Intel® Bay Trail J1800 CPU, 2*COM, 1*LAN, 1*Mini-PCIe
规格
General | |
CPU | Intel® Bay Trail J1800 CPU, Dual-core, up to 2.58 GHz, TDP10W |
Chipset | Null |
Memory | Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
Storage | 1*SATA 2.0, 1*mSATA |
Expansion Interface | 1*Mini-PCIe (mSATA/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux, Android |
I/O Interface | |
Serial Port | 2*RS232 |
USB | 9*USB 2.0 (4*on rear I/O, 5*header) |
Ethernet | 1*Realtek® PCI-E LAN for 100Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface | 1*VGA: max resolution up to 2560*1600@60Hz |
Multiple Display | Single |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | ATX PSU |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
嵌入式主板
7文章
6092浏览量
35765 -
安卓
5文章
2140浏览量
57808 -
信步科技
7文章
263浏览量
7348
信步科技SV1-18012嵌入式主板介绍
采用Intel Bay Trail J1800处理器
提供2*COM, 9*USB, 1*百兆LAN
提供VGA显示
提供1*Mini-PCIe (支持mSATA/3G/4G)
信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技NVR SV1-1908主板规格英文版
(RS485, 4*in/2*out GPIO) Supports dual display of 1*VGA and 2*HDMI 规格 General CPU Intel Bay Trail
Intel Bay Trail J1900处理器, 9*SATA, 2*Intel千兆LAN, 1*Mini-PCIe, NVR 专用报警端子 采用Intel Bay Trail J1900处理器
