Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, OPS-C+, VGA, HDMI, DP, 4K UHD, 2*Mini-PCIe, DC 12~19V Input
规格
General | |
CPU | Intel® Pentium®/ Celeron®/ 6th and 7th Generation CoreTM i3/i5/i7 CPU, LGA1151 |
Chipset | Intel® H110 Chipset, TDP 6W |
Memory | Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM |
Storage | 1*SATA 3.0 (22Pin), 1*mSATA |
Expansion Interface |
2*Mini-PCIe (1*mSATA Supported,1*Wifi/3G/4G Supported) 1*OPC-C+ Port |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux |
I/O Interface | |
Serial Port | 1*RS232 |
USB | 2*USB 3.0+4*USB 2.0 (rear I/O), 1*USB 3.0+2*USB 2.0 (OPS) |
Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
PS/2 | Null |
Parallel Port | Null |
GPIO | Null |
Feature Interface | IRM (Infrared Receiver Module) |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | 170*190mm |
Power Input | DC 12-19V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3586浏览量
89681 -
嵌入式主板
7文章
6092浏览量
35765 -
信步科技
7文章
263浏览量
7348
信步科技SV-OPS-H270嵌入式主板介绍
Supports Intel® Kaby Lake & 7th Gen Core i3/i5/i7 CPU (LGA1151) with Intel H270 chipset
Supports
信步科技OPS-3855U嵌入式主板介绍
Intel Skylake-U Celeron 3855U CPU
Provides OPS port for Digital White Board
Supports Dual display
信步科技OPS-3855U规格
Skylake-U Celeron 3855U处理器
提供OPS接口, 可搭配信步OPS子卡
支持VGA+HDMI双屏异显, 4K超高清播放
支持mSATA存储, 板载Wifi上网模块
信步科技OPS-J1900规格
处理器
提供OPS接口, 可搭配信步OPS子卡
支持VGA+HDMI双屏异显, 高清播放
采用DC 12V供电
采用OPS行业标准
信步科技OPS-H270规格英文版
Intel® Kaby Lake 7th Gen Core i3/i5/i7 CPU (LGA1151) with H270, Supports OPS-C+, 4K UHD, 2
信步科技SV1-H1116特征英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 6*COM, 12*USB, 1*LAN, 1*Mini-PCIe
信步科技OPS-H81主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, OPS, VGA, HDMI, DP, 4K UHD, 2*Mini-PCIe, DC 19V
信步科技SV1a-H8112P-A1主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 1*VGA, 1*HDMI, Supports OPS, 4K UHD, DC 19V Input
信步科技OPS-H110主板规格英文版
Intel 6/7代Core i3/i5/i7处理器 (LGA1151), OPS-C+, 支持VGA, HDMI, DP双屏异显, 4K超高清, DC 12~19V供电
浅谈高性能OPS H110主板解决方案
凌壹科技推出搭载Intel®Skylake高效能平台OPS H110主板,以优异的效能、节能表现,可灵活搭配的处理器、双通道DDR4内存,可支持画面精致细腻的4K超高分辨率,为客户最佳性价比的数字标牌、多媒体教学解决方案。
