Intel® Kaby Lake-U Celeron 3865U CPU, 6*COM, 11*USB, 1*LAN, 1*VGA, 1*LVDS, 1*Mini-PCIe
- Intel® Kaby Lake-U Celeron® 3865U CPU
- 6*COM, 11*USB, 1*1000 Mbps LAN
- Supports dual display of VGA and LVDS
- 1*Mini-PCIe (Supports mSATA/3G)
- Supports DC 12V Input
规格
General | |
CPU | Intel® Kaby Lake-U 3865U CPU, Dual-core, 1.6GHz, TDP 15W |
Chipset | Null |
Memory | Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
Storage | 2*SATA 3.0, 1*mSATA |
Expansion Interface | 1*Mini-PCIe (mSATA/3G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux |
I/O Interface | |
Serial Port | 6*RS232 (COM6 TTL optional) |
USB | 2*USB 3.0, 9*USB 2.0 (4*on rear I/O, 7*header) |
Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
PS/2 | 1*PS/2 |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface |
1*Cash Drawer wafer 1*Touch PannelController |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200 1*LVDS: Dual Channel24bit LVDS, max resolution up to 1920*1200 |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
3文章
3498浏览量
87725 -
嵌入式主板
7文章
6076浏览量
34866 -
信步科技
6文章
263浏览量
7059
嵌入式主板品牌有哪些_6大嵌入式主板品牌盘点
嵌入式主板一般理解为嵌入在设备里面做控制、数据处理使用的CPU板,也就是设备的“大脑”。嵌入式到设备里面,当然就会对主板的体积以及功耗(
信步科技SER SV-620嵌入式主板介绍
Socket P0 LGA 3647系列CPU
16*DIMM,支持ECC内存
板载BMC,支持IPMI管理功能
14*SATA,2*Intel千兆网卡
4*PCIe x16,3*PCIe x8,1*M.2
信步科技EPC SV-19026嵌入式主板介绍
采用Intel Bay Trail单芯片处理器
嵌入式工控机专用主板
6*COM, 9*USB, 2*千兆网口
2*Mini-PCIe支持mSATA和Wifi/3G/4G
1*VGA,
信步科技SV1a-H2716P嵌入式主板介绍
With SVIO support SV-M6 I/O Module to extend COM/USB/PCI
信步科技SV1-38526C嵌入式主板介绍
SV-M5 I/O Extension Modules)
Supports triple display of VGA, HDM and LVDS/eDP
2*1000 Mbps LAN
支持Intel Skylake-U Celeron 3855U处理器
采用双层I/O设计, 可搭配SV-M5子卡, 扩展至18*COM, 18*USB
提供1*VGA, 1*HDMI, 1
