Intel Atom D2550 CPU, 4*COM, 1*LAN, 1*Mini-PCIe, DC 12V Input
- Intel Atom D2550 CPU with Intel NM10 chipset
- 4*COM, 8*USB, 1*100 Mbps LAN
- Supports dual display of VGA and LVDS
- 1*Mini-PCIe (Supports mSATA)
- Supports DC 12V Input
- Thin Mini-ITX (thickness≤17mm)
规格
| General | |
| CPU | Intel® AtomTM D2550 CPU, Dual-core, up to 1.86 GHz, TDP 10W |
| Chipset | Intel® NM10 Chipset, TDP 1.5W |
| Memory | Up to 4 GB DDR3 1066/800 MHz, 1*SO-DIMM |
| Storage | 1*SATA 2.0, 1*mSATA |
| Expansion Interface | 1*Mini-PCIe (mSATA Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows XP/7, Linux |
| I/O Interface | |
| Serial Port | 4*RS232 (COM3 TTL optional) |
| USB | 8*USB 2.0 (4*on rear I/O, 4*header) |
| Ethernet | 1*Realtek® PCI-E LAN for 100Mbps |
| Audio |
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports 1*Amplifer |
| PS/2 | 1*PS/2 header (Keyboard and Mouse Supported) |
| Parallel Port | 1*LPT |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz 1*LVDS: Single Channel 24bit, max resolution up to 1440*900@60Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | Mini-ITX, 170*170mm |
| Power Input | DC 12V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3707浏览量
94340 -
嵌入式主板
7文章
6107浏览量
37171 -
信步科技
7文章
264浏览量
7974
热点推荐
华硕 A7N266-C主板英文版说明书
华硕 A7N266-C主板英文版说明书Hardware Installation ProcessTo set up your computer, you must complete
发表于 02-22 13:41
•0次下载
华擎 P4 Combo主板英文版说明书
华擎 P4 Combo主板英文版说明书
Instances of Non-Warranty1. Damage due to natural disaster, accident or
发表于 02-22 16:30
•0次下载
信步科技SV1-31716P主板规格英文版
Intel® 3rd Gen Core i3-3217U CPU with HM76, 6*COM, 1*LAN, 2*Mini-PCIe, 1*Cash Drawer, DC 12V Input
信步科技SV1-13716P主板规格英文版
Intel Celeron 1037U CPU with NM70, 6*COM, 1*LAN, 2*Mini-PCIe, DC 12V or ATX Input (optional)
信步科技SV1a-25514P-C主板介绍英文版
