Intel Skylake-U Celeron 3855U CPU, 4*COM , 2*LAN, 2*Mini-PCIe, DC 12V Input, Thin Mini-ITX
规格
General | |
CPU | Intel® Skylake-U 3855U CPU, Dual-core, 1.6 GHz, TDP 15W |
Chipset | Null |
Memory | Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM |
Storage | 1*SATA 2.0, 1*mSATA |
Expansion Interface | 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux |
I/O Interface | |
Serial Port | 4*RS232 (COM3 TTL optional) |
USB | 2*USB 3.0, 7*USB 2.0 (4*on rear I/O, 5*header) |
Ethernet | 2*Realtek® PCI-E LAN for 1000Mbps |
Audio |
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports 1*Amplifier |
PS/2 | 1*PS/2 header (Keyboard and Mouse Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | 1*Cash Drawercontrol header |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
3文章
3544浏览量
88666 -
嵌入式主板
7文章
6085浏览量
35319 -
信步科技
6文章
263浏览量
7179
信步科技SV1a-H1116P规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 6*COM, 10*USB, 1*LAN, 2*Mini-PCIe
信步科技SV1-H2726C规格英文版
H270 chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension
信步科技SV1a-38614P规格英文版
Intel® Kaby Lake-U Celeron 3865U CPU, Supports triple display of VGA, HDMI and LVDS/eDP, 1*LAN, 2
信步科技SV1-38516P规格英文版
Intel Skylake-U Celeron 3855U CPU, 6*COM, 11*USB, 1*LAN, 1*VGA, 1*LVDS/eDP, 1*Mini-PCIe
I
信步科技SV1-H1126C规格英文版
chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension Modules
信步科技SV1a-38524P主板规格英文版
Intel Skylake-U Celeron 3855U CPU, Supports triple display of VGA, HDMI and LVDS/eDP, 2*LAN, 2*Mini-PCIe
信步科技SV1a-38514P规格英文版
Intel Skylake-U Celeron 3855U CPU, Supports triple display of VGA, HDMI and LVDS/eDP, 1*LAN, 2*Mini-PCIe
信步科技SV1-31716P主板规格英文版
Intel® 3rd Gen Core i3-3217U CPU with HM76, 6*COM, 1*LAN, 2*Mini-PCIe, 1*Cash Drawer, DC 12V Input
Intel Skylake-U 3855U处理器, 1*VGA, 1*HDMI, 1*LVDS/eDP, 支持三屏异显, 2*LAN, 2*Mini-PCIe
信步科技SV1a-38524P-C主板规格英文版
Intel Skylake-U 3855U处理器, 4*COM, 2*LAN, 2*Mini-PCIe, DC 12V供电, 薄型 Mini-ITX (170*170mm)
