),PI,TWO_PI);
arc(0,0,(width-width*0.27),(width-width*0.27),PI,TWO_PI);
arc(0,0,(width-width*0.479),(width-width*0.479),PI,TWO_PI);
arc(0,0,(width-width*0.687),(width-width*0.687),PI,TWO_PI);
// draws the angle lines
line(-width/2,0,width/2,0);
line(0,0,(-width/2)*cos(radians(30)),(-width/2)*sin(radians(30)));
line(0,0,(-width/2)*cos(radians(60)),(-width/2)*sin(radians(60)));
line(0,0,(-width/2)*cos(radians(90)),(-width/2)*sin(radians(90)));
line(0,0,(-width/2)*cos(radians(120)),(-width/2)*sin(radians(120)));
line(0,0,(-width/2)*cos(radians(150)),(-width/2)*sin(radians(150)));
line((-width/2)*cos(radians(30)),0,width/2,0);
popMatrix();
void drawObject() {
pushMatrix();
strokeWeight(9);
stroke(255,10,10); // red color
pixsDistance = iDistance*((height-height*0.1666)*0.025); // covers the distance from the sensor from cm to pixels
// limiting the range to 40 cms
if(iDistance《40){
// draws the object according to the angle and the distance
line(pixsDistance*cos(radians(iAngle)),-pixsDistance*sin(radians(iAngle)),(width-width*0.505)*cos(radians(iAngle)),-(width-width*0.505)*sin(radians(iAngle)));
popMatrix();
void drawLine() {
pushMatrix();
strokeWeight(9);
stroke(30,250,60);
line(0,0,(height-height*0.12)*cos(radians(iAngle)),-(height-height*0.12)*sin(radians(iAngle))); // draws the line according to the angle
popMatrix();
void drawText() { // draws the texts on the screen
pushMatrix();
if(iDistance》40) {
noObject = “Out of Range”;
else {
noObject = “In Range”;
fill(0,0,0);
noStroke();
rect(0, height-height*0.0648, width, height);
fill(98,245,31);
textSize(25);
text(“10cm”,width-width*0.3854,height-height*0.0833);
text(“20cm”,width-width*0.281,height-height*0.0833);
text(“30cm”,width-width*0.177,height-height*0.0833);
text(“40cm”,width-width*0.0729,height-height*0.0833);
textSize(40);
text(“Ryan‘s Radar”, width-width*0.875, height-height*0.0277);
text(“Angle: ” + iAngle +“ °”, width-width*0.48, height-height*0.0277);
text(“Distance: ”, width-width*0.26, height-height*0.0277);
if(iDistance《40) {
text(“ ” + iDistance +“ cm”, width-width*0.225, height-height*0.0277);
textSize(25);
fill(98,245,60);
translate((width-width*0.4994)+width/2*cos(radians(30)),(height-height*0.0907)-width/2*sin(radians(30)));
rotate(-radians(-60));
text(“30°”,0,0);
resetMatrix();
translate((width-width*0.503)+width/2*cos(radians(60)),(height-height*0.0888)-width/2*sin(radians(60)));
rotate(-radians(-30));
text(“60°”,0,0);
resetMatrix();
translate((width-width*0.507)+width/2*cos(radians(90)),(height-height*0.0833)-width/2*sin(radians(90)));
rotate(radians(0));
text(“90°”,0,0);
resetMatrix();
translate(width-width*0.513+width/2*cos(radians(120)),(height-height*0.07129)-width/2*sin(radians(120)));
rotate(radians(-30));
text(“120°”,0,0);
resetMatrix();
translate((width-width*0.5104)+width/2*cos(radians(150)),(height-height*0.0574)-width/2*sin(radians(150)));
rotate(radians(-60));
text(“150°”,0,0);
popMatrix();
步骤4:超声波传感器支架
由于我对此项目的启发并未包含任何类型的支架来固定超声波传感器在适当的位置,我决定3D打印这个支架是一个好主意,让完成的设计看起来更整洁,并使一切更容易组合。保持超声波传感器的部分最终相对紧密地安装在超声波传感器周围,在保持其就位方面做得很好。然而,在下面切出的用于伺服臂进入的孔有点太大,所以我需要添加很多胶水来保持它的位置。但总的来说,它的效果非常好,并且设计看起来很漂亮。
第5步:激光切割盒设计
实施此框以使项目具有干净和专业的外观。它在隐藏所有电线和arduino板本身方面做得很好。为了创建实际的盒子设计,我使用网站http://www.makercase.com/来获得手指边缘以将盒子的每一侧连接在一起。这是一个非常有用的网站,因为它节省了我大量的时间,并且非常容易使用。从雷达的成品中可以看出,我在设计的侧面和顶部切出了测量孔,以便允许项目的部分需要在外面。这包括用于伺服的孔,我从下面粘到盒子上,连接到超声波传感器,蜂鸣器,以及从计算机到arduino板本身。这是相当大的(盒子里有很多空间),但至少它给你很大的工作空间,没有任何东西是狭窄的。如果你自己做一个盒子设计,你肯定可以做得更小,一切都会适合。
步骤6:接线构造
根据arduino代码,超声波传感器必须连接到引脚10 11.虽然和所有超声波传感器一样,它也必须连接到地和5V引脚。伺服必须连接到引脚12(myServo.attach(12);),它还必须连接到地和5V引脚。至于蜂鸣器,它只接地和模拟输出引脚A0。一旦你为雷达附加了所有必要的物品,你的电路应该看起来有点像上图。此外,尽量保持一切整洁!一旦电路在盒子里,电线都非常缠结,有可能一根或两根电线滑出不到位置并导致雷达发生故障。它发生在我身上,我发现它从那时起就保持整洁,减少了这些事件的发生。
步骤7:组装
使用强力超级胶水组装激光切割盒,因此完成后不会有碎片分开雷达。我发现更容易使用一些书来支撑盒子的一侧,这样我就可以粘上相邻的一面。在那里拿着它约5分钟后,我会继续到下一侧,依此类推。记住不要粘上其中一端,因为你显然需要放入并取出雷达。一旦盒子上的胶水硬化,您就可以继续装配。首先,我将蜂鸣器粘在外壳的顶部(如上图所示),然后当它干燥时,我将电线穿过相对的孔并将它们连接到蜂鸣器上。当谈到伺服系统时,我将伺服的小翼粘在盒子下面,所以只有伺服的顶部显示出来。这使得整个产品看起来既美观又保持其实用性,伺服头可随时轻松访问。然后使用3D打印支架中的超声波传感器,使用胶水将支架连接到伺服系统,以确保其安全。完成后,您的项目即可进行测试!
步骤8:执行
首先将计算机连接到arduino板。接下来,打开两个程序。加载arduino代码后,将其上传到主板。这应该开始伺服和蜂鸣器,因此会产生噪音,伺服也会相应转动。然后,当加载处理代码时,单击运行,如果一切顺利运行,则应显示雷达的动画。如果没有发生这种情况,请检查您使用的端口名称是否与代码中的名称完全相同。例如,如果我使用端口“/dev/cu.usbmodem143401”,请确保处理中的代码行显示“myPort = new Serial(this,”/dev/cu.usbmodem143401“,9600);”。这应该解决所有问题,它应该运行顺利。启动和运行的过程都可以在上面的视频链接上看到它正在工作和检测对象。
  • 雷达
  • Arduino
    Arduino采集雷达模块数据与串口绘图
    的头像 发表于 12-14 11:44 212次阅读
    <b class='flag-5'>Arduino</b>采集<b class='flag-5'>雷达</b>模块数据与串口绘图
    OLED 显示雷达数据
    使用萤火工场CEM5826-M11雷达模块,Arduino IDE 编译代码,OLED显示雷达数据
    的头像 发表于 12-10 13:38 167次阅读
    OLED 显示<b class='flag-5'>雷达</b>数据
    自己设计的Arduino UNO R3主控板原理图+PCB源文件(可直接打样)
    一年前做的Arduino UNO r3,开源精神,把自己这块板子奉献给大家,板子没有什么问题,可以直接打样制作,原理图文件都表明了型号。不用谢~ Arduino UNO R3主控板原理图部分截图: *附件:MYArduino
    发表于 12-10 10:14
    开源项目!基于 Arduino 的 MIDI 架子鼓
    牢固地固定在插槽中。 第 6 步:给鼓垫接线 1、固定电缆: 使用热胶将带状电缆连接到垫子上。 2、焊接鼓垫: 通过焊接将鼓垫连接到多频段带状电缆。 第 7 步:制作 Arduino 扩展板 1
    发表于 11-25 12:00
    基于Arduino的串口通信项目
    基于Arduino的串口通信项目涉及多个方面,包括硬件连接、软件编程、串口参数配置等。 一、硬件准备 Arduino开发板 :确保你有一块Arduino开发板,如Arduino Uno
    的头像 发表于 11-22 09:24 644次阅读
    定华雷达仪表学堂:雷达液位计的导波管的使用注意事项
    在安装时对导波管有其要求,要求导波管内径等于102.3毫米,壁厚6毫米,且安装要求垂直偏差小于+/-0.5度。   2、雷达液位计底部需制作一个支撑架,与导波管的间隙为15~30毫米,减少进料时湍流的冲击,导波管底部还需安装反射板和校
    的头像 发表于 11-20 17:24 194次阅读
    相控阵雷达电源芯片详解
    一相控阵雷达简介 相控阵雷达即相位控制电子扫描阵列雷达,其快速而精确转换波束的能力使雷达能够在1min内完成全空域的扫描。所谓相控阵雷达是由
    发表于 11-17 10:53
    汽车雷达回波发生器的技术原理和应用场景
    汽车雷达回波发生器是一种新型的雷达测试设备,以下是对其技术原理和应用场景的详细介绍:技术原理汽车雷达设备在发送电磁波信号时,若遇到目标物体,该物体会反射出回波信号,随后被雷达接收机捕获
    发表于 11-15 14:06
    如何使用Arduino实现CAN总线通信
    CAN总线(Controller Area Network)是一种多主控制的串行通信协议,广泛应用于汽车电子、工业自动化等领域。它以其高可靠性、实时性和灵活性而受到青睐。Arduino作为一个
    的头像 发表于 11-12 10:09 986次阅读
    如何用Arduino制作一个简易自动喂鱼器
    如果你家里养有鱼,并想找到一种自动化喂食的方法,这个项目可能会对你有所启发。 在这个教程中,作者将展示如何制作自己的基于Arduino的自动喂鱼器,让小鱼不在饿肚子。 自动喂鱼器的工作原理非常
    发表于 03-28 11:25
    雷达检测概率曲线的影响因素
    在阅读雷达书籍和相关论文时发现,雷达的检测概率Pd和信噪比有一个函数关系 我的问题是如果这个函数关系是通用的,那么在门限一定的情况下,不同的雷达的检测概率曲线是不是都一样了?如果不是,那么
    发表于 03-27 19:54
    如何制作自己的Arduino电容计
    在这个项目中,您将学习如何制作自己的Arduino电容计(测量电容器的值,范围从pF到1000的uF)。一般来说,电子爱好者喜欢设计自己的小工具而不是购买。在这个项目中,我们使用两种电容测量方法,即
    的头像 发表于 02-25 15:10 1602次阅读
    如何<b class='flag-5'>制作</b>自己的<b class='flag-5'>Arduino</b>电容计
    如何使用Arduino制作智能垃圾箱
    在这个项目中,我将向您展示如何使用Arduino制作智能垃圾箱,当您带着垃圾接近时,垃圾箱的盖子会自动打开。
    的头像 发表于 02-11 12:22 3066次阅读
    如何使用<b class='flag-5'>Arduino</b><b class='flag-5'>制作</b>智能垃圾箱
    使用Arduino Nano制作一个4×4×4 LED立方体
    在这个项目中,我们将使用 Arduino Nano 制作一个很酷的 4×4×4 LED立方体。LED 立方体,也称为 LED矩阵,可以照亮您的房间、学习空间或创客区域,使其看起来非常酷炫。此外,它非常容易构建,并帮助您在电子和编码方面发挥创意。
    的头像 发表于 02-11 12:07 3248次阅读
    使用<b class='flag-5'>Arduino</b> Nano<b class='flag-5'>制作</b>一个4×4×4 LED立方体
    Arduino制作循迹小车教程
    Arduino制作循迹小车完全教程
    发表于 01-05 11:09 7次下载
