Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, Double-layer Rear I/O which can expand to 18*COM and 18*USB
规格
General | |
CPU | Intel® Pentium®/ Celeron®/ 4th Generation CoreTM i3/i5/i7 CPU, LGA1150 |
Chipset | Intel® H81 Chipset, TDP 4.1W |
Memory | Up to 16 GB DDR3 1600/1333 MHz, 2*DIMM |
Storage | 1*SATA 2.0, 1*SATA 3.0, 1*mSATA |
Expansion Interface | 1*PCI-E 16X, 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows7/8/10, Linux |
I/O Interface | |
Serial Port | 6*RS232 (Up to 18*RS232 with SV-M5-CU) |
USB | 2*USB 3.0, 8*USB 2.0 (Up to18*USB with SV-M5-CU) |
Ethernet | 2*Realtek® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
PS/2 | 1*PS/2(Keyboard Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | ATX PSU |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
![信步科技SV1-H8126C主板规格英文版](http://file.elecfans.com/web1/M00/A7/60/pIYBAF2DXwuANn0jAAO1x3gM_Dw976.jpg)
![信步科技SV1-H8126C主板规格英文版](http://file.elecfans.com/web1/M00/AD/4A/o4YBAF3N9yeAb8fsAABf8yWJhs4475.jpg)
![信步科技SV1-H8126C主板规格英文版](http://file.elecfans.com/web1/M00/AD/A2/pIYBAF3N93-AQzafAAAzlDYP0Kw028.jpg)
举报投诉
WINDOWS
4文章
3584浏览量
89483 -
嵌入式主板
7文章
6087浏览量
35672 -
信步科技
7文章
263浏览量
7297
信步科技SV1a-H1116P规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 6*COM, 10*USB, 1*LAN, 2*Mini-PCIe
![<b class='flag-5'>信步</b>科技<b class='flag-5'>SV1a-H</b>1116P<b class='flag-5'>规格</b><b class='flag-5'>英文版</b>](https://file.elecfans.com/web1/M00/A7/5F/pIYBAF2DXc2AJiL6AAOmh3s8bfA537.jpg)
信步科技SV1-H2726C规格英文版
H270 chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension
![<b class='flag-5'>信步</b>科技<b class='flag-5'>SV1-H2726C</b><b class='flag-5'>规格</b><b class='flag-5'>英文版</b>](https://file.elecfans.com/web1/M00/A7/5F/pIYBAF2DXdyAJqG0AANuMtBvRWA538.jpg)
信步科技SV1-H1126C规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, Double-layer Rear I/O which can expand
![<b class='flag-5'>信步</b>科技<b class='flag-5'>SV1-H1126C</b><b class='flag-5'>规格</b><b class='flag-5'>英文版</b>](https://file.elecfans.com/web1/M00/A7/5F/pIYBAF2DXlGAZuOzAANuMtBvRWA075.jpg)
信步科技SV1-H6116主板规格英文版
Intel 2nd & 3rd Core i3/i5/i7 Gen CPU (LGA1155) with H61, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-
![<b class='flag-5'>信步</b>科技<b class='flag-5'>SV1-H</b>6116<b class='flag-5'>主板</b><b class='flag-5'>规格</b><b class='flag-5'>英文版</b>](https://file.elecfans.com/web1/M00/A7/0D/o4YBAF2DXpiAAUPUAAO7EXN4Oa4531.jpg)
信步科技SV1-H812C主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 12*COM, 10*USB, 2*LAN, 1*PCI-E 16X, 1*Mini-PCIe
![<b class='flag-5'>信步</b>科技<b class='flag-5'>SV1-H812C</b><b class='flag-5'>主板</b><b class='flag-5'>规格</b><b class='flag-5'>英文版</b>](https://file.elecfans.com/web1/M00/A7/60/pIYBAF2DXxGASKkAAAOhPeKxLwY847.jpg)
信步科技SV1-H812C-A1主板规格英文版
Intel® 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 12*COM, 2*LAN, 1*PCI-E 16X, 1*Mini-PCIe
![<b class='flag-5'>信步</b>科技<b class='flag-5'>SV1-H812C-A1</b><b class='flag-5'>主板</b><b class='flag-5'>规格</b><b class='flag-5'>英文版</b>](https://file.elecfans.com/web1/M00/A7/60/pIYBAF2DXxaAVoI0AAOhPeKxLwY398.jpg)
信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
![<b class='flag-5'>信步</b>科技<b class='flag-5'>SV1-H</b>8116<b class='flag-5'>主板</b><b class='flag-5'>规格</b><b class='flag-5'>英文版</b>](https://file.elecfans.com/web1/M00/A7/0D/o4YBAF2DXrCAP_tXAAPZOZ29UJU716.jpg)
信步科技SV1a-H8112P-A1主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 1*VGA, 1*HDMI, Supports OPS, 4K UHD, DC 19V Input
![<b class='flag-5'>信步</b>科技<b class='flag-5'>SV1a-H8112P-A1</b><b class='flag-5'>主板</b><b class='flag-5'>规格</b><b class='flag-5'>英文版</b>](https://file.elecfans.com/web1/M00/A7/60/pIYBAF2DXyiAafRBAARNPexjWIA101.jpg)
信步科技SV4-H8134主板规格英文版
Intel LGA1150 CPU with H81, 3*PCI-E, 4*PCI, 1*Mini-PCIe, 1*DVI, 6*COM, 2*LAN, ATX (305*220mm)
![<b class='flag-5'>信步</b>科技<b class='flag-5'>SV4-H</b>8134<b class='flag-5'>主板</b><b class='flag-5'>规格</b><b class='flag-5'>英文版</b>](https://file.elecfans.com/web1/M00/A7/0D/o4YBAF2DXsGAYIIhAAK2xEfxuXM582.jpg)
