Intel Core i3-3227U处理器, 1*VGA, 1*LVDS, 4*COM, 1* LAN, 2*Mini-PCIe
规格
General | |
CPU | Intel® CoreTM i3-3227U CPU, Dual-core, 1.9 GHz, TDP 17W |
Chipset | Intel® HM76 Chipset, TDP 4.1W |
Memory | Up to 8 GB DDR3/3L 1600/1333 MHz, 1*SO-DIMM |
Storage | 1*SATA 3.0, 2*SATA 2.0, 1*mSATA |
Expansion Interface | 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows XP/7/8/10, Linux |
I/O Interface | |
Serial Port | 4*RS232 (COM3 TTL optional) |
USB | 7*USB 2.0 (4*on rear I/O, 3*header) |
Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
Audio |
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports 1*Amplifier |
PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 2048*1536@75Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
3文章
3541浏览量
88628 -
嵌入式主板
7文章
6085浏览量
35297 -
信步科技
6文章
263浏览量
7170
信步科技SV3b-25516主板规格英文版
Intel Atom D2550 CPU at the solder side of M/B, with 6*COM, 1*LAN, 2*Mini-PCIe
信步科技SV1-31716P主板规格英文版
Intel® 3rd Gen Core i3-3217U CPU with HM76, 6*COM, 1*LAN, 2*Mini-PCIe, 1*Cash Drawer, DC 12V Input
信步科技SV1-13716P主板规格英文版
Intel Celeron 1037U CPU with NM70, 6*COM, 1*LAN, 2*Mini-PCIe, DC 12V or ATX Input (optional)
