Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, Double-layer Rear I/O which can expand to 18*COM and 18*USB
规格
General | |
CPU | Intel® Pentium®/ Celeron®/ 6th and 7thGeneration CoreTM i3/i5/i7 CPU, LGA1151 |
Chipset | Intel® H110 Chipset, TDP 6W |
Memory | Up to 32 GB DDR4 2133/1866 MHz, 2*DIMM |
Storage | 2*SATA 3.0, 1*mSATA |
Expansion Interface | 1*PCI-E 16X, 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows7/8/10, Linux |
I/O Interface | |
Serial Port | 6*RS232 (Up to 18*RS232 with SV-M5-CU) |
USB | 2*USB 3.0, 8*USB 2.0 (Up to 18*USB with SV-M5-CU) |
Ethernet | 2*Realtek® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
PS/2 | 1*PS/2 |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | ATX PSU |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3586浏览量
89922 -
嵌入式主板
7文章
6092浏览量
35835 -
信步科技
7文章
263浏览量
7381
信步科技SV1a-H1116P规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 6*COM, 10*USB, 1*LAN, 2*Mini-PCIe
信步科技SV1-H2726C规格英文版
H270 chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension
信步科技SV1-H1116特征英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 6*COM, 12*USB, 1*LAN, 1*Mini-PCIe
信步科技SV1-H6116主板规格英文版
Intel 2nd & 3rd Core i3/i5/i7 Gen CPU (LGA1155) with H61, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-
信步科技SV1-H812C主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 12*COM, 10*USB, 2*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1-H812C-A1主板规格英文版
Intel® 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 12*COM, 2*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1a-H8112P-A1主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 1*VGA, 1*HDMI, Supports OPS, 4K UHD, DC 19V Input
信步科技SV4-H8134主板规格英文版
Intel LGA1150 CPU with H81, 3*PCI-E, 4*PCI, 1*Mini-PCIe, 1*DVI, 6*COM, 2*LAN, ATX (305*220mm)
