Intel® Kaby Lake 7th Gen Core i3/i5/i7 CPU (LGA1151) with H270, Supports OPS-C+, 4K UHD, 2*Mini-PCIe, DC 19V Input
规格
| General | |
| CPU | Intel® Kaby Lake Pentium®/ Celeron®/ 7th Generation CoreTM i3/i5/i7 CPU, LGA1151 |
| Chipset | Intel® H270 Chipset, TDP 6W |
| Memory | Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM |
| Storage | 1*SATA 3.0 (22Pin), 1*mSATA |
| Expansion Interface |
2*Mini-PCIe (1*mSATA Supported,1*Wifi/3G/4G Supported) 1*OPC-C+ Port |
| BIOS | AMI UEFI BIOS |
| System | Windows 10 x64, Linux |
| I/O Interface | |
| Serial Port | 1*RS232 |
| USB | 2*USB 3.0, 4*USB 2.0 (6*on rear I/O) |
| Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
| PS/2 | Null |
| Parallel Port | Null |
| GPIO | Null |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200 1*HDMI: max resolutionup to 4096*2160 |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | 170*190mm |
| Power Input | DC 19V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3710浏览量
94423 -
嵌入式主板
7文章
6107浏览量
37197 -
信步科技
7文章
264浏览量
7977
热点推荐
信步科技SV-OPS-H270嵌入式主板介绍
Supports Intel® Kaby Lake & 7th Gen Core i3/i5/i7 CPU (LGA1151) with Intel H270 chipset
Supports
信步科技OPS-3855U规格
Skylake-U Celeron 3855U处理器
提供OPS接口, 可搭配信步OPS子卡
支持VGA+HDMI双屏异显, 4K超高清播放
支持mSATA存储, 板载Wifi上网模块
信步科技OPS-J1900规格
处理器
提供OPS接口, 可搭配信步OPS子卡
支持VGA+HDMI双屏异显, 高清播放
采用DC 12V供电
采用OPS行业标准
信步科技SV1-H2726C规格英文版
Intel® Kaby Lake 7th Gen Core i3/i5/i7 CPU (LGA1151) with H270, Double-layer Rear I/O which can
信步科技NVR SV4-H27A6规格英文版
Intel® LGA1151 CPU with H270, 18*SATA, 2*1000 Mbps Intel LAN, 1*PCI-E, 1*Mini-PCIe, NVR Alarm port
信步科技OPS-H110主板介绍英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, OPS-C+, VGA, HDMI, DP, 4K UHD, 2*Mini-PCIe, DC 12~19V Input
信步科技OPS-H81主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, OPS, VGA, HDMI, DP, 4K UHD, 2*Mini-PCIe, DC 19V
信步科技SV1a-H8112P-A1主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 1*VGA, 1*HDMI, Supports OPS, 4K UHD, DC 19V Input
信步科技OPS-H110主板规格英文版
Intel 6/7代Core i3/i5/i7处理器 (LGA1151), OPS-C+, 支持VGA, HDMI, DP双屏异显, 4K超高清, DC 12~19V供电
信步科技OPS-H270规格英文版
