Intel® LGA1151 CPU with H270, 18*SATA, 2*1000 Mbps Intel LAN, 1*PCI-E, 1*Mini-PCIe, NVR Alarm port
规格
General | |
CPU | Intel®Kaby Lake Pentium®/ Celeron®/ 7th Generation CoreTM i3/i5/i7 CPU, LGA1151 |
Chipset | Intel® H270 Chipset, TDP 6W |
Memory | Up to 32 GB DDR4 2133/1866 MHz, 2*DIMM |
Storage | 4*Mini-SAS (16*SATA), 1*SATA 3.0, 1*mSATA |
Expansion Interface | 1*PCI-E 16X, 1*Mini-PCIe (mSATA/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows10 x64, Server 2008/2012, Linux |
I/O Interface | |
Serial Port | 2*RS232 (1*RS485 optional) |
USB | 4*USB 3.0, 6*USB 2.0 (6*on rear I/O, 4*header) |
Ethernet | 2*Intel® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface |
1*FrontAudio 1*Buzzer Mute |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200 2*HDMI: max resolutionup to 4096*2160 |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | ATX,275*210mm |
Power Input | ATX PSU |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
3文章
3541浏览量
88633 -
嵌入式主板
7文章
6085浏览量
35302 -
信步科技
6文章
263浏览量
7170
信步科技SV-NVR-H27A6嵌入式主板介绍
H270 chipset
4*Mini-SAS (16*SATA), 1*SATA 3.0, 2*1000 Mbps Intel LAN
NVR Alarm port (RS485, 4
信步科技SV1a-H1116P规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 6*COM, 10*USB, 1*LAN, 2*Mini-PCIe
信步科技SV1-H2726C规格英文版
H270 chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension
信步科技SV1-H1126C规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, Double-layer Rear I/O which can expand
信步科技NVR SV4-B85B4主板规格英文版
Intel LGA1150 CPU with B85, 26*SATA, 3*1000 Mbps Intel LAN, 2*PCI-E, 1*Mini-PCIe, NVR Alarm port
信步科技NVR SV4-H11A6主板规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 18*SATA, 2*1000 Mbps Intel LAN, 1*PCI-E 16X, 1*Mini-PCIe, N
信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV4-H8134主板规格英文版
Intel LGA1150 CPU with H81, 3*PCI-E, 4*PCI, 1*Mini-PCIe, 1*DVI, 6*COM, 2*LAN, ATX (305*220mm)
信步科技NVR SV1-190A6主板规格英文版
Intel Bay Trail J1900 CPU, 17*SATA, 2*1000 Mbps Intel LAN, 1*Mini-PCIe, NVR Alarm port
信步科技NVR SV1-1908主板规格英文版
(RS485, 4*in/2*out GPIO) Supports dual display of 1*VGA and 2*HDMI 规格 General CPU Intel Bay Trail
信步科技NVR SV6-B75A6主板规格英文版
Intel LGA1155全系列处理器, 17*SATA, 2*Intel千兆LAN, 1*PCI-E 16X, 2*Mini-PCIe, NVR专用报警端子
提供9*SATA, 2*Intel千兆LAN 提供NVR专用报警端子 (RS485, 4 in/2 out GPIO) 提供1*Mini-PCIe (支持mSATA) 提供1*VGA, 2*HDMI
Intel 6/7代CoreTM i3/i5/i7处理器 (LGA1151), 18*SATA, 2*Intel千兆LAN, 1*PCI-E 16X, 1*Mini-PCIe, ATX (275*210mm)
及全系列LGA1150处理器 采用Intel B85芯片组 提供6*Mini-SAS (24*SATA), 2*SATA 3.0, 3*Intel千兆LAN 提供NVR专用报警端子(RS485, 4
