Intel Bay Trail J1900处理器, 6*COM, 提供钱箱和触摸屏专用接口, 支持双eDP显示, DC12V或ATX供电可选
规格
General | |
CPU | Intel® Bay Trail J1900 CPU, Quad-core, up to 2.42 GHz, TDP 10W |
Chipset | Null |
Memory | Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
Storage | 2*SATA 2.0 |
Expansion Interface | 1*Mini-PCIe (mSATA/WiFi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux, Android |
I/O Interface | |
Serial Port | 6*RS232 (COM5 TTL optional) |
USB | 1*USB 3.0, 7*USB 2.0 (4*on rear I/O, 4*header) |
Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
PS/2 | 1*PS/2 (Keyboard Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface |
1*RJ11 Port (Cash Drawer) 1*Touch Panel Controller Pin Header |
Display | |
Display Interface |
1*VGA: max resolution up to 2560*1600@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | ATX PSU or DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
嵌入式主板
7文章
6085浏览量
35316 -
安卓
5文章
2129浏览量
57175 -
信步科技
6文章
263浏览量
7179
信步科技SV3b-19016EP嵌入式主板介绍
采用Intel Bay Trail 单芯片处理器
6*COM, 9*USB, 1*千兆网卡
1*VGA, 2*eDP, 支持双eDP独立显示
2*Mini-PCIe支持mSATA和Wifi/3G/4G
3.5寸, DC 12V供电
信步科技SV1-H2726C规格英文版
H270 chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension
信步科技SV1-19016EP规格英文版
Control, DC 12V or ATX Input.
Supports Intel Bay Trail J1900 CPU
6*COM, 8*USB, 1*1000 Mbps LAN
信步科技SV1-38516P规格
Intel Skylake-U 3855U处理器, 6*COM, 11*USB, 1*LAN, 1*VGA, 1*LVDS/eDP, 1*Mini-PCIe, DC 12V供电
信步科技SV1-19016T主板规格
Intel Bay Trail J1900 CPU with eDP, 6*COM, 1*RJ11 Cash Drawer Control port, 1*Touch Panel Control
信步科技SV1-H1126C规格英文版
chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension Modules
信步科技NSE SV5-19016P主板规格
Intel Bay Trail J1900处理器, 6*Intel千兆网卡, 1*Bypass, 1*CF, 2*Mini-PCIe, ATX或DC 12V供电
