Intel 2nd & 3rd Core i3/i5/i7 Gen CPU (LGA1155) with H61, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
规格
General | |
CPU | Intel® Pentium®/ Celeron®/ 2nd and 3rd Generation CoreTM i3/i5/i7 CPU, LGA1155 |
Chipset | Intel® H61 Chipset, TDP 6.1W |
Memory | Up to 8 GB DDR3 1333/1066 MHz, 1*DIMM |
Storage | 2*SATA 2.0 |
Expansion Interface | 1*PCI-E 16X, 1*Mini-PCIe (Wifi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows XP/7/8/10, Linux |
I/O Interface | |
Serial Port | 6*RS232 (COM3 RS485 optional) |
USB | 8*USB 2.0 (4*on rear I/O, 4*header) |
Ethernet | 1*Realtek® PCI-E LAN for 100Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
PS/2 | 2*PS/2 (Keyboard and Mouse Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | ATX PSU |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
3文章
3540浏览量
88594 -
嵌入式主板
7文章
6085浏览量
35292 -
信步科技
6文章
263浏览量
7169
微星 MS-6116主板使用手册/说明书(英文版)
微星 MS-6116主板使用手册说明书(英文版Hardware Installation ProcessTo set up your computer, you must complete
发表于 02-21 11:22
•0次下载
信步科技SV1-H6116主板介绍
支持Intel 2代, 3代Core i3/i5/i7处理器 (LGA1155)
采用Intel H61芯片组
提供6*COM, 8*USB, 1*百兆LAN
提供1*VGA,1
发表于 09-24 16:39
•8742次阅读
信步科技SV1a-H1116P规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 6*COM, 10*USB, 1*LAN, 2*Mini-PCIe
信步科技SV1-H2726C规格英文版
H270 chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension
信步科技SV1-H1126C规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, Double-layer Rear I/O which can expand
信步科技SV1-H611A-B主板规格英文版
Intel® 2nd & 3rd Core i3/i5/i7 Gen CPU (LGA1155) with H61, 10*COM, 1*LAN, 1*PCI-E, 1*Mini-PC
信步科技SV1-H812C主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 12*COM, 10*USB, 2*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1-H812C-A1主板规格英文版
Intel® 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 12*COM, 2*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1-H811A主板规格英文版
Intel® 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 10*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1a-H8112P-A1主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 1*VGA, 1*HDMI, Supports OPS, 4K UHD, DC 19V Input
信步科技SV4-H8134主板规格英文版
Intel LGA1150 CPU with H81, 3*PCI-E, 4*PCI, 1*Mini-PCIe, 1*DVI, 6*COM, 2*LAN, ATX (305*220mm)
信步科技NVR SV1-1908主板规格英文版
(RS485, 4*in/2*out GPIO) Supports dual display of 1*VGA and 2*HDMI 规格 General CPU Intel Bay Trail
Intel Bay Trail J1900处理器, 9*SATA, 2*Intel千兆LAN, 1*Mini-PCIe, NVR 专用报警端子 采用Intel Bay Trail J1900处理器
