Intel® Kaby Lake-U Celeron® 3865U CPU, Double-layer Rear I/O which can expand to 18*COM and 16*USB
规格
General | |
CPU | Intel® Kaby Lake-U Celeron® 3865U CPU, Dual-core,1.8 GHz,TDP 15W |
Chipset | Null |
Memory | Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM |
Storage | 1*SATA 3.0, 1*mSATA |
Expansion Interface |
1*PCI-E 16X (4X Signal) 2*Mini-PCIe (1*mSATASupported, 1*Wifi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows7/8/10, Linux |
I/O Interface | |
Serial Port | 6*RS232 (Up to 18*RS232 with SV-M5-CU) |
USB | 2*USB 3.0, 8*USB 2.0 (Up to 16*USB with SV-M5-CU) |
Ethernet | 2*Realtek® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
PS/2 | 1*PS/2 |
Parallel Port | Null |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200 1*HDMI:max resolution up to 4096*2160 1*LVDS/eDP:Dual Channel 24bit, max resolution up to 1920*1200 eDP max resolution upto 1920*1080 |
Multiple Display | Triple |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | ATX PSU or DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
3文章
3524浏览量
88398 -
嵌入式主板
7文章
6085浏览量
35196 -
信步科技
6文章
263浏览量
7139
嵌入式主板品牌有哪些_6大嵌入式主板品牌盘点
嵌入式主板一般理解为嵌入在设备里面做控制、数据处理使用的CPU板,也就是设备的“大脑”。嵌入式到设备里面,当然就会对主板的体积以及功耗(
信步科技EPC SV-19026嵌入式主板介绍
采用Intel Bay Trail单芯片处理器
嵌入式工控机专用主板
6*COM, 9*USB, 2*千兆网口
2*Mini-PCIe支持mSATA和Wifi/3G/4G
1*VGA, 1*HDMI/eDP, 1*LVDS/eDP, 支持双屏异显
信步科技SV-IPC-7200嵌入式主板介绍
Intel® Kaby Lake-U 7th Gen Core i5-7200U CPU
6*COM, 2*USB 3.0, 6*USB 2.0, 1*SATA 3.0
2*Intel
信步科技SV-KBL-U6嵌入式主板介绍
4*COM, 10*USB, 1*1000 Mbps LAN
Supports dual display of 2
信步科技SV-KBL-U4嵌入式主板介绍
Intel® Kaby Lake-U Celeron 3865U CPU
Provides OPS port for Digital White Board
Supports Dual
信步科技SV1-38526C嵌入式主板介绍
SV-M5 I/O Extension Modules)
Supports triple display of VGA, HDM and LVDS/eDP
2*1000 Mbps LAN
支持Intel Skylake-U Celeron 3855U处理器
采用双层I/O设计, 可搭配SV-M5子卡, 扩展至18*COM, 18*USB
提供1*VGA, 1*HDMI, 1
嵌入式主板是什么意思?嵌入式主板全面解析
嵌入式主板,通常被称为嵌入式系统的核心组件,是一种用于控制和数据处理的计算机硬件,其设计旨在嵌入特定设备中执行专门任务。嵌入式
