Intel LGA1155全系列处理器, 17*SATA, 2*Intel千兆LAN, 1*PCI-E 16X, 2*Mini-PCIe, NVR专用报警端子
规格
| General | |
| CPU | Intel® Pentium®/ Celeron®/ 2nd and 3rd Generation CoreTM i3/i5/i7 CPU, LGA1155 |
| Chipset | Intel® B75 Chipset, TDP 6.7W |
| Memory | Up to 16 GB DDR3 1600/1333/1066 MHz, 2*DIMM |
| Storage | 4*Mini-SAS (16*SATA), 1*SATA, 1*mSATA |
| Expansion Interface | 1*PCI-E 16X, 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows XP/7/8/10, Server 2008/2012, Linux |
| I/O Interface | |
| Serial Port | 2*RS232 (1*RS485 optional) |
| USB | 4*USB 3.0, 4*USB 2.0 (4*on rear I/O, 4*header) |
| Ethernet | 2*Intel® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
| PS/2 | 1*PS/2 header (Keyboard and Mouse Supported) |
| Parallel Port | Null |
| GPIO | 8 programmable GPIO, 4 in/2 out Opto-Isolated GPIO |
| Feature Interface | 1*Alarm Port |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | Micro-ATX, 254*210mm |
| Power Input | ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3710浏览量
94422 -
嵌入式主板
7文章
6107浏览量
37197 -
信步科技
7文章
264浏览量
7977
热点推荐
信步科技SV3b-38626规格英文版
Intel® Kaby Lake-U Celeron 3865U CPU at the solder side of M/B, with 6*COM, 2*1000 Mbps Intel LAN
信步科技NVR SV4-H27A6规格英文版
Intel® LGA1151 CPU with H270, 18*SATA, 2*1000 Mbps Intel LAN, 1*PCI-E, 1*Mini-PCIe, NVR Alarm port
信步科技NVR SV6-B75A6主板英文版
Intel LGA1155 CPU with B75, 17*SATA, 2*1000 Mbps Intel LAN, 1*PCI-E 16X, 2*Mini-PCIe, NVR Alarm port
信步科技NVR SV4-B85B4主板规格英文版
Intel LGA1150 CPU with B85, 26*SATA, 3*1000 Mbps Intel LAN, 2*PCI-E, 1*Mini-PCIe, NVR Alarm port
信步科技NVR SV4-H11A6主板规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 18*SATA, 2*1000 Mbps Intel LAN, 1*PCI-E 16X, 1*Mini-PCIe, NVR Alarm port
信步科技SV3b-25516主板规格英文版
Intel Atom D2550 CPU at the solder side of M/B, with 6*COM, 1*LAN, 2*Mini-PCIe
信步科技SV3b-19026主板规格英文版
Intel Bay Trail J1900 CPU at the solder side of M/B, with 6*COM, 2*LAN, 2*Mini-PCIe, 3.5'' (146*105mm)
信步科技NVR SV1-190A6主板规格英文版
Intel Bay Trail J1900 CPU, 17*SATA, 2*1000 Mbps Intel LAN, 1*Mini-PCIe, NVR Alarm port
信步科技NVR SV1-1908主板规格英文版
Intel Bay Trail J1900 CPU, 9*SATA, 2*1000 Mbps Intel LAN, 1*Mini-PCIe, NVR Alarm port Intel Bay
Intel Bay Trail J1900处理器, 9*SATA, 2*Intel千兆LAN, 1*Mini-PCIe, NVR 专用报警端子 采用Intel Bay Trail J1900处理器
Intel 6/7代CoreTM i3/i5/i7处理器 (LGA1151), 18*SATA, 2*Intel千兆LAN, 1*PCI-E 16X, 1*Mini-PCIe, ATX (275*210mm)
及全系列LGA1150处理器 采用Intel B85芯片组 提供6*Mini-SAS (24*SATA), 2*SATA 3.0, 3*Intel千兆LAN 提供NVR专用报警端子(RS485, 4
信步科技NVR SV6-B75A6主板规格英文版
