Intel® Kaby Lake-U Celeron 3865U CPU, OPS, Dual display of VGA and HDMI, 4K UHD, Wifi+BT Module on board, DC 12V Input
规格
General | |
CPU | Intel® Kaby Lake-U Celeron® 3855U CPU, Dual-core, 1.8 GHz,TDP 15W |
Chipset | Null |
Memory | Up to 8 GB DDR3L 1600 MHz, 1*SO-DIMM |
Storage | 1*SATA 3.0 (22Pin), 1*mSATA |
Expansion Interface |
2*Mini-PCIe (1*mSATA Supported,1*Wifi/3G/4G Supported) 1*OPC Port |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux |
I/O Interface | |
Serial Port | 1*RS232 |
USB | 2*USB 3.0+2*USB 2.0 (rear I/O), 1*USB 3.0+2*USB 2.0 (OPS) |
Ethernet |
1*Realtek® PCI-E LAN for 1000Mbps 1*Realtek® Wifi+BTmodule 2.4 GHz |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
PS/2 | Null |
Parallel Port | Null |
GPIO | Null |
Feature Interface | 1*Antenna Terminal Connector |
Display | |
Display Interface |
1*VGA: max resolution up to 2560*1600 1*HDMI:max resolution up to 1920*1200 1*OPS_HDMI: max resolutionup to 4096*2160 |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | 170*190mm |
Power Input | DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
3文章
3504浏览量
87942 -
嵌入式主板
7文章
6083浏览量
34971 -
信步科技
6文章
263浏览量
7073
嵌入式主板品牌有哪些_6大嵌入式主板品牌盘点
嵌入式主板一般理解为嵌入在设备里面做控制、数据处理使用的CPU板,也就是设备的“大脑”。嵌入式到设备里面,当然就会对主板的体积以及功耗(
信步科技EPC SV-19026嵌入式主板介绍
采用Intel Bay Trail单芯片处理器
嵌入式工控机专用主板
6*COM, 9*USB, 2*千兆网口
2*Mini-PCIe支持mSATA和Wifi/3G/4G
1*VGA, 1*HDMI/eDP, 1*LVD
信步科技SV7-38526嵌入式主板介绍
*LVDS/eDP, 1*HDMI, 支持双屏异显
提供MX34车载端子,便捷扩展COM/USB接口
提供2*Mini-PCIe (支持1*mSATA, 1*Wifi/3G/4G)
4寸紧凑式设计, DC 24V供电
信步科技SV-OPS-3865U嵌入式主板介绍
Provides OPS port for Digital White Board
Supports Dual
信步科技SV-IPC-3862U嵌入式主板介绍
Intel® Kaby Lake-U Celeron® 3865U CPU
10*COM, 2*USB 3.0, 12*USB 2.0
2*1000 Mbps LAN, 1*PCI-E 4
信步科技SV-IPC-7200嵌入式主板介绍
Intel® Kaby Lake-U 7th Gen Core i5-7200U CPU
6*COM, 2*USB 3.0, 6*USB 2.0, 1*SATA 3.0
2*Intel
信步科技SV-KBL-U6嵌入式主板介绍
4*COM, 10*USB, 1*1000 Mbps LAN
Supports dual display of 2
信步科技SV-KBL-S4嵌入式主板介绍
*Intel Ethernet Controller i210 for 6*RJ45 and 2*SFP, 3*Bypass
1*VGA, 2*COM, 2*USB, 4*SATA 3.0, 1*CF, 1*mSATA
1*PCI-E 16X, 1*PCI-E 1X
ATX Power Input
信步科技SV-KBL-U5嵌入式主板介绍
Double-layer Rear I/O which can expand to 18*COM and 16*USB
信步科技SV1-38526C嵌入式主板介绍
Intel Skylake-U Celeron 3855U CPU
Double-layer Rear I/O which can expand to 18*COM and 16*USB (use
支持Intel Skylake-U Celeron 3855U处理器
采用双层I/O设计, 可搭配SV-M5子卡, 扩展至18*COM, 18*USB
提供1*VGA, 1*HDMI, 1
