Intel® Kaby Lake-U Celeron 3865U CPU at the solder side of M/B, with 6*COM, 2*1000 Mbps Intel LAN, 2*Mini-PCIe, 3.5'' (146*105mm)
规格
General | |
CPU | Intel® Kaby Lake-U Celeron 3865U CPU, Dual-core, up to 1.80GHz, TDP 15W |
Chipset | Null |
Memory | Up to 8 GB DDR3L 1600 MHz, 1*SO-DIMM |
Storage | 1*SATA 3.0, 1*mSATA |
Expansion Interface | 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux |
I/O Interface | |
Serial Port | 6*RS232 (COM6 RS485 optional) |
USB | 7*USB 2.0 (2*on rear I/O, 5*header) |
Ethernet | 2*Intel® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
Parallel Port | Null |
GPIO | 8 programmable GPIO |
Feature Interface | 1*SVIO Connector |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200 1*HDMI: max resolution up to 1920*1200 1*LVDS/eDP: DualChannel 24bit LVDS, max resolution up to 1920*1200; eDP max resolution up to 1920*1080 |
Multiple Display | Triple |
Mechanical & Environment | |
Dimension | 3.5'', 146*105mm |
Power Input | DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
3文章
3540浏览量
88596 -
嵌入式主板
7文章
6085浏览量
35292 -
信步科技
6文章
263浏览量
7169
信步科技SV1-H2726C规格英文版
Intel® Kaby Lake 7th Gen Core i3/i5/i7 CPU (LGA1151) with H270, Double-layer Rear I/O which can
信步科技NVR SV4-B15B4规格英文版
Intel LGA1151 CPU with B150, 25*SATA, 3*1000 Mbps Intel LAN, 12*USB, 2*PCI-E, 1*Mini-PCIe, ATX (305
信步科技SV1-H1126C规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, Double-layer Rear I/O which can expand
信步科技SV3b-62026规格英文版
Intel Skylake-U 6th Gen Core i5-6200U CPU at the solder side of M/B, with 6*COM, 2*1000 Mbps Intel
信步科技NVR SV4-B85B4主板规格英文版
Intel LGA1150 CPU with B85, 26*SATA, 3*1000 Mbps Intel LAN, 2*PCI-E, 1*Mini-PCIe, NVR Alarm port
信步科技SV3b-25516主板规格英文版
Intel Atom D2550 CPU at the solder side of M/B, with 6*COM, 1*LAN, 2*Mini-PCIe
信步科技SV3b-26016-C主板规格英文版
Intel® Atom N2600 CPU at the solder side of M/B, with 6*COM, 1*LAN, 2*Mini-PCIe
信步科技SV3b-19026主板规格英文版
Intel Bay Trail J1900 CPU at the solder side of M/B, with 6*COM, 2*LAN, 2*Mini-PCIe, 3.5'' (146*105mm)
信步科技SV3b-62026主板规格英文版
Intel Skylake-U Core i5-6200U处理器, 6*COM, 2*Intel千兆LAN, 2*Mini-PCIe, 背置CPU, 3.5寸 (146*105mm)
及全系列LGA1150处理器 采用Intel B85芯片组 提供6*Mini-SAS (24*SATA), 2*SATA 3.0, 3*Intel千兆LAN 提供NVR专用报警端子(RS485, 4
