Intel Bay Trail J1900处理器, 6*COM, 提供钱箱和触摸屏专用接口, 支持eDP
规格
General | |
CPU | Intel® Bay Trail J1900 CPU, Quad-core, up to 2.42 GHz, TDP 10W |
Chipset | Null |
Memory | Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
Storage | 2*SATA 2.0 |
Expansion Interface | 1*Mini-PCIe (mSATA/WiFi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux, Android |
I/O Interface | |
Serial Port | 6*RS232 (COM5 TTL optional) |
USB | 8*USB 2.0 (4*on rear I/O, 4*header) |
Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
PS/2 | 1*PS/2 (Keyboard Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface |
1*RJ11 Port (Cash Drawer) 1*Touch Panel Controller Pin Header |
Display | |
Display Interface |
2*VGA: max resolution up to 1920*1200@60Hz 1*LVDS/eDP: LVDS, Dual channel 24 bit, max resolution up to 1920*1200@60Hz eDP, max resolution up to 1920*1200@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | ATX PSU or DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
嵌入式主板
7文章
6085浏览量
35292 -
安卓
5文章
2125浏览量
57133 -
信步科技
6文章
263浏览量
7169
信步科技SV1-19016EP规格英文版
Control, DC 12V or ATX Input.
Supports Intel Bay Trail J1900 CPU
6*COM, 8*USB, 1*1000 Mbps LAN
信步科技SV1-19016T主板规格
Intel Bay Trail J1900 CPU with eDP, 6*COM, 1*RJ11 Cash Drawer Control port, 1*Touch Panel Control
信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技NVR SV1-1908主板规格英文版
(RS485, 4*in/2*out GPIO) Supports dual display of 1*VGA and 2*HDMI 规格 General CPU Intel Bay Trail
Intel Bay Trail J1900处理器, 9*SATA, 2*Intel千兆LAN, 1*Mini-PCIe, NVR 专用报警端子 采用Intel Bay Trail J1900处理器
