Intel Bay Trail J1900处理器, OPS, 提供VGA, HDMI, 双屏异显, 板载Wifi上网模块, DC 12V供电
- 采用Intel Bay Trail J1900处理器
- 提供OPS接口, 可搭配信步OPS子卡
- 支持VGA+HDMI双屏异显, 高清播放
- 支持mSATA存储, 板载Wifi上网模块
- 采用DC 12V供电
- 采用OPS行业标准尺寸170*190mm
规格
General | |
CPU | Intel® Bay Trail J1900 CPU, Quad-core, up to 2.42 GHz, TDP 10W |
Chipset | Null |
Memory | Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
Storage | 1*SATA 2.0 (22Pin), 1*mSATA |
Expansion Interface |
2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) 1*OPS Port |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux |
I/O Interface | |
Serial Port | 1*RS232 |
USB | 1*USB 3.0+2*USB 2.0 (rear I/O), 3*USB 2.0 (OPS) |
Ethernet |
1*Realtek® PCI-E LAN for 1000Mbps 1*Realtek® Wifi+BTmodule 2.4 GHz |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
PS/2 | Null |
Parallel Port | Null |
GPIO | Null |
Feature Interface | 1*Antenna Terminal Connector |
Display | |
Display Interface |
1*VGA: max resolution up to 2560*1600@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | 170*190mm |
Power Input | DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3567浏览量
89209 -
嵌入式主板
7文章
6086浏览量
35555 -
信步科技
7文章
263浏览量
7268
信步科技SV-1900-DS嵌入式主板介绍
Support Intel Bay Trail J1900 CPU
Designed for Digital Signage/Multimedia display device
信步科技SV-1900D嵌入式主板介绍
2*COM, 10*USB, 1*1000 Mbps LAN
Support dual display of VGA
信步科技SCM-J1900嵌入式主板介绍
Intel Bay Trail J1900处理器, 6*COM, 8*USB, 2*LAN, SCM核心模块
采用Intel® Bay Trail单芯片处理器
与载板通过B2B连接器进行整合
信步科技OPS-3855U规格
Skylake-U Celeron 3855U处理器
提供OPS接口, 可搭配信步OPS子卡
支持VGA+HDMI双屏异显, 4K超高清播放
信步科技OPS-H270规格英文版
Intel® Kaby Lake 7th Gen Core i3/i5/i7 CPU (LGA1151) with H270, Supports OPS-C+, 4K UHD, 2
信步科技NVR SV1-1908主板规格英文版
Intel Bay Trail J1900 CPU, 9*SATA, 2*1000 Mbps Intel LAN, 1*Mini-PCIe, NVR Alarm port Intel Bay
,支持多种双屏异显 规格 General CPU Intel Bay Trail J1900CPU, Quad-core, up to 2.42 GHz, TDP 10W Chipset Null
信步科技OPS-H110主板规格英文版
Intel 6/7代Core i3/i5/i7处理器 (LGA1151), OPS-C+, 支持VGA, HDMI, DP双屏异显, 4K超高清, DC 12~19V供电
RK3568与J1900性能对比
RK3568与J1900性能对比 面向人工智能、物联网、安防等新兴领域,RK3568是瑞芯微推出的一款高性能SoC芯片,而J1900则是英特尔推出的低功耗桌面级芯片。这两款芯片的性能有何差别呢?本文
