Intel Bay Trail J1900 CPU, 17*SATA, 2*1000 Mbps Intel LAN, 1*Mini-PCIe, NVR Alarm port
规格
General | |
CPU |
Intel®Bay Trail J1900 CPU, Quad-core, 2.0 GHz, TDP 10W |
Chipset |
Null |
Memory |
Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
Storage |
2*Mini-SAS (8*SATA), 9*SATA 2.0, 1*mSATA |
Expansion Interface |
1*Mini-PCIe (mSATA Supported) |
BIOS |
AMI UEFI BIOS |
System | |
I/O Interface | |
Serial Port | |
USB |
7*USB 2.0 (4*on rear I/O, 3*header) |
Ethernet |
2*Intel®PCI-E LAN for 1000Mbps |
Audio |
Realtek®ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
PS/2 |
Null |
Parallel Port |
Null |
GPIO |
8 programmable GPIO, 4 in/2 out Opto-Isolated GPIO |
Feature Interface |
1*Alarm Port |
Display | |
Display Interface |
1*VGA: max resolution up to 2560*1600@60Hz |
Multiple Display |
Dual |
Mechanical & Environment | |
Dimension |
Mini-ITX, 170*170mm |
Power Input |
ATX PSU |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
嵌入式主板
7文章
6085浏览量
35307 -
安卓
5文章
2127浏览量
57158 -
信步科技
6文章
263浏览量
7172
